luisrs 1 Posted August 31, 2017 Posted August 31, 2017 Since the last update it stops after a while I thought it was transcoding and I turned it off even though it still stops only after a while Adjunct logs https://www.dropbox.com/s/hy7j8vhtk2kxdlx/server-63639776030.txt?dl=0
Luke 42245 Posted August 31, 2017 Posted August 31, 2017 This log looks OK and only represents two minutes. Is this from the time of the problem?
luisrs 1 Posted September 4, 2017 Author Posted September 4, 2017 Since the last update where several add-ons gave problems I had many problems Every time I have to enter by terminal and use the service emby-server start command because it stops without any warning I am attaching log last time I ran https://www.dropbox.com/s/7yvscppnlxgj1e7/server-63640074142.txt?dl=0
Luke 42245 Posted September 5, 2017 Posted September 5, 2017 hi @@luisrs, sorry to hear about this. If you're up for trying something new, check out our testing thread for Emby Server on .NET Core (instead of Mono). .NET Core is considerably smaller, faster and more stable than mono. Eventually it will replace mono in our official packages.
