Luke 42243 Posted July 2, 2018 Posted July 2, 2018 I just barely setup an emby server and am experiencing this issue on a few different Roku devices as well. I am curious what this means, "...The documented cases of it we've seen have been the result of the server sending over full-resolution images to the app due to the lack of an image processor to resize them on the server." I am running the emby server on a Windows 10, i7 cpu, with 32GB of ram. What would I need to do to make sure there is an image processor setup correctly to resize them? Thanks! Hi there, can you please attach the emby server log? i'd like to see if there's anything i can spot. you can learn how to do that here: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks !
betamax 0 Posted July 2, 2018 Posted July 2, 2018 (edited) Thanks! Here are my logs from when I startup the Emby App on the Roku and choose one of the categories in "My Media" and then Look at the details of one movies. It blinks uncontrollably when trying to view any of the movie or tv details as well as when browsing the movie or tv lists. It appears that it is having a problem of applying the darken overlay to the backgrounds. The backgrounds go full brightness and a darkened subdued brightness back and forth. This happens to me all the time in every area regardless of if I am browsing TV Shows or Movies, or looking at the page of the individual movies or tv shows. I have unchecked "Enable backdrops" in the Display settings on both the server and on the roku app. The backgrounds still appear in the individual Movie and TV Show details. I have tried it with and without Enabling Image Enhancers. I have also tried it with and without the CoverArt mod and nothing seams to affect or even change the frequency in which it happens, which for me is non stop when doing anything within the roku app. As others have noted, which may not be relevant, none of these devices have problems with plex. I also tried loading the Emby Theater on my desktop, and it did not experience any issues and looked beautiful. Here are the logs, with a new "Roku® Streaming Stick®", their mid range offering. Please let me know if you would like a copy with the debugging turned on as well. embyserver.txt Edited July 2, 2018 by betamax
Luke 42243 Posted July 2, 2018 Posted July 2, 2018 Can you please attach the complete log file starting with the server startup sequences? Thanks !
betamax 0 Posted July 2, 2018 Posted July 2, 2018 The background of All Movies, when in All Movies list blinks light gray and dark gray. While all the cover arts just randomly flickers independently of each other. In that log file, I also went to the first movie in that collection, which was 101 Dalmatians II Patch's London Adventure. While on that movie details screen, the background (fanart) flashes between the image washed out, full brightness, and dark grey. Most of the other icons as well flicker, such as the emby logo, the star rating icon, the rotten tomato icon, the movie logo, the Play, Watched, and Favorite icons. The dark gray back drop behind the casts flickers off and on as well as the cast photos, Looks like pretty much everything minus the text flickers off and on rapidly and randomly at different intervals.
betamax 0 Posted July 2, 2018 Posted July 2, 2018 Mine looks very similar to the video that was posted in another similar topic here, https://emby.media/community/index.php?/topic/59739-movies-list-constantly-flashes/page-2&do=findComment&comment=592748
syralk 13 Posted July 20, 2018 Posted July 20, 2018 I got the same issue with the Roku express flashing backdrop all the time
ebr 16335 Posted July 20, 2018 Posted July 20, 2018 Can one of you with this problem please be sure your server is updated to 3.5.0 then turn on the debug logging option and re-start the server. Then reproduce this problem with the app and post the server log out here. Please also give us an indication of the time the problem occurred. Thanks!
ebr 16335 Posted July 25, 2018 Posted July 25, 2018 Please, can anyone give us a debug server log from 3.5.x when this issue is occurring? We'd really like to address this but need to know exactly why it is happening. Thanks.
Kevin M. 1 Posted July 26, 2018 Posted July 26, 2018 (edited) I just installed Emby 3.5.0.0 on my Synology DS-218+. Viewing Emby with my Roku streaming stick, I got the flashing between the two grey colors when I launched the Roku app. The time was 10:08pm. It happened on the main screen, when I clicked into my "TV Series" library, when I opened a show. 2018-07-25 22:06:35.974 Info Main: Emby Command line: /var/packages/EmbyServer/target/server/MediaBrowser.Server.Mono.exe -package synology -programdata /var/packages/EmbyServer/target/var -ffmpeg /var/packages/EmbyServer/target/ffmpeg/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/ffmpeg/bin/ffprobe -restartpath /var/packages/EmbyServer/scripts/restart Operating system: Unix 4.4.59.0 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 5.10.1.47 (tarball Sat Apr 21 19:46:45 CST 2018) Processor count: 2 Program data path: /var/packages/EmbyServer/target/var Application directory: /volume1/@appstore/EmbyServer/releases/v3.5.0.0 2018-07-25 22:06:37.130 Info App: Application version: 3.5.0.0 2018-07-25 22:06:37.132 Info App: Loading assemblies 2018-07-25 22:06:37.177 Info App: File /var/packages/EmbyServer/target/var/plugins/IMVDb.dll has version 1.0.1.0 2018-07-25 22:06:37.241 Info App: File /volume1/@appstore/EmbyServer/releases/v3.5.0.0/plugins/IMVDb.dll has version 1.0.1.0 2018-07-25 22:06:37.276 Info App: File /var/packages/EmbyServer/target/var/plugins/OpenSubtitles.dll has version 1.0.2.0 2018-07-25 22:06:37.281 Info App: File /volume1/@appstore/EmbyServer/releases/v3.5.0.0/plugins/OpenSubtitles.dll has version 1.0.2.0 2018-07-25 22:06:37.376 Info App: Loading IMVDb, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null from /var/packages/EmbyServer/target/var/plugins/IMVDb.dll 2018-07-25 22:06:37.376 Info App: Loading IsoMounter, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null from /var/packages/EmbyServer/target/var/plugins/IsoMounter.dll 2018-07-25 22:06:37.377 Info App: Loading OpenSubtitles, Version=1.0.2.0, Culture=neutral, PublicKeyToken=null from /var/packages/EmbyServer/target/var/plugins/OpenSubtitles.dll 2018-07-25 22:06:37.377 Info App: Loading MediaBrowser.Api, Version=3.5.0.0, Culture=neutral, PublicKeyToken=null 2018-07-25 22:06:37.377 Info App: Loading MediaBrowser.WebDashboard, Version=3.5.0.0, Culture=neutral, PublicKeyToken=null 2018-07-25 22:06:37.377 Info App: Loading MediaBrowser.Model, Version=3.5.0.0, Culture=neutral, PublicKeyToken=null 2018-07-25 22:06:37.377 Info App: Loading MediaBrowser.Common, Version=3.5.0.0, Culture=neutral, PublicKeyToken=null 2018-07-25 22:06:37.377 Info App: Loading MediaBrowser.Controller, Version=3.5.0.0, Culture=neutral, PublicKeyToken=null 2018-07-25 22:06:37.377 Info App: Loading MediaBrowser.Providers, Version=3.5.0.0, Culture=neutral, PublicKeyToken=null 2018-07-25 22:06:37.377 Info App: Loading Emby.Photos, Version=3.5.0.0, Culture=neutral, PublicKeyToken=null 2018-07-25 22:06:37.377 Info App: Loading Emby.Server.Implementations, Version=3.5.0.0, Culture=neutral, PublicKeyToken=null 2018-07-25 22:06:37.377 Info App: Loading Emby.Server.MediaEncoding, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-07-25 22:06:37.377 Info App: Loading Emby.Dlna, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-07-25 22:06:37.377 Info App: Loading MediaBrowser.LocalMetadata, Version=3.5.0.0, Culture=neutral, PublicKeyToken=null 2018-07-25 22:06:37.377 Info App: Loading Emby.Notifications, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-07-25 22:06:37.377 Info App: Loading MediaBrowser.XbmcMetadata, Version=3.5.0.0, Culture=neutral, PublicKeyToken=null 2018-07-25 22:06:37.377 Info App: Loading MediaBrowser.Server.Mono, Version=3.5.0.0, Culture=neutral, PublicKeyToken=null 2018-07-25 22:06:37.377 Info App: Loading Emby.Server.Connect, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-07-25 22:06:37.377 Info App: Loading Emby.Server.Sync, Version=3.5.0.0, Culture=neutral, PublicKeyToken=null 2018-07-25 22:06:37.613 Info SqliteUserRepository: Sqlite version: 3.23.1 2018-07-25 22:06:37.615 Info SqliteUserRepository: Sqlite compiler options: COMPILER=gcc-5.5.0,ENABLE_FTS3,ENABLE_RTREE,THREADSAFE=1 2018-07-25 22:06:37.705 Info SqliteUserRepository: Default journal_mode for /var/packages/EmbyServer/target/var/data/users.db is wal 2018-07-25 22:06:37.708 Info SqliteUserRepository: PRAGMA synchronous=1 2018-07-25 22:06:37.724 Info AuthenticationRepository: Default journal_mode for /var/packages/EmbyServer/target/var/data/authentication.db is wal 2018-07-25 22:06:37.725 Info AuthenticationRepository: PRAGMA synchronous=1 2018-07-25 22:06:37.831 Info ActivityRepository: Default journal_mode for /var/packages/EmbyServer/target/var/data/activitylog.db is wal 2018-07-25 22:06:37.832 Info ActivityRepository: PRAGMA synchronous=1 2018-07-25 22:06:37.836 Info SqliteDisplayPreferencesRepository: Default journal_mode for /var/packages/EmbyServer/target/var/data/displaypreferences.db is wal 2018-07-25 22:06:37.836 Info SqliteDisplayPreferencesRepository: PRAGMA synchronous=1 2018-07-25 22:06:38.077 Debug XmlSerializer: Deserializing file /var/packages/EmbyServer/target/var/config/users/403cd3692c6f472da5a47805c635494d/policy.xml 2018-07-25 22:06:38.228 Info SqliteItemRepository: Default journal_mode for /var/packages/EmbyServer/target/var/data/library.db is wal 2018-07-25 22:06:38.229 Info SqliteItemRepository: PRAGMA synchronous=1 2018-07-25 22:06:38.503 Debug XmlSerializer: Deserializing file /var/packages/EmbyServer/target/var/config/encoding.xml 2018-07-25 22:06:38.689 Info HttpServer: Calling ServiceStack AppHost.Init 2018-07-25 22:06:39.933 Info HttpServer: Adding HttpListener prefix http://+:8096/ 2018-07-25 22:06:39.934 Info HttpServer: Adding HttpListener prefix https://+:8920/ 2018-07-25 22:06:40.450 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/67.0.3396.99 Safari/537.36 2018-07-25 22:06:40.499 Info HttpServer: HTTP Response 503 to 192.168.1.107. Time: 72ms. http://192.168.1.100:8096/emby/ScheduledTasks?IsEnabled=true 2018-07-25 22:06:40.507 Info App: [LinuxIsoManager] Implementation version is [2018.2.7.1]. 