MeowingTree 2 Posted November 12, 2022 Posted November 12, 2022 Could we please get a fix for this? It's a considerable problem, most shows I encounter with "specials" have major ongoing story-arc content in their "specials", and the 'next up' feature is the most reliable way to track currently in progress shows.
Luke 42301 Posted November 13, 2022 Posted November 13, 2022 On 11/11/2022 at 9:43 PM, MeowingTree said: Could we please get a fix for this? It's a considerable problem, most shows I encounter with "specials" have major ongoing story-arc content in their "specials", and the 'next up' feature is the most reliable way to track currently in progress shows. Hi, can you please describe the issue that you're having? Thanks.
MeowingTree 2 Posted November 13, 2022 Posted November 13, 2022 5 hours ago, Luke said: Hi, can you please describe the issue that you're having? Thanks. Yes, special episodes (season 0) don't show up in next up. In your own words: On 06/09/2017 at 15:29, Luke said: We currently dont' include specials in next up. it's something to consider for a future update, thanks.
Luke 42301 Posted November 13, 2022 Posted November 13, 2022 9 hours ago, MeowingTree said: Yes, special episodes (season 0) don't show up in next up. In your own words: They do now. Did you enable the advanced option to display specials in the seasons they aired in?
Happy2Play 9814 Posted November 13, 2022 Posted November 13, 2022 11 hours ago, MeowingTree said: Yes, special episodes (season 0) don't show up in next up. In your own words: On 9/5/2017 at 8:29 PM, Luke said: We currently dont' include specials in next up. it's something to consider for a future update, thanks. Sorry but something that applied in 2017 doesn't necessarily apply today. But specific example with specials metadata are needed.
