heula 192 Posted August 20, 2017 Posted August 20, 2017 (edited) Because nothing happened after posting this issue in an existing topic about another issue with auto organizing I try it with a new and seperate topic. My recorded tv shows are renamed to show name with a date format that used to be picked up by the auto organize option. For a few months now I get with some of these recordings an error with auto organize and I don't understand why? My recording looks like this "Match of the Day .2017.08.19.mp4" The info for the recordings is available for longer than one or two days at the tvdb.com but every time auto organize tries to organize it gives an NULL error. When I do it myself and choose the right serie with season number and episode number I get the same NULL error. Can this please be looked into and fixed? Link to Match of the day at the tvdb.com Server log Thanks Edited August 20, 2017 by heula
Luke 42253 Posted August 21, 2017 Posted August 21, 2017 As a test, if you refresh the series, then try it again, what happens? thanks.
heula 192 Posted August 21, 2017 Author Posted August 21, 2017 As a test, if you refresh the series, then try it again, what happens? thanks. That did the trick. Good to know it is that simple! Thanks
heula 192 Posted September 9, 2017 Author Posted September 9, 2017 Today I have this issue again and now refreshing the serie doesn't work. Goede Tijden, Slechte Tijden .2017.09.08.mp4 http://thetvdb.com/?tab=episode&seriesid=104271&seasonid=728054&id=6297241&lid=13 2017-09-09 04:03:36.312 Warn App: Object waarvoor null is toegestaan, moet een waarde hebben. Translated - 2017-09-09 04: 03: 36.312 Warn App: Object for which null is allowed must have a value. Why does this happen every time? Server log
Luke 42253 Posted September 9, 2017 Posted September 9, 2017 As a test, give it a try again later today and see if it works. Thanks.
heula 192 Posted September 9, 2017 Author Posted September 9, 2017 As a test, give it a try again later today and see if it works. Thanks.It has been sorted now but why didn't it do that two days ago. The info at the tvdb was available and I had refreshed the serie some time ago on your advice. Thanks.
heula 192 Posted September 24, 2017 Author Posted September 24, 2017 Auto Organize keeps giving me problems. It looks like it is only happening when there are dates in the file name. These two shows with TVDB indo just won't be organized and give the null error again. Flikken Rotterdam .2017.09.22.ts Dance Dance Dance .2017.09.23.mp4 Refreshed both series (again) but it doesn't work anymore. Why and what does the NULL error mean? Server log