2018-07-25 22:06:40.508 Debug App: [LinuxIsoManager] System PATH is currently set to [/var/packages/EmbyServer/scripts/utilities/sbin:/var/packages/EmbyServer/target/mono/bin:/var/packages/EmbyServer/target/ffmpeg/bin:/var/packages/EmbyServer/target/imagemagick/bin:/var/packages/EmbyServer/target/sqlite/bin:/sbin:/bin:/usr/sbin:/usr/bin:/usr/syno/sbin:/usr/syno/bin:/usr/local/sbin:/usr/local/bin]. 2018-07-25 22:06:40.508 Debug App: [LinuxIsoManager] System path separator is [:]. 2018-07-25 22:06:40.508 Debug App: [LinuxIsoManager] Mount point root is [/tmp/Emby]. 2018-07-25 22:06:40.509 Debug App: [LinuxIsoManager] Searching path [/var/packages/EmbyServer/scripts/utilities/sbin] for [sudo]. 2018-07-25 22:06:40.509 Info App: [LinuxIsoManager] Using version of [sudo] located at [/var/packages/EmbyServer/scripts/utilities/sbin/sudo]. 2018-07-25 22:06:40.509 Debug App: [LinuxIsoManager] Searching path [/var/packages/EmbyServer/scripts/utilities/sbin] for [mount]. 2018-07-25 22:06:40.509 Info App: [LinuxIsoManager] Using version of [mount] located at [/var/packages/EmbyServer/scripts/utilities/sbin/mount]. 2018-07-25 22:06:40.509 Debug App: [LinuxIsoManager] Searching path [/var/packages/EmbyServer/scripts/utilities/sbin] for [umount]. 2018-07-25 22:06:40.509 Info App: [LinuxIsoManager] Using version of [umount] located at [/var/packages/EmbyServer/scripts/utilities/sbin/umount]. 2018-07-25 22:06:40.520 Info Main: Skia not available. Will try next image processor. libSkiaSharp 2018-07-25 22:06:40.572 Info ImageMagick: ImageMagick version: ImageMagick 6.9.9-40 Q8 x86_64 2018-04-21 http://www.imagemagick.org 2018-07-25 22:06:40.622 Info TaskManager: Daily trigger for Chapter image extraction set to fire at 7/26/2018 2:00:00 AM, which is 233.322994683333 minutes from now. 2018-07-25 22:06:40.647 Info TaskManager: Daily trigger for Rotate log file set to fire at 7/26/2018 12:00:00 AM, which is 113.32254265 minutes from now. 2018-07-25 22:06:40.681 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/System/Info. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/67.0.3396.99 Safari/537.36 2018-07-25 22:06:40.682 Info HttpServer: HTTP Response 503 to 192.168.1.107. Time: 2ms. http://192.168.1.100:8096/emby/System/Info 2018-07-25 22:06:40.688 Info MediaEncoder: FFMpeg: /var/packages/EmbyServer/target/ffmpeg/bin/ffmpeg 2018-07-25 22:06:40.688 Info MediaEncoder: FFProbe: /var/packages/EmbyServer/target/ffmpeg/bin/ffprobe 2018-07-25 22:06:40.689 Info MediaEncoder: Validating media encoder at /var/packages/EmbyServer/target/ffmpeg/bin/ffmpeg 2018-07-25 22:06:40.693 Info MediaEncoder: Running /var/packages/EmbyServer/target/ffmpeg/bin/ffmpeg -decoders 2018-07-25 22:06:41.781 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/67.0.3396.99 Safari/537.36 2018-07-25 22:06:41.782 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/System/Info. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/67.0.3396.99 Safari/537.36 2018-07-25 22:06:41.782 Info HttpServer: HTTP Response 503 to 192.168.1.107. Time: 1ms. http://192.168.1.100:8096/emby/ScheduledTasks?IsEnabled=true 2018-07-25 22:06:41.782 Info HttpServer: HTTP Response 503 to 192.168.1.107. Time: 0ms. http://192.168.1.100:8096/emby/System/Info 2018-07-25 22:06:41.790 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/67.0.3396.99 Safari/537.36 2018-07-25 22:06:41.791 Info HttpServer: HTTP Response 503 to 192.168.1.107. Time: 1ms. http://192.168.1.100:8096/emby/ScheduledTasks?IsEnabled=true 2018-07-25 22:06:41.809 Info HttpServer: WS http://192.168.1.100:8096/embywebsocket?api_key=e5ae314c75e74e9aa4f4602454fd9818&deviceId=9cbf7c6f20a25ad5a1cb5592ac071c4b9e71b076. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/67.0.3396.99 Safari/537.36 2018-07-25 22:06:41.815 Debug HttpServer: Web socket connection allowed 2018-07-25 22:06:42.020 Debug SessionManager: Creating new WebSocketController 2018-07-25 22:06:42.439 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/System/Info. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/67.0.3396.99 Safari/537.36 2018-07-25 22:06:42.440 Info HttpServer: HTTP Response 503 to 192.168.1.107. Time: 1ms. http://192.168.1.100:8096/emby/System/Info 2018-07-25 22:06:43.054 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/System/Info. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/67.0.3396.99 Safari/537.36 2018-07-25 22:06:43.054 Info HttpServer: HTTP Response 503 to 192.168.1.107. Time: 0ms. http://192.168.1.100:8096/emby/System/Info 2018-07-25 22:06:43.641 Info TaskManager: StartupTrigger fired for task: Check for plugin updates 2018-07-25 22:06:43.644 Info TaskManager: Queueing task PluginUpdateTask 2018-07-25 22:06:43.644 Info TaskManager: StartupTrigger fired for task: Check for application updates 2018-07-25 22:06:43.645 Info TaskManager: Queueing task SystemUpdateTask 2018-07-25 22:06:43.651 Info TaskManager: Executing Check for application updates 2018-07-25 22:06:43.651 Info TaskManager: Executing Check for plugin updates 2018-07-25 22:06:43.666 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/System/Info. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/67.0.3396.99 Safari/537.36 2018-07-25 22:06:43.667 Info HttpServer: HTTP Response 503 to 192.168.1.107. Time: 0ms. http://192.168.1.100:8096/emby/System/Info 2018-07-25 22:06:43.934 Info TaskManager: Check for plugin updates Completed after 0 minute(s) and 0 seconds 2018-07-25 22:06:43.960 Info TaskManager: Check for application updates Completed after 0 minute(s) and 0 seconds 2018-07-25 22:06:44.001 Info TaskManager: ExecuteQueuedTasks 2018-07-25 22:06:44.001 Info TaskManager: ExecuteQueuedTasks 2018-07-25 22:06:44.303 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/System/Info. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/67.0.3396.99 Safari/537.36 2018-07-25 22:06:44.305 Info HttpServer: HTTP Response 503 to 192.168.1.107. Time: 1ms. http://192.168.1.100:8096/emby/System/Info 2018-07-25 22:06:44.916 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/System/Info. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/67.0.3396.99 Safari/537.36 2018-07-25 22:06:44.917 Info HttpServer: HTTP Response 503 to 192.168.1.107. Time: 1ms. http://192.168.1.100:8096/emby/System/Info 2018-07-25 22:06:45.245 Info MediaEncoder: Decoder available: mpeg2video 2018-07-25 22:06:45.248 Info MediaEncoder: Decoder available: h264_qsv 2018-07-25 22:06:45.250 Info MediaEncoder: Decoder available: hevc_qsv 2018-07-25 22:06:45.253 Info MediaEncoder: Decoder available: mpeg2_qsv 2018-07-25 22:06:45.259 Info MediaEncoder: Decoder available: vc1_qsv 2018-07-25 22:06:45.433 Info MediaEncoder: Decoder available: ac3 2018-07-25 22:06:45.440 Info MediaEncoder: Decoder available: aac 2018-07-25 22:06:45.449 Info MediaEncoder: Decoder available: mp3 2018-07-25 22:06:45.451 Info MediaEncoder: Decoder available: h264 2018-07-25 22:06:45.453 Info MediaEncoder: Decoder available: hevc 2018-07-25 22:06:45.551 Info MediaEncoder: Running /var/packages/EmbyServer/target/ffmpeg/bin/ffmpeg -encoders 2018-07-25 22:06:45.567 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/System/Info. