pir8radio 1313 Posted August 16, 2017 Posted August 16, 2017 (edited) I have been noticing motion artifacts on HD SD live TV content, at least on the web gui. I ll have to test other clients and report back. But these artifacts show up when objects are moving fast. I don't seem to see them when using the hdhomerun client, emby seems to bring out these issues... Motion artifacts: Scrolling bar on the weather channel. Her hand. Same scroller, White block not moving no artifacts on the "SEVERE" block like above, white block is solid, letters look fine. Word "day" is still scrolling and shows artifacts. Edited August 17, 2017 by pir8radio 1
Luke 42244 Posted August 17, 2017 Posted August 17, 2017 Hi there @@pir8radio, we're very sorry to hear about your issue. In order for us to best help you, please attach the information requested in how to report a media playback issue. Thanks !
pir8radio 1313 Posted August 17, 2017 Author Posted August 17, 2017 Hi there @@pir8radio, we're very sorry to hear about your issue. In order for us to best help you, please attach the information requested in how to report a media playback issue. Thanks ! Transcode log with screenshot of NON HD video playing... If you truly require the server log let me know, its not small, I will have to host it on my site. http://website.com/emby/videos/6c09658bdd33676ba9c41ce1ed8e7593/live.m3u8?DeviceId=91d9c6969ba456265321546c00d5bf6d09422f&MediaSourceId=ceadffa73f69431d8612a1c6d7805d90_native_09863c5f2732e93e9d8b40615f0ce31b_eaee2d9afbad7646aa1584e2d3dbc74a&VideoCodec=h264&AudioCodec=aac&AudioStreamIndex=1&VideoBitrate=220433655&AudioBitrate=256000&Level=51&Profile=high&PlaySessionId=1c3d14837bc840f88261177854e5aa25&api_key=673f8b8ee9b641f2be94365e8c2c9048&LiveStreamId=a17c75760a04e99b68cf766e11316e1c_09efa0d56b934a82adec00a87b837fb0_ceadffa73f69431d8612a1c6d7805d90_native_09863c5f2732e93e9d8b40615f0ce31b_eaee2d9afbad7646aa1584e2d3dbc74a&CopyTimestamps=false&TranscodingMaxAudioChannels=6&EnableSubtitlesInManifest=false&RequireAvc=true&RequireNonAnamorphic=false&DeInterlace=true&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&TranscodeReasons=ContainerNotSupported,VideoCodecNotSupported,AudioCodecNotSupported {"Protocol":"Http","Id":"ceadffa73f69431d8612a1c6d7805d90_native_09863c5f2732e93e9d8b40615f0ce31b_eaee2d9afbad7646aa1584e2d3dbc74a","Path":"http://127.0.0.1:8080/LiveTv/LiveStreamFiles/5bae83eebcd744a1a3b9347cf728ea0a/stream.ts","Type":"Default","Container":"mpegts","IsRemote":false,"ReadAtNativeFramerate":false,"IgnoreDts":true,"IgnoreIndex":false,"GenPtsInput":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":false,"IsInfiniteStream":true,"RequiresOpening":true,"RequiresClosing":true,"SupportsProbing":true,"LiveStreamId":"a17c75760a04e99b68cf766e11316e1c_09efa0d56b934a82adec00a87b837fb0_ceadffa73f69431d8612a1c6d7805d90_native_09863c5f2732e93e9d8b40615f0ce31b_eaee2d9afbad7646aa1584e2d3dbc74a","BufferMs":0,"RequiresLooping":false,"MediaStreams":[{"Codec":"mpeg2video","TimeBase":"1/90000","CodecTimeBase":"1001/60000","IsInterlaced":false,"RefFrames":1,"IsDefault":false,"IsForced":false,"Height":480,"Width":544,"AverageFrameRate":29.97003,"RealFrameRate":29.97003,"Profile":"Main","Type":"Video","AspectRatio":"4:3","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuv420p","Level":8,"IsAnamorphic":false},{"Codec":"ac3","TimeBase":"1/90000","CodecTimeBase":"1/48000","DisplayTitle":"Dolby