mbguy 40 Posted August 25, 2017 Posted August 25, 2017 Trying Emby for Android (v3.8) on my Android TV box for the first time today. I really like the fact I don't have to mess with Kodi and get all my libraries right away. But! There is no navigation highlight! Emby doesn't show which show/link/icon/section is being selected. Is there something wrong my Android TV box or this is a bug? I don't have this issue on any of my other apps on the same box though.
Solution ebr 16337 Posted August 25, 2017 Solution Posted August 25, 2017 Hi. Sounds like you installed the mobile app which is designed for touch devices. There is no concept of a focused item in that interface... Do you have a true Android TV box or just a box running Android hooked to your TV? 1
