Happy2Play 9811 Posted August 27, 2017 Posted August 27, 2017 @@Happy2Play This one is not working. File not Supported (like in the beginning). Here is your log: https://github.com/bi4/log/blob/master/server-63639472278.txt Oh just curious, is it normal that if I open my media player on TV, that before I can choose emby it disappears very fast and comes back 6 seconds later? (have this since beginning - a little bit annoying tho ) Try removing what Luke suggest from the profile. Dashboard-DLNA-Profiles-select custom profile-Info-Subtitle Profiles-Click on srt and delete the one that contains "Embeded within container", ensure to hit save.
bi4s 0 Posted August 28, 2017 Author Posted August 28, 2017 (edited) Try removing what Luke suggest from the profile. Dashboard-DLNA-Profiles-select custom profile-Info-Subtitle Profiles-Click on srt and delete the one that contains "Embeded within container", ensure to hit save. @@Happy2Play Still not working. What if we do this with the profile which worked, does this makes sense? log: https://github.com/bi4/log/blob/master/server-63639513376.txt Edited August 28, 2017 by bi4s
bi4s 0 Posted August 30, 2017 Author Posted August 30, 2017 Hey @@Happy2Play Do you have any work around yet?
Happy2Play 9811 Posted August 31, 2017 Posted August 31, 2017 Sorry I have no idea how to make the profile work with your TV, everything that should work doesn't.
bi4s 0 Posted September 1, 2017 Author Posted September 1, 2017 @@Happy2Play Well we have a profile that works indeed. Just with no subtitles....
bi4s 0 Posted September 1, 2017 Author Posted September 1, 2017 @@Luke Maybe a Dev could look into that?
Happy2Play 9811 Posted September 1, 2017 Posted September 1, 2017 The issues is I haven't seen any errors in the logs so it will be hard to find out why your TV is rejecting what is sent.
bi4s 0 Posted September 1, 2017 Author Posted September 1, 2017 @@Happy2Play I did some more testing and watched some movies. With the config you gave me who works with no subtitles. Here is the result: no laggs, no delays, good quality. And I think we do not write about the same issue: when I say subtitles are not working then I am talking about the subtitles I can normally choose with the TV settings and switch between different languages (file subtitles). Here it comes, while testing I noticed that the emby? Subtitles are working in the language from emby settings. And those are not available in TV settings. Somehow this makes sense to me thats why I guess we actually have a working profile in general?! I mean its literally perfect beside the fact that I cant switch the subtitle language while watching.
jj_bsb 0 Posted October 29, 2017 Posted October 29, 2017 I am new at forum and I also have panasonic TV, Viera E6 32". I got same error. I don't know if it will help, but I used UMS with same files and I didn't have problems to stream H264 format. UMS doesn't stream H265 format. I am trying to change my DLNA server because UMS consumes a lot of memory. Plex has same problem than EMBY to use Panasonic TV. Example of used video format: H264 - MPEG-4 AVC, 1280 x 738, fps 23.976, YUV planar. Audio AAC mp4a 48KHz
jj_bsb 0 Posted October 29, 2017 Posted October 29, 2017 Here my latest log after trying to access a movie using my Panasonic TV. Params=f2a8d0a0f8c8f945819b6e8d46873e8a;test;74d59d6f417f7e78bae6cb9019f0ee58;true;;;;2;;;;;;;0;;;;;;;;;74d59d6f417f7e78bae6cb9019f0ee58;false;Embed;;false;1446f62395464c76e13512be15d4a321;false;;false;false;. User-Agent=Panasonic, Accept=*/*, Range=bytes=430420094-, Connection=close, Host=192.168.2.26:80962017-10-29 09:19:52.482 Info HttpResultFactory: Setting range response values for /data/seriados/Mr.Robot.S01E01.hellofriend.mov.720p.WEBdl.EN-SUB.x264-[MULVAcoded].mkv. RangeRequest: bytes=430420094- Content-Length: 40880, Content-Range: bytes 430420094-430460973/4304609742017-10-29 09:19:52.485 Info HttpServer: HTTP Response 206 to 192.168.2.50. Time: 4ms. http://192.168.2.26:8096/videos/74d59d6f417f7e78bae6cb9019f0ee58/stream.mkv?Params=f2a8d0a0f8c8f945819b6e8d46873e8a;test;74d59d6f417f7e78bae6cb9019f0ee58;true;;;;2;;;;;;;0;;;;;;;;;74d59d6f417f7e78bae6cb9019f0ee58;false;Embed;;false;1446f62395464c76e13512be15d4a321;false;;false;false;2017-10-29 09:19:52.499 Info HttpServer: HTTP Response 500 to 192.168.2.50. Time: 