bi4s 0 Posted August 24, 2017 Author Posted August 24, 2017 (edited) @@Happy2Play sadly there is no ffmpeg-transcode file this time. But I got a server file: #deleted logs Edited August 25, 2017 by bi4s
Happy2Play 9811 Posted August 24, 2017 Posted August 24, 2017 (edited) Try replaceing your custom profile with this one and restart your server and see if it makes a difference. C:\Users\Administrator\AppData\Roaming\Emby-Server\config\dlna\user removed profile Edited August 24, 2017 by Happy2Play
bi4s 0 Posted August 24, 2017 Author Posted August 24, 2017 (edited) Try replaceing your custom profile with this one and restart your server and see if it makes a difference. C:\Users\Administrator\AppData\Roaming\Emby-Server\config\dlna\user @@Happy2Play Did not work. New log: #deleted logs Edited August 25, 2017 by bi4s
Happy2Play 9811 Posted August 24, 2017 Posted August 24, 2017 Is just the TV rejecting playback as the log does show any errors that I can see..
bi4s 0 Posted August 24, 2017 Author Posted August 24, 2017 Is just the TV rejecting playback as the log does show any errors that I can see.. @Happy2Play Hm what do we do now? Could it be the audio or some subtitles?
bi4s 0 Posted August 24, 2017 Author Posted August 24, 2017 (edited) @@Happy2Play wait, sec. I think the server log has DELAY! Got two 2 minutes later, here you go: #deleted logs Edited August 25, 2017 by bi4s
Happy2Play 9811 Posted August 24, 2017 Posted August 24, 2017 (edited) I can't see anything in the logs. But here is one more change to try. Edited August 24, 2017 by Happy2Play removed profile
bi4s 0 Posted August 24, 2017 Author Posted August 24, 2017 @@Happy2Play not working, tried twice. Should I reinstall emby? Could this help?
Happy2Play 9811 Posted August 24, 2017 Posted August 24, 2017 No, you don't need to reinstall. Looking at your original logs, are your subtitles internal/inside the mp4 or external?
bi4s 0 Posted August 24, 2017 Author Posted August 24, 2017 (edited) No, you don't need to reinstall. Looking at your original logs, are your subtitles internal/inside the mp4 or external? @@Happy2Play All I have is this: #deleted logs and I have no subtitle-file next to my mp4 file.. Edited August 25, 2017 by bi4s
Luke 42239 Posted August 24, 2017 Posted August 24, 2017 @@Happy2Play looks like that should direct play, no?
Happy2Play 9811 Posted August 24, 2017 Posted August 24, 2017 (edited) Looking at that my best guess is your subtitles are the issue. But not sure if I am interpreting that correctly as I don't use subs. ■ Supported Subtitles formats ● MicroDVD, SubRip, TMPlayer (.srt, .sub, .txt) The video file and subtitles text file are inside the same folder, and the file names are the same except for the file extensions. ● If there are more than one subtitles text files inside the same folder, they are displayed in the following order of priority: ".srt", ".sub", ".txt". - 118 - Edited August 24, 2017 by Happy2Play edited format issue
Happy2Play 9811 Posted August 24, 2017 Posted August 24, 2017 (edited) @@Happy2Play looks like that should direct play, no? Without subtitles I would say yes. To me only external subs are supported by TV. Edited August 24, 2017 by Happy2Play
Luke 42239 Posted August 24, 2017 Posted August 24, 2017 Without subtitles I would say yes. To me only external subs are supported by TV. That's OK because we can still direct play the video and then feed in the subtitles externally, so i would just give him a profile that will direct play it. thanks.
bi4s 0 Posted August 24, 2017 Author Posted August 24, 2017 Without subtitles I would say yes. To me only external subs are supported by TV. @@Happy2Play @@Luke But those files with subtitles are working with twonky and plex i'm sorry that I always come with the same argument but it's kinda reasonable :-D
Luke 42239 Posted August 24, 2017 Posted August 24, 2017 @@Happy2Play @@Luke But those files with subtitles are working with twonky and plex i'm sorry that I always come with the same argument but it's kinda reasonable :-D happy2play and i are not talking about working/not working.
Happy2Play 9811 Posted August 24, 2017 Posted August 24, 2017 @@Happy2Play @@Luke But those files with subtitles are working with twonky and plex i'm sorry that I always come with the same argument but it's kinda reasonable :-D That still comes back to the method of playback. @@Luke can you see the playback requests in any of the previous logs?
bi4s 0 Posted August 24, 2017 Author Posted August 24, 2017 @@Happy2Play @@Luke Is it completely impossible that something broke over time or some settings broke the ability to stream those mp4? I may vague remember that I saw some mpeg2s or something like that, instead of the mp4 file, first time ever I tried emby. But its only vague because I can't remember exactly if it was an mp4 file which got tagged as mpeg2s (or similar) and was playable. Could that theoreticaly be possible? That's why I asked if I should reinstall.
Happy2Play 9811 Posted August 24, 2017 Posted August 24, 2017 Why do you ask? All I see is "Info UpnpContentDirectory: Profile: Panasonic Viera-Custom, Path: G:\Filme und Serien\Series\Game Of Thrones\Staffel 6\S06E10.Die Winde des Winters.mp4, isEligibleForDirectPlay: True, isEligibleForDirectStream: True", but nothing else.
bi4s 0 Posted August 24, 2017 Author Posted August 24, 2017 All I see is "Info UpnpContentDirectory: Profile: Panasonic Viera-Custom, Path: G:\Filme und Serien\Series\Game Of Thrones\Staffel 6\S06E10.Die Winde des Winters.mp4, isEligibleForDirectPlay: True, isEligibleForDirectStream: True", but nothing else. I hope I do not write to much between your conversation. I may add that I always tried to play several files each time we changed profile. Most of the time one or two out of the path of ...\Staffel 7\..
Happy2Play 9811 Posted August 24, 2017 Posted August 24, 2017 (edited) Do you have any mp4 files without subtitles to test with? And start over using original profile (delete custom profile from dashboard). Edited August 24, 2017 by Happy2Play
bi4s 0 Posted August 24, 2017 Author Posted August 24, 2017 (edited) Do you have any mp4 files without subtitles to test with? And start over using original profile (delete custom profile from dashboard). @@Happy2Play yea lets try with this: #deleted logs Do you think its good to test I guess this is somehow different to the other mp4 isn't it Edited August 25, 2017 by bi4s
Happy2Play 9811 Posted August 24, 2017 Posted August 24, 2017 @@Happy2Play yea lets try with this: https://pastebin.com/D6ydpHLi Do you think its good to test I guess this is somehow different to the other mp4 isn't it The file should work. And yes it would be good to know what other formats work or don't work also.
bi4s 0 Posted August 24, 2017 Author Posted August 24, 2017 (edited) The file should work. And yes it would be good to know what other formats work or don't work also. @@Happy2Play okay I tried to play it with your custom file -> did not work. I deleted custom file, restarted server, did not add any custom profiles -> did not work. meanwhile I have a ffmpeg-transcode log in my log but from 11:48 PM. This stuff has a huge delay I guess?!? here is the ffmpeg log 1 hour ago: #deleted logs But I see some file paths I never tried. See 5. first two lines. This is an .avi file which I never tried to play. Oh and now I tried to play it! it plays but the screen is green shuttered, can't see anything. (with twonky working). Seems like not only mp4 is not working, avi does neither. latest server log: #deleted logs p.s Its already late in EU, I will be back in 8 hours and checking your next post :-) I hope we can figure this out. If you write some things to test I'll test them in 8 hours. see you soon. Edited August 25, 2017 by bi4s
