pir8radio 1313 Posted September 6, 2017 Posted September 6, 2017 (edited) For any of you using PRTG to monitor your servers, I found this little gem: http://furytech.net/prtg-hdhomerun-plugin/ a plugin to monitor your HDHomerun(s). Provides general signal strength and quality readings for the CableCard, as well as the same info per tuner including mbps streaming rate per tuner. Works on OTA tuners too. Handy to monitor when/if all of your tuners are in use at once, or troubleshooting bad recordings. @@Swynol @@JeremyFr79 Edited September 6, 2017 by pir8radio
Guest asrequested Posted September 6, 2017 Posted September 6, 2017 Nice! I gave PTRG a run, but I was getting too many alerts lol
JeremyFr79 228 Posted September 6, 2017 Posted September 6, 2017 Nice, won't work for me though since I run Cetons in my setup, but this is very cool.
Swynol 375 Posted September 7, 2017 Posted September 7, 2017 good find. although i dont use HDhomerun i have though about getting one for a while
ttgapers 99 Posted April 20, 2020 Posted April 20, 2020 For any of you using PRTG to monitor your servers, I found this little gem: http://furytech.net/prtg-hdhomerun-plugin/ a plugin to monitor your HDHomerun(s). Provides general signal strength and quality readings for the CableCard, as well as the same info per tuner including mbps streaming rate per tuner. Works on OTA tuners too. Handy to monitor when/if all of your tuners are in use at once, or troubleshooting bad recordings. @@Swynol @@JeremyFr79 Boom. Implemented, but had to make a few changes for the stats to be parsed from the XML. I have forked and completed a pull request with the owner of the repo. Just in case anyone else was having issues with stats showing up. Cheers! 1
