BillOatman 597 Posted April 9, 2021 Posted April 9, 2021 @Mohammednt0 Pardon the probably stupid question, but are you using xTeVe to pride the channels to Emby?
Mohammednt0 1 Posted April 9, 2021 Posted April 9, 2021 (edited) 9 hours ago, ebr said: Are they transcoding? To have any ideas we'd have to look at a specific example. ffmpeg-transcode-cc13f74e-034b-4b55-8119-2f61faa9f5ca_1.txtembyserver.txt i don't know if they are transcoding, please check the attached files Edited April 10, 2021 by Mohammednt0
Mohammednt0 1 Posted April 9, 2021 Posted April 9, 2021 4 hours ago, BillOatman said: @Mohammednt0 Pardon the probably stupid question, but are you using xTeVe to pride the channels to Emby? no, i'm using a free iptv link, i don't know if it's allowed here to share a free iptv links, if yes i will share it
ebr 16336 Posted April 9, 2021 Posted April 9, 2021 1 hour ago, Mohammednt0 said: i don't know if they are transcoding, please check the attached files Hi. There are no files attached...
Mohammednt0 1 Posted April 10, 2021 Posted April 10, 2021 (edited) 2 hours ago, ebr said: Hi. There are no files attached... sorry embyserver.txt ffmpeg-transcode-cc13f74e-034b-4b55-8119-2f61faa9f5ca_1.txt Edited April 10, 2021 by Mohammednt0
ebr 16336 Posted April 10, 2021 Posted April 10, 2021 Yes, they are transcoding due to the app requesting a very low max bitrate (800kb/s). What do you have set in the app for quality?
Mohammednt0 1 Posted May 23, 2021 Posted May 23, 2021 On 4/10/2021 at 3:50 PM, ebr said: Yes, they are transcoding due to the app requesting a very low max bitrate (800kb/s). What do you have set in the app for quality? I change it to auto, the loading time is faster now but still slow between 25 to 40 seconds to load the channel , when im using iptv app the channel change instantly !
ebr 16336 Posted May 23, 2021 Posted May 23, 2021 5 hours ago, Mohammednt0 said: I change it to auto, the loading time is faster now but still slow between 25 to 40 seconds to load the channel , when im using iptv app the channel change instantly ! Hi. We'd have to look at logs again to see what is happening now but it may still be transcoding.
Mohammednt0 1 Posted May 23, 2021 Posted May 23, 2021 31 minutes ago, ebr said: Hi. We'd have to look at logs again to see what is happening now but it may still be transcoding. check the attached files, waiting for your advise embyserver.txt ffmpeg-directstream-0825d4ee-4029-437b-92d7-3743ef183b27_1.txt ffmpeg-transcode-7eb80c53-806b-4d98-bc54-5171d7432967_1.txt
Luke 42243 Posted June 12, 2021 Posted June 12, 2021 On 5/23/2021 at 9:53 AM, Mohammednt0 said: check the attached files, waiting for your advise embyserver.txt 4.59 MB · 2 downloads ffmpeg-directstream-0825d4ee-4029-437b-92d7-3743ef183b27_1.txt 41.1 kB · 8 downloads ffmpeg-transcode-7eb80c53-806b-4d98-bc54-5171d7432967_1.txt 2.73 MB · 3 downloads @Mohammednt0 are you still having an issue with this?
fantaxp7 191 Posted September 29, 2021 Posted September 29, 2021 Hello, Any updates to channel changing speed? I see ebr mentioning it is fast locally on the Shield which I'd be using however I am curious as to how long it may take outside of that. I had switched from using HD Homeruns to Youtube TV though now they are talking about removing more channels...may have to switch back. Thanks
Luke 42243 Posted September 30, 2021 Posted September 30, 2021 We are working on improving it. Thanks for the feedback.