118ms. http://192.168.2.26:8096/videos/74d59d6f417f7e78bae6cb9019f0ee58/stream.mkv?Params=f2a8d0a0f8c8f945819b6e8d46873e8a;test;74d59d6f417f7e78bae6cb9019f0ee58;true;;;;2;;;;;;;0;;;;;;;;;74d59d6f417f7e78bae6cb9019f0ee58;false;Embed;;false;1446f62395464c76e13512be15d4a321;false;;false;false;2017-10-29 09:19:52.515 Info HttpServer: HTTP GET http://192.168.2.26:8096/videos/74d59d6f417f7e78bae6cb9019f0ee58/stream.mkv?Params=f2a8d0a0f8c8f945819b6e8d46873e8a;test;74d59d6f417f7e78bae6cb9019f0ee58;true;;;;2;;;;;;;0;;;;;;;;;74d59d6f417f7e78bae6cb9019f0ee58;false;Embed;;false;1446f62395464c76e13512be15d4a321;false;;false;false;. User-Agent=Panasonic, Accept=*/*, Range=bytes=5629-, Connection=close, Host=192.168.2.26:8096 2017-10-29 09:19:52.517 Info HttpResultFactory: Setting range response values for /data/seriados/Mr.Robot.S01E01.hellofriend.mov.720p.WEBdl.EN-SUB.x264-[MULVAcoded].mkv. RangeRequest: bytes=5629- Content-Length: 430455345, Content-Range: bytes 5629-430460973/4304609742017-10-29 09:19:52.670 Info HttpServer: HTTP GET http://192.168.2.26:8096/videos/74d59d6f417f7e78bae6cb9019f0ee58/stream.mkv?Params=f2a8d0a0f8c8f945819b6e8d46873e8a;test;74d59d6f417f7e78bae6cb9019f0ee58;true;;;;2;;;;;;;0;;;;;;;;;74d59d6f417f7e78bae6cb9019f0ee58;false;Embed;;false;1446f62395464c76e13512be15d4a321;false;;false;false;. User-Agent=Panasonic, Accept=*/*, Range=bytes=5625-, Connection=close, Host=192.168.2.26:8096 2017-10-29 09:19:52.672 Info HttpResultFactory: Setting range response values for /data/seriados/Mr.Robot.S01E01.hellofriend.mov.720p.WEBdl.EN-SUB.x264-[MULVAcoded].mkv. RangeRequest: bytes=5625- Content-Length: 430455349, Content-Range: bytes 5625-430460973/4304609742017-10-29 09:19:52.681 Info HttpServer: HTTP Response 500 to 192.168.2.50. Time: 166ms. http://192.168.2.26:8096/videos/74d59d6f417f7e78bae6cb9019f0ee58/stream.mkv?Params=f2a8d0a0f8c8f945819b6e8d46873e8a;test;74d59d6f417f7e78bae6cb9019f0ee58;true;;;;2;;;;;;;0;;;;;;;;;74d59d6f417f7e78bae6cb9019f0ee58;false;Embed;;false;1446f62395464c76e13512be15d4a321;false;;false;false;2017-10-29 09:20:13.300 Info HttpServer: HTTP GET http://192.168.2.26:8096/Items/74d59d6f417f7e78bae6cb9019f0ee58/Images/Primary/0/467bd23ede328fedce73afabacea45dc/jpg/480/480/0/0. UserAgent: Panasonic MIL DLNA CP UPnP/1.0 DLNADOC/1.50 2017-10-29 09:20:13.301 Info HttpResultFactory: Transmit file /opt/emby-server/bin/cache/images/resized-images/3/3c48c939-c494-a235-b678-83b138a511c6.jpg2017-10-29 09:20:13.301 Info HttpServer: HTTP Response 200 to 192.168.2.50. Time: 1ms. http://192.168.2.26:8096/Items/74d59d6f417f7e78bae6cb9019f0ee58/Images/Primary/0/467bd23ede328fedce73afabacea45dc/jpg/480/480/0/02017-10-29 09:20:20.546 Info HttpServer: HTTP GET http://192.168.2.26:8096/emby/System/Configuration/encoding. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/61.0.3163.100 Safari/537.36 2017-10-29 09:20:20.551 Info HttpServer: HTTP Response 200 to 192.168.2.57. Time: 5ms. http://192.168.2.26:8096/emby/System/Configuration/encoding2017-10-29 09:20:20.558 Info HttpServer: HTTP GET http://192.168.2.26:8096/emby/System/Info. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/61.0.3163.100 Safari/537.36 2017-10-29 09:20:20.560 Info HttpServer: HTTP Response 200 to 192.168.2.57. Time: 2ms. http://192.168.2.26:8096/emby/System/Info2017-10-29 09:20:40.747 Info HttpServer: HTTP GET http://192.168.2.26:8096/dlna/2daeb12949ed4498881d650041033205/description.xml. UserAgent: Panasonic MIL DLNA CP UPnP/1.0 DLNADOC/1.50 2017-10-29 09:20:40.748 Info HttpServer: HTTP Response 200 to 192.168.2.50. Time: 1ms. http://192.168.2.26:8096/dlna/2daeb12949ed4498881d650041033205/description.xml2017-10-29 09:21:02.519 Info HttpResultFactory: Transmit file /opt/emby-server/system/dashboard-ui/dashboard/logpage.js2017-10-29 09:21:02.834 Info HttpServer: HTTP GET http://192.168.2.26:8096/emby/System/Logs. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/61.0.3163.100 Safari/537.36 2017-10-29 09:21:02.835 Info HttpServer: HTTP GET http://192.168.2.26:8096/emby/System/Configuration. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/61.0.3163.100 Safari/537.36
Luke 42239 Posted October 29, 2017 Posted October 29, 2017 It looks like it tried to play your mkv but the Panasonic didn't like it and aborted the connection. so it would appear that the dlna profile needs adjustment to force a transcode of some kind.