Digital 5.1","IsInterlaced":false,"ChannelLayout":"5.1","BitRate":256000,"Channels":6,"SampleRate":48000,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0}],"Formats":[],"Bitrate":256000,"RequiredHttpHeaders":{},"AnalyzeDurationMs":3000,"DefaultAudioStreamIndex":1} C:\Users\USER\AppData\Roaming\Emby-Server\ffmpeg\20160410\ffmpeg.exe -analyzeduration 3000000 -fflags +igndts -f mpegts -i "http://127.0.0.1:8080/LiveTv/LiveStreamFiles/5bae83eebcd744a1a3b9347cf728ea0a/stream.ts" -map_metadata -1 -map_chapters -1 -threads 0 -map 0:0 -map 0:1 -map -0:s -codec:v:0 libx264 -pix_fmt yuv420p -preset superfast -crf 23 -maxrate 220433655 -bufsize 440867310 -profile:v high -level 4.1 -x264opts:0 subme=0:me_range=4:rc_lookahead=10:me=dia:no_chroma_me:8x8dct=0:partitions=none -force_key_frames "expr:gte(t,n_forced*3)" -flags -global_header -vsync cfr -codec:a:0 aac -strict experimental -ac 6 -ab 256000 -f segment -max_delay 5000000 -avoid_negative_ts disabled -start_at_zero -segment_time 3 -individual_header_trailer 0 -segment_format mpegts -segment_list_entry_prefix "hls/f885d4660bd2265526da3f6b5bde25a7/" -segment_list_type m3u8 -segment_start_number 0 -segment_list "D:\MB Transcode\transcoding-temp\f885d4660bd2265526da3f6b5bde25a7.m3u8" -y "D:\MB Transcode\transcoding-temp\f885d4660bd2265526da3f6b5bde25a7%d.ts" ffmpeg version N-79277-g0c90b2e Copyright (c) 2000-2016 the FFmpeg developers built with gcc 5.3.0 (GCC) configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmfx --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-libzimg --enable-lzma --enable-decklink --enable-zlib libavutil 55. 20.100 / 55. 20.100 libavcodec 57. 34.100 / 57. 34.100 libavformat 57. 32.100 / 57. 32.100 libavdevice 57. 0.101 / 57. 0.101 libavfilter 6. 41.100 / 6. 41.100 libswscale 4. 1.100 / 4. 1.100 libswresample 2. 0.101 / 2. 0.101 libpostproc 54. 0.100 / 54. 0.100 [mpeg2video @ 000000000255f4a0] Invalid frame dimensions 0x0. Last message repeated 1 times [mpegts @ 0000000000728fe0] Could not find codec parameters for stream 2 (Unknown: none ([134][0][0][0] / 0x0086)): unknown codec Consider increasing the value for the 'analyzeduration' and 'probesize' options [mpegts @ 0000000000728fe0] Could not find codec parameters for stream 3 (Unknown: none (ETV1 / 0x31565445)): unknown codec Consider increasing the value for the 'analyzeduration' and 'probesize' options [mpegts @ 0000000000728fe0] Could not find codec parameters for stream 4 (Unknown: none (ETV1 / 0x31565445)): unknown codec Consider increasing the value for the 'analyzeduration' and 'probesize' options Input #0, mpegts, from 'http://127.0.0.1:8080/LiveTv/LiveStreamFiles/5bae83eebcd744a1a3b9347cf728ea0a/stream.ts': Duration: N/A, start: 