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/67.0.3396.99 Safari/537.36 2018-07-25 22:06:45.567 Info HttpServer: HTTP Response 503 to 192.168.1.107. Time: 1ms. http://192.168.1.100:8096/emby/System/Info 2018-07-25 22:06:45.577 Info MediaEncoder: Encoder available: libx264 2018-07-25 22:06:45.578 Info MediaEncoder: Encoder available: libx265 2018-07-25 22:06:45.580 Info MediaEncoder: Encoder available: mpeg4 2018-07-25 22:06:45.582 Info MediaEncoder: Encoder available: msmpeg4 2018-07-25 22:06:45.584 Info MediaEncoder: Encoder available: libvpx 2018-07-25 22:06:45.586 Info MediaEncoder: Encoder available: libvpx-vp9 2018-07-25 22:06:45.589 Info MediaEncoder: Encoder available: aac 2018-07-25 22:06:45.594 Info MediaEncoder: Encoder available: libmp3lame 2018-07-25 22:06:45.597 Info MediaEncoder: Encoder available: libopus 2018-07-25 22:06:45.602 Info MediaEncoder: Encoder available: libvorbis 2018-07-25 22:06:45.607 Info MediaEncoder: Encoder available: srt 2018-07-25 22:06:45.619 Info MediaEncoder: Encoder available: h264_qsv 2018-07-25 22:06:45.620 Info MediaEncoder: Encoder available: hevc_qsv 2018-07-25 22:06:45.646 Info MediaEncoder: Encoder available: h264_vaapi 2018-07-25 22:06:45.647 Info MediaEncoder: Encoder available: hevc_vaapi 2018-07-25 22:06:45.648 Info MediaEncoder: Encoder available: h264_v4l2m2m 2018-07-25 22:06:45.651 Info MediaEncoder: Encoder available: libwebp 2018-07-25 22:06:45.654 Info MediaEncoder: Encoder available: ac3 2018-07-25 22:06:45.660 Info MediaEncoder: Running /var/packages/EmbyServer/target/ffmpeg/bin/ffmpeg -protocols 2018-07-25 22:06:45.683 Info MediaEncoder: Encoder validation complete 2018-07-25 22:06:45.683 Info MediaEncoder: ffmpeg supported protocols: async,cache,concat,crypto,data,file,ftp,gopher,hls,http,httpproxy,https,mmsh,mmst,pipe,rtp,srtp,subfile,tcp,tls,udp,udplite,unix,rtmp,rtmpe,rtmps,rtmpt,rtmpte 2018-07-25 22:06:45.683 Info App: ServerId: 2fccf22623d74e558d4012ccfa8bc5f8 2018-07-25 22:06:45.746 Info App: Starting entry point MediaBrowser.WebDashboard.ServerEntryPoint 2018-07-25 22:06:45.748 Info App: Entry point completed: MediaBrowser.WebDashboard.ServerEntryPoint. Duration: 0.001951 seconds 2018-07-25 22:06:45.749 Info App: Starting entry point Emby.Dlna.Main.DlnaEntryPoint 2018-07-25 22:06:45.869 Debug XmlSerializer: Deserializing file /var/packages/EmbyServer/target/var/config/dlna/system/Default.xml 2018-07-25 22:06:46.048 Debug XmlSerializer: Deserializing file /var/packages/EmbyServer/target/var/config/dlna/system/Denon AVR.xml 2018-07-25 22:06:46.079 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/System/Info. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/67.0.3396.99 Safari/537.36 2018-07-25 22:06:46.079 Info HttpServer: HTTP Response 503 to 192.168.1.107. Time: 0ms. http://192.168.1.100:8096/emby/System/Info 2018-07-25 22:06:46.292 Debug XmlSerializer: Deserializing file /var/packages/EmbyServer/target/var/config/dlna/system/DirecTV HD-DVR.xml 2018-07-25 22:06:46.343 Debug XmlSerializer: Deserializing file /var/packages/EmbyServer/target/var/config/dlna/system/Dish Hopper-Joey.xml 2018-07-25 22:06:46.467 Debug XmlSerializer: Deserializing file /var/packages/EmbyServer/target/var/config/dlna/system/LG Smart TV.xml 2018-07-25 22:06:46.592 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/System/Info. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/67.0.3396.99 Safari/537.36 2018-07-25 22:06:46.593 Info HttpServer: HTTP Response 503 to 192.168.1.107. Time: 1ms. http://192.168.1.100:8096/emby/System/Info 2018-07-25 22:06:46.627 Debug XmlSerializer: Deserializing file /var/packages/EmbyServer/target/var/config/dlna/system/Linksys DMA2100.xml 2018-07-25 22:06:46.690 Debug XmlSerializer: Deserializing file /var/packages/EmbyServer/target/var/config/dlna/system/Marantz.xml 2018-07-25 22:06:46.697 Debug XmlSerializer: Deserializing file /var/packages/EmbyServer/target/var/config/dlna/system/MediaMonkey.xml 2018-07-25 22:06:46.698 Debug XmlSerializer: Deserializing file /var/packages/EmbyServer/target/var/config/dlna/system/Panasonic Viera.xml 2018-07-25 22:06:46.700 Debug XmlSerializer: Deserializing file /var/packages/EmbyServer/target/var/config/dlna/system/Popcorn Hour.xml 2018-07-25 22:06:46.816 Debug XmlSerializer: Deserializing file /var/packages/EmbyServer/target/var/config/dlna/system/Samsung Smart TV.xml 2018-07-25 22:06:46.817 Debug XmlSerializer: Deserializing file /var/packages/EmbyServer/target/var/config/dlna/system/Sharp Smart TV.xml 2018-07-25 22:06:46.822 Debug XmlSerializer: Deserializing file /var/packages/EmbyServer/target/var/config/dlna/system/Sony Blu-ray Player 2013.xml 2018-07-25 22:06:46.832 Debug XmlSerializer: Deserializing file /var/packages/EmbyServer/target/var/config/dlna/system/Sony Blu-ray Player 2014.xml 2018-07-25 22:06:46.926 Debug XmlSerializer: Deserializing file /var/packages/EmbyServer/target/var/config/dlna/system/Sony Blu-ray Player 2015.xml 2018-07-25 22:06:47.056 Debug XmlSerializer: Deserializing file /var/packages/EmbyServer/target/var/config/dlna/system/Sony Blu-ray Player 2016.xml 2018-07-25 22:06:47.064 Debug XmlSerializer: Deserializing file /var/packages/EmbyServer/target/var/config/dlna/system/Sony Blu-ray Player.xml 2018-07-25 22:06:47.068 Debug XmlSerializer: Deserializing file /var/packages/EmbyServer/target/var/config/dlna/system/Sony Bravia (2010).xml 2018-07-25 22:06:47.107 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/System/Info. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/67.0.3396.99 Safari/537.36 2018-07-25 22:06:47.108 Info HttpServer: HTTP Response 503 to 192.168.1.107. Time: 1ms. http://192.168.1.100:8096/emby/System/Info 2018-07-25 22:06:47.125 Debug XmlSerializer: Deserializing file /var/packages/EmbyServer/target/var/config/dlna/system/Sony Bravia (2011).xml 2018-07-25 22:06:47.126 Debug XmlSerializer: Deserializing file /var/packages/EmbyServer/target/var/config/dlna/system/Sony Bravia (2012).xml 2018-07-25 22:06:47.178 Debug XmlSerializer: Deserializing file /var/packages/EmbyServer/target/var/config/dlna/system/Sony Bravia (2013).xml 2018-07-25 22:06:47.233 Debug XmlSerializer: Deserializing file /var/packages/EmbyServer/target/var/config/dlna/system/Sony Bravia (2014).xml 2018-07-25 22:06:47.312 Debug XmlSerializer: Deserializing file /var/packages/EmbyServer/target/var/config/dlna/system/Sony PlayStation 3.xml 2018-07-25 22:06:47.370 Debug XmlSerializer: Deserializing file /var/packages/EmbyServer/target/var/config/dlna/system/Sony PlayStation 4.xml 2018-07-25 22:06:47.412 Debug XmlSerializer: Deserializing file /var/packages/EmbyServer/target/var/config/dlna/system/WDTV Live.xml 2018-07-25 22:06:47.434 Debug XmlSerializer: Deserializing file /var/packages/EmbyServer/target/var/config/dlna/system/Xbox One.xml 2018-07-25 22:06:47.447 Debug XmlSerializer: Deserializing file /var/packages/EmbyServer/target/var/config/dlna/system/foobar2000.xml 2018-07-25 22:06:47.591 Debug XmlSerializer: Deserializing file /var/packages/EmbyServer/target/var/config/dlna.xml 2018-07-25 22:06:47.623 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/System/Info. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/67.0.3396.99 Safari/537.36 2018-07-25 22:06:47.624 Info HttpServer: HTTP Response 503 to 192.168.1.107. Time: 0ms. http://192.168.1.100:8096/emby/System/Info 2018-07-25 22:06:47.691 Info App: Entry point completed: Emby.Dlna.Main.DlnaEntryPoint. Duration: 1.941961 seconds 2018-07-25 22:06:47.691 Info App: Starting entry point Emby.Server.Connect.ConnectEntryPoint 2018-07-25 22:06:47.693 Info App: Loading data from /var/packages/EmbyServer/target/var/data/connect.txt 2018-07-25 22:06:47.701 Info App: Loading data from /var/packages/EmbyServer/target/var/data/wan.dat 2018-07-25 22:06:47.788 Info App: Entry point completed: Emby.Server.Connect.ConnectEntryPoint. Duration: 0.097074 seconds 2018-07-25 22:06:47.788 Info App: Core startup complete 2018-07-25 22:06:47.788 Info App: Post-init migrations complete 2018-07-25 22:06:47.788 Info App: Starting entry point MediaBrowser.Api.ApiEntryPoint 2018-07-25 22:06:47.789 Info App: Entry point completed: MediaBrowser.Api.ApiEntryPoint. Duration: 6.1E-05 seconds 2018-07-25 22:06:47.789 Info App: Starting entry point Emby.Server.Implementations.News.NewsEntryPoint 2018-07-25 22:06:47.790 Info App: Entry point completed: Emby.Server.Implementations.News.NewsEntryPoint. Duration: 0.000274 seconds 2018-07-25 22:06:47.790 Info App: Starting entry point Emby.Server.Implementations.LiveTv.EmbyTV.EntryPoint 2018-07-25 22:06:47.855 Info App: Loading live tv data from /var/packages/EmbyServer/target/var/data/livetv/timers 2018-07-25 22:06:47.877 Debug XmlSerializer: Deserializing file /var/packages/EmbyServer/target/var/config/livetv.xml 2018-07-25 22:06:47.930 Debug App: Ping test result to http://192.168.1.100:8096/system/ping. Success: True 2018-07-25 22:06:48.137 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/System/Info. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/67.0.3396.99 Safari/537.36 2018-07-25 22:06:48.241 Info HttpServer: HTTP Response 200 to 192.168.1.107. Time: 104ms. http://192.168.1.100:8096/emby/System/Info 2018-07-25 22:06:48.294 Info HttpClient: HttpClientManager GET: https://emby.media/community/index.php?