reuveng 1 Posted August 29, 2017 Posted August 29, 2017 Few issues on 2017 Samsung TV 65MU8000. 1: This error after turning the TV on and starting the application: 2: Player does not remember playback position if exiting meaning playback will start from the beginning. 3: No subtitles with DTS-MA sound track. Log.txt Log1.txt
Luke 42241 Posted August 29, 2017 Posted August 29, 2017 Hi there @@reuveng, for #2 and #3 can you please discuss examples? Please attach the information requested in how to report a media playback issue. thanks !
reuveng 1 Posted August 29, 2017 Author Posted August 29, 2017 I have attached the logs (in the original post) from the described activities.
mikeeed 0 Posted August 31, 2017 Posted August 31, 2017 (edited) I'm getting the same thing on mine, a un55mu6300f, also get endingtimevalue for end time, and continuewatching for resume-able files. all other apps on TV are fine, and all other clients/browsers are fine. I had to replace a last years model (ku6300) and it was fine. Edited August 31, 2017 by mikeeed
Luke 42241 Posted August 31, 2017 Posted August 31, 2017 I'm getting the same thing on mine, a un55mu6300f, also get endingtimevalue for end time, and continuewatching for resume-able files. all other apps on TV are fine, and all other clients/browsers are fine. I had to replace a last years model (ku6300) and it was fine. What do you mean exactly by same thing?
mikeeed 0 Posted August 31, 2017 Posted August 31, 2017 (edited) The buttons have text on them during setup, and instead of ends at time showing a time, the text "endsatvalue" is there. Samsung must have changed something. I plugged in last years (partial broke screen), but I can see enough that the ends at value shows, and the buttons are normal. I removed and reinstalled on new tv, it's doing the same. Also, Luke, thanks for all y'all do, I can't imagine what life would be like without emby. Edited August 31, 2017 by mikeeed
Luke 42241 Posted August 31, 2017 Posted August 31, 2017 yea those texts are resolved for the next release, thanks.
brock0011 0 Posted September 10, 2017 Posted September 10, 2017 (edited) Trying to Direct Play from a Windows 10 x64 Application version: 3.2.30.0 to a Samsung MU7500 with the newest Emby installed. I've tried wired and wireless and from auto to 120mbps. Here's the log of a file that has to transcode as some of mine are fine. Application version: 3.2.30.0 http://192.168.0.7:8096/emby/videos/395784ac75b1822595e0ea05ba2d7245/live.m3u8?DeviceId=6f6700c02a0a772238ae9a7eae51a04a669bde7c&MediaSourceId=395784ac75b1822595e0ea05ba2d7245&VideoCodec=h264&AudioCodec=ac3,eac3,aac,mp3&VideoBitrate=119808000&AudioBitrate=192000&Level=51&Profile=high&PlaySessionId=c02d130827b14875a43674871ea301bc&api_key=7fc78ae0f0404287a63571e4ae4677fb&CopyTimestamps=false&TranscodingMaxAudioChannels=6&EnableSubtitlesInManifest=false&Tag=79b360cf2d3dcd2da9d3dbb42c3d3b89&RequireAvc=false&RequireNonAnamorphic=false&DeInterlace=false&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=False&TranscodeReasons=ContainerBitrateExceedsLimit {"Protocol":"File","Id":"395784ac75b1822595e0ea05ba2d7245","Path":"F:\\4K\\The.Smurfs.2.2013.COMPLETE.UHD.BLURAY-THRONE","Type":"Default","Name":"Bluray","IsRemote":false,"ETag":"79b360cf2d3dcd2da9d3dbb42c3d3b89","ReadAtNativeFramerate":false,"IgnoreDts":false,"IgnoreIndex":false,"GenPtsInput":false,"SupportsTranscoding":true,"SupportsDirectStream":false,"SupportsDirectPlay":true,"IsInfiniteStream":false,"RequiresOpening":false,"RequiresClosing":false,"SupportsProbing":true,"EnableMpDecimate":false,"RequiresLooping":false,"VideoType":"BluRay","MediaStreams":[],"Formats":[],"RequiredHttpHeaders":{}} User