PhilWhite 64 Posted February 17, 2019 Author Posted February 17, 2019 (edited) @@unhooked, Thanks again for all the info. I am reading the Porter's Handbook now and learning C basics and C#. It will take me a while to produce anything, if I can get any part to work, but learning is always worth it. Current plan is to translate comcut to C# and compile in mono. Edited February 17, 2019 by PhilWhite 1
unhooked 17 Posted February 17, 2019 Posted February 17, 2019 @@unhooked, Thanks again for all the info. I am reading the Porter's Handbook now and learning C basics and C#. It will take me a while to produce anything, if I can get any part to work, but learning is always worth it. Current plan is to translate comcut to C# and compile in mono. Yeah, you seem to be enjoying yourself.
PhilWhite 64 Posted February 20, 2019 Author Posted February 20, 2019 (edited) @@unhooked, Quick question. I'm trying to understand everything in the comcut script but I am not completely sure about one of the constructions -- early in the script he uses a case statement and sets pathways to deal with $1. The construction goes: key="$1" case $key in --ffmpeg=*) ffmpegPath="${key#*=} shift ;; I think I understand most of it, but I am not entirely sure of the convention for the variable/parameter expansion of "key." From what I understand, the following #* will cut the smallest part of the expansion in a general way -- which I assume is a way of cutting out the file extension (but maintaining the recording name and entire pathway, which is included in "$1"). But what is the purpose of the = after that? Does it do something else? I've searched for an answer and can't seem to find one easily. The other thing that bothered me about that section is that it is passed through a while loop triggered by the number of arguments passed being greater than 1. Shouldn't that read greater than or equal to 1? It is written: while [[ S# -gt 1 ]] do key="$1" case $key in ..... I was wondering if that might be why I have seen different behavior in the script depending on if an output file is specified. Bash has many ways of removing file extensions it appears. From what I gather, this isn't so easy in C. Basename and dirname exist in C (as you know, I'm sure), but I can't seem to discover if there is a trick, as in shell script, to strip off the extension using backticks and following with the file extension. Does that come into play if you #define _GNU_source? Would something like: char var var = basename($1 .ts) (or path for $1) -- where $1 stand in for the first argument and has a known .ts extension, work in C? I think the answer is 'no' but thought I'd ask anyway. I know I'm not following the proper convention (which I am only learning now), but I hope you understand the idea behind the question. ETA: or maybe never mind with the latter question since strip_ext looks like it will work with a few lines of code. Edited February 21, 2019 by PhilWhite
PhilWhite 64 Posted February 21, 2019 Author Posted February 21, 2019 I do have one thing to report. I have been playing around with comcut because it seemed to act strangely with multiple recordings but only when you specify an outfile -- if you do not specify an outfile it simply overwrites the infile, "$1", with the commercial cuts; and I have yet to see that configuration fail. With multiple recordings ending at the same time the lockfile didn't seem to work very well, and sometimes I would lose one conversion while at other times all the conversions failed. There are a couple of extraneous commands in comcut that are a relic of it being an offshoot of comchap that I deleted, but that is of no real consequence, I think -- just mentioned it if anyone wants to clean up that script. But the while loop for checking on the presence of a lockfile was nested in an if-then statement designed only to send a message that the lockfile is in use. The trigger is the absence of an empty lockfile, while the trigger for locking the processing is the presence of the file. I simply separated the if - then statement from the while loop, un-nested the while statement, and I was able to convert four simultaneous recordings with a specified outfile. I need to see how this repeats, but I don't see why it would fail the way it is set up now. The commercial cutting was poor on two of the programs, but one had a weather advisory ticker at the top of the screen, and that always interferes with the process using the comskip.ini file I use currently. I'm looking into finding a more 'aggressive' option. It's a simple fix that removes the need to use any while-if-then loops in your post-processing script, or the need to create a lockfile in the post-processing script as some have done. But it does require changing the comcut script. I'm not sure how reliable it is yet, though. The other thing is that just as there is a basename command, there is also a dirname command; so it is easier to write the command to maintain the 'head' of the path in the post.sh variables. I changed the directions for my post.sh to reflect that in post #70.
unhooked 17 Posted February 21, 2019 Posted February 21, 2019 (edited) Case reads input, think of it like a nested if/then loop. Historically if was used to create menu scripts for user interaction. But here it's parsing command line arguments. Comcut was written with slower systems in mind, that seems to be the only reason for the lockfile. Just so you don't smoke your system, but if you want to bypass the lock and do multiple runs, just make sure all of those variables are defined so it doesn't clobber the temp files used when it's parsing the ts and spitting out chunks before it reassembles things. Edited February 21, 2019 by unhooked
unhooked 17 Posted February 21, 2019 Posted February 21, 2019 Case reads input, think of it like a nested if/then loop. Historically if was used to create menu scripts for user interaction. But here it's parsing command line arguments. Comcut was written with slower systems in mind, that seems to be the only reason for the lockfile. Just so you don't smoke your system, but if you want to bypass the lock and do multiple runs, just make sure all of those variables are defined so it doesn't clobber the temp files used when it's parsing the ts and spitting out chunks before it reassembles things. I mean, you could probably change the lock file to something like /tmp/$1.lock and then check for the existence of that just to be sure it's not trying to process the same file twice, then go onto running a different job.
PhilWhite 64 Posted February 21, 2019 Author Posted February 21, 2019 (edited) Case reads input, think of it like a nested if/then loop. Historically if was used to create menu scripts for user interaction. But here it's parsing command line arguments. Comcut was written with slower systems in mind, that seems to be the only reason for the lockfile. Just so you don't smoke your system, but if you want to bypass the lock and do multiple runs, just make sure all of those variables are defined so it doesn't clobber the temp files used when it's parsing the ts and spitting out chunks before it reassembles things. Thanks. I'm not sure my system is capable of 4 concurrent runs, but it does seem to handle 3 with no problems. It seems to me as though there is something wrong in the logic since it does not appear to lock down the process. When I have watched the files being generated at least 2 of them progress to the point where all the text files are created and also the edl file is read and different parts of the ts file are created before being reassembled. A third run quickly follows before that whole process is completed, then the fourth gets into the picture a little later (when I have tested with four concurrent recordings). There are no problems with ffmpeg dealing with multiple runs. I was thinking of removing the lockfile from the case statement section next to see how that works. Doesn't hurt to try. ETA: Or is it set up actually to be a lockfile to prevent the same file from being processed again -- each show has its own lockfile, but there is no lockfile for the process as a whole? ETA: Update....watching the lock file, only one instance is created. It looks like comcut is just wicked fast, at least with 30 minute shows. I have done this twice now with four concurrent recordings (all 30 minute to get quicker results) and no failures in the process using a defined outfile. The only change I made was separating an if-then statement from a while loop and it seems to have fixed the issue. Not that I expect anyone to record four programs of equal length at one time, but just in case. It appears there is no need for an extraneous lock file in the post-processing script, but it won't hurt either. With the second set of recordings, even with quick processing, the commercial cutting (even with four concurrent shows) was spot on. Edited February 21, 2019 by PhilWhite
PhilWhite 64 Posted February 27, 2019 Author Posted February 27, 2019 (edited) I've been playing with comcut to learn how it works. Nice script, but some of it is not really necessary when you already know where the supporting programs are located (comskip in /usr/local/bin, etc.), that there will be a an incoming file (since it is only being used in this situation once triggered for post-processing), and that there will not be an empty work-directory. I tried to make it work in csh and now hate it; it works fine does not work in the older Bourne shell, so bash is still needed. Unfortunately this script uses an array twice, and the older Bourne shell does not support the use of arrays. You will have to change the pathways in the script for comskip, comskip.ini, and ffmpeg if they are in a different location. Still learning C, but the only tricky parts (as far as I can tell) are variable expansion and how to read the edl file. I have a means of extracting closed captioning but left the command out of this script. There is a package for ccextractor, so the extraction process is simple. I haven't yet tried remuxing the extracted .srt file in ffmpeg, but that doesn't look difficult either. #!/usr/bin/env bash #LD_LIBRARY_PATH is set and will mess up ffmpeg, unset it, then re-set it when done ldPath=${LD_LIBRARY_PATH} unset LD_LIBRARY_PATH infile=$1 outfile="$infile" comskipdir=${infile%/*} edlfile="${infile%.*}.edl" metafile="${infile%.*}.ffmeta" logfile="${infile%.*}.log" logofile="${infile%.*}.logo.txt" txtfile="${infile%.*}.txt" /usr/local/bin/comskip --output="$comskipdir" --ini=/Comskip/comskip.ini "$infile" start=0 i=0 hascommercials=false concat="" totalcutduration=0 tempfiles=() echo ";FFMETADATA1" > "$metafile" # Reads in from $edlfile, see end of loop. while IFS=$'\t' read -r -a line do end="${line[0]}" startnext="${line[1]}" if [ `echo "$end" | awk '{printf "%i", $0 * 1000}'` -gt `echo "$start" | awk '{printf "%i", $0 * 1000}'` ]; then ((i++)) hascommercials=true echo [CHAPTER] >> "$metafile" echo TIMEBASE=1/1000 >> "$metafile" echo START=`echo "$start $totalcutduration" | awk '{printf "%i", ($1 - $2) * 1000}'` >> "$metafile" echo END=`echo "$end $totalcutduration" | awk '{printf "%i", ($1 - $2) * 1000}'` >> "$metafile" echo "title=Chapter $i" >> "$metafile" chapterfile="${infile%.*}.part-$i.ts" tempfiles+=("$chapterfile") concat="$concat|$chapterfile" duration=`echo "$end" "$start" | awk '{printf "%f", $1 - $2}'` /usr/local/bin/ffmpeg -hide_banner -loglevel error -nostdin -i "$infile" -ss "$start" -t "$duration" -c copy -y "$chapterfile" totalcutduration=`echo "$totalcutduration" "$startnext" "$end" | awk '{print $1 + $2 - $3}'` fi start=$startnext done < "$edlfile" if $hascommercials ; then #dont forget to add the final part from last commercial to end of file end=`/usr/local/bin/ffmpeg -hide_banner -nostdin -i "$infile" 2>&1 | grep Duration | awk '{print $2}' | tr -d , | awk -F: '{ printf "%f", ($1*3600)+($2*60)+$3 }'` if [ `echo "$end" | awk '{printf "%i", $0 * 1000}'` -gt `echo "$start" | awk '{printf "%i", $0 * 1000}'` ]; then ((i++)) echo [CHAPTER] >> "$metafile" echo TIMEBASE=1/1000 >> "$metafile" echo START=`echo "$start $totalcutduration" | awk '{printf "%i", ($1 - $2) * 1000}'` >> "$metafile" echo END=`echo "$end $totalcutduration" | awk '{printf "%i", ($1 - $2) * 1000}'` >> "$metafile" echo "title=Chapter $i" >> "$metafile" chapterfile="${infile%.*}.part-$i.ts" tempfiles+=("$chapterfile") concat="$concat|$chapterfile" duration=`echo "$end" "$start" | awk '{printf "%f", $1 - $2}'` /usr/local/bin/ffmpeg -hide_banner -loglevel error -nostdin -i "$infile" -ss "$start" -t "$duration" -c copy -y "$chapterfile" fi /usr/local/bin/ffmpeg -hide_banner -loglevel error -nostdin -i "$metafile" -i "concat:${concat:1}" -c copy -map_metadata 0 -y "$outfile" fi for i in "${tempfiles[@]}" do rm "$i" done export LD_LIBRARY_PATH="$ldPath" rm "$edlfile" rm "$metafile" rm "$logfile" rm "$logofile" rm "$txtfile" I also have a different post.sh file I am playing with, that only cuts commercials from some recordings and passes on the rest to ffmpeg to convert to mkv. But it isn't working, so need to keep playing with it. ETA: Yeah, ignorant me, grep is for contents inside files, find is for file names -- and file names is what I need -- so I need to search for the right way to use 'find' in this situation. #!bin/sh lockfile="/tmp/post.lock" while [ -f "$lockfile" ]; do echo "Waiting" sleep 5 done touch "$lockfile" show=${1%.*} a=`echo "$show".mkv` /comcut "$1" if [ `echo "$a" | grep -Eqw 'Colbert|Trevor'` ] then break else /usr/local/bin/ffmpeg -i "$1" -vf yadif -c:v libx264 -preset slow -crf 18 -max_muxing_queue_size 1024 -c:a copy "$a" fi mv "$1" /media/ts_archive/ rm "$lockfile" There are several other possible changes. Edited March 2, 2019 by PhilWhite 1
PhilWhite 64 Posted February 27, 2019 Author Posted February 27, 2019 Well, I thought it worked last night, but it hangs up now at tempfiles=() -- get syntax error, bad function name. Will try to figure it out.
unhooked 17 Posted February 28, 2019 Posted February 28, 2019 Well, I thought it worked last night, but it hangs up now at tempfiles=() -- get syntax error, bad function name. Will try to figure it out. tempfiles+= vs tempfiles?
