Luke 42234 Posted December 3, 2021 Posted December 3, 2021 Universal closed caption support is coming: 2
Luke 42234 Posted August 2, 2025 Posted August 2, 2025 On 11/5/2017 at 11:56 AM, warrentc3 said: I really could use some help on this from someone with more cshell experience. EDIT.... after fighting with this to get it just right for longer than I care to admit... #!/bin/csh set path = ($path /usr/local/bin) set w1 = `jot -r 1 2 15` set filename = `printf "%s " $1:t:r:r` set grab = `printf "%s " $1:h` set a = `echo "$filename".ts` set b = `echo "$grab/$filename"_cut.ts` set c = `echo "$grab/$filename".mp4` sleep $w1 while (1) if ( ! -e "$b" ) then echo "Running Comcut" comcut --ffmpeg=/usr/bin/ffmpeg --comskip=/usr/bin/comskip --lockfile=/tmp/comchap.lock --comskip-ini=/media/Comskip/comskip.ini "$1" "$b" echo "Comcut complete" else echo "Comcut already done" endif break end while (1) if ( ! `pgrep HandBrakeCLI` ) then break endif echo "HandBrakeCLI is still running. Will try again in a minute." sleep 60 end HandBrakeCLI --input "$b" --output "$c" --preset-import-file /media/comchap/hb-dvr.json rm $b mv "$1" "/media/PlexDVR/.plexignore/$a" new ignore features are coming:
