don.alcombright 15 Posted August 16, 2017 Author Posted August 16, 2017 I guess it was working, it just seems a bunch of collections aren't being picked up for some reason despite the collection ID existing.
arrbee99 1836 Posted August 16, 2017 Posted August 16, 2017 Guess a developer will help, but in the meantime - its better than it was, its picking up some, but not others ? I presume its picking up movie names correctly, with correct meta data, but not adding to collections ? You didn't set the minimum number of movies for it to count as a collection to high (I set mine to only 2). You can add movies to collections manually but it shouldn't really be necessary. Sorry. Don't think that helped at all actually...
Happy2Play 9814 Posted August 17, 2017 Posted August 17, 2017 Have you looked at the collection.xml to see if it corrupted? Have you ttried deleting the collections in the data/collections folder and allowing them to rebuild. I don't have multiple versions but have done a clean install and all collections were recreated properly on this new install.
Luke 42252 Posted August 17, 2017 Posted August 17, 2017 Thanks @@Happy2Play for trying it out and confirming that.