policy for Jeff: EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: TrueC:\Users\Jeff\AppData\Roaming\Emby-Server\ffmpeg\20170308\ffmpeg.exe -i file:"F:\4K\The.Smurfs.2.2013.COMPLETE.UHD.BLURAY-THRONE\BDMV\STREAM\00001.m2ts" -map_metadata -1 -map_chapters -1 -threads 0 -sn -codec:v:0 libx264 -pix_fmt yuv420p -preset veryfast -crf 23 -maxrate 119808000 -bufsize 239616000 -profile:v high -level 4.1 -x264opts:0 subme=0:me_range=4:rc_lookahead=10:me=dia:no_chroma_me:8x8dct=0:partitions=none -force_key_frames "expr:gte(t,n_forced*3)" -flags -global_header -vsync -1 -codec:a:0 ac3 -ac 6 -ab 192000 -f segment -max_delay 5000000 -avoid_negative_ts disabled -start_at_zero -segment_time 3 -individual_header_trailer 0 -segment_format mpegts -segment_list_entry_prefix "hls/c26dc49d6b23c2927e5a5eb583587f20/" -segment_list_type m3u8 -segment_start_number 0 -segment_list "C:\Users\Brock\AppData\Roaming\Emby-Server\transcoding-temp\c26dc49d6b23c2927e5a5eb583587f20.m3u8" -y "C:\Users\Brock\AppData\Roaming\Emby-Server\transcoding-temp\c26dc49d6b23c2927e5a5eb583587f20%d.ts"ffmpeg version N-83781-g3016e91 Copyright © 2000-2017 the FFmpeg developersbuilt with gcc 6.3.0 (GCC)configuration: --enable-gpl --enable-version3 --enable-cuda --enable-cuvid --enable-d3d11va --enable-dxva2 --enable-libmfx --enable-nvenc --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenh264 --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-libzimg --enable-lzma --enable-zliblibavutil 55. 48.100 / 55. 48.100libavcodec 57. 82.102 / 57. 82.102libavformat 57. 66.103 / 57. 66.103libavdevice 57. 3.100 / 57. 3.100libavfilter 6. 74.100 / 6. 74.100libswscale 4. 3.101 / 4. 3.101libswresample 2. 4.100 / 2. 4.100libpostproc 54. 2.100 / 54. 2.100[mpegts @ 00000000024a3600] start time for stream 7 is not set in estimate_timings_from_pts[mpegts @ 00000000024a3600] start time for stream 8 is not set in estimate_timings_from_pts[mpegts @ 00000000024a3600] start time for stream 9 is not set in estimate_timings_from_pts[mpegts @ 00000000024a3600] start time for stream 10 is not set in estimate_timings_from_pts[mpegts @ 00000000024a3600] start time for stream 11 is not set in estimate_timings_from_pts[mpegts @ 00000000024a3600] Could not find codec parameters for stream 7 (Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)): unspecified sizeConsider increasing the value for the 'analyzeduration' and 'probesize' options[mpegts @ 00000000024a3600] Could not find codec parameters for stream 8 (Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)): unspecified sizeConsider increasing the value for the 'analyzeduration' and 'probesize' options[mpegts @ 00000000024a3600] Could not find codec parameters for stream 9 (Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)): unspecified sizeConsider increasing the value for the 'analyzeduration' and 'probesize' options[mpegts @ 00000000024a3600] Could not find codec parameters for stream 10 (Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)): unspecified sizeConsider increasing the value for the 'analyzeduration' and 'probesize' options[mpegts @ 00000000024a3600] Could not find codec parameters for stream 11 (Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)): unspecified sizeConsider increasing the value for the 'analyzeduration' and 'probesize' optionsInput #0, mpegts, from 'file:F:\4K\The.Smurfs.2.2013.COMPLETE.UHD.BLURAY-THRONE\BDMV\STREAM\00001.m2ts':Duration: 01:44:54.31, start: 11.642667, bitrate: 72514 kb/sProgram 1Stream #0:0[0x1011]: Video: hevc (Main 10) (HDMV / 0x564D4448), yuv420p10le(tv, bt2020nc/bt2020/smpte2084), 3840x2160 [sAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 90k tbn, 23.98 tbcStream #0:1[0x1100]: Audio: truehd (AC-3 / 0x332D4341), 48000 Hz, 7.1, s32 (24 bit)Stream #0:2[0x1100]: Audio: ac3 (AC-3 / 0x332D4341), 48000 Hz, 5.1(side), fltp, 640 kb/sStream #0:3[0x1101]: Audio: ac3 (AC-3 / 0x332D4341), 48000 Hz, 5.1(side), fltp, 640 kb/sStream #0:4[0x1102]: Audio: dts (DTS-HD MA) ([134][0][0][0] / 0x0086), 48000 Hz, 5.1(side), s16pStream #0:5[0x1103]: Audio: ac3 (AC-3 / 0x332D4341), 48000 Hz, stereo, fltp, 192 kb/sStream #0:6[0x1104]: Audio: ac3 (AC-3 / 0x332D4341), 48000 Hz, 5.1(side), fltp, 640 kb/sStream #0:7[0x12a0]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)Stream #0:8[0x12a1]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)Stream #0:9[0x12a2]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)Stream #0:10[0x12a3]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)Stream #0:11[0x12a4]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)Stream mapping:Stream #0:0 -> #0:0 (hevc (native) -> h264 (libx264))Stream #0:1 -> #0:1 (truehd (native) -> ac3 (native))Press [q] to stop, [?] for help[libx264 @ 0000000004b0af20] using SAR=1/1[libx264 @ 0000000004b0af20] frame MB size (240x135) > level limit (8192)[libx264 @ 0000000004b0af20] DPB size (4 frames, 129600 mbs) > level limit (1 frames, 32768 mbs)[libx264 @ 0000000004b0af20] VBV bitrate (119808) > level limit (50000)[libx264 @ 0000000004b0af20] VBV buffer (239616) > level limit (62500)[libx264 @ 0000000004b0af20] MB rate (776823) > level limit (245760)[libx264 @ 0000000004b0af20] using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX FMA3 AVX2 LZCNT BMI2[libx264 @ 0000000004b0af20] profile Main, level 4.1Output #0, segment, to 'C:\Users\Brock\AppData\Roaming\Emby-Server\transcoding-temp\c26dc49d6b23c2927e5a5eb583587f20%d.ts':Metadata:encoder : Lavf57.66.103Stream #0:0: Video: h264 (libx264), yuv420p, 3840x2160 [sAR 1:1 DAR 16:9], q=-1--1, 23.98 fps, 90k tbn, 23.98 tbcMetadata:encoder : Lavc57.82.102 libx264Side data:cpb: bitrate max/min/avg: 119808000/0/0 buffer size: 239616000 vbv_delay: -1Stream #0:1: Audio: ac3, 48000 Hz, 5.1, fltp (24 bit), 192 kb/sMetadata:encoder : Lavc57.82.102 ac3frame= 23 fps=0.0 q=0.0 size=N/A time=00:00:00.63 bitrate=N/A speed=1.26xframe= 51 fps= 50 q=28.0 size=N/A time=00:00:01.78 bitrate=N/A speed=1.77xframe= 79 fps= 52 q=28.0 size=N/A time=00:00:03.00 bitrate=N/A speed=1.97xframe= 98 fps= 48 q=28.0 size=N/A time=00:00:03.77 bitrate=N/A speed=1.87x Edited September 10, 2017 by brock0011
Luke 42241 Posted September 10, 2017 Posted September 10, 2017 @@brock0011, hi, welcome. Are you experiencing a problem, and if so, what is the problem? thanks !
brock0011 0 Posted September 10, 2017 Posted September 10, 2017 It's having to transcode instead of direct playing, reducing the audio and video it appears
Luke 42241 Posted September 10, 2017 Posted September 10, 2017 This is a bluray folder rip, right? This will always transcode because Tizen does not support them natively. For a better experience, consider converting to a plain mkv file. Let us know if this helps, thanks !
