dcrdev 255 Posted April 4, 2018 Author Posted April 4, 2018 Thanks for getting back to me, I really appreciate it! So, like I wrote earlier, I have reached out to them - and they've been a tremendous help. But the issue is still unresolved and it looks like the issue isn't really with them but rather with my hardware and/or choice of OS. Basically the working theory is that the CentOS distributed kernel doesn't have the proper drivers (vaapi? intel? libva?). So, scouring the web, I stumbled in here and what you did - and from the looks of it you seem to really understand how it all fits together so maybe you would be willing to spread the knowledge a little bit? Basically I either want to fix it - or reach the conclusion that in my case (combination of hardware and OS) it is unfixable. At least within reason. So you say you get artefacts? Is the CPU utilisation still reduced when using hardware acceleration? One thing to bear in mind is that according to the matrix https://wiki.libav.org/Hardware/vaapi - Sandbridge only has support for the h264 encoding extension. Is your media encoded h264? What's the output of "vainfo" ? You'll need to have libva, libva-intel-driver and libva-utils packages installed - which are in Epel I believe, failing that they are also in https://negativo17.org/repos/epel-multimedia.repo . It wont be the kernel as you suggested - libva-intel-driver is a usermode driver that plugs into i915, which is the in-tree driver your chipset uses. Have you checked that the rendering device actually gets created under /dev/dri/render* ? Is the user under which this software is running a member of the video group i.e. usermod -aG video rhymesWithFlex (Requires Reboot)? 1
BeyondEvil 0 Posted April 4, 2018 Posted April 4, 2018 (edited) So you say you get artefacts? Is the CPU utilisation still reduced when using hardware acceleration? One thing to bear in mind is that according to the matrix https://wiki.libav.org/Hardware/vaapi - Sandbridge only has support for the h264 encoding extension. Is your media encoded h264? What's the output of "vainfo" ? You'll need to have libva, libva-intel-driver and libva-utils packages installed - which are in Epel I believe, failing that they are also in https://negativo17.org/repos/epel-multimedia.repo . It wont be the kernel as you suggested - libva-intel-driver is a usermode driver that plugs into i915, which is the in-tree driver your chipset uses. Have you checked that the rendering device actually gets created under /dev/dri/render* ? Is the user under which this software is running a member of the video group i.e. usermod -aG video rhymesWithFlex (Requires Reboot)? Yes, CPU goes down significantly during HW transcoding (from +300% to 20-30% or less). The media I've been using for comparison says "Codec H264" when reading the meta. I'll get back to you with vainfo info Need to install it etc. $ ls -l /dev/dri/ total 0 crw-rw---- 1 root video 226, 0 Apr 3 14:42 card0 crw-rw---- 1 root video 226, 128 Apr 3 14:42 renderD128 Above was done when no transcoding was taking place. I'll re-do it when transcoding is taking place and together with vainfo. $ sudo groups flex flex : flex video usenet Edit: $ yum search libva ... libva-devel.x86_64 : Development files for libva libva.x86_64 : Video Acceleration (VA) API for Linux libva-intel-hybrid-driver.x86_64 : VA driver for Intel G45 & HD Graphics family libva-utils.x86_64 : Tools for VAAPI (including vainfo) libva-vdpau-driver.x86_64 : HW video decode support for VDPAU platforms Will the hybrid driver suffice? I have epel and elrepo repos (base) enabled. yum list installed | grep libva turns up empty yum list installed | grep intel results in: xorg-x11-drv-intel.x86_64 2.99.917-26.20160929.el7 Sidenote: I can probably uninstall x11 and all those dependencies right? Since the server is headless. Edit 2: Running vainfo as root with no transcoding happening resulted in: # vainfo error: can't connect to X server! libva info: VA-API version 0.40.0 libva info: va_getDriverName() returns 0 libva info: Trying to open /usr/lib64/dri/i965_drv_video.so libva info: va_openDriver() returns -1 vaInitialize failed with error code -1 (unknown libva error),exit Edit 3: Ok, with media playing and transcoding happening (verified H264): # ls -l /dev/dri/ total 0 crw-rw---- 1 root video 226, 0 Apr 3 14:42 card0 crw-rw---- 1 root video 226, 128 Apr 3 14:42 renderD128 # vainfo error: can't connect to X server! libva info: VA-API version 0.40.0 libva info: va_getDriverName() returns 0 libva info: Trying to open /usr/lib64/dri/i965_drv_video.so libva info: va_openDriver() returns -1 vaInitialize failed with error code -1 (unknown libva error),exit # ls /usr/lib64/dri/ hybrid_drv_video.so Edit 4: I tried two things. 