bla8291 1 Posted August 23, 2017 Posted August 23, 2017 Sorry if I've posted this to wrong section, since this is really a Chromecast issue, but it seems like all the other Chromecast posts are here. I was trying to cast a channel to my Chromecast Ultra, and any channel I select plays successfully, but it stops after 8 seconds. The video freezes for a few seconds with no audio, and then changes to a black screen and pauses. If I press play, or try to seek, nothing happens. However, when I cast to my SHIELD, it keeps playing, but still with a small and negligible skip at 8 seconds. I have tried the following: - Check for server updates and restart. Updated from 3.2.27.0 to 3.2.28.0 - Check Emby for Android app for updates. Already up-to-date - Reboot server. - Reboot Chromecast. - Play video directly on my phone. No problems I attached some server and transcode logs from around the time I had the issues. ffmpeg-transcode-5606e56b-6793-40e5-bac6-eaa3da6e8ea4.txt ffmpeg-transcode-99075c7f-4dfb-4750-ab5d-e7d8fdc6feb4.txt server-63639053970.txt server-63639108661.txt
Luke 42243 Posted August 24, 2017 Posted August 24, 2017 Hi, as a test, please try disabling quick sync encoding and see if that makes a difference. thanks.
bla8291 1 Posted August 24, 2017 Author Posted August 24, 2017 That did the trick. I tried several channels and I couldn't reproduce the issue. Thanks!
