HdHomerun official firmware release ....20170815
Release 20170815:
Update to work with new Silicondust guide servers.
Support broadcasts where multiple PMTs are on the same PID with intermixed sequence numbers.
Support broadcasts where one video ES is shared by multiple programs.
Increase the amount of video data that can be buffered.
Improvements to XML processing.
Improvements to system logging and diagnostic logging.
Add support for upgrading the firmware via the device webpage.
Add X-HDHomeRun-Error HTTP header to provide additional information when a stream request is rejected.
Drop RUI support until a TV with RUI support is available.
CC/DC models: Fix problem where Ethernet could stall and stop receiving packets.
HDHR4 models: Support SSDP multicast test.
Legacy models: Update to work with new Silicondust guide servers.
  • Like 2
Thanks for the info.
  • 2 weeks later...
revengineer
I caution folks about upgrading, especially if you own a Prime, which cannot be downgraded. Many folks shot themselves in the foot with the 2016 upgrade and have found themselves to be slaves of the beta cycles hoping for a fix with every new release. If things work, don't touch. I am still running the 2015 version and it works well. I am worried that the new version will be required at some point because they shut down the old guide servers.
Guest asrequested
It all works just fine, on both of my primes.
"Add support for upgrading the firmware via the device webpage."
So much yes - took me a while to find out how to upgrade the firmware but for future upgrades, it should be easier
