DuffHQ 0 Posted August 24, 2017 Posted August 24, 2017 Hi! First post so bear with me. Trying Emby for the first time, coming from that "other" server. - Clean install, version 3.2.28.0. - Every transcoder setting is default with throttle ON. Force transcode on the webclient and transcoder just keeps going, using 8 threads 100% and no throttle until movie/episode is done transcoding. Been playing around with the preset and crf setting and it does not make much difference cpu-wise. This is exactly the reason I'm trying Emby now as that other server currently has the exact same problem with their new web client and devs. are looking in to it. Is this a know "bug" ? Regards.
Luke 42203 Posted August 24, 2017 Posted August 24, 2017 Hi @@DuffHQ, thanks for the report. We'll do some testing.
rainmakerraw 0 Posted September 2, 2017 Posted September 2, 2017 I have this exact same issue on 3.2.30.0 also.
Luke 42203 Posted September 2, 2017 Posted September 2, 2017 Thanks @@rainmakerraw, it's being looked into.
atropa 10 Posted September 21, 2017 Posted September 21, 2017 (edited) Hey, tested with the new stable version 3.2.31.0 and Android Mobile Galaxy S6, but cpu does not throttle. It trancodes the entire video without throttling. Edited September 21, 2017 by atropa
