michael72 0 Posted December 8, 2017 Posted December 8, 2017 Hi freeflight29,I can reach the web interface easily on my as6404t. No problems at all. I can open emby and look a few hours later on the web interface, no disconnection, everything runs smooth.
freeflight29 2 Posted December 8, 2017 Posted December 8, 2017 Hi freeflight29, I can reach the web interface easily on my as6404t. No problems at all. I can open emby and look a few hours later on the web interface, no disconnection, everything runs smooth. that 's crazy, my one is new with new disks "'seegate ironwolf" and the only time that it was working it was with the "native" app emby on the nas
freeflight29 2 Posted December 8, 2017 Posted December 8, 2017 (edited) @@Luke, i have tried to install the latest package ...... it's even worth. i'm stuk on the installation of emby. if you want to access to the nas and check what happen, let me know , i wil let you to access to my nas. Edit: i think it may be because i install emby without all disks synchronised in the raid. i will retry once when the disks will be synchronised. Edited December 8, 2017 by freeflight29
freeflight29 2 Posted December 8, 2017 Posted December 8, 2017 @mickael72 Could you tell me wich version have you about your adm, wich kind of disk ? the version of emby app you are using ? Thanks
michael72 0 Posted December 9, 2017 Posted December 9, 2017 (edited) Hi freeflight29, i have AS6404T with ADM 3.0.3RAI4, Bios 1.21 Currently newest emby Version 3.2.50.0 Currently 1x10TB HGST HDN721010ALE604 (Deskstar NAS HD) 16port Network switch Netgear GSS116E-100EUS Router Fritzbox 6490 Edited December 9, 2017 by michael72
michael72 0 Posted December 9, 2017 Posted December 9, 2017 (edited) @@alucryd I´m admin UID999 in the administrator group and I have given all rights (read/write) to all directories. But it still doesn´t update my metadata files (nfo/jpg) if I put a new video in the folder. Only if I force metadata update via emby webinterface it does create the metadata files. My settings see above, emby application version: 3.2.50.0 Here ´s my log: Log1.txt Log2.txt Edited December 9, 2017 by michael72
Luke 42237 Posted December 9, 2017 Author Posted December 9, 2017 @@michael72 try running a library scan
michael72 0 Posted December 9, 2017 Posted December 9, 2017 @@LukeAfter a library scan everything is fine, every metadata file (nfo/jpg) is created.I did a scan and I attached the log. But that is not my main target.The main disappointment is that the Qnap TVS-873 does "real-time" library monitoring, that means that if I put a video clip in a folder about 2 minutes later the metadata-files will be created.The Asus 6404T doesn´t do a "real-time" library monitoring, even after hours no metadata files will be created.Perhaps you can tell me if that is a NAS/emby/user privilege problem?How can I fix this? Or maybe is this something for the emby "to-do" list?I have no Mono version installed, only stock AsusMedia apps and then emby 3.2.50.0.Thx, Michael. Log4.txt
Luke 42237 Posted December 9, 2017 Author Posted December 9, 2017 @@Luke After a library scan everything is fine, every metadata file (nfo/jpg) is created. I did a scan and I attached the log. But that is not my main target. The main disappointment is that the Qnap TVS-873 does "real-time" library monitoring, that means that if I put a video clip in a folder about 2 minutes later the metadata-files will be created. The Asus 6404T doesn´t do a "real-time" library monitoring, even after hours no metadata files will be created. Perhaps you can tell me if that is a NAS/emby/user privilege problem? How can I fix this? Or maybe is this something for the emby "to-do" list? I have no Mono version installed, only stock AsusMedia apps and then emby 3.2.50.0. Thx, Michael. Looks like there's an error coming from your file system 2017-12-09 19:17:30.460 Error LibraryMonitor: Error in Directory watcher for: /share/femdom *** Error Report *** Version: 3.2.50.0 Command line: /volume1/.@plugins/AppCentral/emby-server/system/EmbyServer.dll -programdata /home/emby -ffmpeg /usr/local/AppCentral/emby-server/bin/ffmpeg -ffprobe /usr/local/AppCentral/emby-server/bin/ffprobe -updatepackage emby-server-asustor_{version}_x86-64.apk Operating system: Unix 4.4.24.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 4 Program data path: /home/emby Application directory: /volume1/.@plugins/AppCentral/emby-server/system System.UnauthorizedAccessException: Access to the path '/share/femdom/#Recycle' is denied. ---> System.IO.IOException: Permission denied --- End of inner exception stack trace --- System.UnauthorizedAccessException No Stack Trace Available InnerException: System.IO.IOException System.IO.IOException: Permission denied