brock0011 0 Posted September 10, 2017 Posted September 10, 2017 Correct that was a bluray folder rip. Here's an MKV causing transcoding as well: Application version: 3.2.30.0http://192.168.0.7:8096/emby/videos/aa32e6b524d12a828934c2b4440eba8f/hls1/main/0.ts?DeviceId=6f6700c02a0a772238ae9a7eae51a04a669bde7c&MediaSourceId=aa32e6b524d12a828934c2b4440eba8f&VideoCodec=h264&AudioCodec=ac3,eac3,aac,mp3&AudioStreamIndex=1&VideoBitrate=119616000&AudioBitrate=384000&Level=51&Profile=high&PlaySessionId=529e7a1e64914c06b7eb9cdba5fb175f&api_key=7fc78ae0f0404287a63571e4ae4677fb&CopyTimestamps=false&TranscodingMaxAudioChannels=6&EnableSubtitlesInManifest=false&Tag=f6b23a0bfc5abddfca9c250fbf64f56e&RequireAvc=false&RequireNonAnamorphic=false&DeInterlace=false&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=False{"Protocol":"File","Id":"aa32e6b524d12a828934c2b4440eba8f","Path":"F:\\4K\\Teenage.Mutant.Ninja.Turtles.Out.Of.The.Shadows.2016.UltraHD.BluRay.2160p.HEVC.BT2020.TrueHD 7.1.Atmos-HDLeader\\Teenage.Mutant.Ninja.Turtles.Out.Of.The.Shadows.2016.UltraHD.BluRay.2160p.HEVC.BT2020.TrueHD 7.1.Atmos-HDLeader.mkv","Type":"Default","Container":"mkv,webm","Name":"4K/HEVC/TRUEHD","IsRemote":false,"ETag":"f6b23a0bfc5abddfca9c250fbf64f56e","RunTimeTicks":67298480128,"ReadAtNativeFramerate":false,"IgnoreDts":false,"IgnoreIndex":false,"GenPtsInput":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":false,"RequiresOpening":false,"RequiresClosing":false,"SupportsProbing":true,"EnableMpDecimate":false,"RequiresLooping":false,"VideoType":"VideoFile","MediaStreams":[{"Codec":"hevc","TimeBase":"1/1000","CodecTimeBase":"1001/24000","IsInterlaced":false,"BitRate":66300791,"RefFrames":1,"IsDefault":true,"IsForced":true,"Height":2160,"Width":3840,"AverageFrameRate":23.9760246,"RealFrameRate":23.9760246,"Profile":"Main 10","Type":"Video","AspectRatio":"16:9","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuv420p10le","Level":153,"IsAnamorphic":false},{"Codec":"truehd","Language":"eng","TimeBase":"1/1000","CodecTimeBase":"1/48000","DisplayTitle":"Eng TRUEHD 7.1 Default","IsInterlaced":false,"ChannelLayout":"7.1","BitDepth":24,"Channels":8,"SampleRate":48000,"IsDefault":true,"IsForced":false,"Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0,"IsAnamorphic":false},{"Codec":"ac3","Language":"eng","TimeBase":"1/1000","CodecTimeBase":"1/48000","DisplayTitle":"Eng Dolby Digital 5.1","IsInterlaced":false,"ChannelLayout":"5.1","BitRate":640000,"Channels":6,"SampleRate":48000,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":2,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0,"IsAnamorphic":false}],"Formats":[],"Bitrate":66940791,"RequiredHttpHeaders":{}}User policy for Brock: EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: TrueC:\Users\Brock\AppData\Roaming\Emby-Server\ffmpeg\20170308\ffmpeg.exe -f matroska,webm -i file:"F:\4K\Teenage.Mutant.Ninja.Turtles.Out.Of.The.Shadows.2016.UltraHD.BluRay.2160p.HEVC.BT2020.TrueHD 7.1.Atmos-HDLeader\Teenage.Mutant.Ninja.Turtles.Out.Of.The.Shadows.2016.UltraHD.BluRay.2160p.HEVC.BT2020.TrueHD 7.1.Atmos-HDLeader.mkv" -map_metadata -1 -map_chapters -1 -threads 0 -map 0:0 -map 0:1 -map -0:s -codec:v:0 libx264 -pix_fmt yuv420p -preset