30055.487511, bitrate: N/A Program 37 Stream #0:0[0x188a]: Video: mpeg2video (Main) ([2][0][0][0] / 0x0002), yuv420p(tv), 544x480 [SAR 20:17 DAR 4:3], Closed Captions, max. 18000 kb/s, 29.97 fps, 29.97 tbr, 90k tbn, 59.94 tbc Stream #0:1[0x188b]: Audio: ac3 ([129][0][0][0] / 0x0081), 48000 Hz, 5.1(side), fltp, 256 kb/s Stream #0:2[0x188c]: Unknown: none ([134][0][0][0] / 0x0086) Stream #0:3[0x188d]: Unknown: none (ETV1 / 0x31565445) Stream #0:4[0x188e]: Unknown: none (ETV1 / 0x31565445) [libx264 @ 0000000002ebd0a0] using SAR=20/17 [libx264 @ 0000000002ebd0a0] VBV bitrate (220433) > level limit (50000) [libx264 @ 0000000002ebd0a0] VBV buffer (440867) > level limit (62500) [libx264 @ 0000000002ebd0a0] using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX [libx264 @ 0000000002ebd0a0] profile Main, level 4.1 Output #0, segment, to 'D:\MB Transcode\transcoding-temp\f885d4660bd2265526da3f6b5bde25a7%d.ts': Metadata: encoder : Lavf57.32.100 Stream #0:0: Video: h264 (libx264), yuv420p, 544x480 [SAR 20:17 DAR 4:3], q=-1--1, max. 220433 kb/s, 29.97 fps, 90k tbn, 29.97 tbc Metadata: encoder : Lavc57.34.100 libx264 Side data: cpb: bitrate max/min/avg: 220433000/0/0 buffer size: 440867000 vbv_delay: -1 Stream #0:1: Audio: aac (LC), 48000 Hz, 5.1, fltp, 256 kb/s Metadata: encoder : Lavc57.34.100 aac Stream mapping: Stream #0:0 -> #0:0 (mpeg2video (native) -> h264 (libx264)) Stream #0:1 -> #0:1 (ac3 (native) -> aac (native)) Press [q] to stop, [?] for help frame= 89 fps=0.0 q=27.0 size=N/A time=00:00:02.51 bitrate=N/A dup=18 drop=0 speed=5.03x frame= 141 fps=141 q=26.0 size=N/A time=00:00:04.11 bitrate=N/A dup=18 drop=0 speed=4.12x frame= 154 fps=103 q=26.0 size=N/A time=00:00:04.58 bitrate=N/A dup=18 drop=0 speed=3.06x frame= 170 fps= 82 q=26.0 size=N/A time=00:00:05.14 bitrate=N/A dup=18 drop=0 speed=2.49x frame= 182 fps= 71 q=25.0 size=N/A time=00:00:05.61 bitrate=N/A dup=18 drop=0 speed=2.19x frame= 199 fps= 65 q=27.0 size=N/A time=00:00:06.18 bitrate=N/A dup=18 drop=0 speed=2.02x frame= 216 fps= 61 q=25.0 size=N/A time=00:00:06.67 bitrate=N/A dup=18 drop=0 speed=1.87x frame= 234 fps= 57 q=24.0 size=N/A time=00:00:07.18 bitrate=N/A dup=18 drop=0 speed=1.74x frame= 245 fps= 53 q=23.0 size=N/A time=00:00:07.70 bitrate=N/A dup=18 drop=0 speed=1.67x frame= 263 fps= 51 q=25.0 size=N/A time=00:00:08.17 bitrate=N/A dup=18 drop=0 speed=1.59x frame= 277 fps= 49 q=23.0 size=N/A time=00:00:08.74 bitrate=N/A dup=18 drop=0 speed=1.55x frame= 292 fps= 48 q=25.0 size=N/A time=00:00:09.23 bitrate=N/A dup=18 drop=0 speed=1.51x frame= 307 fps= 46 q=23.0 size=N/A time=00:00:09.70 bitrate=N/A dup=18 drop=0 speed=1.47x frame= 325 fps= 45 q=25.0 size=N/A time=00:00:10.19 bitrate=N/A dup=18 drop=0 speed=1.42x frame= 342 fps= 44 q=25.0 size=N/A time=00:00:10.70 bitrate=N/A dup=18 drop=0 speed=1.39x frame= 355 fps= 43 q=22.0 size=N/A time=00:00:11.30 bitrate=N/A dup=18 drop=0 speed=1.38x frame= 370 fps= 43 q=27.0 size=N/A time=00:00:11.79 bitrate=N/A dup=18 drop=0 speed=1.36x frame= 385 fps= 42 q=26.0 size=N/A time=00:00:12.26 bitrate=N/A dup=18 drop=0 