nague 5 Posted August 23, 2017 Posted August 23, 2017 (edited) Hi, I've just tested 4K UHD content on my Android 6.0.1 Sony TV (55X8509C) with Emby Android TV App. Video Codec is HEVC (5Mbps), container is mkv. It works like a charm, in direct play (this TV support hevc decoding in hardware), video is smooth … until I activated subtitles. When the first subtitle is displayed, video playback start being stuttering. Subtitle codec is SUBRIP. Is there a known issue with Android TV App, 4K and SUBRIP subtitles ? Edited August 23, 2017 by nague
mastrmind11 722 Posted August 23, 2017 Posted August 23, 2017 Hi, I've just tested 4K UHD content on my Android 6.0.1 Sony TV (55X8509C) with Emby Android TV App. Video Codec is HEVC (5Mbps), container is mkv. It works like a charm, in direct play (this TV support hevc decoding in hardware), video is smooth … until I activated subtitles. When the first subtitle is displayed, video playback start being stuttering. Subtitle codec is SUBRIP. Is there a known issue with Android TV App, 4K and SUBRIP subtibles ? Sounds like your server is struggling to transcode the video once you turn on subtitles.
nague 5 Posted August 23, 2017 Author Posted August 23, 2017 (edited) Sounds like your server is struggling to transcode the video once you turn on subtitles. I don't think: server still reports "direct play" when subtitles is enable. Edited August 23, 2017 by nague
nague 5 Posted August 23, 2017 Author Posted August 23, 2017 Please try the beta of the app. I joined the beta and tested version 1.3.43g : same issue with SUBRIP subtitles. Actually, external SRT subtitles are working fine, it’s a suitable workaround for the time being.
ebr 16337 Posted August 23, 2017 Posted August 23, 2017 I joined the beta and tested version 1.3.43g : same issue with SUBRIP subtitles. Actually, external SRT subtitles are working fine, it’s a suitable workaround for the time being. It should be able to embed those in the stream but I'd need to see a log from the app to have a better idea of what is happening. How to Report a Problem
maegibbons 1287 Posted August 24, 2017 Posted August 24, 2017 "an app from the log" - wow thats a new feature - didnt see that in the How To Krs Mark
ebr 16337 Posted August 24, 2017 Posted August 24, 2017 "an app from the log" - wow thats a new feature - didnt see that in the How To Krs Mark Doh!