veryfast -crf 23 -maxrate 119616000 -bufsize 239232000 -profile:v high -level 4.1 -x264opts:0 subme=0:me_range=4:rc_lookahead=10:me=dia:no_chroma_me:8x8dct=0:partitions=none -force_key_frames "expr:gte(t,n_forced*3)" -copyts -vsync -1 -codec:a:0 ac3 -ac 6 -ab 384000 -f segment -max_delay 5000000 -avoid_negative_ts disabled -start_at_zero -segment_time 3 -individual_header_trailer 0 -segment_format mpegts -segment_list_type m3u8 -segment_start_number 0 -segment_list "C:\Users\Brock\AppData\Roaming\Emby-Server\transcoding-temp\dfaf6d3993aee2614181ca59984ce6a6.m3u8" -y "C:\Users\Brock\AppData\Roaming\Emby-Server\transcoding-temp\dfaf6d3993aee2614181ca59984ce6a6%d.ts"ffmpeg version N-83781-g3016e91 Copyright © 2000-2017 the FFmpeg developersbuilt with gcc 6.3.0 (GCC)configuration: --enable-gpl --enable-version3 --enable-cuda --enable-cuvid --enable-d3d11va --enable-dxva2 --enable-libmfx --enable-nvenc --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenh264 --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-libzimg --enable-lzma --enable-zliblibavutil 55. 48.100 / 55. 48.100libavcodec 57. 82.102 / 57. 82.102libavformat 57. 66.103 / 57. 66.103libavdevice 57. 3.100 / 57. 3.100libavfilter 6. 74.100 / 6. 74.100libswscale 4. 3.101 / 4. 3.101libswresample 2. 4.100 / 2. 4.100libpostproc 54. 2.100 / 54. 2.100Input #0, matroska,webm, from 'file:F:\4K\Teenage.Mutant.Ninja.Turtles.Out.Of.The.Shadows.2016.UltraHD.BluRay.2160p.HEVC.BT2020.TrueHD 7.1.Atmos-HDLeader\Teenage.Mutant.Ninja.Turtles.Out.Of.The.Shadows.2016.UltraHD.BluRay.2160p.HEVC.BT2020.TrueHD 7.1.Atmos-HDLeader.mkv':Metadata:encoder : libebml v1.3.4 + libmatroska v1.4.5creation_time : 2016-10-30T00:07:44.000000ZDuration: 01:52:09.85, start: 0.000000, bitrate: 66300 kb/sStream #0:0: Video: hevc (Main 10), yuv420p10le(tv, bt2020nc/bt2020/smpte2084), 3840x2160, SAR 1:1 DAR 16:9, 23.98 fps, 23.98 tbr, 1k tbn, 23.98 tbc (default) (forced)Metadata:BPS : 60512222BPS-eng : 60512222DURATION : 01:52:09.848000000DURATION-eng : 01:52:09.848000000NUMBER_OF_FRAMES: 161355NUMBER_OF_FRAMES-eng: 161355NUMBER_OF_BYTES : 50904757533NUMBER_OF_BYTES-eng: 50904757533_STATISTICS_WRITING_APP: mkvmerge v9.5.0 ('Quiet Fire') 64bit_STATISTICS_WRITING_APP-eng: mkvmerge v9.5.0 ('Quiet Fire') 64bit_STATISTICS_WRITING_DATE_UTC: 2016-10-30 00:07:44_STATISTICS_WRITING_DATE_UTC-eng: 2016-10-30 00:07:44_STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES_STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTESStream #0:1(eng): Audio: truehd, 48000 Hz, 7.1, s32 (24 bit) (default)Metadata:BPS : 5080850BPS-eng : 5080850DURATION : 01:52:07.597000000DURATION-eng : 01:52:07.597000000NUMBER_OF_FRAMES: 8073116NUMBER_OF_FRAMES-eng: 8073116NUMBER_OF_BYTES : 4272739222NUMBER_OF_BYTES-eng: 4272739222_STATISTICS_WRITING_APP: mkvmerge v9.5.0 ('Quiet Fire') 64bit_STATISTICS_WRITING_APP-eng: mkvmerge v9.5.0 ('Quiet Fire') 64bit_STATISTICS_WRITING_DATE_UTC: 2016-10-30 00:07:44_STATISTICS_WRITING_DATE_UTC-eng: 2016-10-30 00:07:44_STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES_STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTESStream #0:2(eng): Audio: ac3, 48000 Hz, 5.1(side), fltp, 640 kb/sMetadata:BPS : 640000BPS-eng : 