PhilWhite 64 Posted February 28, 2019 Author Posted February 28, 2019 (edited) tempfiles-() ...... then tempfiles+=("$chapterfile") works fine in Bash but not in sh. ETA: actually tempfiles is there to easily remove the chapterfiles when the process is done. It is an array that collects the chapterfiles as they are produced; you then remove them after the process is complete, so removing it is a mistake. Next problem is an error trying to read the edl file. Does -a not exist as an option for 'read' in the Bourne shell? If not, the whole reading setup will have to be changed. In the Bash script things are set up to take advantage of the -a option -- the first line is separated into the two tokens from the edl file and assigned to line[0] and line[1], which are "$end" and "$startnext". I think I see why Brett Sheleski used bash. It's all much easier that way, not that he didn't put a huge amount of effort into this. Very nice script. ETA: OK, so arrays basically don't exist in the Bourne shell (aside from $1, $2, etc), so trying to make this work in the Bourne shell is probably more work than it is worth. On to working with C and C#, which is going to take a much longer time. The only other way around this is to use awk, but I haven't really learned how it works yet; and I'm not sure that will be able to solve the problem. Well, at least, there is an easier way to write comcut in bash for use in this situation (and it is very situation specific). And I found a simpler way to create the directory/showtitle for post sh scripts, which I added to one of the posts above. I am trying out 'case' for directing programs to where I want them to go -- since I have more than one option to choose from. Simple grep statements work well, but the pattern matching in case is more powerful. Edited March 2, 2019 by PhilWhite
PhilWhite 64 Posted March 3, 2019 Author Posted March 3, 2019 (edited) Again, if anyone is interested. this post.sh file actually works (finally) to determine which recordings proceed through conversion to mkv and also moves the completed files that you wish to move to another location of your choosing. Files you do not wish to move will stay in their original folder. So, it basically: cuts commercials from all recordings returns the file (with commercials removed) to its original folder avoids conversion to mkv for selected recordings moves selected recordings after they are converted to mkv to another location so they won't clutter your Recent Recordings This script strips the recording name to its directory name to ease comparison. So, if you record an episode of "Home Improvement", Emby creates a folder "Home Improvement (1991)" with a subfolder for season which then contains the recording. The commands strip away the basename of the show -- say Home Improvement S06E21 Insult to Injury.ts -- and also strips away the Season and the upstream path -- for instance, /media/Recordings. What you are left with is a simpler string to match, and that string is invariable for all instances of that show. If the name is found, you can avoid moving on to the next step -- calling ffmpeg. The latter portion basically does the same thing after the file is converted and moves it if a match is found. You can redirect any number of shows where you want them with this approach. Just add elif [match] then [command] as many times as you want and with whichever shows you want to redirect (just be sure to use the entire name of the directory, including year if it is there). Oh, and I took the lockfile out of my version of comcut and put it in post.sh to better control the work flow. Personally I move shows I don't want to watch soon into a bigger archive with all my old recordings in their own folders, so my mv commands look more like: mv "$a" "./media/Recorded TV/Drunk History/"$d" mv "$a" "./media/Recorded TV/Elementary/"$d" But, I also do not keep tidy files separated into seasons. You could maintain the "season" part of the path by not using `basename "$a"`, for instance; instead, you could use d=${a##*/}, which would create "show directory/season/show name" and then move it where you wish. You can also remove the original .ts file if you convert to mkv, so that you are left with only one recording (if you have experience with it and are comfortable that conversions won't fail). If you want to save a copy of the original recording, the safest path would be to cp "$1" wherever you want before the rest of the script kicks in. ETA: Forgot to mention, you can also add something like: /usr/bin/find ./media/Recordings/ -type f -name "The Big Bang Theory*.nfo" -exec /bin/mv {} "./media/Recorded TV/The Big Bang Theory (2007)/" \; if you want to move the .nfo file. (and replace with .jpg if you want to move the .jpg file) that Emby generates with the recordings, so that you get metadata and picture along with it. You could add commands to move season info and poster if you wish as well. This version uses the Bourne shell; if you want to use csh the commands differ a little. #!/bin/sh lockfile="/tmp/post.lock" while [ -f "$lockfile" ]; do echo "Waiting" sleep 5 done touch "$lockfile" show=${1%.*} a=`echo "$show".mkv` b=${1%/*} c=${b%/*} title=${c##*/} /comcut "$1" if [ "$title" == "I Am the Night" ] then echo "Not for conversion" elif [ "$title" == "The Late Show With Stephen Colbert (2015)" ] then echo "Not for conversion" elif [ "$title" == "Home Improvement (1991)" ] then echo "Not for conversion" else /usr/local/bin/ffmpeg -i "$1" -vf yadif -c:v libx264 -preset slow -crf 18 -max_muxing_queue_size 1024 -c:a copy "$a" fi d=`basename "$a"` if [ "$title" == "The Big Bang Theory (2007)" ] then mv "$a" "./media/ts_archive/$d" fi rm "$lockfile" Edited March 3, 2019 by PhilWhite
PhilWhite 64 Posted March 13, 2019 Author Posted March 13, 2019 OK, I do now have a working form of comcut that does not require bash. I haven't started working on versions in C or C# yet, though. This works in sh. The current version has hard coded paths to ffmpeg, comskip, and comskip.ini, but replacing those with options you can add in your post.sh script is easy to replace. It also does not have a mechanism to keep any of the log files/edl file/ffmetadata file, etc. That is also easy to keep if needed. Since arrays are not available in sh, I had to read the edl file differently and the concatenation step had to be expanded; and it requires a few additional variables. Cleanup had to change as well. But it works. #!/bin/sh PATH=$PATH:/usr/local/bin:/usr/bin #LD_LIBRARY_PATH is set and will mess up ffmpeg, unset it, then re-set it when done ldPath=${LD_LIBRARY_PATH} unset LD_LIBRARY_PATH infile=$1 outfile="$infile" comskipdir=${infile%/*} show="${infile%.*}" edlfile="${show}.edl" metafile="${show}.ffmeta" logfile="${show}.log" logofile="${show}.logo.txt" txtfile="${show}.txt" i=0 start=0 hascommercials=false chapterfile="" totalcutduration=0 temp1="${show}.1.ts" temp2="${show}.2.ts" /usr/local/bin/comskip --output="$comskipdir" --ini=/Comskip/comskip.ini "$infile" echo ";FFMETADATA1" > "$metafile" # Reads in from $edlfile, see end of loop. while IFS=$'\t\n' read -r end startnext c _; do if [ `echo "$end" | awk '{printf "%i", $0 * 1000}'` -gt `echo "$start" | awk '{printf "%i", $0 * 1000}'` ] then i=$((i + 1)) hascommercials=true echo [CHAPTER] >> "$metafile" echo TIMEBASE=1/1000 >> "$metafile" echo START=`echo "$start $totalcutduration" | awk '{printf "%i", ($1 - $2) * 1000}'` >> "$metafile" echo END=`echo "$end $totalcutduration" | awk '{printf "%i", ($1 - $2) * 1000}'` >> "$metafile" echo "title=Chapter $i" >> "$metafile" chapterfile="${infile%.*}.part-$i.ts" duration=`echo "$end" "$start" | awk '{printf "%f", $1 - $2}'` /usr/local/bin/ffmpeg -hide_banner -loglevel error -nostdin -i "$infile" -ss $start -t $duration -c copy -y "$chapterfile" totalcutduration=`echo "$totalcutduration" "$startnext" "$end" | awk '{print $1 + $2 - $3}'` fi start=$startnext done < "$edlfile" #dont forget to add the final part from last commercial to end of file end=`/usr/local/bin/ffmpeg -hide_banner -nostdin -i "$infile" 2>&1 | grep Duration | awk '{print $2}' | tr -d , | awk -F: '{ printf "%f", ($1*3600)+($2*60)+$3 }'` if [ `echo "$end" | awk '{printf "%i", $0 * 1000}'` -gt `echo "$start" | awk '{printf "%i", $0 * 1000}'` ] then i=$((i + 1)) echo [CHAPTER] >> "$metafile" echo START=`echo "$start $totalcutduration" | awk '{printf "%i", ($1 - $2) * 1000}'` >> "$metafile" echo END=`echo "$end $totalcutduration" | awk '{printf "%i", ($1 - $2) * 1000}'` >> "$metafile" echo "title = Chapter $i" >> "$metafile" chapterfile="${show}.part-$i.ts" duration=`echo "$end" "$start" | awk '{printf "%f", $1 - $2}'` /usr/local/bin/ffmpeg -hide_banner -loglevel error -nostdin -i "$infile" -ss $start -t $duration -c copy -y "$chapterfile" fi /usr/local/bin/ffmpeg -hide_banner -loglevel error -nostdin -i "$show.part-1.ts" -c copy -y "$temp1" i=2 while [ -e "$show.part-$i.ts" ] do cp "$temp1" "$temp2" /usr/local/bin/ffmpeg -hide_banner -loglevel error -nostdin -i "concat:$temp2|$show.part-$i.ts" -c copy -y "$temp1" i=$((i + 1)) done /usr/local/bin/ffmpeg -hide_banner -loglevel error -nostdin -i "$metafile" -i "$temp1" -c copy -map_metadata 0 -y "$outfile" export LD_LIBRARY_PATH="$ldPath" rm "$edlfile" rm "$metafile" rm "$logfile" rm "$logofile" rm "$txtfile" rm "$temp1" rm "$temp2" rm "${show}".part-*.ts 1
PhilWhite 64 Posted April 9, 2019 Author Posted April 9, 2019 And here is another version of comcut that works in sh. This uses a function to do most of the work and also uses ffmpeg's concat demuxer method to concatenate the files (which I think is more elegant than the work-around in the previous version). I moved the working directory to /tmp to avoid an issue with the concat demuxer, which I kind of like. This version still uses absolute paths to comskip, ffmpeg and comskip.ini rather than passing along the optional paths from comcut and it also still simply removes the working files at the end rather than providing the option to retain them with an optional command in comcut. #!/bin/sh PATH=$PATH:/usr/local/bin:/usr/bin #LD_LIBRARY_PATH is set and will mess up ffmpeg, unset it, then re-set it when done ldPath=${LD_LIBRARY_PATH} unset LD_LIBRARY_PATH infile=$1 outfile="$infile" show=`basename "$infile"` edlfile="/tmp/${show%.*}.edl" metafile="/tmp/${show%.*}.ffmeta" logfile="/tmp/${show%.*}.log" logofile="/tmp/${show%.*}.logo.txt" txtfile="/tmp/${show%.*}.txt" showfile="/tmp/${show%.*}_a.txt" chapterfile="" i=0 start=0 hascommercials=false totalcutduration=0 writefiles() { echo [CHAPTER] >> "$metafile" echo TIMEBASE=1/1000 >> "$metafile" echo START=`echo "$start $totalcutduration" | awk '{printf "%i", ($1 - $2) * 1000}'` >> "$metafile" echo END=`echo "$end $totalcutduration" | awk '{printf "%i", ($1 - $2) * 1000}'` >> "$metafile" echo "title=Chapter $i" >> "$metafile" printf "file '%s'\n" "$chapterfile" >> "$showfile" duration=`echo "$end" "$start" | awk '{printf "%f", $1 - $2}'` /usr/local/bin/ffmpeg -hide_banner -loglevel error -nostdin -i "$infile" -ss $start -t $duration -c copy -y "$chapterfile" } /usr/local/bin/comskip --output=/tmp --ini=/Comskip/comskip.ini "$infile" echo ";FFMETADATA1" > "$metafile" # Reads in from $edlfile, see end of loop. while IFS=$'\t\n' read -r end startnext c _; do if [ `echo "$end" | awk '{printf "%i", $0 * 1000}'` -gt `echo "$start" | awk '{printf "%i", $0 * 1000}'` ] then i=$((i + 1)) hascommercials=true chapterfile=/tmp/part-$i.ts writefiles $end $start $totalcutduration $i "$metafile" "$chapterfile" "$showfile" totalcutduration=`echo "$totalcutduration" "$startnext" "$end" | awk '{print $1 + $2 - $3}'` fi start=$startnext done < "$edlfile" #dont forget to add the final part from last commercial to end of file if [ $hascommercials=true ] then end=`/usr/local/bin/ffmpeg -hide_banner -nostdin -i "$infile" 2>&1 | grep Duration | awk '{print $2}' | tr -d , | awk -F: '{ printf "%f", ($1*3600)+($2*60)+$3 }'` if [ `echo "$end" | awk '{printf "%i", $0 * 1000}'` -gt `echo "$start" | awk '{printf "%i", $0 * 1000}'` ] then i=$((i + 1)) chapterfile=/tmp/part-$i.ts writefiles $end $start $totalcutduration $i "$metafile" "$chapterfile" "$showfile" fi fi /usr/local/bin/ffmpeg -hide_banner -loglevel error -nostdin -f concat -safe 0 -i "$showfile" -c copy -y "$outfile" export LD_LIBRARY_PATH="$ldPath" rm "$edlfile" rm "$metafile" rm "$logfile" rm "$logofile" rm "$txtfile" rm /tmp/part-*.ts rm "$showfile" 1
Baenwort 119 Posted April 28, 2019 Posted April 28, 2019 So it looks like I may have to redo my entire commercial removal setup as I'm getting little help in resolving an issue with upgrading from 4.0.2.0 to the recently released newer versions. Do you have more instructions for how to use the code you've been posting? Do I just place it in a post.sh and link it in Emby's post process tab?
