arrbee99 1836 Posted September 2, 2017 Posted September 2, 2017 Noticed Ember updated yesterday to 4.4.280.0 Getting the message when I open/try to log in - 'Access is currently restricted. Please try again later'. Never seen it before. Ember is on the same machine as the server. Windows 10 PC.
7illusions 1249 Posted September 2, 2017 Posted September 2, 2017 Can you verify that this still correct: https://emby.media/community/index.php?/topic/4360-howto-runnning-server-and-app-on-the-same-machine/&do=findComment&comment=65973
7illusions 1249 Posted September 2, 2017 Posted September 2, 2017 Strange, never seen that myself. How do you connect and how far do you get? (Emby Connect, or local user),( Reaches user selection or not)
arrbee99 1836 Posted September 2, 2017 Author Posted September 2, 2017 (edited) I open Ember and I have a choice of selecting 'Family (last seen one second ago)' or Manual Login. I select Family. I get 'Access is currently restricted etc' and then a choice of Gigabyte (which is what my main PC is called), Emby Connect, Add New, or Offline. If I click on Gigabyte, I'm back to Family or Manual Login. I click on Family again and I'm back to 'Access is currently restricted' and the same choice as previous. I click on Emby Connect this time, go to sign in, type one letter and it starts to go to the home page (Latest Movies, etc), but thats all it puts up (i.e. Latest Movies). Edit: if I run Ember from the Windows menu, not from the taskbar short cut (maybe coincidentally) it lets me type in my name and password for Emby Connect and then goes back to Family / Manual Login. Click Family and its Access Denied.... That seems to be reproducable. Will un and re-install. Might be a simple fix. Edited September 2, 2017 by arrbee99
arrbee99 1836 Posted September 2, 2017 Author Posted September 2, 2017 Tried reinstalling. Still not working.
Happy2Play 9811 Posted September 2, 2017 Posted September 2, 2017 @@arrbee99 Are you on beta server? @@7illusions I get the same results on beta server. But everything appears fine connecting to my stable server.
CBers 7554 Posted September 2, 2017 Posted September 2, 2017 Not sure if it's a common issue with the beta server, but I'm having "token" issues using the Android TV app, whereas against stable its fine. https://emby.media/community/index.php?/topic/50569-server-connection-issue/ If not the same/similar, please disregard my intrusion. 1
Happy2Play 9811 Posted September 2, 2017 Posted September 2, 2017 Looks to be similar/same When I try to access via app I get this 2017-09-02 15:27:42.015 Info HttpServer: HTTP GET http://192.168.151.11:8096/emby/Users//Items?Limit=9&SortBy=DateCreated&EnableTotalRecordCount=False&sortOrder=Descending&SeriesStatuses=&fields=Taglines,ShortOverview&Filters=IsNotFolder,IsUnplayed&ImageTypes=&VideoTypes=&AirDays=&recursive=True&EnableImageTypes=&MediaTypes=&Genres=&Ids=&StudioIds=&ExcludeItemTypes=&IncludeItemTypes=Movie&ArtistIds=&PersonIds=&PersonTypes=&Years=&format=json. UserAgent: 2017-09-02 15:27:42.015 Error HttpServer: Error processing request *** Error Report *** Version: 3.2.30.5 Command line: C:\Users\Administrator\AppData\Roaming\Emby-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 4 Program data path: C:\Users\Administrator\AppData\Roaming\Emby-Server Application directory: C:\Users\Administrator\AppData\Roaming\Emby-Server\System MediaBrowser.Controller.Net.SecurityException: Access token is required. at Emby.Server.Implementations.HttpServer.Security.AuthService.ValidateSecurityToken(IServiceRequest request, String token) at Emby.Server.Implementations.HttpServer.Security.AuthService.ValidateUser(IServiceRequest request, IAuthenticationAttributes authAttribtues) at Emby.Server.Implementations.HttpServer.HttpListenerHost.ApplyRequestFilters(IRequest req, IResponse res, Object requestDto) at Emby.Server.Implementations.Services.ServiceHandler.