Scrubsss 5 Posted April 2, 2018 Author Posted April 2, 2018 Hey @@Luke Any updates on the whireshark caps i send you?. Did you notice anything different between the two server versions? I'm back from my vacation now and happy to help where i can. Greetings and Happy Easter
Luke 42238 Posted April 5, 2018 Posted April 5, 2018 Yea i have, I just haven't been able to find the difference between them yet.
akarpych 7 Posted April 11, 2018 Posted April 11, 2018 Hello! I also have a problem. Installed a new version of Raspbian. Through BubbleUpnp all folders and files are visible, and Samsung TV does not see the files. TV series F, H, JU. Is there a problem with the profiles?
Scrubsss 5 Posted April 15, 2018 Author Posted April 15, 2018 @@Luke Ok thats strange. But we both agree that there is a commit between the two versions that bricked this functionality right? I had a quick look over the commits between the versions but couldn't find anything obvious, but thats likley because i am not much into programming. But i am able to run the source in Visual Studio. I got the latest dev version to run in Release mode in VS. So if you maybe have some patches for me i can test them immediately on my TV to debug this. I hope that helps a bit. Greetings Ps. And you can also see that a bunch of people have the same problem so i'm not the only one.
Luke 42238 Posted April 15, 2018 Posted April 15, 2018 But we both agree that there is a commit between the two versions that bricked this functionality right? I don't necessarily agree, rather I'm just not sure at the moment. I have a 2014 Samsung for testing that is able to display the content.
Scrubsss 5 Posted April 15, 2018 Author Posted April 15, 2018 (edited) Wich model is it? Both of my TVs are 2012/2013. I dont know what else i can do to help. But for sure there are a bunch of people that are having this issue after 3.2.26. Also just to let you know the 2 TVs are in to completly seperate networks. One is in my house and one at my friends house. Both same issue. Could there be other interference with upnp servers? We both got a AVM FritzBox wich is running upnp. Edited April 15, 2018 by Scrubsss
akarpych 7 Posted April 16, 2018 Posted April 16, 2018 Hi, I have 3 TVs. F, H, JU series. Works only on the JU series. 1
Scrubsss 5 Posted April 23, 2018 Author Posted April 23, 2018 (edited) @@Luke Got a used TV today. It's a UE40H5510 With latest software: T-MST12DEUC-2880.2 Its completly reset. Screenshot attached of what it looks like. So now i have 3 TVs that are not working with emby over DLNA This is my list now Model: UE40ES6300 Software: T-MST10PDEUC-2007.0 Model: UE40F6500 Software: T-MST12DEUC-2126.0 Model: UE40H5510 Software: T-MST12DEUC-2880.2 So we can see E , F and H Series are all not working Edited April 23, 2018 by Scrubsss
Scrubsss 5 Posted April 25, 2018 Author Posted April 25, 2018 (edited) @@Luke Update This commit destroys the functionality: https://github.com/MediaBrowser/Emby/commit/7f88fce137ddb77843706aef1ff809fa0b1f2ff7 Is that helping you? Edit: I think I found the change that is causing the issues. I reverted my code base back to the commit that is breaking the DLNA discovery service for me (https://github.com/MediaBrowser/Emby/commit/7f88fce137ddb77843706aef1ff809fa0b1f2ff7) and changed back the line 540 (https://github.com/MediaBrowser/Emby/commit/7f88fce137ddb77843706aef1ff809fa0b1f2ff7#diff-5d3872849a12318e37a2b1bb42c15e68R540). After this change (and nothing else) it is working fine again. This fix does however not work for the latest master code base of the repository but definately fixes 3.2.27.0 for me and my TV. Hope this helps you a bit more. Edited April 25, 2018 by Scrubsss
Luke 42238 Posted April 26, 2018 Posted April 26, 2018 Thanks for the investigation. I suspected it was that commit, the problem is there's nothing obvious there about how it would affect dlna. You said you tried this on a new server install. What kind of libraries did you setup with the new server?
Scrubsss 5 Posted April 26, 2018 Author Posted April 26, 2018 Hey @@Luke. Thanks for the quick reply.Like I said above, I not only found the commit (7f88fce137ddb77843706aef1ff809fa0b1f2ff7) but actually the specific line/change that breaks it (line 540 in the file `Emby.Dlna/ContentDirectory/ControlHandler.cs`) as can be seen on this link (which links to the specific line): https://github.com/MediaBrowser/Emby/commit/7f88fce137ddb77843706aef1ff809fa0b1f2ff7#diff-5d3872849a12318e37a2b1bb42c15e68R540 . Change it back from `PresetViews = new string[] { },` to `PresetViews = new[] { CollectionType.Movies, CollectionType.TvShows },`, run the server, add a media library and everything works fine again. I tried with a movie library with just one movie in it. Sorry if I wasn't clear enough on this.About the new server install. Yes, I tried all that and of course used a fresh library. The thing is that this obviously is not correlated to the problem described in this thread at all. I can tell because I ran everyone of the commits between version 3.2.26.0 and 3.2.27.0 in a dev envrionment in Visual Studio until the functionality started to break. Then I cleaned the repository to make sure that only a change of the line affects it. And yes, I also tried the current master branch of the open github repository. So I think a new server install isn't problem oriented at all in this case.Hope I could clear a few things up and thank you for you patience and hard work on this lovely project!
Luke 42238 Posted April 26, 2018 Posted April 26, 2018 Great investigation, thanks. Now to find out the end result of what difference that creates in upnp didl output, because I'd prefer to avoid setting that property back to the old way.
panosl 0 Posted April 29, 2018 Posted April 29, 2018 I'm having the same issue on SAMSUNG UE46EH6030It shows the top folders but no content. Works fine when viewing it from iOS VLC etc. Problem is I'm on a macOS, so I can't try the windows build @@Scrubsss is suggesting.
Scrubsss 5 Posted April 29, 2018 Author Posted April 29, 2018 (edited) @@panosl You could set up a Windows VM in VirtualBox and test the server there. It is important that you set the virtual machine from NAT to network bridge. The Windows 10 ISO is available directly from Microsoft. Or you compile the server yourself. @@Luke Thanks, I'm doing my best, but it might take a little while because it's all new to me. I'll be back home in two days and try to analyze the problem further. I'll keep you posted. Edited April 29, 2018 by Scrubsss
newby 5 Posted March 17, 2019 Posted March 17, 2019 Hello Guys, DLNA dont work on Samsung TV since weeks. I have several Samstung TV. But not al TVs work with emby. Other DLNA Server (TV Mosaic) work like a charme. HELP
Luke 42238 Posted March 17, 2019 Posted March 17, 2019 Hello Guys, DLNA dont work on Samsung TV since weeks. I have several Samstung TV. But not al TVs work with emby. Other DLNA Server (TV Mosaic) work like a charme. HELP Hi there @@newby, please attach the information requested in how to report a problem. thanks !