PhilWhite 64 Posted April 28, 2019 Author Posted April 28, 2019 So it looks like I may have to redo my entire commercial removal setup as I'm getting little help in resolving an issue with upgrading from 4.0.2.0 to the recently released newer versions. Do you have more instructions for how to use the code you've been posting? Do I just place it in a post.sh and link it in Emby's post process tab? Hi Baenwort. Sorry to hear about your problems. I ran into the same or similar issue when I tried to update to 4.0.2.0 in one of my play jails. Turns on and then turns off immediately, probably because I am using chrome also. I can see three options. First is recreate all the steps in the original post, but that would be silly. Second, if you had to delete your jail and start over, would be to use the instructions in post 70 -- which will install all the components to your jail in a few steps. If you still have all the needed bits (comskip, ffmpeg, comskip.ini), then you can certainly try to use this stripped down version of comcut as a post.sh script -- but with a few caveats. It uses direct paths for ffmpeg, comskip and comskip.ini. You can change the paths in the script to suit your needs or ensure that comskip and ffmpeg are in /usr/local/bin and comskip.ini in /Comskip. The relevant line to alter, if needed, is: /usr/local/bin/comskip --output=/tmp --ini=/Comskip/comskip.ini "$infile" and any call to ffmpeg (I think there are three or four). If you want to use it as a post.sh file, then you don't need to make any other changes to it if you want to end up with a .ts file with commercials removed; but I think adding a lock file for safety would be a good idea since I can't vouch for its behavior when multiple recordings end at the same time. For simply cutting commercials it does its job in only a few minutes, though. If you want to convert recordings to .mp4 or .mkv, then you need to add a few other lines. A more complete version would be: #!/bin/sh PATH=$PATH:/usr/local/bin:/usr/bin #LD_LIBRARY_PATH is set and will mess up ffmpeg, unset it, then re-set it when done ldPath=${LD_LIBRARY_PATH} unset LD_LIBRARY_PATH lockfile="/tmp/post.lock" while [ -f "$lockfile" ]; do echo "Waiting" sleep 5 done touch "$lockfile" infile=$1 outfile="$infile" show=`basename "$infile"` edlfile="/tmp/${show%.*}.edl" metafile="/tmp/${show%.*}.ffmeta" logfile="/tmp/${show%.*}.log" logofile="/tmp/${show%.*}.logo.txt" txtfile="/tmp/${show%.*}.txt" showfile="/tmp/${show%.*}_a.txt" chapterfile="" a=${1%.*} b=`echo "$a".mkv` i=0 start=0 hascommercials=false totalcutduration=0 writefiles() { echo [CHAPTER] >> "$metafile" echo TIMEBASE=1/1000 >> "$metafile" echo START=`echo "$start $totalcutduration" | awk '{printf "%i", ($1 - $2) * 1000}'` >> "$metafile" echo END=`echo "$end $totalcutduration" | awk '{printf "%i", ($1 - $2) * 1000}'` >> "$metafile" echo "title=Chapter $i" >> "$metafile" printf "file '%s'\n" "$chapterfile" >> "$showfile" duration=`echo "$end" "$start" | awk '{printf "%f", $1 - $2}'` /usr/local/bin/ffmpeg -hide_banner -loglevel error -nostdin -i "$infile" -ss $start -t $duration -c copy -y "$chapterfile" } /usr/local/bin/comskip --output=/tmp --ini=/Comskip/comskip.ini "$infile" echo ";FFMETADATA1" > "$metafile" # Reads in from $edlfile, see end of loop. while IFS=$'\t\n' read -r end startnext c _; do if [ `echo "$end" | awk '{printf "%i", $0 * 1000}'` -gt `echo "$start" | awk '{printf "%i", $0 * 1000}'` ] then i=$((i + 1)) hascommercials=true chapterfile=/tmp/part-$i.ts writefiles $end $start $totalcutduration $i "$metafile" "$chapterfile" "$showfile" totalcutduration=`echo "$totalcutduration" "$startnext" "$end" | awk '{print $1 + $2 - $3}'` fi start=$startnext done < "$edlfile" #dont forget to add the final part from last commercial to end of file if [ $hascommercials=true ] then end=`/usr/local/bin/ffmpeg -hide_banner -nostdin -i "$infile" 2>&1 | grep Duration | awk '{print $2}' | tr -d , | awk -F: '{ printf "%f", ($1*3600)+($2*60)+$3 }'` if [ `echo "$end" | awk '{printf "%i", $0 * 1000}'` -gt `echo "$start" | awk '{printf "%i", $0 * 1000}'` ] then i=$((i + 1)) chapterfile=/tmp/part-$i.ts writefiles $end $start $totalcutduration $i "$metafile" "$chapterfile" "$showfile" fi fi /usr/local/bin/ffmpeg -hide_banner -loglevel error -nostdin -f concat -safe 0 -i "$showfile" -c copy -y "$outfile" export LD_LIBRARY_PATH="$ldPath" rm "$edlfile" rm "$metafile" rm "$logfile" rm "$logofile" rm "$txtfile" rm /tmp/part-*.ts rm "$showfile" /usr/local/bin/ffmpeg -i "$outfile" -vf yadif -c:v libx264 -preset slow -crf 18 -max_muxing_queue_size 1024 -c:a copy "$b" rm "$lockfile" I haven't tried it as a post.sh file, only from the command line in my tests, but I don't see why it wouldn't work. I hope this helps.
Baenwort 119 Posted April 28, 2019 Posted April 28, 2019 Have you reported your 4.0.2.0 problems to them? They seem to think it is isolated to a few people as their sole tester @@sluggo45 was coming from the beta versions and had no problem. I currently end my post.sh with a handbrake call to re-encode to a .mkv file and then delete the original .ts file so I'd likely need to do the same again or develop a ffmpeg call that performs the same. Right now I encode the video to x264 and copy the audio along with a version that is encoded to AAC stereo and then I strip the subs out to a .srt file. Can all of that be done with a ffmpeg call? I've never directly called ffmpeg but instead worked via Handbrake.
PhilWhite 64 Posted April 28, 2019 Author Posted April 28, 2019 Have you reported your 4.0.2.0 problems to them? They seem to think it is isolated to a few people as their sole tester @@sluggo45 was coming from the beta versions and had no problem. I currently end my post.sh with a handbrake call to re-encode to a .mkv file and then delete the original .ts file so I'd likely need to do the same again or develop a ffmpeg call that performs the same. Right now I encode the video to x264 and copy the audio along with a version that is encoded to AAC stereo and then I strip the subs out to a .srt file. Can all of that be done with a ffmpeg call? I've never directly called ffmpeg but instead worked via Handbrake. Haven't reported it yet because I haven't looked at the logfile yet. I think something important is missing. I may be able to get to that issue in a few days. The ffmpeg call that I use just copies the native audio, so you should be fine with it; and it encodes video to x264 as well, so that should be about the same. Handbrake, it turns out, is just a gui wrapper for ffmpeg, so it's basically the same thing. You could just replace the added ffmpeg call in the above with your usual calls in your old post.sh. It's all about the same. The calls to strip out subtitles to a .srt file would be the same as you currently use. You can do that with ffmpeg (sluggo45 provided an example earlier in the thread) or use another pkg (forgot the name). When I first started playing with it I just used the original comcut script and added my post.sh commands to the end. The only change you would make would be to change "$1" to "$outfile" as input in your Handbrake call. That should replace the .ts file with the new .mkv file (but I haven't paid attention to that for a while so I am not sure it replaces the original recording. If not, then add another command: rm "$1" after you run the conversion and strip the subtitles (and before you release the lock file).
PhilWhite 64 Posted May 9, 2019 Author Posted May 9, 2019 (edited) Last update for a while probably. I created a new script for installing all the needed components (there are two options, the original called package.sh and the new one called package2.sh); it uses the pared-down version of Brett Sheleski's comcut with a call to ffmpeg to convert files to .mkv. You could use this as your post-processing file if you wish; just place it (called post3.sh) in the post-processing section of the DVR in the emby dashboard. I left the package installer script in csh for no particular reason other than laziness. To install, just do the usual -- open a shell in Freenas, then iocage console <jailname>, then cd /, then: fetch -o - https://raw.githubusercontent.com/pawhite/Commercialcut/master/package2.sh | csh And that should install everything. This version removes bash and the need to clone comchap/comcut. Most of the packages that need to be installed are simply there to enable comskip to be compiled and to work. The script looks like this: #!/bin/csh set path = ($path /usr/local/bin) cd / pkg install -y git pkg install -y argtable pkg install -y autoconf pkg install -y automake pkg install -y libtool pkg install -y ffmpeg echo y | pkg set -o devel/pkg-config:devel/pkgconf echo y | pkg install -f devel/pkgconf setenv CC clang /usr/local/bin/git clone https://github.com/erikkaashoek/Comskip fetch https://raw.githubusercontent.com/pawhite/Commercialcut/master/post3.sh chmod +x /post3.sh cd /Comskip ./autogen.sh ./configure make install fetch https://raw.githubusercontent.com/pawhite/Commercialcut/master/comskip.ini and the new post3.sh looks like this: #!/bin/sh PATH=$PATH:/usr/local/bin:/usr/bin #LD_LIBRARY_PATH is set and will mess up ffmpeg, unset it, then re-set it when done ldPath=${LD_LIBRARY_PATH} unset LD_LIBRARY_PATH lockfile="/tmp/post.lock" while [ -f "$lockfile" ]; do echo "Waiting" sleep 5 done touch "$lockfile" infile=$1 outfile="$infile" show=`basename "$infile"` edlfile="/tmp/${show%.*}.edl" metafile="/tmp/${show%.*}.ffmeta" logfile="/tmp/${show%.*}.log" logofile="/tmp/${show%.*}.logo.txt" txtfile="/tmp/${show%.*}.txt" showfile="/tmp/${show%.*}_a.txt" chapterfile="" a="${infile%.