ernstgot 17 Posted August 19, 2017 Posted August 19, 2017 Would you suggest having a dedicated SSD for transcoding files from a mechanical drive? 1
Luke 42213 Posted August 19, 2017 Posted August 19, 2017 I would definitely suggest an SSD for the drive that Emby is installed on. The database will perform considerably faster. To be honest though in this day and age I would suggest an SSD anyway for anything that is not used for storage.
ernstgot 17 Posted August 19, 2017 Author Posted August 19, 2017 I have Emby installed on an SSD with Windows but all other files are stored off on other hard drives.
Guest asrequested Posted August 19, 2017 Posted August 19, 2017 I have a dedicated M.2 SSD for my transcode drive. It gets a lot of use. Much better to have that separated from your primary drive, if you transcode a lot.
Tur0k 148 Posted August 19, 2017 Posted August 19, 2017 (edited) I have an SSD raid group for my OS and applications and 2x raid groups of conventional drive (7200 RPM NAS 4 TB drives). One has 3 drives the other has 4 drives. On of the raid groups lives on a NAS the other lives on my HTPC server. Sent from my iPhone using Tapatalk Edited August 19, 2017 by Tur0k
Guest asrequested Posted August 19, 2017 Posted August 19, 2017 I have an SSD raid group for my OS and applications and 2x raid groups of conventional drive (7200 RPM NAS 4 TB drives). One has 3 drives the other has 4 drives. On of the raid groups lives on a NAS the other lives on my HTPC server. Sent from my iPhone using Tapatalk What's the NAS group for? Faster transfer/access? Does the bus support that bandwidth? Sorry for the rapid fire questions lol
Tur0k 148 Posted August 21, 2017 Posted August 21, 2017 Well, depending on configuration, you could setup a NAS with the purpose of sustained write/read capability. I use the OS SSD raid group for redundancy, in the event of a single system drive failure. My NAS RAID group is split up for 1. My shared folders 2. Videos I want to keep. 3. my network backups for my network systems. 4. My long term backups. Sent from my iPhone using Tapatalk
CBers 7542 Posted August 21, 2017 Posted August 21, 2017 Would you suggest having a dedicated SSD for transcoding files from a mechanical drive? Perhaps the first question should be, why is my media transcoding. 99.9% of my media direct streams. 1
Guest asrequested Posted August 21, 2017 Posted August 21, 2017 Perhaps the first question should be, why is my media transcoding. 99.9% of my media direct streams. All my recordings are transcoded. That's why I use a dedicated SSD. It gets quite a bit of use.
CBers 7542 Posted August 21, 2017 Posted August 21, 2017 All my recordings are transcoded. That's why I use a dedicated SSD. It gets quite a bit of use. Would you not want them to Direct Play/Stream?
Wilky13 21 Posted August 21, 2017 Posted August 21, 2017 Windows and Emby are installed on my main SSD. Is there a way to tell Emby to use a different SSD for transcode purposes? Sent from my iPad using Tapatalk
Luke 42213 Posted August 21, 2017 Posted August 21, 2017 Hi @@Wilky13, you can learn more about the various transcoding options in our Transcoding wiki: https://github.com/MediaBrowser/Wiki/wiki/Transcoding Please let us know if this helps. Thanks !
Guest asrequested Posted August 21, 2017 Posted August 21, 2017 Would you not want them to Direct Play/Stream? I think you're misunderstanding. When the recording is in process, I've enabled convert on the fly. So each show is being transcoded as it's recording.
CBers 7542 Posted August 21, 2017 Posted August 21, 2017 I think you're misunderstanding. When the recording is in process, I've enabled convert on the fly. So each show is being transcoded as it's recording. That's a different scenario
Guest asrequested Posted August 21, 2017 Posted August 21, 2017 That's a different scenario But it all goes through the same location. That's why I did it. I didn't want my primary drive having that much traffic.
Wilky13 21 Posted August 22, 2017 Posted August 22, 2017 Hi @@Wilky13, you can learn more about the various transcoding options in our Transcoding wiki: https://github.com/MediaBrowser/Wiki/wiki/Transcoding Please let us know if this helps. Thanks ! Ah, I've never noticed the "transcoding temporary path:" before. Thanks! Sent from my iPad using Tapatalk
ShadowKindjal 21 Posted September 5, 2018 Posted September 5, 2018 I have a dedicated M.2 SSD for my transcode drive. It gets a lot of use. Much better to have that separated from your primary drive, if you transcode a lot. I do this, however get a good quality SSD ment for high usage, I killed an Samsung 850 Evo in less than a year with it as my system drive for Emby/Plex, replaced with a Pro and works fine. Hey, quick question. I have a server that currently has an issue transcoding 1080p content on some devices (480p and some 720p works just fine) and I was wondering, based on your experiences, if that could be caused by a failing SSD. I have about 25 users on my server and it's constantly transcoding to reduce outgoing bandwidth. All that transcoding happens on my boot SSD and I'm wondering if it could be causing some issues with playback.
Luke 42213 Posted September 5, 2018 Posted September 5, 2018 A failing drive could cause any number of problems, yes.
Guest asrequested Posted September 5, 2018 Posted September 5, 2018 Yikes! All that activity on your primary drive? Are you sure you aren't running out of space?
