Trancoding Temporary Location
smokey7722
I currently have Version 3.0.5135.31685 of the Server installed and had changed the Transcoding temporary files path to a network share.  However it seems that on a server restart it is reverting back to the local machines generic path for my installed user.
If I go to the configuration page though it shows the path:
530e56bbcd4d5_ScreenShot20140226at10249P
If I go to info though it shows:
530e56f1ec25c_ScreenShot20140226at10257P
The odd thing is the local path does NOT exist if I browse the path.  And the network path is not being used either way.  If I click SAVE on on the transcoding configuration page it will update the path in the above image to the network path it should have.
This seems to happen every time I restart the server though.
Anyone see this as well?
  • Like 1
Koleckai Silvestri
I can see this issue and have seen another thread about it. Hopefully it gets fixed soon.
smokey7722
I did a search but didn't find anyother post before I created this one.
Sent from my SGH-M919 using Tapatalk
smokey7722
So I did another search yesterday and couldn't find a post talking about this.  I also did a quick look through the current bug list and didn't see this listed.  Did I happen to miss it or has one not been created yet for this to look at?
Koleckai Silvestri
The other post is in a developer area not available to the public. This should be fixed in an upcoming beta release.
smokey7722
Awesome, thanks!
It is fixed since 3.0.5172.664 Dev.