*}.mkv" i=0 start=0 hascommercials=false totalcutduration=0 writefiles() { echo [CHAPTER] >> "$metafile" echo TIMEBASE=1/1000 >> "$metafile" echo START=`echo "$start $totalcutduration" | awk '{printf "%i", ($1 - $2) * 1000}'` >> "$metafile" echo END=`echo "$end $totalcutduration" | awk '{printf "%i", ($1 - $2) * 1000}'` >> "$metafile" echo "title=Chapter $i" >> "$metafile" printf "file '%s'\n" "$chapterfile" >> "$showfile" duration=`echo "$end" "$start" | awk '{printf "%f", $1 - $2}'` /usr/local/bin/ffmpeg -hide_banner -loglevel error -nostdin -i "$infile" -ss $start -t $duration -c copy -y "$chapterfile" } /usr/local/bin/comskip --output=/tmp --ini=/Comskip/comskip.ini "$infile" echo ";FFMETADATA1" > "$metafile" # Reads in from $edlfile, see end of loop. while IFS=$'\t\n' read -r end startnext c _; do if [ `echo "$end" | awk '{printf "%i", $0 * 1000}'` -gt `echo "$start" | awk '{printf "%i", $0 * 1000}'` ] then i=$((i + 1)) hascommercials=true chapterfile=/tmp/part-$i.ts writefiles $end $start $totalcutduration $i "$metafile" "$chapterfile" "$showfile" totalcutduration=`echo "$totalcutduration" "$startnext" "$end" | awk '{print $1 + $2 - $3}'` fi start=$startnext done < "$edlfile" #dont forget to add the final part from last commercial to end of file if [ $hascommercials=true ] then end=`/usr/local/bin/ffmpeg -hide_banner -nostdin -i "$infile" 2>&1 | grep Duration | awk '{print $2}' | tr -d , | awk -F: '{ printf "%f", ($1*3600)+($2*60)+$3 }'` if [ `echo "$end" | awk '{printf "%i", $0 * 1000}'` -gt `echo "$start" | awk '{printf "%i", $0 * 1000}'` ] then i=$((i + 1)) chapterfile=/tmp/part-$i.ts writefiles $end $start $totalcutduration $i "$metafile" "$chapterfile" "$showfile" fi fi /usr/local/bin/ffmpeg -hide_banner -loglevel error -nostdin -f concat -safe 0 -i "$showfile" -c copy -y "$outfile" /usr/local/bin/ffmpeg -i "$outfile" -vf yadif -c:v libx264 -preset slow -crf 18 -max_muxing_queue_size 1024 -c:a copy "$a" export LD_LIBRARY_PATH="$ldPath" rm "$edlfile" rm "$metafile" rm "$logfile" rm "$logofile" rm "$txtfile" rm /tmp/part-*.ts rm "$showfile" rm "$lockfile" My post.sh file looks like this now but with added commands to move files around where I want them. You can put whatever commands are in your post.sh file into this option (like a call to Handbrake instead of the last call to ffmpeg) or whatever else you would like. I would simply add them prior to resetting the library path and removing the other files at the end but after the call the ffmpeg to create "outfile". "Outfile" will be the input for ffmpeg or handbrake. You can call the output anything -- this example uses "a" as the variable name. I haven't actually tested this aside from making sure that it installs everything. ETA: OK, tested, and all works. Components installed, cuts commercials and converts to mkv (and removes the original .ts file). Edited May 9, 2019 by PhilWhite 1
Baenwort 119 Posted January 1, 2020 Posted January 1, 2020 (edited) Last update for a while probably. I created a new script for installing all the needed components (there are two options, the original called package.sh and the new one called package2.sh); it uses the pared-down version of Brett Sheleski's comcut with a call to ffmpeg to convert files to .mkv. You could use this as your post-processing file if you wish; just place it (called post3.sh) in the post-processing section of the DVR in the emby dashboard. I left the package installer script in csh for no particular reason other than laziness. To install, just do the usual -- open a shell in Freenas, then iocage console <jailname>, then cd /, then: fetch -o - https://raw.githubusercontent.com/pawhite/Commercialcut/master/package2.sh | csh And that should install everything. This version removes bash and the need to clone comchap/comcut. Most of the packages that need to be installed are simply there to enable comskip to be compiled and to work. The script looks like this: #!/bin/csh set path = ($path /usr/local/bin) cd / pkg install -y git pkg install -y argtable pkg install -y autoconf pkg install -y automake pkg install -y libtool pkg install -y ffmpeg echo y | pkg set -o devel/pkg-config:devel/pkgconf echo y | pkg install -f devel/pkgconf setenv CC clang /usr/local/bin/git clone https://github.com/erikkaashoek/Comskip fetch https://raw.githubusercontent.com/pawhite/Commercialcut/master/post3.sh chmod +x /post3.sh cd /Comskip ./autogen.sh ./configure make install fetch https://raw.githubusercontent.com/pawhite/Commercialcut/master/comskip.ini and the new post3.sh looks like this: #!/bin/sh PATH=$PATH:/usr/local/bin:/usr/bin #LD_LIBRARY_PATH is set and will mess up ffmpeg, unset it, then re-set it when done ldPath=${LD_LIBRARY_PATH} unset LD_LIBRARY_PATH lockfile="/tmp/post.lock" while [ -f "$lockfile" ]; do echo "Waiting" sleep 5 done touch "$lockfile" infile=$1 outfile="$infile" show=`basename "$infile"` edlfile="/tmp/${show%.*}.edl" metafile="/tmp/${show%.*}.ffmeta" logfile="/tmp/${show%.*}.log" logofile="/tmp/${show%.*}.logo.txt" txtfile="/tmp/${show%.*}.txt" showfile="/tmp/${show%.*}_a.txt" chapterfile="" a="${infile%.*}.mkv" i=0 start=0 hascommercials=false totalcutduration=0 writefiles() { echo [CHAPTER] >> "$metafile" echo TIMEBASE=1/1000 >> "$metafile" echo START=`echo "$start $totalcutduration" | awk '{printf "%i", ($1 - $2) * 1000}'` >> "$metafile" echo END=`echo "$end $totalcutduration" | awk '{printf "%i", ($1 - $2) * 1000}'` >> "$metafile" echo "title=Chapter $i" >> "$metafile" printf "file '%s'\n" "$chapterfile" >> "$showfile" duration=`echo "$end" "$start" | awk '{printf "%f", $1 - $2}'` /usr/local/bin/ffmpeg -hide_banner -loglevel error -nostdin -i "$infile" -ss $start -t $duration -c copy -y "$chapterfile" } /usr/local/bin/comskip --output=/tmp --ini=/Comskip/comskip.ini "$infile" echo ";FFMETADATA1" > "$metafile" # Reads in from $edlfile, see end of loop. while IFS=$'\t\n' read -r end startnext c _; do if [ `echo "$end" | awk '{printf "%i", $0 * 1000}'` -gt `echo "$start" | awk '{printf "%i", $0 * 1000}'` ] then i=$((i + 1)) hascommercials=true chapterfile=/tmp/part-$i.ts writefiles $end $start $totalcutduration $i "$metafile" "$chapterfile" "$showfile" totalcutduration=`echo "$totalcutduration" "$startnext" "$end" | awk '{print $1 + $2 - $3}'` fi start=$startnext done < "$edlfile" #dont forget to add the final part from last commercial to end of file if [ $hascommercials=true ] then end=`/usr/local/bin/ffmpeg -hide_banner -nostdin -i "$infile" 2>&1 | grep Duration | awk '{print $2}' | tr -d , | awk -F: '{ printf "%f", ($1*3600)+($2*60)+$3 }'` if [ `echo "$end" | awk '{printf "%i", $0 * 1000}'` -gt `echo "$start" | awk '{printf "%i", $0 * 1000}'` ] then i=$((i + 1)) chapterfile=/tmp/part-$i.ts writefiles $end $start $totalcutduration $i "$metafile" "$chapterfile" "$showfile" fi fi /usr/local/bin/ffmpeg -hide_banner -loglevel error -nostdin -f concat -safe 0 -i "$showfile" -c copy -y "$outfile" /usr/local/bin/ffmpeg -i "$outfile" -vf yadif -c:v libx264 -preset slow -crf 18 -max_muxing_queue_size 1024 -c:a copy "$a" export LD_LIBRARY_PATH="$ldPath" rm "$edlfile" rm "$metafile" rm "$logfile" rm "$logofile" rm "$txtfile" rm /tmp/part-*.ts rm "$showfile" rm "$lockfile" My post.sh file looks like this now but with added commands to move files around where I want them. You can put whatever commands are in your post.sh file into this option (like a call to Handbrake instead of the last call to ffmpeg) or whatever else you would like. I would simply add them prior to resetting the library path and removing the other files at the end but after the call the ffmpeg to create "outfile". "Outfile" will be the input for ffmpeg or handbrake. You can call the output anything -- this example uses "a" as the variable name. I haven't actually tested this aside from making sure that it installs everything. ETA: OK, tested, and all works. Components installed, cuts commercials and converts to mkv (and removes the original .ts file). Thanks for this @@PhilWhite. If I want to switch from cutting the commercials to marking them as chapters so they can be skipped I would install comchap and replace mentions of comcut with comchap? I would use package.sh instead of your newer second one as I don't see a mention of Comcut in version 2 or post3.sh? Also, it looks like in comskip.ini you have a extra line end that breaks line 71 cuttermaran_options="cut=\"true\" unattended=\"true\" muxResult=\"false\" snapToCutPoints=\"true\" closeApp=\"true\"" into two lines. This used to cause a problem in the older version of comskip.ini you started with. I submitted a pull request on git? Edited January 1, 2020 by Baenwort
PhilWhite 64 Posted January 2, 2020 Author Posted January 2, 2020 Thanks for this @@PhilWhite. If I want to switch from cutting the commercials to marking them as chapters so they can be skipped I would install comchap and replace mentions of comcut with comchap? I would use package.sh instead of your newer second one as I don't see a mention of Comcut in version 2 or post3.sh? Also, it looks like in comskip.ini you have a extra line end that breaks line 71 cuttermaran_options="cut=\"true\" unattended=\"true\" muxResult=\"false\" snapToCutPoints=\"true\" closeApp=\"true\"" into two lines. This used to cause a problem in the older version of comskip.ini you started with. I submitted a pull request on git? Hi Baenwort, happy New Year. Yes, if you want to mark commercials and not cut them, then use comchap. This version does not call on comcut because it is my altered version of comcut that does not require bash to run. I was trying to pare down the number of dependencies to set this up. I'll have to look at comskip.ini, thanks.
Baenwort 119 Posted January 4, 2020 Posted January 4, 2020 (edited) Hi Baenwort, happy New Year. Yes, if you want to mark commercials and not cut them, then use comchap. This version does not call on comcut because it is my altered version of comcut that does not require bash to run. I was trying to pare down the number of dependencies to set this up. I'll have to look at comskip.ini, thanks. I've also run into a problem with your closing rm "/tmp/part-*.ts" does not work when executed from the script. When I run it manually from the shell it works correctly but when using the post3.sh it throws an error about the /tmp/part-*.ts which is odd to me as I've never run across a command that works in the CLI but doesn't when placed in a .sh and run that way. My solution is to replace it with a looping if statement that rolls backwards from the $i variable you used in the merging of the part files and exits when $i is no longer greater than 0. Edited January 4, 2020 by Baenwort
PhilWhite 64 Posted January 4, 2020 Author Posted January 4, 2020 I've also run into a problem with your closing rm "/tmp/part-*.ts" does not work when executed from the script. When I run it manually from the shell it works correctly but when using the post3.sh it throws an error about the /tmp/part-*.ts which is odd to me as I've never run across a command that works in the CLI but doesn't when placed in a .sh and run that way. My solution is to replace it with a looping if statement that rolls backwards from the $i variable you used in the merging of the part files and exits when $i is no longer greater than 0. Good solution. Not sure why that throws an error. I've not seen one, and it removes all those files, which is why I left it in that form. Might be best to switch to the loop, though, since it caused an error on your system. My youngest has been learning C# for work, so I might get her to translate this to C#. I got bogged down learning C and lost interest, I'm afraid.