1. rename the hybrid to i965 # vainfo error: can't connect to X server! libva info: VA-API version 0.40.0 libva info: va_getDriverName() returns 0 libva info: Trying to open /usr/lib64/dri/i965_drv_video.so libva info: Found init function __vaDriverInit_0_34 libva error: /usr/lib64/dri/i965_drv_video.so init failed libva info: va_openDriver() returns -1 vaInitialize failed with error code -1 (unknown libva error),exit 2. cp the i965 that I found under /usr/lib/flexmediaserver/dri/ to /usr/lib64/dri/ # vainfo error: can't connect to X server! libva info: VA-API version 0.40.0 libva info: va_getDriverName() returns 0 libva info: Trying to open /usr/lib64/dri/i965_drv_video.so libva error: /usr/lib64/dri/i965_drv_video.so has no function __vaDriverInit_0_32 libva info: va_openDriver() returns -1 vaInitialize failed with error code -1 (unknown libva error),exit So... what's next? Edited April 4, 2018 by BeyondEvil
dcrdev 255 Posted April 4, 2018 Author Posted April 4, 2018 No the hybrid driver wont work - Maybe it's no longer in epel - definately in negativo though https://negativo17.org/repos/multimedia/epel-7/x86_64/libva-1.8.3-0.1.el7.x86_64.rpm . curl https://negativo17.org/repos/epel-multimedia.repo > /etc/yum.repod.d/epel-multimedia.repo yum install libva libva-intel-driver You need the driver for vainfo to be useful... Since you're managing to utilise hardware transcoding without the libva library and the corresponding driver installed centrally, that implies that flex is packaging their own. That being the case you really would need to seek assistance from them.
BeyondEvil 0 Posted April 4, 2018 Posted April 4, 2018 No the hybrid driver wont work - Maybe it's no longer in epel - definately in negativo though https://negativo17.org/repos/multimedia/epel-7/x86_64/libva-1.8.3-0.1.el7.x86_64.rpm . curl https://negativo17.org/repos/epel-multimedia.repo > /etc/yum.repod.d/epel-multimedia.repo yum install libva libva-intel-driver You need the driver for vainfo to be useful... Since you're managing to utilise hardware transcoding without the libva library and the corresponding driver installed centrally, that implies that flex is packaging their own. That being the case you really would need to seek assistance from them. So here's what I've done. I removed the libva and the hybrid driver that I installed from epel, and then I installed libva and the intel driver from negativo. Now vainfo produces: # vainfo error: can't connect to X server! libva info: VA-API version 0.40.0 libva info: va_getDriverName() returns 0 libva info: Trying to open /usr/lib64/dri/i965_drv_video.so libva info: Found init function __vaDriverInit_0_40 failed to open /usr/lib64/dri/hybrid_drv_video.so Failed to wrapper hybrid_drv_video.so libva info: va_openDriver() returns 0 vainfo: VA-API version: 0.40 (libva ) vainfo: Driver version: Intel i965 driver for Intel(R) Sandybridge Mobile - 1.8.3 vainfo: Supported profile and entrypoints VAProfileMPEG2Simple : VAEntrypointVLD VAProfileMPEG2Main : VAEntrypointVLD VAProfileH264ConstrainedBaseline: VAEntrypointVLD VAProfileH264ConstrainedBaseline: VAEntrypointEncSlice VAProfileH264Main : VAEntrypointVLD VAProfileH264Main : VAEntrypointEncSlice VAProfileH264High : VAEntrypointVLD VAProfileH264High : VAEntrypointEncSlice VAProfileH264StereoHigh : VAEntrypointVLD VAProfileVC1Simple : VAEntrypointVLD VAProfileVC1Main : VAEntrypointVLD VAProfileVC1Advanced : VAEntrypointVLD VAProfileNone : VAEntrypointVideoProc I then replaced the i965 driver that is bundled with flex. And I got this: DEBUG - Streaming Resource: Determining preferred transcode encoders through transcode only decision. DEBUG - Codecs: testing h264_nvenc (encoder) ERROR - [FFMPEG] - Cannot load libcuda.so.1 WARN - avcodec_open2 returned -1313558101 for encoder 'h264_nvenc' DEBUG - Codecs: hardware transcoding: testing API vaapi ERROR - [FFMPEG] - Failed to initialise VAAPI connection: -1 (unknown libva error). DEBUG - Codecs: hardware transcoding: opening hw device failed - probably not supported by this system, error: Input/output error 'ldconfig -p | grep cuda' returns nothing. Is it worth pursuing getting libcuda onto my system, or is it just a never ending rabbit-hole? Is there anything else I can do at this point? Thank you for your patience.
