Happy2Play 9811 Posted August 24, 2017 Posted August 24, 2017 (edited) I see in the ffmpeg log that was from the custom profiles as it converted an avi to mkv. So this test would need to be done on original profile. As for twonky we would need to see there profile used for playback to compare. But googling is showing "there's no sound for MOV/MP4 files with AAC audio, despite the claims from the Panasonic manual that AAC is supported". So there is probably going to be a lot of testing required. (serviio and plex) Edited August 24, 2017 by Happy2Play
bi4s 0 Posted August 25, 2017 Author Posted August 25, 2017 I see in the ffmpeg log that was from the custom profiles as it converted an avi to mkv. So this test would need to be done on original profile. As for twonky we would need to see there profile used for playback to compare. But googling is showing "there's no sound for MOV/MP4 files with AAC audio, despite the claims from the Panasonic manual that AAC is supported". So there is probably going to be a lot of testing required. (serviio and plex) @@Happy2Play I'm back. Anything to test?
Luke 42239 Posted August 25, 2017 Posted August 25, 2017 I would try adjusting the profile to make the mp4 direct play.
Happy2Play 9811 Posted August 25, 2017 Posted August 25, 2017 (edited) How about this? Edited August 25, 2017 by Happy2Play removed profile
bi4s 0 Posted August 25, 2017 Author Posted August 25, 2017 (edited) How about this? @@Happy2Play I copied it in. But the dashboard doesn't show it. C:\Users\Administrator\AppData\Roaming\Emby-Server\config\dlna\user Edited August 25, 2017 by bi4s
Happy2Play 9811 Posted August 25, 2017 Posted August 25, 2017 You need to restart the server to see the added profile.
bi4s 0 Posted August 25, 2017 Author Posted August 25, 2017 You need to restart the server to see the added profile. @@Happy2Play did that like 6 times
bi4s 0 Posted August 25, 2017 Author Posted August 25, 2017 @@Happy2Play Your actual file is broken......... I loaded the old one you gave me and this is working.
Happy2Play 9811 Posted August 25, 2017 Posted August 25, 2017 I see that looks like I missed a couple lines in codec conditions will have a update in a minute.
Happy2Play 9811 Posted August 25, 2017 Posted August 25, 2017 (edited) Try this one. Edited August 25, 2017 by Happy2Play removed profile
bi4s 0 Posted August 25, 2017 Author Posted August 25, 2017 Try this one. @@Happy2Play File loaded into dashboard. mp4 files did not work. btw. is it necessary to select an User library for the custom profile?
Happy2Play 9811 Posted August 25, 2017 Posted August 25, 2017 @@Happy2Play File loaded into dashboard. mp4 files did not work. btw. is it necessary to select an User library for the custom profile? Only if you want to limit the DNLA device to the restrictions of a specific user. What does doesn't work mean? Is it just a TV error? Please post logs.
Happy2Play 9811 Posted August 25, 2017 Posted August 25, 2017 @@Happy2Play mp4 files did not work. Do other formats besides mp4's play?
bi4s 0 Posted August 25, 2017 Author Posted August 25, 2017 (edited) Only if you want to limit the DNLA device to the restrictions of a specific user. What does doesn't work mean? Is it just a TV error? Please post logs. same like always. TV: "File is not supported" here you go: #deleted logs Edited August 25, 2017 by bi4s
bi4s 0 Posted August 25, 2017 Author Posted August 25, 2017 (edited) Can you get any files to play? @@Happy2Play mp4: no (file not supported like always) mpeg2-ts: no ("please wait") mp4-testfile (no sub): no (file not supported like always) avi: no (green like yesterday) mkv: yes (like always) Edited August 25, 2017 by bi4s
Happy2Play 9811 Posted August 25, 2017 Posted August 25, 2017 (edited) Since almost everything is failing, try this. Edited August 25, 2017 by Happy2Play removed profile
bi4s 0 Posted August 25, 2017 Author Posted August 25, 2017 Since almost everything is failing, try this. @@Happy2Play All those files are now tagged as "mkv". All those files can be played BUT horrible. Plays 2 seconds then horrible stutter, double images and after those 2-3 seconds the image is standing still. Not possible to press pause not possible to fast forward.
Happy2Play 9811 Posted August 25, 2017 Posted August 25, 2017 @@Happy2Play All those files are now tagged as "mkv". All those files can be played BUT horrible. Plays 2 seconds then horrible stutter, double images and after those 2-3 seconds the image is standing still. Not possible to press pause not possible to fast forward. Can you post the logs.
bi4s 0 Posted August 25, 2017 Author Posted August 25, 2017 (edited) Can you post the logs. @@Happy2Play to make things easier by this large amount of logs you will find them here, now and in the future: #removed Edited August 27, 2017 by bi4s
Happy2Play 9811 Posted August 25, 2017 Posted August 25, 2017 Ok test changing the transcode method. Go to the custom profile in dashboard click Transcoding tab then click on the Video Protocol Then changing it to ts click ok then save and try to play something. Then do the same thing trying mp4.
bi4s 0 Posted August 25, 2017 Author Posted August 25, 2017 Ok test changing the transcode method. Go to the custom profile in dashboard click Transcoding tab then click on the Video Protocol Then changing it to ts click ok then save and try to play something. Then do the same thing trying mp4. @@Happy2Play I have no mp4. should I change the mkv in "ts" ? and after playing something the ts in mp4?
Happy2Play 9811 Posted August 25, 2017 Posted August 25, 2017 Yep, those are manual custom fields. Try one then the other.
bi4s 0 Posted August 25, 2017 Author Posted August 25, 2017 (edited) Yep, those are manual custom fields. Try one then the other. @@Happy2Play with TS: mp4: no (first "please wait" then green stutter) !!file now tagged as mpeg2-TS!! mpeg2-ts: no (stutter green) mp4-testfile (no sub): (first "please wait" then green stutter) !!file now tagged as mpeg2-TS!! avi: no (first "please wait" then green stutter) !!file now tagged as mpeg2-TS!! mkv: yes (a little bit lagging) with mp4: mp4: yes, but heavy lagging, audio breakdowns, no subtitles, only one aduio language instead of two. mpeg2-ts: yes and no. running good 10 secs, then crashing., no subtitles, only one aduio language instead of two. !!file now tagged as mp4!! avi: yes and no. running good 10 secs, then crashing. !!file now tagged as mp4!! mkv: yes (a little bit lagging) both audio languages logs updated:#removed Edited August 27, 2017 by bi4s