Baenwort 119 Posted January 18, 2020 Posted January 18, 2020 So I had my first failed encode last night. The commercial cutting was successful but the encoding to 264 failed. However, there is no escape from the clean up at the bottom if ffmpeg or handbrake throw an error. This resulted in the .ts being discarded and the failed (1/4 size) mp4 file being left behind. root@emby_2:/ # sh post3.sh "/media/Visual/TV Shows/Recorded/Mystery Science Theater 3000 (1987)/Season 4/Mystery Science Theater 3000 S04E04 Teenagers From Outer Space.ts" Comskip 0.82.010, made using ffmpeg Donator build The commandline used was: /usr/local/bin/comskip --output=/tmp --ini=/Comskip/comskip.ini "/media/Visual/TV Shows/Recorded/Mystery Science Theater 3000 (1987)/Season 4/Mystery Science Theater 3000 S04E04 Teenagers From Outer Space.ts" Setting ini file to /Comskip/comskip.ini as per commandline Using /Comskip/comskip.ini for initiation values. Mpeg: /media/Visual/TV Shows/Recorded/Mystery Science Theater 3000 (1987)/Season 4/Mystery Science Theater 3000 S04E04 Teenagers From Outer Space.ts Exe comskip.exe Logo: /tmp/Mystery Science Theater 3000 S04E04 Teenagers From Outer Space.logo.txt Ini: /Comskip/comskip.ini Detection Methods to be used: 1) Black Frame 2) Logo - Give up after 2000 seconds 3) Resolution Change 4) Aspect Ratio ComSkip throttles back from -0001 to -0001. The time is now 0022 so it's full speed ahead! Settings -------- [Main Settings] ;the sum of the values for which kind of frames comskip will consider as possible cutpoints: 1=uniform (black or any other color) frame, 2=logo, 4=scene change, 8=resolution change, 16=closed captions, 32=aspect ration, 64=silence, 255=all. detect_method=43 ;Set to 10 to show a lot of extra info, level 5 is also OK, set to 0 to disable verbose=10 ;Frame not black if any of the pixels of the frame has a brightness greater than this (scale 0 to 255) max_brightness=60 maxbright=1 ;Frame not pure black if a small number of the pixels of the frame has a brightness greater than this. To decide if the frame is truly black, comskip will also check average brightness (scale 0 to 255) test_brightness=40 ; max_avg_brightness=25 ; max_commercialbreak=600 ; min_commercialbreak=25 ; max_commercial_size=125 ; min_commercial_size=4 ; min_show_segment_length=250 ; max_volume=0 ; max_silence=100 ; non_uniformity=500 [Detailed Settings] min_silence=12 remove_silent_segments=0 noise_level=5 brightness_jump=200 fps=1 validate_silence=1 validate_uniform=1 validate_scenechange=1 global_threshold=1.05 disable_heuristics=4 cut_on_ac_change=1 [CPU Load Reduction] thread_count=2 hardware_decode=0 play_nice_start=-1 play_nice_end=-1 play_nice_sleep=2 [Input Correction] max_repair_size=200 ms_audio_delay=5 volume_slip=40 lowres=0 skip_b_frames=0 [Aspect Ratio] ar_delta=0.08 cut_on_ar_change=1 [Global Removes] padding=0 remove_before=0 remove_after=0 added_recording=14 delete_show_after_last_commercial=0 delete_show_before_first_commercial=0 delete_show_before_or_after_current=0 delete_block_after_commercial=0 min_commercial_break_at_start_or_end=39 always_keep_first_seconds=0 always_keep_last_seconds=0 [USA Specific] intelligent_brightness=1 black_percentile=0.0076 uniform_percentile=0.003 score_percentile=0.71 [Main Scoring] length_strict_modifier=3 length_nonstrict_modifier=1.5 combined_length_strict_modifier=2 combined_length_nonstrict_modifier=1.25 ar_wrong_modifier=2 ac_wrong_modifier=1 excessive_length_modifier=0.01 dark_block_modifier=0.3 min_schange_modifier=0.5 max_schange_modifier=2 logo_present_modifier=0.01 punish_no_logo=1 [Detailed Scoring] punish=0 reward=0 punish_threshold=1.3 punish_modifier=2 reward_modifier=0.5 [Logo Finding] border=10 give_up_logo_search=2000 delay_logo_search=0 logo_max_percentage_of_screen=0.12 ticker_tape=0 ticker_tape_percentage=0 top_ticker_tape=0 top_ticker_tape_percentage=0 ignore_side=0 ignore_left_side=0 ignore_right_side=0 subtitles=0 logo_at_bottom=0 logo_threshold=0.75 logo_percentage_threshold=0.25 logo_filter=0 aggressive_logo_rejection=0 edge_level_threshold=5 edge_radius=2 edge_weight=10 edge_step=1 num_logo_buffers=50 use_existing_logo_file=1 two_pass_logo=1 [Logo Interpretation] connect_blocks_with_logo=1 logo_percentile=0.92 logo_fraction=0.4 shrink_logo=5 shrink_logo_tail=0 before_logo=0 after_logo=0 where_logo=0 min_black_frames_for_break=1 [Closed Captioning] ccCheck=0 cc_commercial_type_modifier=4 cc_wrong_type_modifier=2 cc_correct_type_modifier=0.75 [Live TV] live_tv=0 live_tv_retries=4 require_div5=0 div5_tolerance=-1 incommercial_frames=1000 [Output Control] output_default=1 output_chapters=0 output_plist_cutlist=0 output_zoomplayer_cutlist=0 output_zoomplayer_chapter=0 output_scf=0 output_vcf=0 output_vdr=0 output_projectx=0 output_avisynth=0 output_videoredo=0 output_videoredo3=0 videoredo_offset=2 output_btv=0 output_edl=1 output_live=0 edl_offset=0 timeline_repair=1 edl_skip_field=0 output_edlp=0 output_bsplayer=0 output_edlx=0 output_cuttermaran=0 output_mpeg2schnitt=0 output_womble=0 output_mls=0 output_mpgtx=0 output_dvrmstb=0 output_dvrcut=0 output_ipodchap=0 output_framearray=0 output_debugwindow=0 output_tuning=0 output_training=0 output_false=0 output_aspect=0 output_demux=0 output_data=0 output_srt=0 output_smi=0 output_timing=0 output_incommercial=0 output_ffmeta=0 output_ffsplit=0 delete_logo_file=0 output_mkvtoolnix=0 cutscene_frame=0 cutscene_threshold=10 windowtitle="Comskip - %s" cuttermaran_options="cut=\"true\" unattended=\"true\" muxResult=\"false\" snapToCutPoints=\"true\" closeApp=\"true\"" mpeg2schnitt_options="mpeg2schnitt.exe /S /E /R25 /Z %2 %1" avisynth_options="LoadPlugin(\"MPEG2Dec3.dll\") \nMPEG2Source(\"%s\")\n" dvrcut_options="dvrcut \"%s.dvr-ms\" \"%s_clean.dvr-ms\" " [Sage Workarounds] sage_framenumber_bug=0 sage_minute_bug=0 enable_mencoder_pts=0 Input #0, mpegts, from '/media/Visual/TV Shows/Recorded/Mystery Science Theater 3000 (1987)/Season 4/Mystery Science Theater 3000 S04E04 Teenagers From Outer Space.ts': Duration: 01:30:39.66, start: 1.400000, bitrate: 2158 kb/s Program 1 Metadata: service_name : Service01 service_provider: FFmpeg Stream #0:0[0x100]: Video: mpeg2video (Main) ([2][0][0][0] / 0x0002), yuv420p(tv, top first), 704x480 [SAR 40:33 DAR 16:9], Closed Captions, 29.97 fps, 29.97 tbr, 90k tbn, 59.94 tbc Stream #0:1[0x101](eng): Audio: ac3 ([129][0][0][0] / 0x0081), 48000 Hz, stereo, fltp, 192 kb/s [mpeg2video @ 0x80ac16500] gray decoding requested but not enabled at configuration time Frame Rate set to 29.970 f/s Initial audio pts = 0.000 Format changed to [704 : 480] Frame: 1 Ratio: 1.16 MinY: 1 MaxY: 480 MinX: 86 MaxX: 618 Frame: 1 Channels: 2 Resizing scene change array to accomodate 2000 frames. Looking For Logo in frames 29 to 1450. Edge count - 3128 Percentage of screen - 1.11%, Check: 0 Double checking - 1 Looking For Logo in frames 58 to 1479. Edge count - 3130 Percentage of screen - 1.11%, Check: 1 Double checking - 2 Doublechecking frames 58 to 1479 for logo. 78901234567890123456789012345678901234567890123456789012345678901234567890123 369: 370: 371: 372: 373: -- 374: -+ -- 375: ||++ | ----- 376: ||++||| ++-+--- ---- 377: ||++||| |++++++++ ------- -- 378: |||||| |++++++++++| +-++++++ ----- - 379: ||||||||++++--++++|+++++++++| |-+--- ----- 380: ||||||||++++--++++|++++-+++++||++++++||-+--- ------- 381: ||||||||++|-++++++|+++---++++|++++++||+++++++|-++-+--- -------- 382: |||||||||||-+++||+|++|-+--|++|++||+++|++++++|+++++++++++--------- 383: |||||||||||-++|++|+++|+++++++|+||||++++|+++||++++--+++++++----+--- 384: |||||||||||++|+++|||||++-|||||||||||+|++|||||++++---++++++-----+++|| 385: ||||||||||||++||++||||+++||||||||||||||||||||+|||-++++++++----++++|| 386: ||||||||||||||++-+||||||||||||||||||++||||||||||| ++-++++-||||++++| 387: ||||||||||||||+++-+|||||++||||||||||||+|| |||||||||++++++++||||+++|| 388: ||||||||||||||+++++|||||||||| ||||| | +|| ||||||||||+----++||||+++| 389: ||||||||||||||+--++||||||||||||||||||-||| |||||||||++- -++||||+++ 390: ||||||||||||||+--+|||||||||||||||||-|||||-|||||||||++- ||||||||+| 391: ||||||||||||||| |||||||||||||||||-|||+|+|||||||| +++|| ||||||||| 392: ||||||||||||||| |||||||||||||||||++ - |+|||||||| ++++||||||||||| 393: ||||||||||||||| ||||||||||||||||||||| -|||||||||| +++|||||||||||| 394: ||||||||||||||| |||||||||||||||||||+|-- ||||||||||+++|||||||||||| 395: ||||||||||||||| |||||||||||||||||||||++ ||||||||||+++ |||||||||| 396: |||||||||||||| -++|||||||||||||||||+|+||||||||||||+++ |||||||||| 397: |||||||||||||||--++|||||||||||||||||+||||||||||||||++| |||||||||| 398: ||||||||||||||+-+++|||||||||||||||||||||||||||||||||| ||||||||| 399: ||||||||||||||+++++||||||||||||||||||||||||||||||||++--- ||||||||| 400: ||||||||||||||+++++||||++||+||||||| ||||||||||||||+++---|||||||||| 401: ||||||||||||+++++++||||+++||+|||||||||||||||||||||++++++|||||+++|| 402: |||||||||||++++|||||||++++|+||||||||||||||||||||+---+++|||||+++|| 403: |||||||||||+++++++||+|--- +++||||| | ++||+++||||+---+-+|||+++++|| 404: |||||||||+++---+++|||-+--++++|||+++| ++| |+++|+++--++++|||++++++- 405: |||||||||||++--++++|++++++++++||||-+++-++-+++|+++---++++|+++++++--- 406: ||||||||++||++-++++|+||-++++++|+++++++++++++++++++--++++-------+-+ | 407: ||||||||+|++||++++|+++++-++++||+++++---+-+-- ------------+-+|---+++|| 408: ||||||||++++++++++ +++++++++ --- ---------------+++-++-------+++|| 409: ||||||| +++++++++ ++++--+ ------------++++++++++-----++++++++++ 410: ||||||| |+++-+||| ----------------++++++++------+++-++---+------ 411: ||||||| -------------------++-++++++--------+++++--------------- 412: |||||++|-- --------------+-++-+----++-+++++--+------------ 413: |||+|+++-----+-+++++++++----+++++++++------------ - 414: |||+|+++--+++++++----+++-++++++++------------ 415: ||+++++-++-----++++++++------------- 416: |++++-+-++++----------------- 417: +++-+-------------- 418: ------------ 419: ------ 420: 421: 422: 423: Logo found at frame 1479 logoMinX=497 logoMaxX=573 logoMinY=369 logoMaxY=423 ******************* End of Logo Processing *************** Frame: 1 Ratio: 1.16 MinY: 1 MaxY: 480 MinX: 86 MaxX: 618 Frame: 1 Channels: 2 0:00:02 - 1552 frames in 1.00 sStart logo cblock 000 seframe 290 fps), 0% Frame 3438 (114.648s) - Black frame with brightness of 16,uniform of 0 and volume of -737987527 Frame 3439 (114.681s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 3440 (114.715s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 3441 (114.748s) - Black frame with brightness of 18,uniform of 1298 and volume of -1 End logo block 0 frame 3302 Length - 0:01:44.23 Strange video pts step of 1.43974 instead of 0.03337 at frame 3529 Frame 3551 (120.044s) - Black frame with brightness of 16,uniform of 0 and volume of 2898 Frame 3552 (120.078s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 3553 (120.112s) - Black frame with brightness of 19,uniform of 733 and volume of -1 Nonlogo Length - 0:00:11.44 Start logo cblock 1 frame 3596 Frame 27070 (917.048s) - Black frame with brightness of 16,uniform of 0 and volume of 726 Frame 27071 (917.081s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 27072 (917.115s) - Black frame with brightness of 21,uniform of 2683 and volume of -1 End logo block 1 frame 26937 Length - 0:13:06.01 Strange video pts step of 1.03168 instead of 0.03337 at frame 27151 Frame: 27151 Ratio: 1.47 MinY: 1 MaxY: 480 MinX: 1 MaxX: 704 Frame 27188 (922.013s) - Black frame with brightness of 16,uniform of 0 and volume of 776 Frame 27189 (922.046s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 27190 (922.080s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 27191 (922.113s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 27192 (922.146s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 27193 (922.180s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 27194 (922.213s) - Black frame with brightness of 17,uniform of 825 and volume of -1 Nonlogo Length - 0:00:10.90 Start logo cblock 2 frame 27231 Frame 33455 (1131.122s) - Black frame with brightness of 20,uniform of 2308 and volume of 2801 Frame 33456 (1131.156s) - Black frame with brightness of 20,uniform of 1666 and volume of -1 Frame 33457 (1131.189s) - Black frame with brightness of 19,uniform of 827 and volume of -1 Frame 33458 (1131.222s) - Black frame with brightness of 17,uniform of 252 and volume of -1 Frame 33459 (1131.256s) - Black frame with brightness of 17,uniform of 57 and volume of -1 Frame 33460 (1131.289s) - Black frame with brightness of 16,uniform of 19 and volume of -1 Frame 33461 (1131.322s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 33462 (1131.356s) - Black frame with brightness of 16,uniform of 5 and volume of -1 Frame 33463 (1131.389s) - Black frame with brightness of 16,uniform of 1 and volume of -1 Frame 33464 (1131.423s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 33465 (1131.456s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 33466 (1131.489s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 33467 (1131.523s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 33468 (1131.556s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 33469 (1131.589s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 33470 (1131.623s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 33471 (1131.656s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 33472 (1131.690s) - Black frame with brightness of 16,uniform of 74 and volume of -1 Frame 33473 (1131.723s) - Black frame with brightness of 16,uniform of 24 and volume of -1 Frame 33474 (1131.756s) - Black frame with brightness of 16,uniform of 8 and volume of -1 Frame 33475 (1131.790s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 33476 (1131.823s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 33477 (1131.856s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 33478 (1131.890s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 33479 (1131.923s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 33480 (1131.956s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 33481 (1131.990s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 33482 (1132.023s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 33483 (1132.057s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 33484 (1132.090s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 33485 (1132.123s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 33486 (1132.157s) - Black frame with brightness of 16,uniform of 1 and volume of -1 Frame 33487 (1132.190s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 33488 (1132.223s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 33489 (1132.257s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 33490 (1132.290s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 33491 (1132.323s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 33492 (1132.357s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 33493 (1132.390s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 33494 (1132.424s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 33495 (1132.457s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 33496 (1132.490s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 33497 (1132.524s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 33498 (1132.557s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 33499 (1132.590s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 33500 (1132.624s) - Black frame with brightness of 16,uniform of 6 and volume of -1 Frame 33501 (1132.657s) - Black frame with brightness of 16,uniform of 43 and volume of -1 Frame 33502 (1132.691s) - Black frame with brightness of 16,uniform of 217 and volume of -1 Frame: 421571646Ratio: 1.1120.80MinY: 10MaxY: 480, 1.00 MinX: 88.00 fps)MaxX: 616 Frame 45775 (1542.200s) - Black frame with brightness of 16,uniform of 0 and volume of 591 Frame 45776 (1542.233s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 45777 (1542.266s) - Black frame with brightness of 18,uniform of 1358 and volume of -1 End logo block 2 frame 45642 Length - 0:10:09.34 Frame: 45866 Ratio: 1.47 MinY: 1 MaxY: 480 MinX: 1 MaxX: 704 Frame 45920 (1547.480s) - Black frame with brightness of 16,uniform of 0 and volume of 508 Frame 45921 (1547.514s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 45922 (1547.547s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 45923 (1547.581s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 45924 (1547.614s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 45925 (1547.648s) - Black frame with brightness of 22,uniform of 3441 and volume of -1 0:25:42 - 47694 frames in 23.77 sec(2006.48 fps), 1.00 sec(1912.00 fps), 28% Nonlogo Length - 0:00:11.22 Start logo cblock 3 frame 45965 Strange video pts step of 2.30561 instead of 0.03337 at frame 62701 fps), 37% Frame 62702 (2107.441s) - Black frame with brightness of 16,uniform of 0 and volume of 3012 Frame 62703 (2109.747s) - Black frame with brightness of 16,uniform of 1 and volume of -1 Frame 62704 (2109.786s) - Black frame with brightness of 23,uniform of 2490 and volume of -1 End logo block 3 frame 62549 Length - 0:09:08.38 Nonlogo Length - 0:00:09.23 Start logo cblock 4 frame 62756 Frame 77020 (2588.993s) - Black frame with brightness of 16,uniform of 0 and volume of 1135 Frame 77021 (2589.027s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 77022 (2589.060s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 77023 (2589.094s) - Black frame with brightness of 17,uniform of 848 and volume of -1 End logo block 4 frame 76846 Length - 0:07:45.16 Frame: 77026 Ratio: 1.12 MinY: 1 MaxY: 480 MinX: 86 MaxX: 620 Nonlogo Length - 0:00:08.38 Start logo cblock 5 frame 77053 Frame 80052 (2690.163s) - Black frame with brightness of 20,uniform of 1587 and volume of 1419 Frame 87980 (2959.866s) - Black frame with brightness of 16,uniform of 0 and volume of 1345 Frame 87981 (2959.899s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 87982 (2959.933s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 87983 (2959.966s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 87984 (2960.000s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 87985 (2960.033s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 87986 (2960.066s) - Black frame with brightness of 16,uniform of 0 and volume of -1 End logo block 5 frame 87808 Length - 0:05:59.05 Frame 87987 (2960.100s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 87988 (2960.133s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 87989 (2960.166s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 87990 (2960.200s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 87991 (2960.233s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 87992 (2960.266s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 87993 (2960.300s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 87994 (2960.333s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 87995 (2960.367s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 87996 (2960.400s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 87997 (2960.433s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 87998 (2960.467s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 87999 (2960.500s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 88000 (2960.533s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 88001 (2960.567s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 88002 (2960.600s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 88003 (2960.633s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 88004 (2960.667s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 88005 (2960.700s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 88006 (2960.734s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 88007 (2960.767s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 88008 (2960.800s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 88009 (2960.834s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 88010 (2960.867s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 88011 (2960.900s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 88012 (2960.934s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 88013 (2960.967s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 88014 (2961.001s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 88015 (2961.034s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 88016 (2961.067s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 88017 (2961.101s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 88018 (2961.134s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 88019 (2961.167s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 88020 (2961.201s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 88021 (2961.234s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 88031 (2961.568s) - Black frame with brightness of 16,uniform of 0 and volume of 1699 Frame 88032 (2961.601s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 88033 (2961.634s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Nonlogo Length - 0:00:07.87 Start logo cblock 6 frame 88044 Frame 92984 (3127.734s) - Black frame with brightness of 21,uniform of 3043 and volume of 1000 Frame 92985 (3127.767s) - Black frame with brightness of 17,uniform of 476 and volume of -1 Frame 92986 (3127.800s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 92987 (3127.834s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 92988 (3127.867s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 92989 (3127.901s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 92990 (3127.934s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 92991 (3127.967s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 92992 (3128.001s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 92993 (3128.034s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 92994 (3128.067s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 92995 (3128.101s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 92996 (3128.134s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 92997 (3128.168s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 92998 (3128.201s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 92999 (3128.234s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 93000 (3128.268s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 93001 (3128.301s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 93002 (3128.334s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 93003 (3128.368s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 93004 (3128.401s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 93005 (3128.434s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 93006 (3128.468s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 93007 (3128.501s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 93008 (3128.535s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 93009 (3128.568s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 93010 (3128.601s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 93011 (3128.635s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 93012 (3128.668s) - Black frame with brightness of 21,uniform of 2106 and volume of -1 Resizing scene change array to accomodate 4000 frames.00 sec(2127.00 fps), 63% Resizing frame array to accomodate 197893 frames.), 1.00 sec(1976.00 fps), 64% Frame 108065 (3630.936s) - Black frame with brightness of 16,uniform of 0 and volume of 649 Frame 108066 (3630.970s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 108067 (3631.003s) - Black frame with brightness of 22,uniform of 1809 and volume of -1 End logo block 6 frame 107934 Length - 0:10:59.59 Strange video pts step of 2.19622 instead of 0.03337 at frame 108130 Frame 108133 (3635.374s) - Black frame with brightness of 16,uniform of 0 and volume of 461 Frame 108134 (3635.413s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 108135 (3635.451s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 108136 (3635.489s) - Black frame with brightness of 17,uniform of 881 and volume of -1 Frame 108137 (3635.526s) - Black frame with brightness of 22,uniform of 3330 and volume of -1 Nonlogo Length - 0:00:10.09 Start logo cblock 7 frame 108170 Frame: 119599036Ratio: 0.00 60.4MinY: 3492.12 fpMaxY: 448sec(1964.00 fps), 72% Frame: 121321235Ratio: 1.10 61.4MinY: 19MaxY: 480), 1.00MinX: 882.00 fpsMaxX: 616 1:09:30 - 126468 frames in 63.42 sec(1994.13 fps), 1.00 sec(2034.00 fps), 76% End logo block 7 frame 125972 Length - 0:09:49.02 Frame 126158 (4237.971s) - Black frame with brightness of 16,uniform of 0 and volume of 345 Frame 126159 (4238.004s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 126160 (4238.037s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 126161 (4238.071s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 126162 (4238.104s) - Black frame with brightness of 22,uniform of 3858 and volume of -1 Nonlogo Length - 0:00:08.98 Start logo cblock 8 frame 126208 Frame: 138460863Ratio: 0.00 69.4MinY: 1897.10 fpMaxY: 450sec(2161.00 fps), 84% Frame 138857 (4661.694s) - Black frame with brightness of 16,uniform of 0 and volume of 1973 Frame 138858 (4661.727s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 138859 (4661.761s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 138860 (4661.794s) - Black frame with brightness of 18,uniform of 927 and volume of -1 End logo block 8 frame 138703 Length - 0:06:51.94 Strange video pts step of 1.30094 instead of 0.03337 at frame 138936 Frame: 138937 Ratio: 1.47 MinY: 1 MaxY: 480 MinX: 1 MaxX: 704 Frame 138964 (4666.560s) - Black frame with brightness of 16,uniform of 0 and volume of 151 Frame 138965 (4666.593s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 138966 (4666.627s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 138967 (4666.660s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 138968 (4666.694s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 138969 (4666.727s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 138970 (4666.761s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 138971 (4666.794s) - Black frame with brightness of 18,uniform of 1311 and volume of -1 Frame 138972 (4666.828s) - Black frame with brightness of 22,uniform of 5511 and volume of -1 1:17:23 - 