paulsalter 84 Posted September 10, 2017 Posted September 10, 2017 Hi, I have noticed an issue with the desktop version of Theater When the Next-Up popup is enabled, it is sending the watched info twice to Trakt In my log this happened to all episodes of MOM watched today Neighbours S33E172 & Home and Away S30E141 If it shows any difference, with Neighbours S33E173 i clicked on hide for the Next-Up pop up and it only sent the watched info once If i turn this option off in settings everything is fine Thanks server-63640598403.txt
Luke 42243 Posted September 10, 2017 Posted September 10, 2017 does it show playback stopped twice on the emby server dashboard?
paulsalter 84 Posted September 10, 2017 Author Posted September 10, 2017 Thanks That i am not sure, didnt look at the dashboard, next time i play something with it i will check I just started it going and let it play through the episodes If I turn off the prompt about next episodes starting in xx seconds, i dont get the issue I have cleared out the duplicates from Trakt now, but the 2 entries for each episode have the same time on them
