Vidarr 10 Posted September 5, 2017 Posted September 5, 2017 Hello there, i did some research but i guess my knowledge is not good enough to understand fully how it's working. I have an atom D2702 it's a weak processor we agree but i can't transcode anything with it and sometime it does transcode for no reason i would like to know why and how to prevent it or try to make emby just read the file because it doesn't need any transcode. i would also wnat to know how to set the transcoding part at it's best and i'm a bit lost about it atm.. thank you for your reply and help.
Luke 42239 Posted September 5, 2017 Posted September 5, 2017 hi @@Vidarr, can you give us an example? please attach the information requested in how to report a media playback issue. thanks !
Vidarr 10 Posted September 5, 2017 Author Posted September 5, 2017 My log is here https://pastebin.com/iNykJUjK it's for the hobbit this one but i have the same problem with every transcode operation.
Solution Luke 42239 Posted September 5, 2017 Solution Posted September 5, 2017 What Emby app were you playing from? If you were playing from the web app then please be aware that there is currently no browser available that supports HEVC, therefore turning off transcoding would result in having no ability to play that file. Does this answer your question? 1
Vidarr 10 Posted September 5, 2017 Author Posted September 5, 2017 (edited) I was playing with chrome on my desktop Ok so basically he is turning my HEVC file into H264 file that does indeed answer one part of my question. For the 2nd part is there any way i could try atleast to transcode one fil at 30 fps atleast with my current setup or it's lost for the nation ? Edited September 5, 2017 by Vidarr
Luke 42239 Posted September 5, 2017 Posted September 5, 2017 No, you either need better hardware, or replace your file with a version that is already h264.
Vidarr 10 Posted September 5, 2017 Author Posted September 5, 2017 Ok thank you for the tip and your fast answer.Anyway your app is amazing and have a lot of potential keep on the good work : )
Luke 42239 Posted September 29, 2017 Posted September 29, 2017 We have a new QNAP package available for testing: https://emby.media/community/index.php?/topic/51334-new-qnap-package-for-testing/ Unlike the current package in the QNAP community, this is built by the Emby Team and will be tested and supported by us. It is also built with the new .NET Core runtime from Microsoft, which has major performance improvements over the mono runtime used by the community package. Please try it out if interested in helping us test it. Thanks !
Vidarr 10 Posted September 29, 2017 Author Posted September 29, 2017 I'll try this out and report anybug i can found .