speed=1.34x frame= 398 fps= 41 q=27.0 size=N/A time=00:00:12.75 bitrate=N/A dup=18 drop=0 speed=1.32x frame= 415 fps= 41 q=25.0 size=N/A time=00:00:13.22 bitrate=N/A dup=18 drop=0 speed= 1.3x frame= 432 fps= 40 q=27.0 size=N/A time=00:00:13.71 bitrate=N/A dup=18 drop=0 speed=1.28x frame= 443 fps= 40 q=26.0 size=N/A time=00:00:14.25 bitrate=N/A dup=18 drop=0 speed=1.27x frame= 458 fps= 39 q=27.0 size=N/A time=00:00:14.74 bitrate=N/A dup=18 drop=0 speed=1.26x frame= 473 fps= 39 q=27.0 size=N/A time=00:00:15.31 bitrate=N/A dup=18 drop=0 speed=1.26x frame= 490 fps= 39 q=27.0 size=N/A time=00:00:15.78 bitrate=N/A dup=18 drop=0 speed=1.24x frame= 504 fps= 38 q=24.0 size=N/A time=00:00:16.27 bitrate=N/A dup=18 drop=0 speed=1.23x frame= 520 fps= 38 q=26.0 size=N/A time=00:00:16.74 bitrate=N/A dup=18 drop=0 speed=1.22x frame= 538 fps= 38 q=25.0 size=N/A time=00:00:17.30 bitrate=N/A dup=18 drop=0 speed=1.21x frame= 553 fps= 37 q=24.0 size=N/A time=00:00:17.87 bitrate=N/A dup=18 drop=0 speed=1.21x frame= 565 fps= 37 q=25.0 size=N/A time=00:00:18.34 bitrate=N/A dup=18 drop=0 speed= 1.2x frame= 584 fps= 37 q=25.0 size=N/A time=00:00:18.90 bitrate=N/A dup=18 drop=0 speed= 1.2x frame= 598 fps= 37 q=25.0 size=N/A time=00:00:19.37 bitrate=N/A dup=18 drop=0 speed=1.19x frame= 614 fps= 37 q=23.0 size=N/A time=00:00:19.86 bitrate=N/A dup=18 drop=0 speed=1.18x frame= 628 fps= 36 q=26.0 size=N/A time=00:00:20.43 bitrate=N/A dup=18 drop=0 speed=1.18x frame= 646 fps= 36 q=22.0 size=N/A time=00:00:20.90 bitrate=N/A dup=18 drop=0 speed=1.17x frame= 659 fps= 36 q=25.0 size=N/A time=00:00:21.46 bitrate=N/A dup=18 drop=0 speed=1.17x frame= 674 fps= 36 q=23.0 size=N/A time=00:00:21.93 bitrate=N/A dup=18 drop=0 speed=1.16x frame= 689 fps= 36 q=25.0 size=N/A time=00:00:22.42 bitrate=N/A dup=18 drop=0 speed=1.16x frame= 706 fps= 36 q=23.0 size=N/A time=00:00:22.99 bitrate=N/A dup=18 drop=0 speed=1.16x frame= 721 fps= 35 q=25.0 size=N/A time=00:00:23.46 bitrate=N/A dup=18 drop=0 speed=1.15x frame= 736 fps= 35 q=22.0 size=N/A time=00:00:23.95 bitrate=N/A dup=18 drop=0 speed=1.15x frame= 751 fps= 35 q=25.0 size=N/A time=00:00:24.42 bitrate=N/A dup=18 drop=0 speed=1.14x frame= 766 fps= 35 q=24.0 size=N/A time=00:00:24.91 bitrate=N/A dup=18 drop=0 speed=1.14x frame= 779 fps= 35 q=25.0 size=N/A time=00:00:25.45 bitrate=N/A dup=18 drop=0 speed=1.14x frame= 794 fps= 35 q=25.0 size=N/A time=00:00:25.94 bitrate=N/A dup=18 drop=0 speed=1.13x frame= 809 fps= 35 q=24.0 size=N/A time=00:00:26.41 bitrate=N/A dup=18 drop=0 speed=1.13x frame= 826 fps= 35 q=22.0 size=N/A time=00:00:26.98 bitrate=N/A dup=18 drop=0 speed=1.13x frame= 836 fps= 35 q=-1.0 Lsize=N/A time=00:00:27.82 bitrate=N/A dup=18 drop=0 speed=1.15x video:5048kB audio:854kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown [libx264 @ 0000000002ebd0a0] frame I:10 Avg QP:18.80 size: 24471 1
pir8radio 1313 Posted August 17, 2017 Author Posted August 17, 2017 I'm assuming this is in Theater? No, web gui.. And it looks like I was mistaken in my original post this happens with all SD channels, Ill fix first post.