140647 frames in 70.42 sec(1997.26 fps), 1.00 sec(2008.00 fps), 85% Nonlogo Length - 0:00:12.07 Start logo cblock 9 frame 139026 Frame 152193 (5109.671s) - Black frame with brightness of 23,uniform of 2864 and volume of 1916 Frame: 154502594Ratio: 1.10 77.4MinY: 10MaxY: 480), 1.00MinX: 905.00 fpsMaxX: 618 Frame 159993 (5370.331s) - Black frame with brightness of 16,uniform of 455 and volume of 1331 Frame 159994 (5370.365s) - Black frame with brightness of 16,uniform of 271 and volume of -1 Frame 159995 (5370.398s) - Black frame with brightness of 16,uniform of 145 and volume of -1 Frame 159996 (5370.432s) - Black frame with brightness of 16,uniform of 60 and volume of -1 Frame 159997 (5370.465s) - Black frame with brightness of 16,uniform of 22 and volume of -1 Frame 159998 (5370.498s) - Black frame with brightness of 16,uniform of 22 and volume of -1 Frame 159999 (5370.532s) - Black frame with brightness of 16,uniform of 22 and volume of -1 Frame 160000 (5370.565s) - Black frame with brightness of 16,uniform of 21 and volume of -1 Frame 160001 (5370.598s) - Black frame with brightness of 16,uniform of 22 and volume of -1 Frame 160002 (5370.632s) - Black frame with brightness of 16,uniform of 20 and volume of -1 Frame 160003 (5370.665s) - Black frame with brightness of 16,uniform of 20 and volume of -1 Frame 160004 (5370.698s) - Black frame with brightness of 16,uniform of 19 and volume of -1 Frame 160005 (5370.732s) - Black frame with brightness of 16,uniform of 18 and volume of -1 Frame 160006 (5370.765s) - Black frame with brightness of 16,uniform of 18 and volume of -1 Frame 160007 (5370.799s) - Black frame with brightness of 16,uniform of 17 and volume of -1 Frame 160008 (5370.832s) - Black frame with brightness of 16,uniform of 16 and volume of -1 Frame 160009 (5370.865s) - Black frame with brightness of 16,uniform of 16 and volume of -1 Frame 160010 (5370.899s) - Black frame with brightness of 16,uniform of 15 and volume of -1 Frame 160011 (5370.932s) - Black frame with brightness of 16,uniform of 15 and volume of -1 Frame 160012 (5370.965s) - Black frame with brightness of 16,uniform of 13 and volume of -1 Frame 160013 (5370.999s) - Black frame with brightness of 16,uniform of 14 and volume of -1 Frame 160014 (5371.032s) - Black frame with brightness of 16,uniform of 13 and volume of -1 Frame 160015 (5371.066s) - Black frame with brightness of 16,uniform of 12 and volume of -1 Frame 160016 (5371.099s) - Black frame with brightness of 16,uniform of 12 and volume of -1 Frame 160017 (5371.132s) - Black frame with brightness of 16,uniform of 11 and volume of -1 Frame 160018 (5371.166s) - Black frame with brightness of 16,uniform of 10 and volume of -1 Frame 160019 (5371.199s) - Black frame with brightness of 16,uniform of 10 and volume of -1 Frame 160020 (5371.232s) - Black frame with brightness of 16,uniform of 9 and volume of -1 Frame 160021 (5371.266s) - Black frame with brightness of 16,uniform of 8 and volume of -1 Frame 160022 (5371.299s) - Black frame with brightness of 16,uniform of 8 and volume of -1 Frame 160023 (5371.332s) - Black frame with brightness of 16,uniform of 7 and volume of -1 Frame 160024 (5371.366s) - Black frame with brightness of 16,uniform of 6 and volume of -1 Frame 160025 (5371.399s) - Black frame with brightness of 16,uniform of 5 and volume of -1 Frame 160026 (5371.433s) - Black frame with brightness of 16,uniform of 5 and volume of -1 Frame 160027 (5371.466s) - Black frame with brightness of 16,uniform of 3 and volume of -1 Frame 160028 (5371.499s) - Black frame with brightness of 16,uniform of 3 and volume of -1 Frame 160029 (5371.533s) - Black frame with brightness of 16,uniform of 2 and volume of -1 Frame 160030 (5371.566s) - Black frame with brightness of 16,uniform of 2 and volume of -1 Frame 160031 (5371.599s) - Black frame with brightness of 16,uniform of 1 and volume of -1 Frame 160032 (5371.633s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160033 (5371.666s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160034 (5371.699s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160035 (5371.733s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160036 (5371.766s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160037 (5371.800s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160038 (5371.833s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160039 (5371.866s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160040 (5371.900s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160041 (5371.933s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160042 (5371.966s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160043 (5372.000s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160044 (5372.033s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160045 (5372.067s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160046 (5372.100s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160047 (5372.133s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160048 (5372.167s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160049 (5372.200s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160050 (5372.233s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160051 (5372.267s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160052 (5372.300s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160053 (5372.333s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160054 (5372.367s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160055 (5372.400s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160056 (5372.434s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160057 (5372.467s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160058 (5372.500s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160059 (5372.534s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160060 (5372.567s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160061 (5372.600s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160062 (5372.634s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160063 (5372.667s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160064 (5372.700s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160065 (5372.734s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160066 (5372.767s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160067 (5372.801s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160068 (5372.834s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160069 (5372.867s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160070 (5372.901s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160071 (5372.934s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160072 (5372.967s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160073 (5373.001s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160074 (5373.034s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160075 (5373.068s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160076 (5373.101s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160077 (5373.134s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160078 (5373.168s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160079 (5373.201s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160080 (5373.234s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160081 (5373.268s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160082 (5373.301s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160083 (5373.334s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160084 (5373.368s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160085 (5373.401s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160086 (5373.435s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160087 (5373.468s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160088 (5373.501s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160089 (5373.535s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160090 (5373.568s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160091 (5373.601s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160092 (5373.635s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160093 (5373.668s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160094 (5373.701s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160095 (5373.735s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160096 (5373.768s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160097 (5373.802s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160098 (5373.835s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160099 (5373.868s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160100 (5373.902s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160101 (5373.935s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160102 (5373.968s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160103 (5374.002s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160104 (5374.035s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160105 (5374.069s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160106 (5374.102s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160107 (5374.135s) - Black frame with brightness of 16,uniform of 0 and volume of -1 Frame 160108 (5374.169s) - Black frame with brightness of 16,uniform of 148 and volume of -1 Frame 160109 (5374.202s) - Black frame with brightness of 16,uniform of 534 and volume of -1 Frame 160110 (5374.235s) - Black frame with brightness of 17,uniform of 906 and volume of -1 Frame 160111 (5374.269s) - Black frame with brightness of 18,uniform of 1212 and volume of -1 1:29:45 - 162877 frames in 80.42 sec(2025.33 fps), 1.00 sec(2095.00 fps), 99% End logo block 9 frame 161758 Length - 0:12:35.62 [mpeg2video @ 0x80ac16500] invalid cbp -1 at 15 18 [mpeg2video @ 0x80ac16500] Warning MVs not available [ac3 @ 0x80ac16f00] incomplete frame 163437 frames decoded in 80.68 seconds (2025.74 fps) Parsed 161958 video frames and 182187 audio frames at 2025.74 fps Maximum Volume found is 11233 Finished scanning file. Starting to build Commercial List. WARNING: Complex timeline or errors in the recording!!!! Results may be wrong, .ref input will be misaligned. .txt editing will produce wrong results Use .edl output if possible Platau@[45980] frames 7, volume 9, distance 1549 seconds Platau@[51213] frames 7, volume 142, distance 174 seconds Platau@[62750] frames 12, volume 0, distance 387 seconds Platau@[88039] frames 47, volume 7, distance 850 seconds Platau@[93041] frames 19, volume 11, distance 167 seconds Platau@[99935] frames 8, volume 4, distance 230 seconds Platau@[139013] frames 7, volume 0, distance 1308 seconds Vol : #Frames 0 : 5 10 : 1 140 : 1 Calculated silence level = 10 Logo Histogram - 0.00147 0.000 - 232 - 0.00143 * 0.050 - 29 - 0.00161 * 0.100 - 116 - 0.00233 * 0.150 - 0 - 0.00233 0.200 - 29 - 0.00251 * 0.250 - 0 - 0.00251 0.300 - 0 - 0.00251 0.350 - 29 - 0.00269 * 0.400 - 51 - 0.00300 * 0.450 - 0 - 0.00300 0.500 - 116 - 0.00372 * 0.550 - 29 - 0.00390 * 0.600 - 116 - 0.00461 * 0.650 - 29 - 0.00479 * 0.700 - 0 - 0.00479 0.750 - 0 - 0.00479 0.800 - 232 - 0.00622 * 0.850 - 1566 - 0.01589 *** 0.900 - 135691 - 0.85371 ********************************************************************************************************************************************************************************************************* 0.950 - 23692 - 0.99999 *********************************** Set Logo Quality = 0.77500 Not enough or too much logo's found (0.97), disabling the use of Logo detection The last ar cblock wasn't closed. Now closing. After Sorting - 3 -------------- Audio channels 2 found on 161958 frames totalling 100.0% Printing AC cblock list ----------------------------------------- Block: 0 Start: 1 End: 161958 audio channels: 2 Length: 1:30:37.19 The last ar cblock wasn't closed. Now closing. Printing AR cblock list before cleaning ----------------------------------------- Block: 0 Start: 1 End: 27150 AR_R: 1.16 Length: 0:15:19.75, [ 704x 480] minX= 86, minY= 1, maxX=618, maxY=480 Block: 1 Start: 27151 End: 42156 AR_R: 1.47 Length: 0:08:21.69, [ 704x 480] minX= 1, minY= 1, maxX=704, maxY=480 Block: 2 Start: 42157 End: 45865 AR_R: 1.11 Length: 0:02:03.72, [ 704x 480] minX= 88, minY= 1, maxX=616, maxY=480 Block: 3 Start: 45866 End: 77025 AR_R: 1.47 Length: 0:17:23.92, [ 704x 480] minX= 1, minY= 1, maxX=704, maxY=480 Block: 4 Start: 77026 End: 119513 AR_R: 1.12 Length: 0:23:45.94, [ 704x 480] minX= 86, minY= 1, maxX=620, maxY=480 Block: 5 Start: 119514 End: 121320 AR_R: 0.00 Length: 0:01:00.26, [ 704x 480] minX= 84, minY= 34, maxX=612, maxY=448 Block: 6 Start: 121321 End: 138379 AR_R: 1.10 Length: 0:09:30.27, [ 704x 480] minX= 88, minY= 1, maxX=616, maxY=480 Block: 7 Start: 138380 End: 138936 AR_R: 0.00 Length: 0:00:18.55, [ 704x 480] minX= 86, minY= 18, maxX=618, maxY=450 Block: 8 Start: 138937 End: 154501 AR_R: 1.47 Length: 0:08:41.45, [ 704x 480] minX= 1, minY= 1, maxX=704, maxY=480 Block: 9 Start: 154502 End: 161958 AR_R: 1.10 Length: 0:04:10.04, [ 704x 480] minX= 90, minY= 1, maxX=618, maxY=480 After Sorting - 