Skelet0r 0 Posted August 19, 2017 Posted August 19, 2017 I have tried to change the themes via Settings->Display->Themes but nothing works but the dark theme. I can get the light theme to work if I go to the admin dashboard an back, then it is light but only light not light (whatever accent). Tried with Safari and Chrome, same issue. Is that broken? Am I doing it wrong?
Luke 42242 Posted August 19, 2017 Posted August 19, 2017 Hi, do you have any custom css? if so then try removing it.
Skelet0r 0 Posted August 19, 2017 Author Posted August 19, 2017 Nope, just installed emby the first time, everything is default. (Running on Debian, if that matters)
Solution Luke 42242 Posted August 20, 2017 Solution Posted August 20, 2017 Ok I am guessing it's because the feature requires Emby Premiere. Am I right? We will have to validate that on save rather than just mentioning it underneath the field. 1
Skelet0r 0 Posted August 20, 2017 Author Posted August 20, 2017 (edited) Ok I am guessing it's because the feature requires Emby Premiere. Am I right? We will have to validate that on save rather than just mentioning it underneath the field. Oh, I have not read/see that. Thanks! But it does switch to light if I set it to light, go to server dashboard and back. Dark theme is unusable for me, makes me depressive. Edited August 20, 2017 by Skelet0r