640000DURATION : 01:52:07.616000000DURATION-eng : 01:52:07.616000000NUMBER_OF_FRAMES: 210238NUMBER_OF_FRAMES-eng: 210238NUMBER_OF_BYTES : 538209280NUMBER_OF_BYTES-eng: 538209280_STATISTICS_WRITING_APP: mkvmerge v9.5.0 ('Quiet Fire') 64bit_STATISTICS_WRITING_APP-eng: mkvmerge v9.5.0 ('Quiet Fire') 64bit_STATISTICS_WRITING_DATE_UTC: 2016-10-30 00:07:44_STATISTICS_WRITING_DATE_UTC-eng: 2016-10-30 00:07:44_STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES_STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTESStream mapping:Stream #0:0 -> #0:0 (hevc (native) -> h264 (libx264))Stream #0:1 -> #0:1 (truehd (native) -> ac3 (native))Press [q] to stop, [?] for help[libx264 @ 0000000002520600] using SAR=1/1[libx264 @ 0000000002520600] frame MB size (240x135) > level limit (8192)[libx264 @ 0000000002520600] DPB size (4 frames, 129600 mbs) > level limit (1 frames, 32768 mbs)[libx264 @ 0000000002520600] VBV bitrate (119616) > level limit (50000)[libx264 @ 0000000002520600] VBV buffer (239232) > level limit (62500)[libx264 @ 0000000002520600] MB rate (776823) > level limit (245760)[libx264 @ 0000000002520600] using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX FMA3 AVX2 LZCNT BMI2[libx264 @ 0000000002520600] profile Main, level 4.1[libx264 @ 0000000002520600] 264 - core 148 r2762 90a61ec - H.264/MPEG-4 AVC codec - Copyleft 2003-2017 - http://www.videolan.org/x264.html - options: cabac=1 ref=1 deblock=1:0:0 analyse=0x1:0 me=dia subme=0 psy=1 psy_rd=1.00:0.00 mixed_ref=0 me_range=4 chroma_me=0 trellis=0 8x8dct=0 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=0 threads=12 lookahead_threads=2 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=3 b_pyramid=2 b_adapt=1 b_bias=0 direct=1 weightb=1 open_gop=0 weightp=1 keyint=250 keyint_min=23 scenecut=40 intra_refresh=0 rc_lookahead=10 rc=crf mbtree=1 crf=23.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 vbv_maxrate=119616 vbv_bufsize=239232 crf_max=0.0 nal_hrd=none filler=0 ip_ratio=1.40 aq=1:1.00 frame= 14 fps=0.0 q=0.0 size=N/A time=-577014:32:22.77 bitrate=N/A speed=N/AOutput #0, segment, to 'C:\Users\Brock\AppData\Roaming\Emby-Server\transcoding-temp\dfaf6d3993aee2614181ca59984ce6a6%d.ts':Metadata:encoder : Lavf57.66.103Stream #0:0: Video: h264 (libx264), yuv420p(progressive), 3840x2160 [sAR 1:1 DAR 16:9], q=-1--1, 23.98 fps, 90k tbn, 23.98 tbc (default) (forced)Metadata:encoder : Lavc57.82.102 libx264Side data:cpb: bitrate max/min/avg: 119616000/0/0 buffer size: 239232000 vbv_delay: -1Stream #0:1: Audio: ac3, 48000 Hz, 5.1, fltp (24 bit), 384 kb/s (default)Metadata:encoder : Lavc57.82.102 ac3frame= 41 fps= 37 q=28.0 size=N/A time=00:00:02.20 bitrate=N/A speed=2.01xframe= 69 fps= 43 q=28.0 size=N/A time=00:00:03.28 bitrate=N/A speed=2.05xframe= 83 fps= 38 q=28.0 size=N/A time=00:00:03.86 bitrate=N/A speed=1.78x
Luke 42241 Posted September 10, 2017 Posted September 10, 2017 That one is because Tizen does not support TrueHD. Have you checked the manual for your TV in regards to supported media formats? My suggestion - just press play, sit back and enjoy your videos. We have already been through all of this and the app will direct play whenever possible. Let us know if this helps. Thanks !
