Luke 42203 Posted August 25, 2017 Posted August 25, 2017 Thanks ! And yes I think that's all this is about.
thatoneguy99 33 Posted August 25, 2017 Posted August 25, 2017 It seems that I can confirm it does NOT create hidden files. I am not sure about my settings but I tried it a few different ways. Download metadata from the internet Download in advance Specified a Metadata folder Save artwork and metadata into media folders. --One thing I did notice is that when I manually set them to hidden, by putting a . before the file name, Emby UI would not show these images. I have attached a log file but I am not sure if it will help. server-63639266308.txt
Outlaw 0 Posted August 25, 2017 Author Posted August 25, 2017 Many thanks for your time and support guys will try the above and back to you TIA
thatoneguy99 33 Posted August 25, 2017 Posted August 25, 2017 @@Outlaw it seems to me like you don't want images to download to your server. You just want them to be there when you're looking through the library. Sounds right? Sent from my phone!
Outlaw 0 Posted August 25, 2017 Author Posted August 25, 2017 @ thatoneguy I was told they always download but in the pay I can't couldn't see them the issue is now I can see them but want to hide them
thatoneguy99 33 Posted August 25, 2017 Posted August 25, 2017 Yeah they do download. If not your UI would be much slower to just show it through the internet. There are a few locations they can download to. You can set it to a specific folder, you can save them in the individual folders with the movies, or they can download to the default metadata folder. When you say that you can see them, where are you looking to see them? Sent from my phone!
Outlaw 0 Posted August 25, 2017 Author Posted August 25, 2017 I have Emby premiere so they always have downloaded etc I can now see them in e.g. Movies folder or Tv shows folder TIA
Luke 42203 Posted August 25, 2017 Posted August 25, 2017 It seems that I can confirm it does NOT create hidden files. I am not sure about my settings but I tried it a few different ways. Download metadata from the internet Download in advance Specified a Metadata folder Save artwork and metadata into media folders. --One thing I did notice is that when I manually set them to hidden, by putting a . before the file name, Emby UI would not show these images. I have attached a log file but I am not sure if it will help. Ok thanks. It is a limitation of both mono and .net core so we will have to live with it for now. I will update the setting to indicate it is for windows only.
Happy2Play 9802 Posted August 25, 2017 Posted August 25, 2017 @ thatoneguy I was told they always download but in the pay I can't couldn't see them the issue is now I can see them but want to hide them Almost sounds like you don't want metadata saved with media (not the hidden option).
thatoneguy99 33 Posted August 25, 2017 Posted August 25, 2017 Do you have this option checked inside of your library? Sent from my phone!
Outlaw 0 Posted August 25, 2017 Author Posted August 25, 2017 Many thanks I will untick " download images in advance " But this means it will still download but hide it ? Otherwise I won't have info or covers for movies ? TIA
Outlaw 0 Posted August 25, 2017 Author Posted August 25, 2017 I will until he first box and leave the second ticked " save artwork " so it won't show
thatoneguy99 33 Posted August 25, 2017 Posted August 25, 2017 Untick the option above that as well. If it is currently ticked. Sent from my phone!
Happy2Play 9802 Posted August 25, 2017 Posted August 25, 2017 If you uncheck "Save artwork and metadata into media folders" it will save metadata and images in different location (not with media). Is that what you are trying to do?
Outlaw 0 Posted August 25, 2017 Author Posted August 25, 2017 Happy2play Yes mate that's it ! In the past I never had this issue but if I do that where will the artwork go?
thatoneguy99 33 Posted August 25, 2017 Posted August 25, 2017 OuterSpace. Lol. Should be in /var/lib/emby-server somewhere. Sent from my phone!
Happy2Play 9802 Posted August 25, 2017 Posted August 25, 2017 Happy2play Yes mate that's it ! In the past I never had this issue but if I do that where will the artwork go? Into a library folder in the servers default Metadata folder location (unless you have customized it). If you look at the Dashboard it will tell you the path.
Outlaw 0 Posted August 25, 2017 Author Posted August 25, 2017 Guys appreciate all your time and help will report back once resolved thanks
blade005 185 Posted August 25, 2017 Posted August 25, 2017 (edited) hi i have tried the above but it still downloads & shows the Thumbs Jpeg despite me having clicked on hide as above any help is greatly appreciated TIA I don't believe that selecting HIDE will prevent the download of images, if that is your goal. HIDE will just save the image with the Hidden Tag enabled. That would prevent them from being viewed in the media folder. Whether you save them in media folder or not, or select HIDE, they will be stored somewhere once an app requests them for display. It will still download and consume disk space. Edited August 25, 2017 by blade005
Outlaw 0 Posted August 25, 2017 Author Posted August 25, 2017 Thanks Blade appreciate your help as well as everyone who commented thanks
Bert 49 Posted September 26, 2017 Posted September 26, 2017 Into a library folder in the servers default Metadata folder location (unless you have customized it). If you look at the Dashboard it will tell you the path. So I have unchecked Save artwork and metadata into media folders. I want this to live on my SSD now for speed. Previously I was saving in with the media. I could go through the media (movies are on own drives) and delete all the fanart, etc and just leave the folders with the movies in them. Is that correct? If so, can you think of any easy way to do that? I'd like to free up some space on those drives since the data will be duplicate now.
Happy2Play 9802 Posted September 26, 2017 Posted September 26, 2017 (edited) So I have unchecked Save artwork and metadata into media folders. I want this to live on my SSD now for speed. Previously I was saving in with the media. I could go through the media (movies are on own drives) and delete all the fanart, etc and just leave the folders with the movies in them. Is that correct? If so, can you think of any easy way to do that? I'd like to free up some space on those drives since the data will be duplicate now. The only way to have duplicate data is if you Refreshed All on your libraries, as the pop says when you change this option it only affect new media. But I would just use explorer and search the library for nfo, jpg and png files and delete them. Edited September 26, 2017 by Happy2Play