/blog/rss/1-media-browser-developers-blog 2018-07-25 22:06:48.560 Debug XmlSerializer: Deserializing file /var/packages/EmbyServer/target/var/root/default/Movies/options.xml 2018-07-25 22:06:48.707 Debug XmlSerializer: Deserializing file /var/packages/EmbyServer/target/var/root/default/TV Shows/options.xml 2018-07-25 22:06:48.735 Info App: Entry point completed: Emby.Server.Implementations.LiveTv.EmbyTV.EntryPoint. Duration: 0.944832 seconds 2018-07-25 22:06:48.735 Info App: Starting entry point Emby.Server.Implementations.Library.DeviceAccessEntryPoint 2018-07-25 22:06:48.735 Info App: Entry point completed: Emby.Server.Implementations.Library.DeviceAccessEntryPoint. Duration: 0.000625 seconds 2018-07-25 22:06:48.735 Info App: Starting entry point Emby.Server.Implementations.IO.LibraryMonitorStartup 2018-07-25 22:06:49.138 Info App: Entry point completed: Emby.Server.Implementations.IO.LibraryMonitorStartup. Duration: 0.402404 seconds 2018-07-25 22:06:49.138 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.AutomaticRestartEntryPoint 2018-07-25 22:06:49.139 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.AutomaticRestartEntryPoint. Duration: 0.000686 seconds 2018-07-25 22:06:49.139 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.ExternalPortForwarding 2018-07-25 22:06:49.140 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.ExternalPortForwarding. Duration: 0.000651 seconds 2018-07-25 22:06:49.140 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.KeepServerAwake 2018-07-25 22:06:49.140 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.KeepServerAwake. Duration: 0.000304 seconds 2018-07-25 22:06:49.140 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.LibraryChangedNotifier 2018-07-25 22:06:49.143 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.LibraryChangedNotifier. Duration: 0.002816 seconds 2018-07-25 22:06:49.143 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.RecordingNotifier 2018-07-25 22:06:49.145 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.RecordingNotifier. Duration: 0.001218 seconds 2018-07-25 22:06:49.145 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.ServerEventNotifier 2018-07-25 22:06:49.147 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.ServerEventNotifier. Duration: 0.002234 seconds 2018-07-25 22:06:49.147 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.StartupWizard 2018-07-25 22:06:49.148 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.StartupWizard. Duration: 0.000603 seconds 2018-07-25 22:06:49.148 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.SystemEvents 2018-07-25 22:06:49.148 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.SystemEvents. Duration: 0.000339 seconds 2018-07-25 22:06:49.148 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.UdpServerEntryPoint 2018-07-25 22:06:49.151 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.UdpServerEntryPoint. Duration: 0.002613 seconds 2018-07-25 22:06:49.151 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.UsageEntryPoint 2018-07-25 22:06:49.153 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.UsageEntryPoint. Duration: 0.001568 seconds 2018-07-25 22:06:49.153 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.UserDataChangeNotifier 2018-07-25 22:06:49.154 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.UserDataChangeNotifier. Duration: 0.00058 seconds 2018-07-25 22:06:49.154 Info App: Starting entry point Emby.Server.Implementations.Devices.DeviceManagerEntryPoint 2018-07-25 22:06:49.155 Info App: Entry point completed: Emby.Server.Implementations.Devices.DeviceManagerEntryPoint. Duration: 0.001295 seconds 2018-07-25 22:06:49.155 Info App: Starting entry point Emby.Server.Implementations.Collections.CollectionManagerEntryPoint 2018-07-25 22:06:49.157 Info App: Entry point completed: Emby.Server.Implementations.Collections.CollectionManagerEntryPoint. Duration: 0.001393 seconds 2018-07-25 22:06:49.157 Info App: Starting entry point Emby.Server.Implementations.Activity.ActivityLogEntryPoint 2018-07-25 22:06:49.160 Info App: Entry point completed: Emby.Server.Implementations.Activity.ActivityLogEntryPoint. Duration: 0.003446 seconds 2018-07-25 22:06:49.160 Info App: Starting entry point Emby.Server.MediaEncoding.Api.ApiEntryPoint 2018-07-25 22:06:49.163 Info App: Entry point completed: Emby.Server.MediaEncoding.Api.ApiEntryPoint. Duration: 0.002124 seconds 2018-07-25 22:06:49.163 Info App: Starting entry point Emby.Notifications.Notifications 2018-07-25 22:06:49.163 Info App: Entry point completed: Emby.Notifications.Notifications. Duration: 0.00067 seconds 2018-07-25 22:06:49.164 Info App: Starting entry point MediaBrowser.XbmcMetadata.EntryPoint 2018-07-25 22:06:49.164 Info App: Entry point completed: MediaBrowser.XbmcMetadata.EntryPoint. Duration: 0.000192 seconds 2018-07-25 22:06:49.164 Info App: Starting entry point Emby.Security.PluginSecurityManager 2018-07-25 22:06:49.164 Info App: Entry point completed: Emby.Security.PluginSecurityManager. Duration: 4.8E-05 seconds 2018-07-25 22:06:49.164 Info App: Starting entry point Emby.Server.Sync.SyncManagerEntryPoint 2018-07-25 22:06:49.172 Info App: Sqlite version: 3.23.1 2018-07-25 22:06:49.172 Info App: Sqlite compiler options: COMPILER=gcc-5.5.0,ENABLE_FTS3,ENABLE_RTREE,THREADSAFE=1 2018-07-25 22:06:49.173 Info App: Default journal_mode for /var/packages/EmbyServer/target/var/data/sync14.db is wal 2018-07-25 22:06:49.175 Info App: PRAGMA synchronous=1 2018-07-25 22:06:49.178 Info App: Entry point completed: Emby.Server.Sync.SyncManagerEntryPoint. Duration: 0.014108 seconds 2018-07-25 22:06:49.178 Info App: Starting entry point Emby.Server.Sync.SyncNotificationEntryPoint 2018-07-25 22:06:49.180 Info App: Entry point completed: Emby.Server.Sync.SyncNotificationEntryPoint. Duration: 0.001532 seconds 2018-07-25 22:06:49.180 Info App: All entry points have started 2018-07-25 22:06:50.718 Info LibraryMonitor: Watching directory /volume1/media/Movies 2018-07-25 22:06:50.737 Debug SessionManager: Disposing session controller WebSocketController 2018-07-25 22:06:51.048 Info LibraryMonitor: Watching directory /volume1/media/TV Shows 2018-07-25 22:06:51.864 Info HttpServer: HTTP GET http://192.168.1.100:8096/web/strings/en-US.json?v=1532581611118. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/67.0.3396.99 Safari/537.36 2018-07-25 22:06:51.867 Info HttpServer: HTTP GET http://192.168.1.100:8096/web/bower_components/emby-webcomponents/strings/en-us.json?v=1532581611118. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/67.0.3396.99 Safari/537.36 2018-07-25 22:06:51.924 Debug HttpResultFactory: Transmit file /volume1/@appstore/EmbyServer/releases/v3.5.0.0/dashboard-ui/strings/en-US.json 2018-07-25 22:06:51.932 Debug HttpResultFactory: Transmit file /volume1/@appstore/EmbyServer/releases/v3.5.0.0/dashboard-ui/bower_components/emby-webcomponents/strings/en-us.json 2018-07-25 22:06:52.001 Info HttpServer: HTTP Response 200 to 192.168.1.107. Time: 134ms. http://192.168.1.100:8096/web/bower_components/emby-webcomponents/strings/en-us.json?v=1532581611118 2018-07-25 22:06:52.016 Info HttpServer: HTTP Response 200 to 192.168.1.107. Time: 152ms. http://192.168.1.100:8096/web/strings/en-US.json?v=1532581611118 2018-07-25 22:06:52.776 Debug XmlSerializer: Deserializing file /var/packages/EmbyServer/target/var/config/branding.xml 2018-07-25 22:06:52.909 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/system/info/public. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/67.0.3396.99 Safari/537.36 2018-07-25 22:06:52.921 Info HttpServer: HTTP Response 200 to 192.168.1.107. Time: 12ms. http://192.168.1.100:8096/emby/system/info/public 2018-07-25 22:06:52.929 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/System/Info. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/67.0.3396.99 Safari/537.36 2018-07-25 22:06:52.935 Info HttpServer: HTTP Response 200 to 192.168.1.107. Time: 6ms. http://192.168.1.100:8096/emby/System/Info 2018-07-25 22:06:52.942 Info App: App Activity: app: Emby Mobile, version: 3.5.0.0, deviceId: 9cbf7c6f20a25ad5a1cb5592ac071c4b9e71b076, deviceName: Chrome 2018-07-25 22:06:52.946 Info HttpServer: HTTP POST http://192.168.1.100:8096/emby/Sessions/Capabilities/Full. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/67.0.3396.99 Safari/537.36 2018-07-25 22:06:52.955 Info HttpServer: WS http://192.168.1.100:8096/embywebsocket?api_key=e5ae314c75e74e9aa4f4602454fd9818&deviceId=9cbf7c6f20a25ad5a1cb5592ac071c4b9e71b076. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/67.0.3396.99 Safari/537.36 2018-07-25 22:06:52.955 Debug HttpServer: Web socket connection allowed 2018-07-25 22:06:52.956 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/Users/403cd3692c6f472da5a47805c635494d. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/67.0.3396.99 Safari/537.36 2018-07-25 22:06:52.956 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/DisplayPreferences/usersettings?userId=403cd3692c6f472da5a47805c635494d&client=emby. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/67.0.3396.99 Safari/537.36 2018-07-25 22:06:52.958 Debug SessionManager: Creating new WebSocketController 2018-07-25 22:06:52.983 Debug XmlSerializer: Deserializing file /var/packages/EmbyServer/target/var/config/users/403cd3692c6f472da5a47805c635494d/config.xml 2018-07-25 22:06:53.138 Info HttpServer: HTTP Response 200 to 192.168.1.107. Time: 182ms. http://192.168.1.100:8096/emby/DisplayPreferences/usersettings?userId=403cd3692c6f472da5a47805c635494d&client=emby 2018-07-25 22:06:53.191 Info HttpServer: HTTP Response 200 to 192.168.1.107. Time: 235ms. http://192.168.1.100:8096/emby/Users/403cd3692c6f472da5a47805c635494d 2018-07-25 22:06:53.195 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/Users/403cd3692c6f472da5a47805c635494d. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/67.0.3396.99 Safari/537.36 2018-07-25 22:06:53.197 Info HttpServer: HTTP Response 200 to 192.168.1.107. Time: 2ms. http://192.168.1.100:8096/emby/Users/403cd3692c6f472da5a47805c635494d 2018-07-25 22:06:53.201 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/Users/403cd3692c6f472da5a47805c635494d. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/67.0.3396.99 Safari/537.36 2018-07-25 22:06:53.204 Info HttpServer: HTTP Response 200 to 192.168.1.107. Time: 2ms. http://192.168.1.100:8096/emby/Users/403cd3692c6f472da5a47805c635494d 2018-07-25 22:06:53.256 Info HttpServer: HTTP Response 204 to 192.168.1.107. Time: 310ms. http://192.168.1.100:8096/emby/Sessions/Capabilities/Full 2018-07-25 22:06:53.550 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/Sessions?ActiveWithinSeconds=960. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/67.0.3396.99 Safari/537.36 2018-07-25 22:06:53.554 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/ScheduledTasks. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/67.0.3396.99 Safari/537.36 2018-07-25 22:06:53.556 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/System/Info. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/67.0.3396.99 Safari/537.36 2018-07-25 22:06:53.557 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/News/Product?StartIndex=0&Limit=4. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/67.0.3396.99 Safari/537.36 2018-07-25 22:06:53.569 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/System/ActivityLog/Entries?startIndex=0&limit=4&minDate=2018-07-19T05%3A06%3A52.810Z&hasUserId=false. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/67.0.3396.99 Safari/537.36 2018-07-25 22:06:53.570 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/System/ActivityLog/Entries?startIndex=0&limit=7&minDate=2018-07-25T05%3A06%3A52.808Z&hasUserId=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/67.0.3396.99 Safari/537.36 2018-07-25 22:06:53.588 Info HttpServer: HTTP Response 200 to 192.168.1.107. Time: 32ms. http://192.168.1.100:8096/emby/System/Info 2018-07-25 22:06:53.588 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/LiveTv/Recordings?UserId=403cd3692c6f472da5a47805c635494d&IsInProgress=true&Fields=CanDelete%2CPrimaryImageAspectRatio&EnableTotalRecordCount=false&EnableImageTypes=Primary%2CThumb%2CBackdrop. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/67.0.3396.99 Safari/537.36 2018-07-25 22:06:53.596 Debug App: SessionInfoWebSocketListener Begin transmitting over websocket to [::ffff:192.168.1.107]:55972 2018-07-25 22:06:53.598 Debug App: ActivityLogWebSocketListener Begin transmitting over websocket to [::ffff:192.168.1.107]:55972 2018-07-25 22:06:53.598 Debug App: ActivityLogWebSocketListener Begin transmitting over websocket to [::ffff:192.168.1.107]:55972 2018-07-25 22:06:53.598 Debug App: ScheduledTasksWebSocketListener Begin transmitting over websocket to [::ffff:192.168.1.107]:55972 2018-07-25 22:06:53.634 Info HttpServer: HTTP Response 200 to 192.168.1.107. Time: 77ms. http://192.168.1.100:8096/emby/News/Product?StartIndex=0&Limit=4 2018-07-25 22:06:53.727 Info HttpServer: HTTP Response 200 to 192.168.1.107. Time: 158ms. http://192.168.1.100:8096/emby/System/ActivityLog/Entries?startIndex=0&limit=7&minDate=2018-07-25T05%3A06%3A52.808Z&hasUserId=true 2018-07-25 22:06:53.734 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/web/configurationpages?pageType=PluginConfiguration&EnableInMainMenu=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/67.0.3396.99 Safari/537.36 2018-07-25 22:06:53.736 Info HttpServer: HTTP Response 200 to 192.168.1.107. Time: 171ms. http://192.168.1.100:8096/emby/System/ActivityLog/Entries?startIndex=0&limit=4&minDate=2018-07-19T05%3A06%3A52.810Z&hasUserId=false 2018-07-25 22:06:53.740 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/Packages/Updates?PackageType=System. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/67.0.3396.99 Safari/537.36 2018-07-25 22:06:53.769 Info HttpServer: HTTP Response 200 to 192.168.1.107. Time: 214ms. http://192.168.1.100:8096/emby/ScheduledTasks 2018-07-25 22:06:53.826 Info HttpServer: HTTP Response 200 to 192.168.1.107. Time: 92ms. http://192.168.1.100:8096/emby/web/configurationpages?pageType=PluginConfiguration&EnableInMainMenu=true 2018-07-25 22:06:53.834 Info HttpServer: HTTP GET http://192.168.1.100:8096/web/css/images/logoblack.png. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/67.0.3396.99 Safari/537.36 2018-07-25 22:06:53.835 Info HttpServer: HTTP Response 304 to 192.168.1.107. Time: 1ms. http://192.168.1.100:8096/web/css/images/logoblack.png 2018-07-25 22:06:53.860 Info HttpServer: HTTP Response 200 to 192.168.1.107. Time: 120ms. http://192.168.1.100:8096/emby/Packages/Updates?PackageType=System 2018-07-25 22:06:53.907 Info HttpServer: HTTP Response 200 to 192.168.1.107. Time: 319ms. http://192.168.1.100:8096/emby/LiveTv/Recordings?UserId=403cd3692c6f472da5a47805c635494d&IsInProgress=true&Fields=CanDelete%2CPrimaryImageAspectRatio&EnableTotalRecordCount=false&EnableImageTypes=Primary%2CThumb%2CBackdrop 2018-07-25 22:06:53.935 Info HttpServer: HTTP Response 200 to 192.168.1.107. Time: 385ms. http://192.168.1.100:8096/emby/Sessions?ActiveWithinSeconds=960 2018-07-25 22:06:54.013 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/Packages/Updates?PackageType=UserInstalled. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/67.0.3396.99 Safari/537.36 2018-07-25 22:06:54.144 Info HttpServer: HTTP Response 200 to 192.168.1.107. Time: 132ms. http://192.168.1.100:8096/emby/Packages/Updates?PackageType=UserInstalled 2018-07-25 22:06:59.036 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/System/Endpoint. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/67.0.3396.99 Safari/537.36 2018-07-25 22:06:59.046 Info HttpServer: HTTP Response 200 to 192.168.1.107. Time: 10ms. http://192.168.1.100:8096/emby/System/Endpoint 2018-07-25 22:08:26.275 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/system/info/public?format=json. UserAgent: Roku/DVP-8.10 (558.10E04137A) 2018-07-25 22:08:26.280 Info HttpServer: HTTP Response 200 to 192.168.1.158. Time: 5ms. http://192.168.1.100:8096/emby/system/info/public?format=json 2018-07-25 22:08:26.388 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/system/info?format=json. UserAgent: Roku/DVP-8.10 (558.10E04137A) 2018-07-25 22:08:26.672 Info App: App Activity: app: Roku SG, version: 3.0.91, deviceId: 2cba4f73-07d8-51cf-a314-7631b9a10e11, deviceName: Roku Front Room 2018-07-25 22:08:26.778 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/System/ActivityLog/Entries?startIndex=0&limit=7&minDate=2018-07-25T05%3A08%3A26.023Z&hasUserId=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/67.0.3396.99 Safari/537.36 2018-07-25 22:08:26.784 Info HttpServer: HTTP Response 200 to 192.168.1.107. Time: 5ms. http://192.168.1.100:8096/emby/System/ActivityLog/Entries?startIndex=0&limit=7&minDate=2018-07-25T05%3A08%3A26.023Z&hasUserId=true 2018-07-25 22:08:26.790 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/System/ActivityLog/Entries?startIndex=0&limit=4&minDate=2018-07-19T05%3A08%3A26.024Z&hasUserId=false. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/67.0.3396.99 Safari/537.36 2018-07-25 22:08:26.792 Info HttpServer: HTTP Response 200 to 192.168.1.107. Time: 3ms. http://192.168.1.100:8096/emby/System/ActivityLog/Entries?startIndex=0&limit=4&minDate=2018-07-19T05%3A08%3A26.024Z&hasUserId=false 2018-07-25 22:08:26.792 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/System/ActivityLog/Entries?startIndex=0&limit=4&minDate=2018-07-19T05%3A08%3A26.025Z&hasUserId=false. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/67.0.3396.99 Safari/537.36 2018-07-25 22:08:26.793 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/System/ActivityLog/Entries?startIndex=0&limit=7&minDate=2018-07-25T05%3A08%3A26.025Z&hasUserId=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/67.0.3396.99 Safari/537.36 2018-07-25 22:08:26.795 Info HttpServer: HTTP Response 200 to 192.168.1.107. Time: 3ms. http://192.168.1.100:8096/emby/System/ActivityLog/Entries?startIndex=0&limit=4&minDate=2018-07-19T05%3A08%3A26.025Z&hasUserId=false 2018-07-25 22:08:26.798 Info HttpServer: HTTP Response 200 to 192.168.1.107. Time: 5ms. http://192.168.1.100:8096/emby/System/ActivityLog/Entries?startIndex=0&limit=7&minDate=2018-07-25T05%3A08%3A26.025Z&hasUserId=true 2018-07-25 22:08:26.848 Info HttpServer: HTTP Response 200 to 192.168.1.158. Time: 459ms. http://192.168.1.100:8096/emby/system/info?format=json 2018-07-25 22:08:26.890 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/Users/403cd3692c6f472da5a47805c635494d. UserAgent: Roku/DVP-8.10 (558.10E04137A) 2018-07-25 22:08:26.892 Info HttpServer: HTTP Response 200 to 192.168.1.158. Time: 2ms. http://192.168.1.100:8096/emby/Users/403cd3692c6f472da5a47805c635494d 2018-07-25 22:08:26.992 Info HttpServer: HTTP POST http://192.168.1.100:8096/emby/Sessions/Capabilities/Full. UserAgent: Roku/DVP-8.10 (558.10E04137A) 2018-07-25 22:08:27.002 Info HttpServer: HTTP Response 204 to 192.168.1.158. Time: 11ms. http://192.168.1.100:8096/emby/Sessions/Capabilities/Full 2018-07-25 22:08:27.609 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/DisplayPreferences/usersettings?client=emby&userid=403cd3692c6f472da5a47805c635494d. UserAgent: Roku/DVP-8.10 (558.10E04137A) 2018-07-25 22:08:27.612 Info HttpServer: HTTP Response 200 to 192.168.1.158. Time: 2ms. http://192.168.1.100:8096/emby/DisplayPreferences/usersettings?client=emby&userid=403cd3692c6f472da5a47805c635494d 2018-07-25 22:08:28.761 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/Users/403cd3692c6f472da5a47805c635494d/Views?sortby=sortname&EnableImageTypes=Primary,Thumb&fields=PrimaryImageAspectRatio. UserAgent: Roku/DVP-8.10 (558.10E04137A) 2018-07-25 22:08:29.051 Info HttpServer: HTTP Response 