brock0011 0 Posted September 11, 2017 Posted September 11, 2017 Thank you Luke! If I were to use a Samsung 4k bluray player and downloaded the Emby app, would I bypass these current restrictions? 4K bluray to receiver Samsung TV to receiver
Luke 42241 Posted September 11, 2017 Posted September 11, 2017 You will have to check the supported formats for the bluray player but I am pretty sure the answer is no. For folder rips - definitely no. For the bluray player I doubt it supports TrueHD.
brock0011 0 Posted September 11, 2017 Posted September 11, 2017 (edited) Wouldn't the bluray player just pass the audio to the receiver (which can handle it)? I can understand the folder rips not working. Edited September 11, 2017 by brock0011
Luke 42241 Posted September 11, 2017 Posted September 11, 2017 Wouldn't the bluray player just pass the audio to the receiver (which can handle it)? I can understand the folder rips not working. According to documentation, no TrueHD: http://www.samsung.com/us/support/answer/ANS00062218/
SamES 1084 Posted September 12, 2017 Posted September 12, 2017 Wouldn't the bluray player just pass the audio to the receiver (which can handle it)? I can understand the folder rips not working. It's unclear whether it would try and pass this through or not. Even if it does, the issue for the app then becomes knowing whether to transcode or pass-through as it has no way of knowing the receivers capability. I expect this could only be done via a playback menu option. If you play something with TrueHD via DLNA or USB does the TV pass the TrueHD through to the amp, or does it fail or give no audio at all?
Bruland 0 Posted September 14, 2017 Posted September 14, 2017 My Samsung 55" Smart TV will not play two MP4 files I have on a WD HDD (Plugged into the USB Port). Both files display "The selected file is not currently supported". I checked many related pages, http://www.videoconverterfactory.com/tips/samsung-tv-mp4.html I would like to think this page can solve my problem but it cannot support Mac OS, so I wanna know if there are similar programs? emby can solve this or not? what should I do next???????? Samsung support didn't give me any feedback
Luke 42241 Posted September 14, 2017 Posted September 14, 2017 hi @@Bruland, why not try Emby for Samsung Smart TV's, and it will convert the video on the fly for you so that you can just press play and enjoy it.
reuveng 1 Posted September 24, 2017 Author Posted September 24, 2017 (edited) The latest update (1.0.29 - Sep 08) created new issue. See attached file. Looks like EMBY is not ready for 2017 Tizen. Edited September 24, 2017 by reuveng
Luke 42241 Posted September 24, 2017 Posted September 24, 2017 That is resolved for the next release of the app, thanks. 2
Luke 42241 Posted October 26, 2017 Posted October 26, 2017 Great news everyone. Emby for Samsung Smart TV's is now available in Ireland. You can learn more here: https://emby.media/community/index.php?/topic/52229-emby-for-samsung-smart-tvs-now-available-in-ireland/ Thanks !
shawnuphold 0 Posted October 30, 2017 Posted October 30, 2017 Hello all i have a Samsung UN55MU7000 Tv and where it should say what time the show or movie will end it says Endsatvalue any idea how to correct this? my ks9000 (2016) model does not have this issue
