osak00006 12 Posted September 4, 2017 Posted September 4, 2017 Hi Guys, I'm stumped. I have Emby for Kodi installed on two identical Kodi (LibreELEC) boxes. On my main box, everything works well. On my basement box, which I don't use nearly as often but is left on 24/7 just like my main box, I have a weird problem where it seems to do small incremental syncs every few minutes. Like 50-200 items. This is all occurring while there have been no substantive changes to my files/content. I'll even see the same content syncing multiple times back to back. As an example, as it's the only one I caught visibly today, Mr. 3000 seems to have synced in back to back Incremental Updates. Log files for Kodi (LibreELEC) is attached. Emby server (Unraid) via DropBox: https://www.dropbox.com/s/0nf9cx1bdiop4np/Log.txt?dl=0 Any help would be greatly appreciated log-2017-09-04-21.49.34.zip
Angelblue05 4132 Posted September 4, 2017 Posted September 4, 2017 It only sync when the server sends an update. But thank you for posting your logs. I'll check it out, but it will most likely be something outside of emby for kodi. Sent from my iPhone using Tapatalk
osak00006 12 Posted September 4, 2017 Author Posted September 4, 2017 It only sync when the server sends an update. But thank you for posting your logs. I'll check it out, but it will most likely be something outside of emby for kodi. Sent from my iPhone using Tapatalk Then shouldn't I see the problem mirrored on both Kodi boxes? Additionally, I'll see deletes not show up in Kodi, without a manual restart. For example, if I remux a movie to remove a track there would be a duplicate temporarily. Once I delete it, that dup doesn't disappear automagically, consistently...
Angelblue05 4132 Posted September 5, 2017 Posted September 5, 2017 You are getting a lot of updates. Like, a lot. What are your server settings under dashboard > library > Nfo settings
osak00006 12 Posted September 5, 2017 Author Posted September 5, 2017 (edited) Attached Edited September 5, 2017 by osak00006
osak00006 12 Posted September 6, 2017 Author Posted September 6, 2017 You are getting a lot of updates. Like, a lot. What are your server settings under dashboard > library > Nfo settings Any ideas?
Luke 42203 Posted September 6, 2017 Posted September 6, 2017 Wouldn't the server log be more useful to help indicate why they were being triggered?
osak00006 12 Posted September 6, 2017 Author Posted September 6, 2017 Wouldn't the server log be more useful to help indicate why they were being triggered? I previously provided that. Anything you'd like to see, just let me know.
Angelblue05 4132 Posted September 6, 2017 Posted September 6, 2017 (edited) Sorry. Your settings look fine. What I saw in your Kodi log was I believe, watched status update and deletions. You had easily over a 10000 updates. Do you use trakt? Do you delete files a lot? Maybe a third party app that modifies your nfos? Sent from my iPhone using Tapatalk Edited September 6, 2017 by Angelblue05
osak00006 12 Posted September 6, 2017 Author Posted September 6, 2017 Sorry. Your settings look fine. What I saw in your Kodi log was I believe, watched status update and deletions. You had easily over a 10000 updates. Do you use trakt? Do you delete files a lot? Maybe a third party app that modifies your nfos? Sent from my iPhone using Tapatalk Nope. I used to use a batch file that modified files nightly, but I disabled that per your recommend in a previous post. No major changes on the level you're describing. In an effort to workaround the problem, is there any way to trigger Emby for Kodi to perform a Manual Sync? I've experimented with the Kodi Callbacks add-on: RunPlugin(plugin.video.emby/?mode=manualsync) But that doesn't seem to accomplish anything...
Angelblue05 4132 Posted September 6, 2017 Posted September 6, 2017 (edited) RunPlugin(plugin://plugin.video.emby/?mode=manualsync) Ok, then that must have been it. Do you still experience a lot of incremental updates since disabling the batch file? Edited September 6, 2017 by Angelblue05
osak00006 12 Posted September 6, 2017 Author Posted September 6, 2017 RunPlugin(plugin://plugin.video.emby/?mode=manualsync) Ok, then that must have been it. Do you still experience a lot of incremental updates since disabling the batch file? AH, that got it going. I'll use a scheduled manual sync in the background as workaround. Not 100% certain of it, but this should work as a catchall solution. Thanks again!! 1
Angelblue05 4132 Posted September 6, 2017 Posted September 6, 2017 (edited) Sure, but you should still try without it, and seeing if you still experience your issue. Let me know if it persists. Edited September 6, 2017 by Angelblue05
osak00006 12 Posted September 7, 2017 Author Posted September 7, 2017 (edited) Sure, but you should still try without it, and seeing if you still experience your issue. Let me know if it persists. Thanks. I'll test both ways. Final question... is there any way to hide the Manual Sync progress, similar to incremental sync? Edited September 7, 2017 by osak00006
Angelblue05 4132 Posted September 7, 2017 Posted September 7, 2017 No because you don't want to do much of anything while it's running. Sent from my iPhone using Tapatalk