200 to 192.168.1.158. Time: 291ms. http://192.168.1.100:8096/emby/Users/403cd3692c6f472da5a47805c635494d/Views?sortby=sortname&EnableImageTypes=Primary,Thumb&fields=PrimaryImageAspectRatio 2018-07-25 22:08:31.391 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/Users/403cd3692c6f472da5a47805c635494d/Items?IncludeMediaTypes=Video&EnableImageTypes=Primary,Thumb&sortby=DatePlayed&filters=IsResumable&sortorder=Descending&recursive=true&fields=PrimaryImageAspectRatio&imagetypelimit=1&limit=30&excludelocationtypes=Virtual. UserAgent: Roku/DVP-8.10 (558.10E04137A) 2018-07-25 22:08:35.769 Debug SqliteItemRepository: GetItems query time (slow): 4337ms. Query: select count (distinct PresentationUniqueKey),UserDatas.UserId,UserDatas.lastPlayedDate,UserDatas.playbackPositionTicks,UserDatas.playcount,UserDatas.isFavorite,UserDatas.played,UserDatas.rating from TypedBaseItems A left join UserDatas on UserDataKey=UserDatas.Key And (UserId=@UserId) where playbackPositionTicks > 0 AND IsVirtualItem=@IsVirtualItem AND (TopParentId in ('5d5fe45867d6efc04c6d2e699eda5a3b','523aae8b8c4fa7294af489d4b2bc5219','2b2bca16aacc8a14d53a11bb829eafa5')) 2018-07-25 22:08:35.770 Info HttpServer: HTTP Response 200 to 192.168.1.158. Time: 4379ms (slow). http://192.168.1.100:8096/emby/Users/403cd3692c6f472da5a47805c635494d/Items?IncludeMediaTypes=Video&EnableImageTypes=Primary,Thumb&sortby=DatePlayed&filters=IsResumable&sortorder=Descending&recursive=true&fields=PrimaryImageAspectRatio&imagetypelimit=1&limit=30&excludelocationtypes=Virtual 2018-07-25 22:08:38.654 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/Users/403cd3692c6f472da5a47805c635494d/Items?IncludeMediaTypes=Video&EnableImageTypes=Primary,Thumb&sortby=DatePlayed&filters=IsResumable&sortorder=Descending&recursive=true&Fields=Overview,OfficialRating&imagetypelimit=1&limit=30&ParentId=767bffe4f11c93ef34b805451a696a4e&excludelocationtypes=Virtual. UserAgent: Roku/DVP-8.10 (558.10E04137A) 2018-07-25 22:08:38.662 Info HttpServer: HTTP Response 200 to 192.168.1.158. Time: 8ms. http://192.168.1.100:8096/emby/Users/403cd3692c6f472da5a47805c635494d/Items?IncludeMediaTypes=Video&EnableImageTypes=Primary,Thumb&sortby=DatePlayed&filters=IsResumable&sortorder=Descending&recursive=true&Fields=Overview,OfficialRating&imagetypelimit=1&limit=30&ParentId=767bffe4f11c93ef34b805451a696a4e&excludelocationtypes=Virtual 2018-07-25 22:08:38.668 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/Shows/NextUp?userId=403cd3692c6f472da5a47805c635494d&EnableImageTypes=Primary,Thumb&Fields=Overview&imagetypelimit=1&limit=30&ParentId=767bffe4f11c93ef34b805451a696a4e. UserAgent: Roku/DVP-8.10 (558.10E04137A) 2018-07-25 22:08:38.708 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/Users/403cd3692c6f472da5a47805c635494d/Items/Latest?IncludeItemTypes=Episode&recursive=true&EnableImageTypes=Primary,Thumb&Fields=Overview,OfficialRating,PrimaryImageAspectRatio&imagetypelimit=1&limit=20&groupitems=true&ParentId=767bffe4f11c93ef34b805451a696a4e&excludelocationtypes=Virtual. UserAgent: Roku/DVP-8.10 (558.10E04137A) 2018-07-25 22:08:38.996 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/Users/403cd3692c6f472da5a47805c635494d/Items?includeitemtypes=Series,Episode&EnableImageTypes=Primary,Thumb&sortby=DateLastContentAdded&filters=IsFavorite&sortorder=Descending&recursive=true&Fields=Overview,OfficialRating,PrimaryImageAspectRatio&imagetypelimit=1&limit=30&ParentId=767bffe4f11c93ef34b805451a696a4e. UserAgent: Roku/DVP-8.10 (558.10E04137A) 2018-07-25 22:08:39.488 Info HttpServer: HTTP Response 200 to 192.168.1.158. Time: 492ms. http://192.168.1.100:8096/emby/Users/403cd3692c6f472da5a47805c635494d/Items?includeitemtypes=Series,Episode&EnableImageTypes=Primary,Thumb&sortby=DateLastContentAdded&filters=IsFavorite&sortorder=Descending&recursive=true&Fields=Overview,OfficialRating,PrimaryImageAspectRatio&imagetypelimit=1&limit=30&ParentId=767bffe4f11c93ef34b805451a696a4e 2018-07-25 22:08:39.816 Info HttpServer: HTTP Response 200 to 192.168.1.158. Time: 1148ms (slow). http://192.168.1.100:8096/emby/Shows/NextUp?userId=403cd3692c6f472da5a47805c635494d&EnableImageTypes=Primary,Thumb&Fields=Overview&imagetypelimit=1&limit=30&ParentId=767bffe4f11c93ef34b805451a696a4e 2018-07-25 22:08:39.938 Info HttpServer: HTTP Response 200 to 192.168.1.158. Time: 1229ms (slow). http://192.168.1.100:8096/emby/Users/403cd3692c6f472da5a47805c635494d/Items/Latest?IncludeItemTypes=Episode&recursive=true&EnableImageTypes=Primary,Thumb&Fields=Overview,OfficialRating,PrimaryImageAspectRatio&imagetypelimit=1&limit=20&groupitems=true&ParentId=767bffe4f11c93ef34b805451a696a4e&excludelocationtypes=Virtual 2018-07-25 22:08:42.765 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/DisplayPreferences/tvshows?client=rokusg&userid=403cd3692c6f472da5a47805c635494d. UserAgent: Roku/DVP-8.10 (558.10E04137A) 2018-07-25 22:08:42.768 Info HttpServer: HTTP Response 200 to 192.168.1.158. Time: 3ms. http://192.168.1.100:8096/emby/DisplayPreferences/tvshows?client=rokusg&userid=403cd3692c6f472da5a47805c635494d 2018-07-25 22:08:42.989 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/System/Endpoint. UserAgent: Roku/DVP-8.10 (558.10E04137A) 2018-07-25 22:08:42.991 Info HttpServer: HTTP Response 200 to 192.168.1.158. Time: 3ms. http://192.168.1.100:8096/emby/System/Endpoint 2018-07-25 22:08:44.058 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/Users/403cd3692c6f472da5a47805c635494d/Items?IncludeItemTypes=Series&EnableImageTypes=Primary,Thumb&SortBy=SortName&SortOrder=Ascending&recursive=true&fields=PrimaryImageAspectRatio&imagetypelimit=1&limit=150&EnableTotalRecordCount=true&ParentId=767bffe4f11c93ef34b805451a696a4e. UserAgent: Roku/DVP-8.10 (558.10E04137A) 2018-07-25 22:08:44.156 Info HttpServer: HTTP Response 200 to 192.168.1.158. Time: 98ms. http://192.168.1.100:8096/emby/Users/403cd3692c6f472da5a47805c635494d/Items?IncludeItemTypes=Series&EnableImageTypes=Primary,Thumb&SortBy=SortName&SortOrder=Ascending&recursive=true&fields=PrimaryImageAspectRatio&imagetypelimit=1&limit=150&EnableTotalRecordCount=true&ParentId=767bffe4f11c93ef34b805451a696a4e 2018-07-25 22:08:49.409 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/Users/403cd3692c6f472da5a47805c635494d/Items/3f597dd55077027a896bfc767c0d5400?fields=Overview. UserAgent: Roku/DVP-8.10 (558.10E04137A) 2018-07-25 22:08:49.668 Info HttpServer: HTTP Response 200 to 192.168.1.158. Time: 259ms. http://192.168.1.100:8096/emby/Users/403cd3692c6f472da5a47805c635494d/Items/3f597dd55077027a896bfc767c0d5400?fields=Overview 2018-07-25 22:08:49.855 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/Items/3f597dd55077027a896bfc767c0d5400/Images/Logo?maxWidth=400&tag=84e6bad8876029746ac515e3695b5717. UserAgent: Roku/DVP-8.10 (558.10E04137A) 2018-07-25 22:08:49.858 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/Items/3f597dd55077027a896bfc767c0d5400/Images/Backdrop/0?EnableImageEnhancers=false&tag=f8dc322ba6fd8056e6be4c63c7e1f4f2&maxheight=504&quality=80. UserAgent: Roku/DVP-8.10 (558.10E04137A) 2018-07-25 22:08:49.963 Debug App: ConvertImageToLocal item 3f597dd5-5077-027a-896b-fc767c0d5400 - image url: https://assets.fanart.tv/fanart/tv/80379/hdtvlogo/the-big-bang-theory-50477a642f672.png 2018-07-25 22:08:49.972 Info HttpClient: HttpClientManager GET: https://assets.fanart.tv/fanart/tv/80379/hdtvlogo/the-big-bang-theory-50477a642f672.png 2018-07-25 22:08:50.004 Debug HttpResultFactory: Transmit file /var/packages/EmbyServer/target/var/cache/images/resized-images/d/d70be035-8fd8-cadb-5c7f-3db2fed5f247.jpg 2018-07-25 22:08:50.109 Info HttpServer: HTTP Response 200 to 192.168.1.158. Time: 251ms. http://192.168.1.100:8096/emby/Items/3f597dd55077027a896bfc767c0d5400/Images/Backdrop/0?EnableImageEnhancers=false&tag=f8dc322ba6fd8056e6be4c63c7e1f4f2&maxheight=504&quality=80 2018-07-25 22:08:50.373 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/Items/4cd4320d0a2e0da84a58f7825e5c7453/Images/Primary/0?EnableImageEnhancers=false&tag=249d0058c870bf2cfb013632a25e8a56&maxheight=200&quality=80. UserAgent: Roku/DVP-8.10 (558.10E04137A) 2018-07-25 22:08:50.374 Debug App: ConvertImageToLocal item 4cd4320d-0a2e-0da8-4a58-f7825e5c7453 - image url: https://www.thetvdb.com/banners/actors/325467.jpg 2018-07-25 22:08:50.375 Info HttpClient: HttpClientManager GET: https://www.thetvdb.com/banners/actors/325467.jpg 2018-07-25 22:08:50.398 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/Items/6bc198330c1b2f03fac281728d320074/Images/Primary/0?EnableImageEnhancers=false&tag=5ba4a29e456114705d7e0fffcef5914a&maxheight=200&quality=80. UserAgent: Roku/DVP-8.10 (558.10E04137A) 2018-07-25 22:08:50.399 Debug App: ConvertImageToLocal item 6bc19833-0c1b-2f03-fac2-81728d320074 - image url: https://www.thetvdb.com/banners/actors/325466.jpg 2018-07-25 22:08:50.399 Info HttpClient: HttpClientManager GET: https://www.thetvdb.com/banners/actors/325466.jpg 2018-07-25 22:08:50.664 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/Items/0fc081fbce07db05e0a37eea308c7125/Images/Primary/0?EnableImageEnhancers=false&tag=5396bd9fafccc0909dbb3b53b29156a3&maxheight=200&quality=80. UserAgent: Roku/DVP-8.10 (558.10E04137A) 2018-07-25 22:08:50.665 Debug App: ConvertImageToLocal item 0fc081fb-ce07-db05-e0a3-7eea308c7125 - image url: https://www.thetvdb.com/banners/actors/325465.jpg 