$50 Refurbished HDHR Connect
Thanks for the tip.
BAlGaInTl
Any reason for me to upgrade my legacy HDHR3 units?
I'm tempted for the simple fact that you can manage channels a bit better on the new ones.
Will I see any change in streaming or efficiency?
Guest asrequested
The software is what manages all of that, so I have to believe that newer models will have more support.
