all4dom 101 Posted September 5, 2017 Posted September 5, 2017 I am looking for some help on how to set up emby for remote access on my phone. Any help is appreciated. Thanks Dom 1
Guest asrequested Posted September 5, 2017 Posted September 5, 2017 Do you know how to forward your ports on you router? Take a look at this, and scroll down to external connetions https://github.com/MediaBrowser/Wiki/wiki/Connectivity
all4dom 101 Posted September 5, 2017 Author Posted September 5, 2017 Hey doofus, thanks for responding. I was just reading that page. Im running windows firewall so I should be able to set that up. How do I download emby connect? Would that be the easiest for remote viewing obn my phone?
Guest asrequested Posted September 5, 2017 Posted September 5, 2017 Hey doofus, thanks for responding. I was just reading that page. Im running windows firewall so I should be able to set that up. How do I download emby connect? Would that be the easiest for remote viewing obn my phone? Here's how to use Emby Connect https://github.com/MediaBrowser/Wiki/wiki/Emby%20Connect
Guest asrequested Posted September 5, 2017 Posted September 5, 2017 Once you get your port forwarded, you should just be able to sign in.
all4dom 101 Posted September 5, 2017 Author Posted September 5, 2017 I have a verizon router. Ill play with it in the morning. Than\ks doofus.
all4dom 101 Posted September 5, 2017 Author Posted September 5, 2017 I was able to get into my router & select port forwarding, but I do not know how to setup. Any suggestions?
Guest asrequested Posted September 5, 2017 Posted September 5, 2017 Does it look like this? http://cache.insteon.com/support/port-forward-verizon-router.html
all4dom 101 Posted September 5, 2017 Author Posted September 5, 2017 I would use the ip addresd of my emby server?
Guest asrequested Posted September 5, 2017 Posted September 5, 2017 (edited) I would use the ip addresd of my emby server? Yes. Use the address and port that you see, here Edited September 11, 2017 by Doofus
all4dom 101 Posted September 10, 2017 Author Posted September 10, 2017 Doofus not sure if u are there, but i just setup the port forwarding...hope i got it right. Now im not understanding emby connect. Do i have to create a guest account?
Happy2Play 9811 Posted September 10, 2017 Posted September 10, 2017 (edited) Doofus not sure if u are there, but i just setup the port forwarding...hope i got it right. Now im not understanding emby connect. Do i have to create a guest account? What are you trying to do? If you are using Connect, the first thing you need to do is link your account to a local user. Edited September 10, 2017 by Happy2Play
all4dom 101 Posted September 11, 2017 Author Posted September 11, 2017 I would ask u a question on that but i am unable to get port forward working. Very frustrating. I used the canuseeme site to sewe if my port is open and I am still getting an error.
Guest asrequested Posted September 11, 2017 Posted September 11, 2017 I would ask u a question on that but i am unable to get port forward working. Very frustrating. I used the canuseeme site to sewe if my port is open and I am still getting an error. I think I steered you a little wrong, earlier. When forwarding, use the Local IP that shows in your dashboard.
Guest asrequested Posted September 11, 2017 Posted September 11, 2017 And then for Emby Connect, as Happy says, you need to link your account. It's pretty easy.
Happy2Play 9811 Posted September 11, 2017 Posted September 11, 2017 The dashboard is showing the right external ip address correct? Are you using a vpn?
all4dom 101 Posted September 11, 2017 Author Posted September 11, 2017 For port forwarding, I used the wan number & tcp & 8096.I did this for my router. I then looked up how to allow access in the windows firewall & I setup that to allow access.I am not using a vpn.
Guest asrequested Posted September 11, 2017 Posted September 11, 2017 For port forwarding, I used the wan number & tcp & 8096.I did this for my router. I then looked up how to allow access in the windows firewall & I setup that to allow access.I am not using a vpn. Use the LAN address, not WAN. The rest is correct
all4dom 101 Posted September 11, 2017 Author Posted September 11, 2017 What about windows firewall....redo with the correct address?
all4dom 101 Posted September 11, 2017 Author Posted September 11, 2017 OK...1st step success....thanks...now on to emby connect.
Guest asrequested Posted September 11, 2017 Posted September 11, 2017 OK...1st step success....thanks...now on to emby connect. Just follow the steps in the picture, that I posted. You already have an account, just link it.
all4dom 101 Posted September 11, 2017 Author Posted September 11, 2017 I got it. Doofus if u were here I would give u a big kiss.........thanks.