Guest asrequested Posted August 17, 2017 Posted August 17, 2017 Well that's interesting. It's definitely a deinterlacing issue, but when transcoded (as it is being), deinterlacing should be happening. Try recording an MPEG2 stream with conversion enabled. And see if that was deinterlaced.
Luke 42244 Posted August 17, 2017 Posted August 17, 2017 It's not deinterlacing because it wasn't detected as interlaced by ffprobe. we may just want to force it for mpeg2 and assume it always is. 1
pir8radio 1313 Posted August 17, 2017 Author Posted August 17, 2017 Well that's interesting. It's definitely a deinterlacing issue, but when transcoded (as it is being), deinterlacing should be happening. Try recording an MPEG2 stream with conversion enabled. And see if that was deinterlaced. I recorded and converted to mkv and it was properly de-interlaced. On the LEFT is what emby shows for the converted MKV which plays clearly, On the RIGHT is the same channel recorded but not converted from its original format, plays with artifacts. Both say Interlaced: NO
Guest asrequested Posted August 17, 2017 Posted August 17, 2017 It's not deinterlacing because it wasn't detected as interlaced by ffprobe. we may just want to force it for mpeg2 and assume it always is. I'm pretty sure MPEG2 is mostly, if not always interlaced. I just did a test recording of an HD MPEG2 show. Emby says it isn't interlaced, but in fact it actually is. 1
pir8radio 1313 Posted August 17, 2017 Author Posted August 17, 2017 anything I need to change to fix this? Or is it something out of my control?
Guest asrequested Posted August 18, 2017 Posted August 18, 2017 anything I need to change to fix this? Or is it something out of my control? It's out of your control. ffprobe doesn't appear to be correctly analyzing the stream. In theater, you have a choice. It's not deinterlacing because it wasn't detected as interlaced by ffprobe. we may just want to force it for mpeg2 and assume it always is. Luke may have to employ his suggestion. 2
pir8radio 1313 Posted August 27, 2017 Author Posted August 27, 2017 Was this fixed in 3.2.29, because i'm having a hard time reproducing this issue in this version..
bungee91 133 Posted August 30, 2017 Posted August 30, 2017 Why do we feel that most MPEG2 is interlaced content? I'd really dislike the idea of assuming all of it is, when the majority of content I watch OTA HDHR is in fact 720P. This is certainly dependent on area, however for me the following are all broadcasted in 720P: ABC, FOX, WCIU, WPWR-DT (plus many other smaller stations). http://www.avsforum.com/forum/45-local-hdtv-info-reception/815397-chicago-il-ota.html Considering the majority of my OTA watching is on FOX (football, nightly news, random shows), I would not want this to be forces as assumed interlaced content and force an unnecessary transcode. However on the opposite side of the coin, my 720P content is currently being probed as 720i, which is incorrect. Details in post here https://emby.media/community/index.php?/topic/50400-live-tv-direct-play-recorded-tv-transcoding/?p=481999 Also attached is the comparison from Emby in comparison to Mediainfo output (double checked this with MPC-HC as well).
Guest asrequested Posted August 31, 2017 Posted August 31, 2017 (edited) That's curious that ffprobe is switching the scan type. In my case, I just figured it wasn't working. But in your case, it's reading it, incorrectly. So maybe it's misreading mine, too? In my case, I don't use the browser. In Theater, I have yadif, enabled. Edited August 31, 2017 by Doofus
bungee91 133 Posted August 31, 2017 Posted August 31, 2017 Definitely, however reading this thread if it was forced, it could be set to display it as interlaced even on progressive content. I don't think that's the case, but I honestly don't know. I don't actually use the WebUI for playback, I just wanted to see the info for a recording so I decided to look there. This seems to be the case for all content that I watch on this channel. Does ffprobe differ between ffmpeg releases and or Emby distributions? I just wonder if these results vary between versions. I can provide a clip to compare if so.
