logic 0 Posted August 17, 2017 Posted August 17, 2017 Hey all, So I just updated to version 3.2.27.0 and my tv shows are now all messed up. Emby seems to think that my TV Show folder on my computer is one tv show (instead of a folder containing many tv shows). My folder structure is this Videos/TVShows/StrikeBack/Season1/S1E1 But in Emby when i click on TV Shows under My Media, it thinks that each TV Show folder is a season Please help!
Luke 42203 Posted August 17, 2017 Posted August 17, 2017 Hi, what does your emby library setup look like? thanks.
logic 0 Posted August 17, 2017 Author Posted August 17, 2017 Hi, what does your emby library setup look like? thanks. So I have one library that has all of my movies and TV Shows in it. I tried to make individual libraries for Tv Shows and Movies but that did not work
Happy2Play 9802 Posted August 17, 2017 Posted August 17, 2017 So you have Videos/TVShows and Videos/Movies, and you set up 2 libraries pointing to each? (one content type TV and on content type Movies).
logic 0 Posted August 17, 2017 Author Posted August 17, 2017 So you have Videos/TVShows and Videos/Movies, and you set up 2 libraries pointing to each? (one content type TV and on content type Movies). So you have Videos/TVShows and Videos/Movies <- yes and you set up 2 libraries pointing to each? (one content type TV and on content type Movies). <- no. I only have one library. I tried to set up two libraries but for some reason they did not populate.
Happy2Play 9802 Posted August 18, 2017 Posted August 18, 2017 So you have Videos/TVShows and Videos/Movies <- yes and you set up 2 libraries pointing to each? (one content type TV and on content type Movies). <- no. I only have one library. I tried to set up two libraries but for some reason they did not populate. So how did you setup the library in Emby? What content type? (Unset/Mixed?)
logic 0 Posted August 18, 2017 Author Posted August 18, 2017 So how did you setup the library in Emby? What content type? (Unset/Mixed?) Yes!
Solution Luke 42203 Posted August 18, 2017 Solution Posted August 18, 2017 I would try deleting the library in emby, then setup two new libraries: Movies Videos/Movies TV Videos/TVShows You'll get a much better experience by using the dedicated content types. Let us know if this helps. Thanks. 1
logic 0 Posted August 18, 2017 Author Posted August 18, 2017 I would try deleting the library in emby, then setup two new libraries: Movies Videos/Movies TV Videos/TVShows You'll get a much better experience by using the dedicated content types. Let us know if this helps. Thanks. Well this worked! So bizarre since I tried to do this before and it didn't work. Bur now it did! Thanks everyone
