Freshman 2 Posted August 18, 2017 Posted August 18, 2017 When I try to play movie with 8ch (7.1) AAC audio, it won't start at all. Couple rounds of spinning wheel and then jumps back to previous screen. Emby Version 3.2.27.0 on Ubuntu 17.04 Tested in Firefox and Chrome (same behavior) Movies with AAC 5.1 (and other formats) are working fine. I am not sure how older versions behaved, noticed it just now. In the trascoding log there is "TranscodingMaxAudioChannels=6" as part of the URL at the begging of the log - is that the reason? Is there any way I can change this value?
Luke 42242 Posted August 18, 2017 Posted August 18, 2017 Can you please attach the emby server and ffmpeg log? Thanks.
Freshman 2 Posted August 18, 2017 Author Posted August 18, 2017 Sure. I anonymized them a little, hope thats okay... ffmpeg-transcode.txt serverlog.txt
Freshman 2 Posted August 20, 2017 Author Posted August 20, 2017 Any idea how to fix it? Or am I only one with this problem?
Freshman 2 Posted August 22, 2017 Author Posted August 22, 2017 New version 3.2.28.0, still can't play around 1/4 of my library
Luke 42242 Posted August 22, 2017 Posted August 22, 2017 Can you provide a sample video for testing? thanks.
Freshman 2 Posted August 22, 2017 Author Posted August 22, 2017 Sure...attached (had to store it in 7z, otherwise "you aren't permitted to upload...") Just a short clip, tested - not working for me in emby web, plays fine anywhere else. test_video_8ch_aac.7z
Luke 42242 Posted August 22, 2017 Posted August 22, 2017 The file plays just fine for me. I would try getting a newer ffmpeg build, as I recall some issues in the 3.2.X versions although I'm currently having difficulty locating the forum topics about it.
Freshman 2 Posted August 22, 2017 Author Posted August 22, 2017 (edited) As a part of my initial troubleshooting I went from some older ffmpeg build to latest "official" for Ubuntu Zesty, which is 3.2 and nothing has changed, so I haven't suspected ffmpeg anymore. But you are right, after forcing update to ffmpeg 3.3 branch it works correctly. Thank you very much for your help. Edited August 22, 2017 by Freshman
