linkplayer 2 Posted September 3, 2017 Posted September 3, 2017 (edited) I have an Emby server installed on my unRaid server by Docker. I use Emby with Kodi. There I have right at the beginning a sync problem.Need help. Sorry for my English My native language is German Edited September 3, 2017 by linkplayer
linkplayer 2 Posted September 4, 2017 Author Posted September 4, 2017 (edited) Emby Server Version 3.2.30.0 Edited September 4, 2017 by linkplayer
Angelblue05 4132 Posted September 4, 2017 Posted September 4, 2017 Oh. I didn't realize /virtualfolders is admin only? I use it to know if series pooling is enabled for the library. Sent from my iPhone using Tapatalk
Luke 42245 Posted September 4, 2017 Posted September 4, 2017 Oh. I didn't realize /virtualfolders is admin only? I use it to know if series pooling is enabled for the library. Sent from my iPhone using Tapatalk For now I would just handle the error so that they don't get an error message, and i'll have to review it. thanks. 1
Angelblue05 4132 Posted September 4, 2017 Posted September 4, 2017 Ok. I will post an update. Sent from my iPhone using Tapatalk
linkplayer 2 Posted September 4, 2017 Author Posted September 4, 2017 (edited) I've done it with help. That helped. Allow this user to run the server. But this can not be right because of security. Edited September 4, 2017 by linkplayer
Angelblue05 4132 Posted September 4, 2017 Posted September 4, 2017 No... just update to 2.3.51 (emby for kodi) that should resolve the error. Sent from my iPhone using Tapatalk
Angelblue05 4132 Posted September 4, 2017 Posted September 4, 2017 Can you post your Kodi log? Sent from my iPhone using Tapatalk
linkplayer 2 Posted September 4, 2017 Author Posted September 4, 2017 Tomorrow. Must go to bed now. My wife is already screaming.
Angelblue05 4132 Posted September 4, 2017 Posted September 4, 2017 @@linkplayer No problem, can you give 2.3.52 when you have a chance. If it still doesn't work, please post your Kodi log. Thank you.
linkplayer 2 Posted September 5, 2017 Author Posted September 5, 2017 2.3.52 works perfectly. The sync runs through. Thanks for the support. 1
