GhostRider 49 Posted September 2, 2017 Posted September 2, 2017 Having display issues with Emby Theater, just updated to the new version with theme features but had these issues before as well. Server is version 3.2.30.0. 1) Plot missing, in Emby Theater only the first episode shows the plot summary, all other episodes are blank. However, using Edge web browser all episode plots are displayed as expected. The .nfo files look fine. 2) Coverart for episodes set to TV but only some episodes get this applied. Can I force the server somehow to rebuild the coverart? A simple catalogue rescan has no effect. No correlation to the above i.e. plot missing. I have blank plots and episodes some with TV Coverart applied and some not. An example: episode 1 shows plot and no TV Coverart applied, episode 2 plot is missing with Coverart applied. Any suggestions to fix these two issues I am experiencing? Many thanks
paulsalter 84 Posted September 2, 2017 Posted September 2, 2017 For the missing plot, have a look in the Settings-->Default Skin I had this before and it looks like the anti spoiler feature, hides details of future episodes Not sure on the other issue 1
GhostRider 49 Posted September 2, 2017 Author Posted September 2, 2017 Thanks Paul, it was the anti spoiler feature at work for the plot information. Still have the Coverart issue if anybody has a suggestion as to what is causing this inconsistent treatment.
Luke 42243 Posted September 2, 2017 Posted September 2, 2017 It is probably just a random treatment failure, when that happens it will return the original image. There are some updates for the next release so please try that when available. Thanks.
