Angelblue05 4132 Posted August 21, 2017 Posted August 21, 2017 Are you saying when you start Kodi, the watch status don't update? Or are you saying while Kodi is running, the watch status does not update?
linds1234 19 Posted August 21, 2017 Author Posted August 21, 2017 Hi @@Angelblue05, I have 2 Kodi boxes.. If I watch something on Box #1, the watched/play-state updates locally on that box, this then gets sent to the Emby server all OK. If I then load Box #2, it will pull down any new show/movie updates, but the play state of what has just been watched on Box #1 is not reflected. When I did all the resetting on both boxes that i mentioned previously, it was working flawlessly for a few hours. Even when both Kodi boxes were on (updates came in "live"). I suspect a change in 3.2.27 is the culprit.
Angelblue05 4132 Posted August 21, 2017 Posted August 21, 2017 (edited) Ok, try the following: In the add-on settings > sync options > Disable fast sync. That should do the trick, it's a little slower than the fast sync but it will pick up on those updates. I'm not sure why the plugin is suddenly throwing an error. In the works, the fast sync is being replaced, but I need a bit of time to get it done. (However, the plugin should still be working until then...) Edited August 21, 2017 by Angelblue05 1
linds1234 19 Posted August 21, 2017 Author Posted August 21, 2017 Does that mean it will bypass the Emby.Kodi Sync Queue plugin on the server entirely? 1
Angelblue05 4132 Posted August 21, 2017 Posted August 21, 2017 Yes Sent from my iPhone using Tapatalk
linds1234 19 Posted August 21, 2017 Author Posted August 21, 2017 Will give it a shot tonight, thanks. Curiously is it not a setting that can be fixed/reverted in Emby server itself? Or is it something that needs to go forward on the server end and the plugins way of doing it is simply outdated?
mireki1975 4 Posted August 21, 2017 Posted August 21, 2017 i have 5 boxes, i´ll run into this issue with the last update, i will try to check your hint
linds1234 19 Posted August 21, 2017 Author Posted August 21, 2017 @@Angelblue05 All working with fast sync turned off. 34s to sync vs ~4s Time to visit Pledgie to encourage that updated FastSync plugin work 1
mireki1975 4 Posted August 21, 2017 Posted August 21, 2017 34s sounds bad :-( is it possible to rollback to version before? thx
Angelblue05 4132 Posted August 21, 2017 Posted August 21, 2017 No. Thank you for your patience. Don't worry this is only a temporary solution. And the fast sync plugin should still be working for everyone (at least it still is for me on windows). But in linds1234' situation, the plugin is throwing an error on mono. What is your server platform @@mireki1975 Sent from my iPhone using Tapatalk
mireki1975 4 Posted August 21, 2017 Posted August 21, 2017 running on OSX my sync in "slow" mode takes 19secs :-D better than nothing or do a manual one 1
linds1234 19 Posted August 22, 2017 Author Posted August 22, 2017 @@Angelblue05 Do you think it would make a difference if I ran Kodi 17 instead of 16.1? I'm guessing the Emby Kodi addon is probably coded the same for Kodi 17 but just thought I'd double-check.
Angelblue05 4132 Posted August 22, 2017 Posted August 22, 2017 No, the error is coming from the server plugin (fast sync plugin)
Maciek 0 Posted August 22, 2017 Posted August 22, 2017 Same problem here. Watched status not syncing anymore. Server: 3.2.28.0 Plugin: 1.4.6362.2868. I've got a big collection. so disabling fast startup is not an option. (its taking over a minute to sync server status without plugin)
Angelblue05 4132 Posted August 22, 2017 Posted August 22, 2017 @@Luke Do you know why this happened? Also, did you get a chance to add the rest of what we discussed so I can replace the fast sync completely? Sent from my iPhone using Tapatalk
Luke 42241 Posted August 22, 2017 Posted August 22, 2017 I'll get an update to the plugin out, thanks. 1
Angelblue05 4132 Posted August 22, 2017 Posted August 22, 2017 I'll get an update to the plugin out, thanks. Thank you Luke. Always on top of things. @others Once this is done, you can re-enable the fast sync option in the add-on settings. Everything will be back to normal then. Keep me posted.
Luke 42241 Posted August 24, 2017 Posted August 24, 2017 I pushed the plugin update. It requires the latest beta server. If you don't run the beta server that's OK, you'll get the plugin update after the next stable release. Thanks. 2
linds1234 19 Posted August 30, 2017 Author Posted August 30, 2017 @@Angelblue05 @@Luke Hi guys, The update of the server plugin has fixed this issue for me. Many thanks. 1
jth 1 Posted September 4, 2017 Posted September 4, 2017 My watched status is also not syncing, but I think I have a different problem. I'm using Kodi 17.4 and Emby plugin 2.3.51. After upgrading to 2.3.51 (not sure what version I was using before), I'm getting a login error and watched status is not syncing. The error summary is "User does not have admin access." and the full log is here: https://pastebin.com/W6eeg6kW I have tried turning off fast sync and adding a startup delay but neither has had any affect. Any idea what is happening?
Luke 42241 Posted September 4, 2017 Posted September 4, 2017 You may need to update again once @@Angelblue05 has released an update. thanks !
Angelblue05 4132 Posted September 4, 2017 Posted September 4, 2017 (edited) I have release the update already (2.3.51). It just catches the error and disables series pooling in Kodi. There should be nothing else different. Can you post your Kodi log? Sent from my iPhone using Tapatalk Edited September 4, 2017 by Angelblue05
jth 1 Posted September 4, 2017 Posted September 4, 2017 (edited) Kodi debug log is here: https://paste.ubuntu.com/25468071/ - thanks for looking. edit: Should also mention I have three Kodi devices. It is happening on both that upgraded to 2.3.51, but not on the one that is at 2.3.49 Edited September 4, 2017 by jth
Angelblue05 4132 Posted September 4, 2017 Posted September 4, 2017 (edited) Thank you. I think I see the problem. Edit: Try version 2.3.52. Let me know if it resolves this. Thank you. Edited September 4, 2017 by Angelblue05