dcrdev 255 Posted April 5, 2018 Author Posted April 5, 2018 So here's what I've done. I removed the libva and the hybrid driver that I installed from epel, and then I installed libva and the intel driver from negativo. Now vainfo produces: # vainfo error: can't connect to X server! libva info: VA-API version 0.40.0 libva info: va_getDriverName() returns 0 libva info: Trying to open /usr/lib64/dri/i965_drv_video.so libva info: Found init function __vaDriverInit_0_40 failed to open /usr/lib64/dri/hybrid_drv_video.so Failed to wrapper hybrid_drv_video.so libva info: va_openDriver() returns 0 vainfo: VA-API version: 0.40 (libva ) vainfo: Driver version: Intel i965 driver for Intel(R) Sandybridge Mobile - 1.8.3 vainfo: Supported profile and entrypoints VAProfileMPEG2Simple : VAEntrypointVLD VAProfileMPEG2Main : VAEntrypointVLD VAProfileH264ConstrainedBaseline: VAEntrypointVLD VAProfileH264ConstrainedBaseline: VAEntrypointEncSlice VAProfileH264Main : VAEntrypointVLD VAProfileH264Main : VAEntrypointEncSlice VAProfileH264High : VAEntrypointVLD VAProfileH264High : VAEntrypointEncSlice VAProfileH264StereoHigh : VAEntrypointVLD VAProfileVC1Simple : VAEntrypointVLD VAProfileVC1Main : VAEntrypointVLD VAProfileVC1Advanced : VAEntrypointVLD VAProfileNone : VAEntrypointVideoProc I then replaced the i965 driver that is bundled with flex. And I got this: DEBUG - Streaming Resource: Determining preferred transcode encoders through transcode only decision. DEBUG - Codecs: testing h264_nvenc (encoder) ERROR - [FFMPEG] - Cannot load libcuda.so.1 WARN - avcodec_open2 returned -1313558101 for encoder 'h264_nvenc' DEBUG - Codecs: hardware transcoding: testing API vaapi ERROR - [FFMPEG] - Failed to initialise VAAPI connection: -1 (unknown libva error). DEBUG - Codecs: hardware transcoding: opening hw device failed - probably not supported by this system, error: Input/output error 'ldconfig -p | grep cuda' returns nothing. Is it worth pursuing getting libcuda onto my system, or is it just a never ending rabbit-hole? Is there anything else I can do at this point? Thank you for your patience. Is this a dual graphics system? You don't need nvenc unless you have an nvidia gpu also, that you intend to use with hardware acceleration. That error indicates that the driver isn't supported by the version of the libva library your using - which makes sense since you've just replaced that.
BeyondEvil 0 Posted April 5, 2018 Posted April 5, 2018 Is this a dual graphics system? You don't need nvenc unless you have an nvidia gpu also, that you intend to use with hardware acceleration. That error indicates that the driver isn't supported by the version of the libva library your using - which makes sense since you've just replaced that. Nope, it's a mac mini. But I installed the driver and libva at the same time from the same repo... Or am I missunderstanding something?
