cherup 3 Posted September 9, 2017 Posted September 9, 2017 (edited) Hi - I do have problems with decoding .ts files (which are recorded with an enigma2 box). I can play them with the enigma box without problems, but using emby the video never starts. In the log I can see [h264 @ 0x80a4f0120] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 0x80a4f0120] decode_slice_header error [h264 @ 0x80a4f0120] no frame! [h264 @ 0x80a4f0120] non-existing PPS 0 referenced maybe somebody has an idea what to do in that case ? Application version_ 3.2.28.0.txt Edited September 9, 2017 by cherup
Luke 42238 Posted September 9, 2017 Posted September 9, 2017 Looks like you have a 2 year old version of ffmpeg installed. I would try updating that. Let us know if this helps. Thanks !
cherup 3 Posted September 9, 2017 Author Posted September 9, 2017 Hmm I am using the emby plugin. So this can only be done by the maintainer, right ? Gesendet von meinem SM-G950F mit Tapatalk
Luke 42238 Posted September 9, 2017 Posted September 9, 2017 I've sent an inquiry about that to the maintainer. Thanks.
Luke 42238 Posted September 10, 2017 Posted September 10, 2017 @@cherup, is this freenas or freebsd? If it is freebsd you can just do pkg upgrade
Luke 42238 Posted November 9, 2017 Posted November 9, 2017 @@cherup if you have an enigma tv tuner then we have a better way of using that with Emby. Now with OpenVix you can add your enigma tuner directly to Emby using Emby's native support. No VU+ plugin needed. You can learn more here: https://emby.media/community/index.php?/topic/52762-enigma2-livetvdvr-support/ Thanks !
cherup 3 Posted November 9, 2017 Author Posted November 9, 2017 @@cherup if you have an enigma tv tuner then we have a better way of using that with Emby. Now with OpenVix you can add your enigma tuner directly to Emby using Emby's native support. No VU+ plugin needed. You can learn more here: https://emby.media/community/index.php?/topic/52762-enigma2-livetvdvr-support/ Thanks ! That's sounds great! Never heard before. Will test it directly. Thanx a lot Gesendet von meinem SM-G950F mit Tapatalk
