freeflight29 2 Posted December 13, 2017 Posted December 13, 2017 Luke the film was a blu ray rip (BR format) [disc] type=BD-ROM version=AnyDVD HD 7.5.9.0 (BDPHash.bin 15-02-23) totalsectors=23133824 label=LA FRENCH speedmenu=0 region=-1 3D=0 fps=24 don't know if it's help
Luke 42237 Posted December 14, 2017 Author Posted December 14, 2017 Ok so you mean a folder rip with m2ts files and bdmv subfolder?
freeflight29 2 Posted December 14, 2017 Posted December 14, 2017 Ok so you mean a folder rip with m2ts files and bdmv subfolder? yes, this is it.
freeflight29 2 Posted December 25, 2017 Posted December 25, 2017 @@Luke Hello, It's seem to be a "general problem" with media scan when it's scanning blu ray rip. I encounter again the problem with an another BR rip with m2ts files. Emby server is unaccessible. Here the log in attachment. The name of the BR rip is GOT_S2_B5_DISC2 Edit : I am on my phone I can't join log file. I will do it tomorrow.
freeflight29 2 Posted December 27, 2017 Posted December 27, 2017 @@Luke Hello, It's seem to be a "general problem" with media scan when it's scanning blu ray rip. I encounter again the problem with an another BR rip with m2ts files. Emby server is unaccessible. Here the log in attachment. The name of the BR rip is GOT_S2_B5_DISC2 Edit : I am on my phone I can't join log file. I will do it tomorrow. hello luke, i have just move the bd rip in a different place, and emby server work like a charm regards
vesely.m 0 Posted July 9, 2018 Posted July 9, 2018 (edited) Hello, I also have a problem playing video. The video will not play and I will write this to you: Playback error No compatible streams are currently available. Please try again later, or contact your system administrator for more details. log in annex. Thank you for your advice. Martin embyserver-63666768421.txt Edited July 9, 2018 by vesely.m
Luke 42237 Posted July 9, 2018 Author Posted July 9, 2018 Hello, I also have a problem playing video. The video will not play and I will write this to you: Playback error No compatible streams are currently available. Please try again later, or contact your system administrator for more details. log in annex. Thank you for your advice. Martin What model asustor?
Luke 42237 Posted July 9, 2018 Author Posted July 9, 2018 Actually, nevermind. It looks like you configured a custom transcoding temporary path, but the server doesn't have write access to this folder: System.UnauthorizedAccessException: Access to the path '/share/Media/transcoding-temp' is denied. ---> System.IO.IOException: Permission denied --- End of inner exception stack trace --- Is there a reason for you to customize this? I would just remove that and set it back to the default value.
vesely.m 0 Posted July 10, 2018 Posted July 10, 2018 Hello, NAS - asustor as5104T. I do not know where to set up. Can you help me?
vesely.m 0 Posted July 10, 2018 Posted July 10, 2018 Thank you very much I found it too much thank you. Martin
Luke 42237 Posted July 10, 2018 Author Posted July 10, 2018 Why did you change it in the first place?
Luke 42237 Posted July 10, 2018 Author Posted July 10, 2018 I understand that, I'm just trying to learn what you wanted to accomplish by changing it. Thanks.
Guest Brawlsvik Posted August 22, 2018 Posted August 22, 2018 Hi!I recently purchased an ASUSTOR 202TE. When trying to install the Emby package from the website (v. 3.5.2) it doesn't really register as an app, making it unable to install. Really unable to explain it better so pics attached.https://imgur.com/a/kPunS2uThanks, Martin
Luke 42237 Posted August 22, 2018 Author Posted August 22, 2018 Those images aren't working for me. Can you please describe in more detail? You can also install from the asustor app store. Thanks.
Guest Brawlsvik Posted August 22, 2018 Posted August 22, 2018 Hi Luke and thanks for helping out!Ok, does clicking the "Imgur" logo in the top left corner work?Essentially, the App Central gives the error "Unable to upload. The file format is invalid for this system. (Ref. 6005)" despite being on the latest version of ADM (3.1.7RKE1) and using the latest file from this website. The file has the .apk extension. It doesn't load into the install process at all. I'd strongly prefer using the most recent version of Emby Thanks, Martin
Luke 42237 Posted August 22, 2018 Author Posted August 22, 2018 I've not heard of that from any one else. Can you install from app central?
Guest Brawlsvik Posted August 22, 2018 Posted August 22, 2018 Yes installing and managing Emby using the current App Central version works just fine. My concern is that over time my inability to install the most recent app will come back to haunt me, preventing me to fix errors or use Emby to the fullest. Emby (3.2.25.r1) is the one I can use atm. Thanks, Martin
Guest zecakeh Posted August 23, 2018 Posted August 23, 2018 You should find and install the "Emby Server" package which is 3.5.1.0 at the moment, not the "Emby" package. It's directly maintained by the Emby team, not Asustor, so it follows quickly their updates.
alucryd 318 Posted August 23, 2018 Posted August 23, 2018 (edited) The 202TE is not x86_64, it's plain x86. We don't have a package for that architecture because Microsoft does not provide a runtime for it, you'll have to keep using the old mono package unfortunately. Edited August 23, 2018 by alucryd
Simantic13 0 Posted December 26, 2018 Posted December 26, 2018 I'm getting the same error as Brawlsvik, and can't find any way around it. I cannot install Emby on my Asustor AS1002T at all. There is no Emby package in App Central on the device. I downloaded the package from the online App Central and I also tried installing all three of the downloads from the Emby website (current and two betas). All of them give me the error: "Unable to upload. The file format is invalid for this system. (Ref. 6005)". I'd really like to be able to run Emby directly from my NAS rather than having it run through my PC, and currently my PC isn't even set up because we're in the middle of moving, so I'm stuck using Plex until I can get this figured out. Any help would be GREATLY appreciated.
Luke 42237 Posted December 26, 2018 Author Posted December 26, 2018 I'm getting the same error as Brawlsvik, and can't find any way around it. I cannot install Emby on my Asustor AS1002T at all. There is no Emby package in App Central on the device. I downloaded the package from the online App Central and I also tried installing all three of the downloads from the Emby website (current and two betas). All of them give me the error: "Unable to upload. The file format is invalid for this system. (Ref. 6005)". I'd really like to be able to run Emby directly from my NAS rather than having it run through my PC, and currently my PC isn't even set up because we're in the middle of moving, so I'm stuck using Plex until I can get this figured out. Any help would be GREATLY appreciated. Hi, that CPU is armv7, right?
