maximilianh75 19 Posted August 9, 2018 Posted August 9, 2018 (edited) I have problems with certains actors/performers for some adult content with actors have a lot of AKA names and make a lot of noise in metadata people. When i have a conflict with an actor the actor dissapear from cast and it's very difficult to fix. It's any possibility to automatic detect and acept Aka for actors, the movie db have this as an option in her data base I give example: Emmanuel Delcour Also Known As Emmanuel Delcour Alex Doriano Jean Valgean Jean Valjean Jean Paul Jon Val Jean Jean Val Jean The other thing is the possibility to auto detect adult actor because now i have to do it manually, I have to copy ACTOR ID from TMDB to identify actor Maybe if we can user from the movie DB to acept automatic adult content inside Edited August 9, 2018 by maximilianh75
Luke 42212 Posted August 9, 2018 Posted August 9, 2018 I'm having a hard time understanding your issue, but if you use emby internet metadata with tmdb then it should be fine. Thanks.
maximilianh75 19 Posted August 9, 2018 Posted August 9, 2018 I'm having a hard time understanding your issue, but if you use emby internet metadata with tmdb then it should be fine. Thanks. Thanks for answer and yes i'm using emby internet metadata with the movie DB and there is when problems come but specially with adult content. And you don't answer my second question. Any possiblility to identify automatically the actors mark like adult, becouse the only way to identify is manually. (I have to copy the ID number inside your search identify item
Luke 42212 Posted August 9, 2018 Posted August 9, 2018 Why is adult content any different than a regular movie? that's what i don't quite understand.
Happy2Play 9802 Posted August 9, 2018 Posted August 9, 2018 Another issue is when an AKA leads to another real person. examples https://www.themoviedb.org/search/person?query=Jean%20Paul&language=en-US https://www.themoviedb.org/search/person?query=Jean%20Del%20Val&language=en-US
Luke 42212 Posted August 9, 2018 Posted August 9, 2018 Another issue is when an AKA leads to another real person. examples https://www.themoviedb.org/search/person?query=Jean%20Paul&language=en-US https://www.themoviedb.org/search/person?query=Jean%20Del%20Val&language=en-US That should not be a problem because the server no longer does tmdb lookups by name.
maximilianh75 19 Posted August 10, 2018 Posted August 10, 2018 Why is adult content any different than a regular movie? that's what i don't quite understand. I belive that if because you need to be log in in The movie DB to access to adult content data (+18). And in users settings of the movie db set adult like visible. If your are not log in and set adult, the adult actors not shown in search tool in TMDB webpage
Happy2Play 9802 Posted August 10, 2018 Posted August 10, 2018 I belive that if because you need to be log in in The movie DB to access to adult content data (+18). And in users settings of the movie db set adult like visible. If your are not log in and set adult, the adult actors not shown in search tool in TMDB webpage Interesting as the actor you linked above and all his movies are accessible without logging in.
maximilianh75 19 Posted August 10, 2018 Posted August 10, 2018 Interesting as the actor you linked above and all his movies are accessible without logging in. Yes but not if you use the search engine provided by The Movie DB. The link it's not bloqued but the search engine not show it if you try to find it
