drikosv8 25 Posted September 11, 2017 Posted September 11, 2017 (edited) I'm having problems with IPTV I have tested 3 paid Iptv lists from different companies and after a few minutes watching the channel, it stops. I noticed that playback is stopped after the progress bar comes to an end. I think the player is not storing enough data so he can be seen without interruption. Check this, because I want to make iptv available to my clients, but this problem must be solved first. I'm using google chrome, I've attached the server log. Thank you Estou tendo problemas com IPTV Testei 3 listas de Iptv pagas de diferentes empresas e depois de alguns minutos assistindo o canal, ela pára. Notei que a reprodução é interrompida depois que a barra de progresso chega ao fim. Eu acho que o jogador não está armazenando dados suficientes para que ele possa ser visto sem interrupção. Verifique isso, porque eu quero tornar o iptv disponível para meus clientes, mas esse problema deve ser resolvido primeiro. Estou usando google chrome, anexei o log do servidor. Obrigado log.txt Edited September 11, 2017 by drikosv8
drikosv8 25 Posted September 11, 2017 Author Posted September 11, 2017 (edited) I'm sorry @@Luke It has the ffmpeg file yes. I've attached it with today's test. As soon as it reaches the end, the channel stops playing, as shown I'm waiting Thank you Me desculpe @@Luke Tem o arquivo ffmpeg sim. Anexei-o com o teste de hoje. Assim que chegar ao final, o canal pára de tocar, como mostrado estou esperando Obrigado ffmpeg.txt log.txt Edited September 11, 2017 by drikosv8