dcrdev 255 Posted April 5, 2018 Author Posted April 5, 2018 Nope, it's a mac mini. But I installed the driver and libva at the same time from the same repo... Or am I missunderstanding something? So let me explain how support for vaapi works in ffmpeg: You can't do a static build of ffmpeg with vaapi support because of that you have to build ffmpeg against a hardcoded location under which the libva and intel drivers reside. Since flex (like Emby) is packaging their own drivers, ffmpeg looks to a directory installed as part of the flex package as it's source for those drivers. When you install libva, libva-intel-driver independently of flex, flex still looks to it's bundled directory for those files. I had interpreted you saying 'replaced' as meaning you physically copied those system-wide libraries over the ones included with flex, I was simply pointing out that it's unlikely that would have worked because libva would be at a mismatch with libva-intel. ----------------------- But in all honesty I don't think any of that's going to help you - Sandybridge is ancient, hardware support in libva-intel is unlikely to have improved in recent times and stands to reason that flex is shipping a reasonably up-to-date stack; given that it works for people with fairly recent hardware. I would look to the videos themselves and also the flex fork of ffmpeg that's being used. You can always install ffmpeg from negativo and try and encode a video manually with that passing it the vaapi directive. That would atleast narrow it down to flex ffmpeg fork vs video.
BeyondEvil 0 Posted April 5, 2018 Posted April 5, 2018 So let me explain how support for vaapi works in ffmpeg: You can't do a static build of ffmpeg with vaapi support because of that you have to build ffmpeg against a hardcoded location under which the libva and intel drivers reside. Since flex (like Emby) is packaging their own drivers, ffmpeg looks to a directory installed as part of the flex package as it's source for those drivers. When you install libva, libva-intel-driver independently of flex, flex still looks to it's bundled directory for those files. I had interpreted you saying 'replaced' as meaning you physically copied those system-wide libraries over the ones included with flex, I was simply pointing out that it's unlikely that would have worked because libva would be at a mismatch with libva-intel. ----------------------- But in all honesty I don't think any of that's going to help you - Sandybridge is ancient, hardware support in libva-intel is unlikely to have improved in recent times and stands to reason that flex is shipping a reasonably up-to-date stack; given that it works for people with fairly recent hardware. I would look to the videos themselves and also the flex fork of ffmpeg that's being used. You can always install ffmpeg from negativo and try and encode a video manually with that passing it the vaapi directive. That would atleast narrow it down to flex ffmpeg fork vs video. Yes, I did replace the i965 driver in the directory under flex's control (/usr/lib/flexmediaserver/), but what I didn't do was replace the libva stuffs: # ls -l libav* libva* -rwxr-xr-x 1 root root 1772872 Mar 16 19:12 libavcodec.so.57 -rwxr-xr-x 1 root root 3277696 Mar 16 19:12 libavformat.so.57 -rwxr-xr-x 1 root root 503480 Mar 16 19:12 libavutil.so.55 -rwxr-xr-x 1 root root 7440 Mar 16 19:12 libva-drm.so.2 -rwxr-xr-x 1 root root 162936 Mar 16 19:12 libva.so.2 So I'll replace those as well and see what happens. I'm also going to boot into my osx implementation and try that. If that works, then I know it's not an hardware issue but rather a driver/software one. What is interesting is, since starting this, more people have reported issues with the HW acc transcoding - and they all have Sandy Bridge.
dcrdev 255 Posted April 5, 2018 Author Posted April 5, 2018 Yes, I did replace the i965 driver in the directory under flex's control (/usr/lib/flexmediaserver/), but what I didn't do was replace the libva stuffs: # ls -l libav* libva* -rwxr-xr-x 1 root root 1772872 Mar 16 19:12 libavcodec.so.57 -rwxr-xr-x 1 root root 3277696 Mar 16 19:12 libavformat.so.57 -rwxr-xr-x 1 root root 503480 Mar 16 19:12 libavutil.so.55 -rwxr-xr-x 1 root root 7440 Mar 16 19:12 libva-drm.so.2 -rwxr-xr-x 1 root root 162936 Mar 16 19:12 libva.so.2 So I'll replace those as well and see what happens. I'm also going to boot into my osx implementation and try that. If that works, then I know it's not an hardware issue but rather a driver/software one. What is interesting is, since starting this, more people have reported issues with the HW acc transcoding - and they all have Sandy Bridge. Yeah I think around 5/6th Gen is when vaapi support began to get traction. As I posted above the libva matrix indicates very poor support for Sandybridge.