michael72 0 Posted December 10, 2017 Posted December 10, 2017 Hi Luke, I installed everything fresh at the AS6404T. Now I haven´t got the filesystem error anymore. It was my fault. I haven´t given privileges to users to access the network recycle bin (only for admins). Now the real-time monitoring works flawless within minutes. No error in the log "permission denied", thanks a lot. :-) :D
freeflight29 2 Posted December 10, 2017 Posted December 10, 2017 (edited) Hello luke, i made a fresh install again, with only "emby-server-asustor_3.2.50.0_x86-64" installed on my as6404t. i launch it one time, and i stuck on the first page "http://192.168.0.100:8096/web/wizardstart.html" (see the pic in attachment) i stop and start the app and same pb, stuck on the first page i let the two logs i have in the folder ".\home\emby\logs" i let them in attachment too regards Edit: i don't change anything with my PC config and the "native" emby package was working, but i think it's may be a pb with Bitdefender or malwarebytes anti malware. home_emby_logs.zip Edited December 10, 2017 by freeflight29
Luke 42237 Posted December 10, 2017 Author Posted December 10, 2017 Hello luke, i made a fresh install again, with only "emby-server-asustor_3.2.50.0_x86-64" installed on my as6404t. i launch it one time, and i stuck on the first page "http://192.168.0.100:8096/web/wizardstart.html" (see the pic in attachment) i stop and start the app and same pb, stuck on the first page i let the two logs i have in the folder ".\home\emby\logs" i let them in attachment too regards Edit: i don't change anything with my PC config and the "native" emby package was working, but i think it's may be a pb with Bitdefender or malwarebytes anti malware. Is it possible there's something wrong with your NAS? You seem to be the only one here reporting this and we're not able to reproduce on our test devices. Or maybe something you've customized?
freeflight29 2 Posted December 10, 2017 Posted December 10, 2017 Is it possible there's something wrong with your NAS? You seem to be the only one here reporting this and we're not able to reproduce on our test devices. Or maybe something you've customized? nothing change between the "native" emby apps and the latest and the native one was working on the same nas BUT, when i turn off bitdefender and malwarebytes antimalware it's seem working good. By now i turn on again bitdefender and emby web interface still reachable I will see if it's malwarebytes antimalware is the problem. i could reach the web interface again with no problem, now i will try to add films in my media folders and will see if i could scan my media library without any issues could you tell me more about this error? 017-12-10 23:12:30.315 Error App: LoaderException: Could not load type 'EmbyServer.Windows.ShellLink' from assembly 'EmbyServer, Version=3.2.50.0, Culture=neutral, PublicKeyToken=null'.
Luke 42237 Posted December 10, 2017 Author Posted December 10, 2017 Thanks for the feedback. The LoaderException is nothing to worry about. We'll remove the message from the log.
suffren1234 0 Posted December 11, 2017 Posted December 11, 2017 Hi Luke, Is there any way to totally wipe out Emby server from the Asustor NAS ? If I delete the app from the ADM control center, it does not delete the Emby folder in ./home, neither does it delete the emby user and usergroup. As mentioned above, I couldn't manage to edit or delete the user or the group manually from the console. I would like to try again from scratch to see if it solves my problem (emby crashes after a few minutes, even with no library set up...) Thx for your help, Romain
Luke 42237 Posted December 11, 2017 Author Posted December 11, 2017 You would have to SSH into the device and delete the folder manually. Unfortunately that's the best i can tell you because if we use the folder that asustor wants us to use, then that folder gets wiped out on every update and there's nothing we can do about that. So we're forced to pick between two imperfect options and that's what we've done.