<ProcessRequestAsync>d__15.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.HttpServer.HttpListenerHost.<RequestHandler>d__74.MoveNext() MediaBrowser.Controller.Net.SecurityException at Emby.Server.Implementations.HttpServer.Security.AuthService.ValidateSecurityToken(IServiceRequest request, String token) at Emby.Server.Implementations.HttpServer.Security.AuthService.ValidateUser(IServiceRequest request, IAuthenticationAttributes authAttribtues) at Emby.Server.Implementations.HttpServer.HttpListenerHost.ApplyRequestFilters(IRequest req, IResponse res, Object requestDto) at Emby.Server.Implementations.Services.ServiceHandler.<ProcessRequestAsync>d__15.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.HttpServer.HttpListenerHost.<RequestHandler>d__74.MoveNext() 2017-09-02 15:27:42.015 Info HttpServer: HTTP Response 401 to 192.168.151.2. Time: 0ms. http://192.168.151.11:8096/emby/Users//Items?Limit=9&SortBy=DateCreated&EnableTotalRecordCount=False&sortOrder=Descending&SeriesStatuses=&fields=Taglines,ShortOverview&Filters=IsNotFolder,IsUnplayed&ImageTypes=&VideoTypes=&AirDays=&recursive=True&EnableImageTypes=&MediaTypes=&Genres=&Ids=&StudioIds=&ExcludeItemTypes=&IncludeItemTypes=Movie&ArtistIds=&PersonIds=&PersonTypes=&Years=&format=json 2017-09-02 15:27:42.030 Info App: Udp message sent to 192.168.151.2:56777 2017-09-02 15:27:42.061 Info App: Udp message sent to 192.168.151.2:56778 2017-09-02 15:27:42.061 Error App: Error in OnMessageReceived *** Error Report *** Version: 3.2.30.5 Command line: C:\Users\Administrator\AppData\Roaming\Emby-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 4 Program data path: C:\Users\Administrator\AppData\Roaming\Emby-Server Application directory: C:\Users\Administrator\AppData\Roaming\Emby-Server\System System.EntryPointNotFoundException: Unable to find an entry point named 'NetworkIsolationEnumAppContainers' in DLL 'FirewallAPI.dll'. at MediaBrowser.ServerApplication.Native.LoopUtil.NetworkIsolationEnumAppContainers(UInt32 Flags, UInt32& pdwCntPublicACs, IntPtr& ppACs) at MediaBrowser.ServerApplication.Native.LoopUtil.PI_NetworkIsolationEnumAppContainers() at MediaBrowser.ServerApplication.Native.LoopUtil.LoadApps() at MediaBrowser.ServerApplication.Native.LoopUtil.Run(String appName) at Emby.Server.Implementations.Udp.UdpServer.<RespondToV2Message>d__9.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.Udp.UdpServer.<OnMessageReceived>d__7.MoveNext() System.EntryPointNotFoundException at MediaBrowser.ServerApplication.Native.LoopUtil.NetworkIsolationEnumAppContainers(UInt32 Flags, UInt32& pdwCntPublicACs, IntPtr& ppACs) at MediaBrowser.ServerApplication.Native.LoopUtil.PI_NetworkIsolationEnumAppContainers() at MediaBrowser.ServerApplication.Native.LoopUtil.LoadApps() at MediaBrowser.ServerApplication.Native.LoopUtil.Run(String appName) at Emby.Server.Implementations.Udp.UdpServer.<RespondToV2Message>d__9.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.Udp.UdpServer.<OnMessageReceived>d__7.MoveNext() 2017-09-02 15:27:42.108 Info App: Udp message sent to 192.168.151.2:56778 1
7illusions 1249 Posted September 3, 2017 Posted September 3, 2017 (edited) @@Luke something that has changed in authentication in recent Beta server? Edited September 3, 2017 by 7illusions 2
Vicpa 612 Posted September 3, 2017 Posted September 3, 2017 Hi Yes seems to be fixed in v3.2.30.6. -vicpa
arrbee99 1836 Posted September 3, 2017 Author Posted September 3, 2017 (edited) Also fixed for me, after a super quick test using this new net.core thingy. BTW would be nice to know what the new version has if possible, the Windows store only talks about fixes etc up to version 4.4.271. Edited September 3, 2017 by arrbee99