BeyondEvil 0 Posted April 6, 2018 Posted April 6, 2018 Yeah I think around 5/6th Gen is when vaapi support began to get traction. As I posted above the libva matrix indicates very poor support for Sandybridge. I'm not sure if I've mentioned it, but I have an MacOS installation on the same machine (dual boot) and there it works as expected. So at least it isn't the hardware that is lacking. Next I'm going to try with ffmpeg. Could you point to a good resource for learning? Thanks!
dcrdev 255 Posted April 6, 2018 Author Posted April 6, 2018 I'm not sure if I've mentioned it, but I have an MacOS installation on the same machine (dual boot) and there it works as expected. So at least it isn't the hardware that is lacking. Next I'm going to try with ffmpeg. Could you point to a good resource for learning? Thanks! There's not much to learn really - you just run a single command it'll take a video re-encode it to a specified location and you pass it the vaapi directive to utilise hardware acceleration. If you really want I'll write an example command out when I get home. Alternatively you could always test out Emby as they are packaging the whole graphics stack, if that works without issues you know it's an issue with certain components packaged by flex.
BeyondEvil 0 Posted April 6, 2018 Posted April 6, 2018 (edited) There's not much to learn really - you just run a single command it'll take a video re-encode it to a specified location and you pass it the vaapi directive to utilise hardware acceleration. If you really want I'll write an example command out when I get home. Alternatively you could always test out Emby as they are packaging the whole graphics stack, if that works without issues you know it's an issue with certain components packaged by flex. Ok, I found these two links (same guy) and felt a bit overwhelmed... https://stackoverflow.com/questions/26000606/how-do-you-get-ffmpeg-to-encode-with-vaapi#38133123 https://gist.github.com/Brainiarc7/95c9338a737aa36d9bb2931bed379219 Wow, yes that would be really helpful! Thanks! Yes, I was actually planning on doing that as well, trying out Emby and compare. Edit: So I installed emby and all that. Same issue, horrible graphics with artifacts/tearing. So the question is, even if I managed to get it working manually using FFmpeg - what's the point? I'm just going to go back to the Macos setup. I've done some other upgrades hardware- and network-wise. So hopefully the issues I was having that made me go the CentOS route are gone. If not, I'll try to deal with those issues instead. Edited April 6, 2018 by BeyondEvil
dubconst 0 Posted April 16, 2018 Posted April 16, 2018 RPMS https://repo.dcrdev....ntos.x86_64.rpm https://repo.dcrdev....ntos.x86_64.rpm https://repo.dcrdev....ntos.x86_64.rpm SOURCE RPMS https://repo.dcrdev.....centos.src.rpm https://repo.dcrdev.....centos.src.rpm https://repo.dcrdev.....centos.src.rpm Not one link does not work (404 Not found). Could you please correct it? I have the same problem on 1245v6 and Supermicro board X11SSE-F
useremby 0 Posted March 1, 2023 Posted March 1, 2023 Hi all Need help with vaapi setup on CentOS 7. Hardware HP ProLiant ML310e Gen8 v2 Xeon® E3-1270 v3 8 Gb Ram AMD RX 550 2Gb ILO on board video Software CentOS 7.9 Radeon™ Software for Linux® version 22.40.3 for RHEL 7.9 libva-1.8.3-1.el7.x86_64 libva-utils-1.8.3-4.el7.x86_64 In BIOS HP ProLiant ML310e Gen8 v2 Primary ILO on board video Secondary AMD RX 550 how to better configure the BIOS for video adapters. Which should be primary which secondary. Or maybe some should be disabled. [root@zmserver scripts]# ffmpeg -hwaccels ffmpeg version 3.4.12 Copyright (c) 2000-2022 the FFmpeg developers built with gcc 4.8.5 (GCC) 20150623 (Red Hat 4.8.5-44) configuration: --prefix=/usr --bindir=/usr/bin --datadir=/usr/share/ffmpeg --docdir=/usr/share/doc/ffmpeg --incdir=/usr/include/ffmpeg --libdir=/usr/lib64 --mandir=/usr/share/man --arch=x86_64 --optflags='-O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic' --extra-ldflags='-Wl,-z,relro ' --extra-cflags=' ' --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libvo-amrwbenc --enable-version3 --enable-bzlib --disable-crystalhd --enable-fontconfig --enable-gcrypt --enable-gnutls --enable-ladspa --enable-libass --enable-libbluray --enable-libcdio --enable-libdrm --enable-indev=jack --enable-libfreetype --enable-libfribidi --enable-libgsm --enable-libmp3lame --enable-nvenc --enable-openal --enable-opencl --enable-opengl --enable-libopenjpeg --enable-libopus --disable-encoder=libopus --enable-libpulse --enable-librsvg --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libvorbis --enable-libv4l2 --enable-libvidstab --enable-libvpx --enable-libx264 --enable-libx265 --enable-libxvid --enable-libzvbi --enable-avfilter --enable-avresample --enable-libmodplug --enable-postproc --enable-pthreads --disable-static --enable-shared --enable-gpl --disable-debug --disable-stripping --shlibdir=/usr/lib64 --enable-libmfx --enable-runtime-cpudetect libavutil 55. 78.100 / 55. 78.100 libavcodec 57.107.100 / 57.107.100 libavformat 57. 83.100 / 57. 83.100 libavdevice 57. 10.100 / 57. 10.100 libavfilter 6.107.100 / 6.107.100 libavresample 3. 7. 0 / 3. 7. 0 libswscale 4. 8.100 / 4. 8.100 libswresample 2. 9.100 / 2. 9.100 libpostproc 54. 7.100 / 54. 7.100 Hardware acceleration methods: vdpau qsv vaapi cuvid root@zmserver scripts]# lshw -c display *-display description: VGA compatible controller product: Lexa PRO [Radeon 540/540X/550/550X / RX 540X/550/550X] vendor: Advanced Micro Devices, Inc. [AMD/ATI] physical id: 0 bus info: pci@0000:04:00.0 version: c7 width: 64 bits clock: 33MHz capabilities: pm pciexpress msi vga_controller bus_master cap_list rom configuration: driver=amdgpu latency=0 resources: irq:31 memory:e0000000-efffffff memory:dfe00000-dfffffff ioport:5000(size=256) memory:fbfc0000-fbffffff memory:fbf00000-fbf1ffff *-display description: VGA compatible controller product: MGA G200EH vendor: Matrox Electronics Systems Ltd. physical id: 0.1 bus info: pci@0000:01:00.1 version: 00 width: 32 bits clock: 33MHz capabilities: pm msi pciexpress vga_controller bus_master cap_list rom configuration: driver=mgag200 latency=0 resources: irq:16 memory:9f000000-9fffffff memory:fbde0000-fbde3fff memory:fb000000-fb7fffff [root@zmserver scripts]# lspci -k | grep VGA 01:00.1 VGA compatible controller: Matrox Electronics Systems Ltd. MGA G200EH 04:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Lexa PRO [Radeon 540/540X/550/550X / RX 540X/550/550X] (rev c7) [root@zmserver scripts]# lspci -k 04:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Lexa PRO [Radeon 540/540X/550/550X / RX 540X/550/550X] (rev c7) Subsystem: Hewlett-Packard Company Device 841e Kernel driver in use: amdgpu Kernel modules: amdgpu [root@zmserver ~]# LIBVA_DRIVER_NAME=radeonsi vainfo libva info: VA-API version 0.40.0 libva info: va_getDriverName() returns -1 libva info: User requested driver 'radeonsi' libva info: Trying to open /usr/lib64/dri/radeonsi_drv_video.so libva error: /usr/lib64/dri/radeonsi_drv_video.so has no function __vaDriverInit_0_32 libva error: /usr/lib64/dri/radeonsi_drv_video.so has no function __vaDriverInit_0_32 noting found about this...
