Sludge Vohaul 23 Posted August 31, 2017 Posted August 31, 2017 Hello, I am one more time stuck with collection issues. I have an arbitrary string and need to check whether a collection matching this string already exists. Background: I am working on a "Plex metadata exporter - Emby metadata importer" tool for movies. In Plex after a movie had been imported and identified, one can add it to one or more (suggested) collections. These collections seem to consist of the name string only in the preconfigured language, no metadata like imbd IDs or the like. So, when I try to import a plex movie object into Emby, I need to check whether a collection matching the name string already exists and create a new one if it doesn't. Example: The to be imported Plex movie object is in a collection: All I have is the collection name string: "Boondock Saints Filmreihe" (the "The" is missing, English/German mix) In Emby, there is already a manually created collection: Path: ".../collections/Der blutige Pfad Gottes Filmreihe [boxset]" Title: "Der blutige Pfad Gottes Filmreihe" MovieDB Id: 87186 Currently, the tool creates the following new collection in Emby. This is wrong, as the already existing collection should be used: Path: ".../collections/Boondock Saints Filmreihe [boxset]" Title: "Der blutige Pfad Gottes Filmreihe" MovieDB Id: 87186 Conclusion: All I can think of is querying the available movie DBs from the tool and check the IDs, which is quite a lot of work. Is there any better way? Thanks again, sv
Solution Luke 42237 Posted August 31, 2017 Solution Posted August 31, 2017 you could try to use the search api to find the collection in the library, although based on your example it won't work in this particular case, but it might for others. failing that i think you will need to use moviedb. 1
Sludge Vohaul 23 Posted September 1, 2017 Author Posted September 1, 2017 Yea, as you said there a cases where a local search does not help. I'll postpone this topic in the tool... Thanks, sv