Guest asrequested Posted August 31, 2017 Posted August 31, 2017 Definitely, however reading this thread if it was forced, it could be set to display it as interlaced even on progressive content. I don't think that's the case, but I honestly don't know. I don't actually use the WebUI for playback, I just wanted to see the info for a recording so I decided to look there. This seems to be the case for all content that I watch on this channel. Does ffprobe differ between ffmpeg releases and or Emby distributions? I just wonder if these results vary between versions. I can provide a clip to compare if so. The version that comes with emby hasn't been updated in a while https://github.com/MediaBrowser/Emby.Resources/tree/master/ffmpeg/windows A lot of people are using newer builds, like https://ffmpeg.zeranoe.com/builds/ and some even build their own. I must admit, I have never thought of just updating ffprobe. Now I want to try that
pir8radio 1313 Posted August 31, 2017 Author Posted August 31, 2017 The version that comes with emby hasn't been updated in a while https://github.com/MediaBrowser/Emby.Resources/tree/master/ffmpeg/windows A lot of people are using newer builds, like https://ffmpeg.zeranoe.com/builds/ and some even build their own. I must admit, I have never thought of just updating ffprobe. Now I want to try that I always thought Emby used custom builds that's why the versions are usually stale.. Is that not the case? What are the side effects of going to a the current release of ffmpeg and probe?
bungee91 133 Posted August 31, 2017 Posted August 31, 2017 The version that comes with emby hasn't been updated in a while https://github.com/MediaBrowser/Emby.Resources/tree/master/ffmpeg/windows A lot of people are using newer builds, like https://ffmpeg.zeranoe.com/builds/ and some even build their own. I must admit, I have never thought of just updating ffprobe. Now I want to try that Sounds like a challenge, you should try it out! I have a clip to test (or if not will make one quickly) if you'd like as well. Would be interesting if yours correctly identifies the content as progressive. As for ffmpeg, I knew that differed, and that people like to load their own preferred ones or update outside of what is packaged.
Guest asrequested Posted August 31, 2017 Posted August 31, 2017 (edited) I always thought Emby used custom builds that's why the versions are usually stale.. Is that not the case? What are the side effects of going to a the current release of ffmpeg and probe? Different ffmpeg builds have varying problems. I always use the stock build that Luke made. Sounds like a challenge, you should try it out! I have a clip to test (or if not will make one quickly) if you'd like as well. Would be interesting if yours correctly identifies the content as progressive. As for ffmpeg, I knew that differed, and that people like to load their own preferred ones or update outside of what is packaged. So I just tested using the stock emby build with zeranoe's ffprobe from version 3.3.3, and well, look what happened... It read it, correctly! Edited August 31, 2017 by Doofus 1
bungee91 133 Posted August 31, 2017 Posted August 31, 2017 Different ffmpeg builds have varying problems. I always use the stock build that Luke made. So I just tested using the stock emby build with zeranoe's ffprobe from version 3.3.3, and well, look what happened... It read it, correctly! Well look at that!!.. To recap: You have content that is interlaced being probed as progressive, and I have progressive being probed as interlaced. I may have to test on my end, or if not send to you to take a lookie (not sure, sometime the Docker is a pain to swap files in).
Guest asrequested Posted August 31, 2017 Posted August 31, 2017 Well look at that!!.. To recap: You have content that is interlaced being probed as progressive, and I have progressive being probed as interlaced. I may have to test on my end, or if not send to you to take a lookie (not sure, sometime the Docker is a pain to swap files in). I can test one, if you want.
bungee91 133 Posted August 31, 2017 Posted August 31, 2017 I can test one, if you want. Thanks, I'll likely take you up on that. Let me poke around later and I can upload a link to a 10 second recording for comparison.
mwongjay 74 Posted August 31, 2017 Posted August 31, 2017 Hey guys, I just ran across this topic and I also have this issue that I've been discussing on another topic from May. https://emby.media/community/index.php?/topic/47389-live-tv-initial-pause-pixelation-and-long-pauses/
Guest asrequested Posted September 6, 2017 Posted September 6, 2017 So, on further testing using bungee's file, probing reveals two different results after a straight remux with no transcoding. In the .ts container emby shows the video (which is progressive) as interlaced. Remuxed to mkv, shows the same video as progressive. This would seem to suggest that ffprobe may be having difficulty with the .ts container.