Luke 42245 Posted March 1, 2023 Posted March 1, 2023 13 hours ago, useremby said: Hi all Need help with vaapi setup on CentOS 7. Hardware HP ProLiant ML310e Gen8 v2 Xeon® E3-1270 v3 8 Gb Ram AMD RX 550 2Gb ILO on board video Software CentOS 7.9 Radeon™ Software for Linux® version 22.40.3 for RHEL 7.9 libva-1.8.3-1.el7.x86_64 libva-utils-1.8.3-4.el7.x86_64 In BIOS HP ProLiant ML310e Gen8 v2 Primary ILO on board video Secondary AMD RX 550 how to better configure the BIOS for video adapters. Which should be primary which secondary. Or maybe some should be disabled. [root@zmserver scripts]# ffmpeg -hwaccels ffmpeg version 3.4.12 Copyright (c) 2000-2022 the FFmpeg developers built with gcc 4.8.5 (GCC) 20150623 (Red Hat 4.8.5-44) configuration: --prefix=/usr --bindir=/usr/bin --datadir=/usr/share/ffmpeg --docdir=/usr/share/doc/ffmpeg --incdir=/usr/include/ffmpeg --libdir=/usr/lib64 --mandir=/usr/share/man --arch=x86_64 --optflags='-O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic' --extra-ldflags='-Wl,-z,relro ' --extra-cflags=' ' --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libvo-amrwbenc --enable-version3 --enable-bzlib --disable-crystalhd --enable-fontconfig --enable-gcrypt --enable-gnutls --enable-ladspa --enable-libass --enable-libbluray --enable-libcdio --enable-libdrm --enable-indev=jack --enable-libfreetype --enable-libfribidi --enable-libgsm --enable-libmp3lame --enable-nvenc --enable-openal --enable-opencl --enable-opengl --enable-libopenjpeg --enable-libopus --disable-encoder=libopus --enable-libpulse --enable-librsvg --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libvorbis --enable-libv4l2 --enable-libvidstab --enable-libvpx --enable-libx264 --enable-libx265 --enable-libxvid --enable-libzvbi --enable-avfilter --enable-avresample --enable-libmodplug --enable-postproc --enable-pthreads --disable-static --enable-shared --enable-gpl --disable-debug --disable-stripping --shlibdir=/usr/lib64 --enable-libmfx --enable-runtime-cpudetect libavutil 55. 78.100 / 55. 78.100 libavcodec 57.107.100 / 57.107.100 libavformat 57. 83.100 / 57. 83.100 libavdevice 57. 10.100 / 57. 10.100 libavfilter 6.107.100 / 6.107.100 libavresample 3. 7. 0 / 3. 7. 0 libswscale 4. 8.100 / 4. 8.100 libswresample 2. 9.100 / 2. 9.100 libpostproc 54. 7.100 / 54. 7.100 Hardware acceleration methods: vdpau qsv vaapi cuvid root@zmserver scripts]# lshw -c display *-display description: VGA compatible controller product: Lexa PRO [Radeon 540/540X/550/550X / RX 540X/550/550X] vendor: Advanced Micro Devices, Inc. [AMD/ATI] physical id: 0 bus info: pci@0000:04:00.0 version: c7 width: 64 bits clock: 33MHz capabilities: pm pciexpress msi vga_controller bus_master cap_list rom configuration: driver=amdgpu latency=0 resources: irq:31 memory:e0000000-efffffff memory:dfe00000-dfffffff ioport:5000(size=256) memory:fbfc0000-fbffffff memory:fbf00000-fbf1ffff *-display description: VGA compatible controller product: MGA G200EH vendor: Matrox Electronics Systems Ltd. physical id: 0.1 bus info: pci@0000:01:00.1 version: 00 width: 32 bits clock: 33MHz capabilities: pm msi pciexpress vga_controller bus_master cap_list rom configuration: driver=mgag200 latency=0 resources: irq:16 memory:9f000000-9fffffff memory:fbde0000-fbde3fff memory:fb000000-fb7fffff [root@zmserver scripts]# lspci -k | grep VGA 01:00.1 VGA compatible controller: Matrox Electronics Systems Ltd. MGA G200EH 04:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Lexa PRO [Radeon 540/540X/550/550X / RX 540X/550/550X] (rev c7) [root@zmserver scripts]# lspci -k 04:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Lexa PRO [Radeon 540/540X/550/550X / RX 540X/550/550X] (rev c7) Subsystem: Hewlett-Packard Company Device 841e Kernel driver in use: amdgpu Kernel modules: amdgpu [root@zmserver ~]# LIBVA_DRIVER_NAME=radeonsi vainfo libva info: VA-API version 0.40.0 libva info: va_getDriverName() returns -1 libva info: User requested driver 'radeonsi' libva info: Trying to open /usr/lib64/dri/radeonsi_drv_video.so libva error: /usr/lib64/dri/radeonsi_drv_video.so has no function __vaDriverInit_0_32 libva error: /usr/lib64/dri/radeonsi_drv_video.so has no function __vaDriverInit_0_32 noting found about this... Hi, does Emby Server detect any hardware support?
