Diedrich 380 Posted August 26, 2017 Posted August 26, 2017 With the new layout within a show's season view; how do I multi-select?
mediacowboy 438 Posted August 26, 2017 Posted August 26, 2017 Long press the first item and then you will just select each item after.
Luke 42243 Posted August 26, 2017 Posted August 26, 2017 Currently you can't. It's something that will be reviewed for a future update, thanks ! 1
Diedrich 380 Posted August 26, 2017 Author Posted August 26, 2017 Currently you can't. It's something that will be reviewed for a future update, thanks !Thanks. That's what I was afraid of. It's a very useful feature and I would say it's quite critical too.
