kanipek 230 Posted October 20, 2017 Posted October 20, 2017 Well I seemed to have stumbled on the answer all by myself. Recently Dropped Kodi for good. I had been using the old ".ignore" method to prevent Emby from syncing that recordings folder to Kodi. So I thought it might come in handy from time to time to be able to see what is in the folder from an Emby client. Deleted the .ignore. Deleted the Recording library in Emby. Created an new one Recording library in Emby. Also put in a specific location for recording series and movies in Emby. One of those changes fixed the issue. May fix yours, may not. Hope it helps someone.
Luke 42203 Posted October 20, 2017 Posted October 20, 2017 Thanks, that makes sense because recordings are just regular library items. If you are using some combination of techniques to hide the folder, then that means your recordings won't show up. It's probably a situation where we offer too many options and we get bit for it.
