rsaxman 0 Posted August 24, 2017 Posted August 24, 2017 I am having an issue with the audio on some files not working properly. All the background noises and ambient sounds are there, but not the dialogue. The real kicker is that it is only on 1 computer which leads me to believe that it is a codec or decoding issue, but im not sure where to start. Any suggestions?
Guest asrequested Posted August 24, 2017 Posted August 24, 2017 We need more detail. Can you post a screenshot of the file details? Are you down mixing to stereo, using surround sound? Are you using the app from the store or from the emby site?
rsaxman 0 Posted August 24, 2017 Author Posted August 24, 2017 The app is from the emby website. No down mixing is being done - just listening over headphones plugged into the computer. What file details do you need? Like I said, it's computer specific and only on certain files (random file types). It is a remote connection though from outside the home
Guest asrequested Posted August 24, 2017 Posted August 24, 2017 The app is from the emby website. No down mixing is being done - just listening over headphones plugged into the computer. What file details do you need? Like I said, it's computer specific and only on certain files (random file types). It is a remote connection though from outside the home So you also get this with music? Specifically, stereo.
Deathsquirrel 745 Posted August 24, 2017 Posted August 24, 2017 Sounds like you're sending a 5.1 mix to a 2.0 playback source and not downmixing to stereo. If all the dialog is in the center channel you get no dialog without a center speaker or downmixing.
Guest asrequested Posted August 24, 2017 Posted August 24, 2017 That's what I was thinking, but if the same is happening with music, that will be ruled out. Pull up the stats when you're playing.
rsaxman 0 Posted August 25, 2017 Author Posted August 25, 2017 So you also get this with music? Specifically, stereo. I don't use Emby for music
rsaxman 0 Posted August 25, 2017 Author Posted August 25, 2017 How do I down mix? I am not knowingly down mixing on other computers and can't replicate the problem
Guest asrequested Posted August 25, 2017 Posted August 25, 2017 What are your audio settings in Theater?
Luke 42243 Posted August 25, 2017 Posted August 25, 2017 @ he's using the web app. So essentially what he's asking for here is an option to force transcoding to 2-channel stereo audio because some browsers don't have very good built-in downmixing. For instance Chrome typically does a good job of it whereas firefox does not.
Guest asrequested Posted August 25, 2017 Posted August 25, 2017 (edited) Ah. There seems to be some confusion between web app and app from the web site. Edited August 25, 2017 by Doofus
rsaxman 0 Posted August 25, 2017 Author Posted August 25, 2017 Sorry for the confusion, I am using Theater.
Guest asrequested Posted August 25, 2017 Posted August 25, 2017 Oh, well OK then. So what are your audio settings?
