fraenhawk 61 Posted February 26, 2014 Posted February 26, 2014 I'm curious about a few things with the new auto-organize screen. Just to clarify, the episode file pattern is what it renames to or the pattern it's looking for in the watch folder? If it's the former, is there a pattern to leave the original filename somewhere in the new file? Reason I mention is that for a brief time I was letting Sabnzbd write directly to my MB3 folders and it was saving as Season Name/Season 03/Season Name - S01E08 - 720p HDTV x264-dimension-repack.mkv as a made up example. I found it convenient to have the "extra" filename info remain so that I could tell the original from the repack or repost and easily know which to delete or keep. Now it's working similar to metabrowser in that it just renames to Season Name - S01E08 - Episode Name.mkv If I don't have the overwrite checkbox checked and a repost/repack downloads, what happens? Will one be (1) in the filename or will it just fail?
Beardyname 199 Posted February 26, 2014 Posted February 26, 2014 If you don't have the overwrite box checked, i would imagine it would not over write the previous file. aka the re-pack would not be placed in your folder.