2018-07-25 22:08:50.665 Info HttpClient: HttpClientManager GET: https://www.thetvdb.com/banners/actors/325465.jpg 2018-07-25 22:08:53.830 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/Items/3f597dd55077027a896bfc767c0d5400/Similar?userId=403cd3692c6f472da5a47805c635494d&EnableImageTypes=Primary,Thumb&fields=PrimaryImageAspectRatio&imagetypelimit=1&limit=10&excludelocationtypes=Virtual. UserAgent: Roku/DVP-8.10 (558.10E04137A) 2018-07-25 22:08:53.831 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/Shows/NextUp?userId=403cd3692c6f472da5a47805c635494d&EnableImageTypes=Primary,Thumb&fields=PrimaryImageAspectRatio&imagetypelimit=1&limit=260&seriesid=3f597dd55077027a896bfc767c0d5400. UserAgent: Roku/DVP-8.10 (558.10E04137A) 2018-07-25 22:08:53.837 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/Shows/3f597dd55077027a896bfc767c0d5400/Seasons?userId=403cd3692c6f472da5a47805c635494d&limit=60&EnableImageTypes=Primary,Thumb&fields=PrimaryImageAspectRatio&imagetypelimit=1. UserAgent: Roku/DVP-8.10 (558.10E04137A) 2018-07-25 22:08:54.179 Info HttpServer: HTTP Response 200 to 192.168.1.158. Time: 349ms. http://192.168.1.100:8096/emby/Shows/NextUp?userId=403cd3692c6f472da5a47805c635494d&EnableImageTypes=Primary,Thumb&fields=PrimaryImageAspectRatio&imagetypelimit=1&limit=260&seriesid=3f597dd55077027a896bfc767c0d5400 2018-07-25 22:08:54.254 Info HttpServer: HTTP Response 200 to 192.168.1.158. Time: 425ms. http://192.168.1.100:8096/emby/Items/3f597dd55077027a896bfc767c0d5400/Similar?userId=403cd3692c6f472da5a47805c635494d&EnableImageTypes=Primary,Thumb&fields=PrimaryImageAspectRatio&imagetypelimit=1&limit=10&excludelocationtypes=Virtual 2018-07-25 22:08:54.282 Debug ProviderManager: Saving image to /var/packages/EmbyServer/target/var/metadata/library/3f/3f597dd55077027a896bfc767c0d5400/logo.png 2018-07-25 22:08:54.281 Debug ProviderManager: Saving image to /var/packages/EmbyServer/target/var/metadata/People/J/Jim Parsons/poster.jpg 2018-07-25 22:08:54.330 Debug XmlSerializer: Deserializing file /var/packages/EmbyServer/target/var/config/xbmcmetadata.xml 2018-07-25 22:08:54.350 Debug ProviderManager: Saving image to /var/packages/EmbyServer/target/var/metadata/People/K/Kaley Cuoco/poster.jpg 2018-07-25 22:08:54.384 Debug ProviderManager: Saving image to /var/packages/EmbyServer/target/var/metadata/People/J/Johnny Galecki/poster.jpg 2018-07-25 22:08:55.073 Debug HttpResultFactory: Transmit file /var/packages/EmbyServer/target/var/cache/images/resized-images/1/19b4ac31-a989-e809-ac06-b3284c0172db.jpg 2018-07-25 22:08:55.074 Info HttpServer: HTTP Response 200 to 192.168.1.158. Time: 4410ms (slow). http://192.168.1.100:8096/emby/Items/0fc081fbce07db05e0a37eea308c7125/Images/Primary/0?EnableImageEnhancers=false&tag=5396bd9fafccc0909dbb3b53b29156a3&maxheight=200&quality=80 2018-07-25 22:08:55.090 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/Items/406ecb05f2f1b0385fbfb561c7e76240/Images/Primary/0?EnableImageEnhancers=false&tag=2161042511f5c6b59e093d1ab8d2a526&maxheight=200&quality=80. UserAgent: Roku/DVP-8.10 (558.10E04137A) 2018-07-25 22:08:55.309 Debug HttpResultFactory: Transmit file /var/packages/EmbyServer/target/var/cache/images/resized-images/d/d7c09e2e-949e-6ac7-fc65-c93dc80a38d4.jpg 2018-07-25 22:08:55.310 Info HttpServer: HTTP Response 200 to 192.168.1.158. Time: 4937ms (slow). http://192.168.1.100:8096/emby/Items/4cd4320d0a2e0da84a58f7825e5c7453/Images/Primary/0?EnableImageEnhancers=false&tag=249d0058c870bf2cfb013632a25e8a56&maxheight=200&quality=80 2018-07-25 22:08:55.324 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/Items/1131c8f94e5e3c26b5a24dc9a1d25294/Images/Primary/0?EnableImageEnhancers=false&tag=526e52902849c576d27d1ab287edbd6b&maxheight=200&quality=80. UserAgent: Roku/DVP-8.10 (558.10E04137A) 2018-07-25 22:08:56.108 Debug HttpResultFactory: Transmit file /var/packages/EmbyServer/target/var/cache/images/resized-images/6/6a20df81-a1ad-9997-1e0a-34d859a5c1f1.png 2018-07-25 22:08:56.110 Info HttpServer: HTTP Response 200 to 192.168.1.158. Time: 6254ms (slow). http://192.168.1.100:8096/emby/Items/3f597dd55077027a896bfc767c0d5400/Images/Logo?maxWidth=400&tag=84e6bad8876029746ac515e3695b5717 2018-07-25 22:08:56.128 Debug App: ConvertImageToLocal item 406ecb05-f2f1-b038-5fbf-b561c7e76240 - image url: https://www.thetvdb.com/banners/actors/325464.jpg 2018-07-25 22:08:56.128 Info HttpClient: HttpClientManager GET: https://www.thetvdb.com/banners/actors/325464.jpg 2018-07-25 22:08:56.129 Debug App: ConvertImageToLocal item 1131c8f9-4e5e-3c26-b5a2-4dc9a1d25294 - image url: https://www.thetvdb.com/banners/actors/325463.jpg 2018-07-25 22:08:56.129 Info HttpClient: HttpClientManager GET: https://www.thetvdb.com/banners/actors/325463.jpg 2018-07-25 22:08:56.133 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/Items/7f2e5422cd6d52b214acaf20640e4332/Images/Primary/0?EnableImageEnhancers=false&tag=e36cfa2272875a4dd0bf330dbaa14e05&maxheight=200&quality=80. UserAgent: Roku/DVP-8.10 (558.10E04137A) 2018-07-25 22:08:56.298 Debug HttpResultFactory: Transmit file /var/packages/EmbyServer/target/var/cache/images/resized-images/c/c6e47375-e563-a42c-ecb1-ab70fa7d443c.jpg 2018-07-25 22:08:56.300 Info HttpServer: HTTP Response 200 to 192.168.1.158. Time: 5902ms (slow). http://192.168.1.100:8096/emby/Items/6bc198330c1b2f03fac281728d320074/Images/Primary/0?EnableImageEnhancers=false&tag=5ba4a29e456114705d7e0fffcef5914a&maxheight=200&quality=80 2018-07-25 22:08:56.307 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/Items/c05f84ed3e2d2a7025953c66597adc6b/Images/Primary/0?EnableImageEnhancers=false&tag=2c5f94a75be14b2ab756415968d4dd28&maxheight=200&quality=80. UserAgent: Roku/DVP-8.10 (558.10E04137A) 2018-07-25 22:08:56.321 Debug ProviderManager: Saving image to /var/packages/EmbyServer/target/var/metadata/People/K/Kunal Nayyar/poster.jpg 2018-07-25 22:08:56.322 Debug ProviderManager: Saving image to /var/packages/EmbyServer/target/var/metadata/People/S/Simon Helberg/poster.jpg 2018-07-25 22:08:56.347 Debug App: ConvertImageToLocal item 7f2e5422-cd6d-52b2-14ac-af20640e4332 - image url: https://www.thetvdb.com/banners/actors/325462.jpg 2018-07-25 22:08:56.348 Info HttpClient: HttpClientManager GET: https://www.thetvdb.com/banners/actors/325462.jpg 2018-07-25 22:08:56.348 Debug App: ConvertImageToLocal item c05f84ed-3e2d-2a70-2595-3c66597adc6b - image url: https://www.thetvdb.com/banners/actors/325461.jpg 2018-07-25 22:08:56.348 Info HttpClient: HttpClientManager GET: https://www.thetvdb.com/banners/actors/325461.jpg 2018-07-25 22:08:56.397 Debug ProviderManager: Saving image to /var/packages/EmbyServer/target/var/metadata/People/M/Mayim Bialik/poster.jpg 2018-07-25 22:08:56.402 Debug ProviderManager: Saving image to /var/packages/EmbyServer/target/var/metadata/People/M/Melissa Rauch/poster.jpg 2018-07-25 22:08:56.746 Debug HttpResultFactory: Transmit file /var/packages/EmbyServer/target/var/cache/images/resized-images/2/2ea953f5-3551-0737-7f40-1ae76569eafb.jpg 2018-07-25 22:08:56.747 Info HttpServer: HTTP Response 200 to 192.168.1.158. Time: 1423ms (slow). http://192.168.1.100:8096/emby/Items/1131c8f94e5e3c26b5a24dc9a1d25294/Images/Primary/0?EnableImageEnhancers=false&tag=526e52902849c576d27d1ab287edbd6b&maxheight=200&quality=80 2018-07-25 22:08:56.771 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/Items/edb4a496f448a0c73eaa567744e0c18d/Images/Primary/0?EnableImageEnhancers=false&tag=660791ce88aacf7985ee65769ffbe250&maxheight=200&quality=80. UserAgent: Roku/DVP-8.10 (558.10E04137A) 2018-07-25 22:08:56.860 Debug HttpResultFactory: Transmit file /var/packages/EmbyServer/target/var/cache/images/resized-images/8/8dae316f-635c-f64e-0650-5fb5f8620d86.jpg 2018-07-25 22:08:56.861 Info HttpServer: HTTP Response 200 to 192.168.1.158. Time: 728ms. http://192.168.1.100:8096/emby/Items/7f2e5422cd6d52b214acaf20640e4332/Images/Primary/0?EnableImageEnhancers=false&tag=e36cfa2272875a4dd0bf330dbaa14e05&maxheight=200&quality=80 2018-07-25 22:08:57.039 Debug HttpResultFactory: Transmit file /var/packages/EmbyServer/target/var/cache/images/resized-images/7/7704db45-ee28-122c-250a-ba4fb4ae78ab.jpg 2018-07-25 22:08:57.040 Info HttpServer: HTTP Response 200 to 192.168.1.158. Time: 733ms. http://192.168.1.100:8096/emby/Items/c05f84ed3e2d2a7025953c66597adc6b/Images/Primary/0?EnableImageEnhancers=false&tag=2c5f94a75be14b2ab756415968d4dd28&maxheight=200&quality=80 2018-07-25 22:08:57.094 Debug HttpResultFactory: Transmit file /var/packages/EmbyServer/target/var/cache/images/resized-images/9/9bd485df-6b6b-7c2f-c671-370a88c91c95.jpg 2018-07-25 22:08:57.096 Info HttpServer: HTTP Response 200 to 192.168.1.158. Time: 2006ms (slow). http://192.168.1.100:8096/emby/Items/406ecb05f2f1b0385fbfb561c7e76240/Images/Primary/0?EnableImageEnhancers=false&tag=2161042511f5c6b59e093d1ab8d2a526&maxheight=200&quality=80 2018-07-25 22:08:57.189 Debug App: ConvertImageToLocal item edb4a496-f448-a0c7-3eaa-567744e0c18d - image url: https://www.thetvdb.com/banners/actors/403186.jpg 2018-07-25 22:08:57.189 Info HttpClient: HttpClientManager GET: https://www.thetvdb.com/banners/actors/403186.jpg 2018-07-25 22:08:57.228 Debug ProviderManager: Saving image to /var/packages/EmbyServer/target/var/metadata/People/C/Carol Ann Susi/poster.jpg 2018-07-25 22:08:57.586 Debug