ThermoDust 12 Posted August 22, 2017 Posted August 22, 2017 (edited) Trying to get an episode to play but the web player just gives a spinning icon of death. Sever Version: 3.2.28.0 Logs: https://1drv.ms/f/s!AtItXRNac1nKhfEAjya8C68lSb3R2g Edited August 22, 2017 by ThermoDust
Luke 42203 Posted August 22, 2017 Posted August 22, 2017 Hi, you have a really old version of ffmpeg installed. Try updating that and then it should work. Thanks.
ThermoDust 12 Posted August 22, 2017 Author Posted August 22, 2017 I thought you might say that. I saw it was old so I am reading up on the best method for Debian.
ThermoDust 12 Posted August 22, 2017 Author Posted August 22, 2017 What do you need it complied with?
Solution Luke 42203 Posted August 22, 2017 Solution Posted August 22, 2017 You might have an easier time just downloading a static build from here and configuring it in the emby server dashboard: https://www.johnvansickle.com/ffmpeg/ Just make sure to mark both the ffmpeg and ffprobe files as executable. If you want to compile it, then I would suggest using everything from that johnvansickle build as a starting point. Thanks. 1
ThermoDust 12 Posted August 22, 2017 Author Posted August 22, 2017 You might have an easier time just downloading a static build from here and configuring it in the emby server dashboard: https://www.johnvansickle.com/ffmpeg/ Just make sure to mark both the ffmpeg and ffprobe files as executable. If you want to compile it, then I would suggest using everything from that johnvansickle build as a starting point. Thanks. Oh yeah. The less I compile the happier I am. PS that worked.