freeflight29 2 Posted December 11, 2017 Posted December 11, 2017 Hi Luke, Is there any way to totally wipe out Emby server from the Asustor NAS ? If I delete the app from the ADM control center, it does not delete the Emby folder in ./home, neither does it delete the emby user and usergroup. As mentioned above, I couldn't manage to edit or delete the user or the group manually from the console. I would like to try again from scratch to see if it solves my problem (emby crashes after a few minutes, even with no library set up...) Thx for your help, Romain Hello, could you tell me what is your NAS model? Thx
freeflight29 2 Posted December 11, 2017 Posted December 11, 2017 (edited) hello luke, i take more times to see whats really happen, so for me i had 2 problems. 1- for a resaon i couldn't explain, when i was reinstalling, i was stuck a the second "wizard page" and lost the connection with the emby server, I turn off antivirus and malwarebytes Anti-Malware. Without malwarebytes I could finish the install of emby. I uninstall malwarebytes and all working fine . 2- after when i add media file i lost randomly the connection to emby server. then i take a look to the log and i notice i lost the connection at the same moment always during a medi scanning and on the same film. 2017-12-11 23:11:05.352 Debug XmlSerializer: Deserializing file /home/emby/config/metadata.xml2017-12-11 23:11:05.686 Debug App: Running ManualCollectionFolderImageProvider for /home/emby/data/collections2017-12-11 23:11:05.886 Debug App: Running CollectionFolderImageProvider for /home/emby/root/default/Series2017-12-11 23:11:05.919 Debug App: Running CollectionFolderImageProvider for /home/emby/root/default/Vidéos et photos personnelles2017-12-11 23:11:05.927 Debug App: Running CollectionFolderImageProvider for /home/emby/root/default/Mangas2017-12-11 23:11:05.929 Debug App: Running CollectionFolderImageProvider for /home/emby/root/default/Documentaires2017-12-11 23:11:05.934 Debug App: Running CollectionFolderImageProvider for /home/emby/root/default/Mangas2017-12-11 23:11:05.937 Debug App: Running CollectionFolderImageProvider for /home/emby/root/default/Vidéos et photos personnelles2017-12-11 23:11:05.939 Debug App: Running CollectionFolderImageProvider for /home/emby/root/default/Series2017-12-11 23:11:05.942 Debug App: Running CollectionFolderImageProvider for /home/emby/root/default/Documentaires2017-12-11 23:11:06.746 Debug App: Running FolderXmlProvider for /share/Videos/Films/La French 2014 1080p Blu-Ray FRA AVC DTS-HD MA 5.1-WiHD2017-12-11 23:11:06.754 Debug App: FolderXmlProvider returned no metadata for /share/Videos/Films/La French 2014 1080p Blu-Ray FRA AVC DTS-HD MA 5.1-WiHD so i delete it. by now and i cross fingers it's working , i have all my film. Regards Edited December 12, 2017 by freeflight29
freeflight29 2 Posted December 12, 2017 Posted December 12, 2017 what exactly did you delete? I delete this film: /share/Videos/Films/La French 2014 1080p Blu-Ray FRA AVC DTS-HD MA 5.1-WiHD In the log I notice that i always lost the connexion to the server when the scan try to discover it. So I delete it This morning my connexion to emby is up. That was not the case before (only few minutes)
freeflight29 2 Posted December 12, 2017 Posted December 12, 2017 what was inside that folder? Yes, the film was inside that folder. All my film are in. I only delete this specific film
freeflight29 2 Posted December 12, 2017 Posted December 12, 2017 (edited) I'm not at home by now and I deleted it. Not sure I could found it in a recycle bin. I just thought may be i still have it on my HDD backup. I will let you know Edited December 12, 2017 by freeflight29