HttpResultFactory: Transmit file /var/packages/EmbyServer/target/var/cache/images/resized-images/6/6569e0d8-f172-ea16-bd1c-d6dd3bb992d6.jpg 2018-07-25 22:08:57.589 Info HttpServer: HTTP Response 200 to 192.168.1.158. Time: 818ms. http://192.168.1.100:8096/emby/Items/edb4a496f448a0c73eaa567744e0c18d/Images/Primary/0?EnableImageEnhancers=false&tag=660791ce88aacf7985ee65769ffbe250&maxheight=200&quality=80 2018-07-25 22:08:57.679 Info HttpServer: HTTP Response 200 to 192.168.1.158. Time: 3842ms (slow). http://192.168.1.100:8096/emby/Shows/3f597dd55077027a896bfc767c0d5400/Seasons?userId=403cd3692c6f472da5a47805c635494d&limit=60&EnableImageTypes=Primary,Thumb&fields=PrimaryImageAspectRatio&imagetypelimit=1 2018-07-25 22:08:58.201 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/Items/20540e0f455eca91c3a5ec2d3521197d/Images/Primary/0?EnableImageEnhancers=false&tag=3e7994661cecb5a228b15820ec706f71&maxheight=200&quality=80. UserAgent: Roku/DVP-8.10 (558.10E04137A) 2018-07-25 22:08:58.201 Debug App: ConvertImageToLocal item 20540e0f-455e-ca91-c3a5-ec2d3521197d - image url: https://www.thetvdb.com/banners/seasons/80379-1-16.jpg 2018-07-25 22:08:58.201 Info HttpClient: HttpClientManager GET: https://www.thetvdb.com/banners/seasons/80379-1-16.jpg 2018-07-25 22:08:58.230 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/Items/e28125be722d0d5e64abbad4eeb47ed6/Images/Primary/0?EnableImageEnhancers=false&tag=5a937155514ca2618184d4b79ed371c6&maxheight=200&quality=80. UserAgent: Roku/DVP-8.10 (558.10E04137A) 2018-07-25 22:08:58.231 Debug App: ConvertImageToLocal item e28125be-722d-0d5e-64ab-bad4eeb47ed6 - image url: https://www.thetvdb.com/banners/seasons/80379-2-9.jpg 2018-07-25 22:08:58.231 Info HttpClient: HttpClientManager GET: https://www.thetvdb.com/banners/seasons/80379-2-9.jpg 2018-07-25 22:08:58.243 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/Items/2c4577effc74d10d4febaa24e82f72fe/Images/Primary/0?EnableImageEnhancers=false&tag=dba09abc81612faf92eb97b3ee928b0d&maxheight=200&quality=80. UserAgent: Roku/DVP-8.10 (558.10E04137A) 2018-07-25 22:08:58.244 Debug App: ConvertImageToLocal item 2c4577ef-fc74-d10d-4feb-aa24e82f72fe - image url: https://www.thetvdb.com/banners/seasons/80379-3-12.jpg 2018-07-25 22:08:58.244 Info HttpClient: HttpClientManager GET: https://www.thetvdb.com/banners/seasons/80379-3-12.jpg 2018-07-25 22:08:58.255 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/Items/4c43bf7b85c2d5c21ff9e039eb107a6d/Images/Primary/0?EnableImageEnhancers=false&tag=da3e32cbb0ff9e22d3617d196cbecee4&maxheight=200&quality=80. UserAgent: Roku/DVP-8.10 (558.10E04137A) 2018-07-25 22:08:58.256 Debug App: ConvertImageToLocal item 4c43bf7b-85c2-d5c2-1ff9-e039eb107a6d - image url: https://www.thetvdb.com/banners/seasons/80379-4-11.jpg 2018-07-25 22:08:58.256 Info HttpClient: HttpClientManager GET: https://www.thetvdb.com/banners/seasons/80379-4-11.jpg 2018-07-25 22:08:58.273 Debug ProviderManager: Saving image to /var/packages/EmbyServer/target/var/metadata/library/20/20540e0f455eca91c3a5ec2d3521197d/poster.jpg 2018-07-25 22:08:58.349 Debug ProviderManager: Saving image to /var/packages/EmbyServer/target/var/metadata/library/e2/e28125be722d0d5e64abbad4eeb47ed6/poster.jpg 2018-07-25 22:08:58.366 Debug ProviderManager: Saving image to /var/packages/EmbyServer/target/var/metadata/library/2c/2c4577effc74d10d4febaa24e82f72fe/poster.jpg 2018-07-25 22:08:58.458 Debug ProviderManager: Saving image to /var/packages/EmbyServer/target/var/metadata/library/4c/4c43bf7b85c2d5c21ff9e039eb107a6d/poster.jpg 2018-07-25 22:08:58.867 Debug HttpResultFactory: Transmit file /var/packages/EmbyServer/target/var/cache/images/resized-images/9/95a7f634-b279-3254-f817-3129749e9662.jpg 2018-07-25 22:08:58.868 Info HttpServer: HTTP Response 200 to 192.168.1.158. Time: 668ms. http://192.168.1.100:8096/emby/Items/20540e0f455eca91c3a5ec2d3521197d/Images/Primary/0?EnableImageEnhancers=false&tag=3e7994661cecb5a228b15820ec706f71&maxheight=200&quality=80 2018-07-25 22:08:58.876 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/Items/641a5d27b28cbd7d56c0fa3479a48def/Images/Primary/0?EnableImageEnhancers=false&tag=fce0af2b369be04569f6982d5fa2c151&maxheight=200&quality=80. UserAgent: Roku/DVP-8.10 (558.10E04137A) 2018-07-25 22:08:58.877 Debug App: ConvertImageToLocal item 641a5d27-b28c-bd7d-56c0-fa3479a48def - image url: https://www.thetvdb.com/banners/seasons/80379-5-12.jpg 2018-07-25 22:08:58.877 Info HttpClient: HttpClientManager GET: https://www.thetvdb.com/banners/seasons/80379-5-12.jpg 2018-07-25 22:08:58.937 Debug ProviderManager: Saving image to /var/packages/EmbyServer/target/var/metadata/library/64/641a5d27b28cbd7d56c0fa3479a48def/poster.jpg 2018-07-25 22:08:59.295 Debug HttpResultFactory: Transmit file /var/packages/EmbyServer/target/var/cache/images/resized-images/4/4c900fcc-7ee1-d190-ba32-b49c4f320c49.jpg 2018-07-25 22:08:59.298 Info HttpServer: HTTP Response 200 to 192.168.1.158. Time: 1055ms (slow). http://192.168.1.100:8096/emby/Items/2c4577effc74d10d4febaa24e82f72fe/Images/Primary/0?EnableImageEnhancers=false&tag=dba09abc81612faf92eb97b3ee928b0d&maxheight=200&quality=80 2018-07-25 22:09:04.524 Debug HttpResultFactory: Transmit file /var/packages/EmbyServer/target/var/cache/images/resized-images/f/f1f877a3-44de-4ee0-f251-34f4a5b19e0f.jpg 2018-07-25 22:09:04.525 Info HttpServer: HTTP Response 200 to 192.168.1.158. Time: 6295ms (slow). http://192.168.1.100:8096/emby/Items/e28125be722d0d5e64abbad4eeb47ed6/Images/Primary/0?EnableImageEnhancers=false&tag=5a937155514ca2618184d4b79ed371c6&maxheight=200&quality=80 2018-07-25 22:09:04.535 Debug HttpResultFactory: Transmit file /var/packages/EmbyServer/target/var/cache/images/resized-images/f/f9a74c49-74f5-efec-93ce-ba26b49f969d.jpg 2018-07-25 22:09:04.536 Info HttpServer: HTTP Response 200 to 192.168.1.158. Time: 6281ms (slow). http://192.168.1.100:8096/emby/Items/4c43bf7b85c2d5c21ff9e039eb107a6d/Images/Primary/0?EnableImageEnhancers=false&tag=da3e32cbb0ff9e22d3617d196cbecee4&maxheight=200&quality=80 2018-07-25 22:09:04.556 Debug HttpResultFactory: Transmit file /var/packages/EmbyServer/target/var/cache/images/resized-images/9/944c2485-cc76-8bdd-8d89-71e14e8d6a63.jpg 2018-07-25 22:09:04.557 Info HttpServer: HTTP Response 200 to 192.168.1.158. Time: 5681ms (slow). http://192.168.1.100:8096/emby/Items/641a5d27b28cbd7d56c0fa3479a48def/Images/Primary/0?EnableImageEnhancers=false&tag=fce0af2b369be04569f6982d5fa2c151&maxheight=200&quality=80 2018-07-25 22:09:23.415 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/Users/403cd3692c6f472da5a47805c635494d. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/67.0.3396.99 Safari/537.36 2018-07-25 22:09:23.419 Info HttpServer: HTTP Response 200 to 192.168.1.107. Time: 3ms. http://192.168.1.100:8096/emby/Users/403cd3692c6f472da5a47805c635494d 2018-07-25 22:09:23.644 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/System/Logs. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/67.0.3396.99 Safari/537.36 2018-07-25 22:09:23.651 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/System/Configuration. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/67.0.3396.99 Safari/537.36 2018-07-25 22:09:23.866 Debug App: SessionInfoWebSocketListener stop transmitting over websocket to [::ffff:192.168.1.107]:55972 2018-07-25 22:09:23.867 Debug App: ScheduledTasksWebSocketListener stop transmitting over websocket to [::ffff:192.168.1.107]:55972 2018-07-25 22:09:23.908 Info HttpServer: HTTP Response 200 to 192.168.1.107. Time: 257ms. http://192.168.1.100:8096/emby/System/Configuration 2018-07-25 22:09:24.067 Info HttpServer: HTTP Response 200 to 192.168.1.107. Time: 423ms. http://192.168.1.100:8096/emby/System/Logs 2018-07-25 22:09:28.473 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/System/Logs/Log?name=server.txt. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/67.0.3396.99 Safari/537.36 2018-07-25 22:09:28.479 Debug HttpResultFactory: Transmit file /var/packages/EmbyServer/target/var/logs/server.txt 2018-07-25 22:09:28.480 Info HttpServer: HTTP Response 200 to 192.168.1.107. Time: 8ms. http://192.168.1.100:8096/emby/System/Logs/Log?name=server.txt Edited July 26, 2018 by Kevin M.
Luke 42243 Posted July 26, 2018 Posted July 26, 2018 Can you zip up this file and attach it here? /var/packages/EmbyServer/target/var/cache/images/resized-images/9/9bd485df-6b6b-7c2f-c671-370a88c91c95.jpg Thanks.
Kevin M. 1 Posted July 26, 2018 Posted July 26, 2018 (edited) Here you go! I see 3.5.1.0 just came out. I'd install that, but it hasn't shown up on my Package Center yet. Edited July 26, 2018 by Kevin M.
Luke 42243 Posted July 26, 2018 Posted July 26, 2018 Actually can you zip that up, because the forum software is going to alter it otherwise. thanks !
Kevin M. 1 Posted July 26, 2018 Posted July 26, 2018 You did tell me to zip it up. Sorry about that! 9bd485df-6b6b-7c2f-c671-370a88c91c95.zip
Kevin M. 1 Posted July 28, 2018 Posted July 28, 2018 FYI: I updated to 3.5.1.0, and the same thing is occurring.
Luke 42243 Posted July 28, 2018 Posted July 28, 2018 Thanks for the update. We are looking making changes to the app to resolve this. Thanks.
timnop 1 Posted August 3, 2018 Posted August 3, 2018 My TV guide was flashing and the beta fixed that for me. Thanks! Will a new release be coming soon?