95 -------------- Aspect Ratio 1.12 found on 23528 frames totalling 88.1% Aspect Ratio 1.11 found on 1971 frames totalling 95.5% Aspect Ratio 1.10 found on 381 frames totalling 96.9% Aspect Ratio 1.47 found on 162 frames totalling 97.5% Aspect Ratio 1.15 found on 110 frames totalling 97.9% Aspect Ratio 1.24 found on 94 frames totalling 98.3% Aspect Ratio 1.09 found on 82 frames totalling 98.6% Aspect Ratio 1.17 found on 41 frames totalling 98.7% Aspect Ratio 1.16 found on 34 frames totalling 98.9% Aspect Ratio 1.32 found on 27 frames totalling 99.0% Aspect Ratio 1.18 found on 24 frames totalling 99.1% Aspect Ratio 1.14 found on 23 frames totalling 99.1% Aspect Ratio 1.07 found on 22 frames totalling 99.2% Aspect Ratio 1.27 found on 22 frames totalling 99.3% Aspect Ratio 1.08 found on 21 frames totalling 99.4% Aspect Ratio 1.30 found on 21 frames totalling 99.5% Aspect Ratio 1.25 found on 20 frames totalling 99.5% Aspect Ratio 1.28 found on 19 frames totalling 99.6% Aspect Ratio 1.26 found on 16 frames totalling 99.7% Aspect Ratio 1.29 found on 14 frames totalling 99.7% Aspect Ratio 0.96 found on 12 frames totalling 99.8% Aspect Ratio 1.31 found on 10 frames totalling 99.8% Aspect Ratio 0.94 found on 8 frames totalling 99.8% Aspect Ratio 0.97 found on 8 frames totalling 99.9% Aspect Ratio 1.19 found on 7 frames totalling 99.9% Aspect Ratio 1.04 found on 3 frames totalling 99.9% Aspect Ratio 1.05 found on 3 frames totalling 99.9% Aspect Ratio 1.21 found on 3 frames totalling 99.9% Aspect Ratio 1.03 found on 2 frames totalling 99.9% Aspect Ratio 1.06 found on 2 frames totalling 99.9% Aspect Ratio 1.20 found on 2 frames totalling 99.9% Aspect Ratio 1.33 found on 2 frames totalling 100.0% Aspect Ratio 1.46 found on 2 frames totalling 100.0% Aspect Ratio 1.67 found on 2 frames totalling 100.0% Aspect Ratio 0.99 found on 1 frames totalling 100.0% Aspect Ratio 1.00 found on 1 frames totalling 100.0% Aspect Ratio 1.01 found on 1 frames totalling 100.0% Aspect Ratio 1.23 found on 1 frames totalling 100.0% Aspect Ratio 1.34 found on 1 frames totalling 100.0% Aspect Ratio 1.35 found on 1 frames totalling 100.0% Aspect Ratio 1.44 found on 1 frames totalling 100.0% Aspect Ratio 1.55 found on 1 frames totalling 100.0% After Sorting - 97 -------------- Aspect Ratio 1.12 found on 97863 frames totalling 61.3% Aspect Ratio 1.47 found on 61731 frames totalling 100.0% Joining AR blocks 4 and 6 because they have a dummy cblock inbetween Printing AR cblock list ----------------------------------------- Block: 0 Start: 1 End: 27150 AR_R: 1.12 Length: 0:15:19.75, [ 704x 480] minX= 86, minY= 1, maxX=618, maxY=480 Block: 1 Start: 27151 End: 42156 AR_R: 1.47 Length: 0:08:21.69, [ 704x 480] minX= 1, minY= 1, maxX=704, maxY=480 Block: 2 Start: 42157 End: 45865 AR_R: 1.12 Length: 0:02:03.72, [ 704x 480] minX= 88, minY= 1, maxX=616, maxY=480 Block: 3 Start: 45866 End: 77025 AR_R: 1.47 Length: 0:17:23.92, [ 704x 480] minX= 1, minY= 1, maxX=704, maxY=480 Block: 4 Start: 77026 End: 138379 AR_R: 1.12 Length: 0:34:16.55, [ 704x 480] minX= 86, minY= 1, maxX=620, maxY=480 Block: 5 Start: 138380 End: 138936 AR_R: 0.00 Length: 0:00:18.55, [ 704x 480] minX= 86, minY= 18, maxX=618, maxY=450 Block: 6 Start: 138937 End: 154501 AR_R: 1.47 Length: 0:08:41.45, [ 704x 480] minX= 1, minY= 1, maxX=704, maxY=480 Block: 7 Start: 154502 End: 161958 AR_R: 1.12 Length: 0:04:10.04, [ 704x 480] minX= 90, minY= 1, maxX=618, maxY=480 Show Histogram - 0.03902 0 - 0 - 0.00000 1 - 0 - 0.00000 2 - 0 - 0.00000 3 - 0 - 0.00000 4 - 0 - 0.00000 5 - 0 - 0.00000 6 - 0 - 0.00000 7 - 0 - 0.00000 8 - 0 - 0.00000 9 - 0 - 0.00000 10 - 0 - 0.00000 11 - 0 - 0.00000 12 - 0 - 0.00000 13 - 0 - 0.00000 14 - 0 - 0.00000 15 - 0 - 0.00000 16 - 276 - 0.00170 *********** 17 - 11 - 0.00177 * 18 - 16 - 0.00187 * 19 - 7 - 0.00191 * 20 - 10 - 0.00198 * 21 - 18 - 0.00209 * 22 - 30 - 0.00227 ** 23 - 72 - 0.00272 *** 24 - 90 - 0.00327 **** 25 - 44 - 0.00354 ** 26 - 90 - 0.00410 **** 27 - 91 - 0.00466 **** 28 - 137 - 0.00551 ****** 29 - 101 - 0.00613 **** Setting brightness threshold to 30 Show Uniform - 0.74074 0 - 270 - 0.00167 ********************************************************************************************************************************************************************************************************* 100 - 2 - 0.00168 ** 200 - 3 - 0.00170 *** 300 - 0 - 0.00170 400 - 2 - 0.00171 ** 500 - 6 - 0.00175 ***** 600 - 6 - 0.00178 ***** 700 - 1 - 0.00179 * 800 - 4 - 0.00182 *** 900 - 4 - 0.00184 *** 1000 - 1 - 0.00185 * 1100 - 1 - 0.00185 * 1200 - 3 - 0.00187 *** 1300 - 2 - 0.00188 ** 1400 - 1 - 0.00189 * 1500 - 2 - 0.00190 ** 1600 - 3 - 0.00192 *** 1700 - 0 - 0.00192 1800 - 1 - 0.00193 * 1900 - 1 - 0.00193 * 2000 - 3 - 0.00195 *** 2100 - 6 - 0.00199 ***** 2200 - 0 - 0.00199 2300 - 1 - 0.00199 * 2400 - 4 - 0.00202 *** 2500 - 0 - 0.00202 2600 - 1 - 0.00203 * 2700 - 1 - 0.00203 * 2800 - 2 - 0.00204 ** 2900 - 1 - 0.00205 * Setting uniform threshold to 6800 Distribution of Black Frame cutting: 4 positive and 0 negative, ratio is 9.9900 Confidence of Black Frame cutting: 0 out of 0 are strict, too low Black Frame cutting too low Distribution of Scene Change cutting: 0 positive and 0 negative, ratio is 9.9900 Confidence of Scene Change cutting: 0 out of 0 are strict, too low Distribution of Uniform Frame cutting: 4 positive and 0 negative, ratio is 9.9900 Confidence of Uniform Frame cutting: 0 out of 0 are strict, too low Black Frame List --------------------------- Black Frame Count = 39 nr frame pts bright uniform volume cause dimcount bright type 0 87998 2960.500 16 0 11 b 0 0 B 1 87999 2960.533 16 0 9 b 0 0 B 2 88000 2960.567 16 0 7 b 0 0 P 3 88001 2960.600 16 0 7 b 0 0 B 4 88002 2960.633 16 0 5 b 0 0 B 5 88003 2960.667 16 0 4 b 0 0 P 6 88004 2960.700 16 0 4 b 0 0 B 7 88005 2960.734 16 0 3 b 0 0 B 8 88006 2960.767 16 0 2 b 0 0 P 9 88007 2960.800 16 0 2 b 0 0 B 10 88008 2960.834 16 0 2 b 0 0 B 11 88009 2960.867 16 0 1 b 0 0 P 12 88010 2960.900 16 0 1 b 0 0 B 13 88011 2960.934 16 0 1 b 0 0 B 14 88012 2960.967 16 0 0 b 0 0 P 15 88013 2961.001 16 0 0 b 0 0 B 16 88014 2961.034 16 0 0 b 0 0 B 17 88015 2961.067 16 0 0 b 0 0 P 18 88016 2961.101 16 0 0 b 0 0 B 19 88017 2961.134 16 0 0 b 0 0 B 20 88018 2961.167 16 0 0 b 0 0 P 21 88019 2961.201 16 0 0 b 0 0 B 22 88020 2961.234 16 0 0 b 0 0 B 23 88021 2961.267 16 0 0 b 0 0 P ----------------------------- 24 88031 2961.601 16 0 0 b 0 0 B 25 88032 2961.634 16 0 0 b 0 0 B 26 88033 2961.668 16 0 0 b 0 0 P ----------------------------- 27 93002 3128.368 16 0 11 b 0 0 B 28 93003 3128.401 16 0 11 b 0 0 P 29 93004 3128.434 16 0 9 b 0 0 B 30 93005 3128.468 16 0 9 b 0 0 P 31 93006 3128.501 16 0 7 b 0 0 B 32 93007 3128.535 16 0 7 b 0 0 P 33 93008 3128.568 16 0 7 b 0 0 B 34 93009 3128.601 16 0 7 b 0 0 P 35 93010 3128.635 16 0 7 b 0 0 B 36 93011 3128.668 16 0 7 b 0 0 P 37 93012 3128.701 21 2106 7 b 0 0 B ----------------------------- 38 161958 5437.198 0 0 0 br 0 0 P Fuzzy scoring of the blocks --------------------------- Block 0 has twice excess length. Block 0 score: Before - 1.00 After - 0.00 Block 0 AR (1.47) is different from dominant AR(1.12). Block 0 score: Before - 0.00 After - 0.00 Block 2 has twice excess length. Block 2 score: Before - 1.00 After - 0.00 Threshold used - 1.0500 After rounding - 1.0500 --------------------- Initial Commercial List --------------------- No change Logo fraction: 0.9730 Logo disabled Maximum volume found: 11233 Average volume: 1600 Sound threshold: 15 Silence threshold: 10 Minimum volume found: 0 Average frames with silence: 98 Black threshold: 30 Minimum brightness found: 16 Minimum bright pixels found: 0 Minimum dim level found: 0 Average brightness: 456 Uniformity level: 6800 Average non uniformity: 232 Maximum gap between logo's: -1 Suggested logo_threshold: 0.7750 Suggested shrink_logo: 0.00 Max commercial size found: -1 Dominant aspect ratio: 1.1200 Score threshold: 1.0500 Framerate: 29.970 Average framerate: 29.787 Total commercial length: 0:00:00.00 Cut codes: F: scene c: change A: aspect t: cutscene E: exceeds l: logo L: logo v: volume B: bright s: scene_change C: combined a: aspect_ratio N: nonstrict u: uniform_frame S: strict b: black_frame r: resolution ---------------------------------------------------- Block list after weighing ---------------------------------------------------- # sbf bs be fs fe ts te len sc scr cmb ar cut bri logo vol sil corr stdev cc 0:+ 18 0 18 1 88015 0.00s 2961.07s 2961.07s 0.00 0.04 0 1.47 AE b 458+ 0.00 1578- 980 0.000 45 1:+ 23 18 5 88016 93006 2961.10s 3128.50s 167.40s 1.00 0.04 0 1.12 b 401- 0.00 1522- 980 0.000 40 2:+ 6 6 0 93007 161958 3128.53s 5437.20s 2308.66s 0.00 0.04 0 1.12 7 { E br 4560 0.00 1635+ 980 0.000 45 161958 Frames Processed Commercials were not found. Pulling Closed captions from '/media/Visual/TV Shows/Recorded/Mystery Science Theater 3000 (1987)/Season 4/Mystery Science Theater 3000 S04E04 Teenagers From Outer Space.ts' to SRT file CCExtractor 0.85, Carlos Fernandez Sanz, Volker Quetschke. Teletext portions taken from Petr Kutalek's telxcc -------------------------------------------------------------------------- Input: /media/Visual/TV Shows/Recorded/Mystery Science Theater 3000 (1987)/Season 4/Mystery Science Theater 3000 S04E04 Teenagers From Outer Space.ts [Extract: 1] [Stream mode: Autodetect] [Program : Auto ] [Hauppage mode: No] [Use MythTV code: Auto] [Timing mode: Auto] [Debug: No] [Buffer input: No] [Use pic_order_cnt_lsb for H.264: No] [Print CC decoder traces: No] [Target format: .srt] [Encoding: UTF-8] [Delay: 0] [Trim lines: No] [Add font color data: Yes] [Add font typesetting: Yes] [Convert case: No] [Video-edit join: No] [Extraction start time: not set (from start)] [Extraction end time: not set (to end)] [Live stream: No] [Clock frequency: 90000] [Teletext page: Autodetect] [Start credits text: None] ----------------------------------------------------------------- Opening file: /media/Visual/TV Shows/Recorded/Mystery Science Theater 3000 (1987)/Season 4/Mystery Science Theater 3000 S04E04 Teenagers From Outer Space.ts Analyzing data in general mode Creating /media/Visual/TV Shows/Recorded/Mystery Science Theater 3000 (1987)/Season 4/Mystery Science Theater 3000 S04E04 Teenagers From Outer Space.srt XDS: ContentAdvisory: MPA Rating: N/A XDS: CGMS: No copying is permited XDS: APS: No APS XDS: Redistribution Control Descriptor: 1 [error][(null)] invalid cbp -1 at 15 18 [error][(null)] Warning MVs not available [info][(null)] concealing 528 DC, 528 AC, 528 MV errors in P frame Number of NAL_type_7: 0 Number of VCL_HRD: 0 Number of NAL HRD: 0 Number of jump-in-frames: 0 Number of num_unexpected_sei_length: 0 Total frames time: 00:00:00:000 (0 frames at 29.97fps) Done, processing time = 82 seconds Issues? Open a ticket here https://github.com/CCExtractor/ccextractor/issues [00:25:09] hb_init: starting libhb thread [00:25:09] thread 808c19c00 started ("libhb") HandBrake 1.3.1 (2020011400) - FreeBSD amd64 - https://handbrake.fr 4 CPUs detected Opening /media/Visual/TV Shows/Recorded/Mystery Science Theater 3000 (1987)/Season 4/Mystery Science Theater 3000 S04E04 Teenagers From Outer Space.ts... [00:25:09] CPU: Intel(R) Core(TM) i3-4130 CPU @ 3.40GHz [00:25:09] - Intel microarchitecture Haswell [00:25:09] - logical processor count: 4 [00:25:09] Intel Quick Sync Video support: no [00:25:09] hb_scan: path=/media/Visual/TV Shows/Recorded/Mystery Science Theater 3000 (1987)/Season 4/Mystery Science Theater 3000 S04E04 Teenagers From Outer Space.ts, title_index=1 udfread ERROR: ECMA 167 Volume Recognition failed disc.c:323: failed opening UDF image /media/Visual/TV Shows/Recorded/Mystery Science Theater 3000 (1987)/Season 4/Mystery Science Theater 3000 S04E04 Teenagers From Outer Space.ts disc.c:424: error opening file BDMV/index.bdmv disc.c:424: error opening file BDMV/BACKUP/index.bdmv bluray.c:2585: nav_get_title_list(/media/Visual/TV Shows/Recorded/Mystery Science Theater 3000 (1987)/Season 4/Mystery Science Theater 3000 S04E04 Teenagers From Outer Space.ts/) failed [00:25:09] bd: not a bd - trying as a stream/file instead libdvdnav: Using dvdnav version 6.0.1 libdvdread: Encrypted DVD support unavailable. libdvdread:DVDOpenFileUDF:UDFFindFile /VIDEO_TS/VIDEO_TS.IFO failed libdvdread:DVDOpenFileUDF:UDFFindFile /VIDEO_TS/VIDEO_TS.BUP failed libdvdread: Can't open file VIDEO_TS.IFO. libdvdnav: vm: failed to read VIDEO_TS.IFO [00:25:09] dvd: not a dvd - trying as a stream/file instead [00:25:09] file is MPEG Transport Stream with 188 byte packets offset 0 bytes [00:25:09] Found the following PIDS [00:25:09] Video PIDS : [00:25:09] 0x100 type MPEG2 (0x2) (PCR) [00:25:09] Audio PIDS : [00:25:09] 0x101 type AC3 (0x81) [00:25:09] Subtitle PIDS : [00:25:09] Other PIDS : [00:25:09] stream id 0x101 (type 0x81 substream 0x0) audio 0x101 [00:25:09] scan: decoding previews for title 1 [00:25:09] file is MPEG Transport Stream with 188 byte packets offset 0 bytes [00:25:09] scan: audio 0x101: ac3, rate=48000Hz, bitrate=192000 English (AC3) (2.0 ch) (192 kbps) [00:25:09] stream: 7 good frames, 0 errors (0%) [00:25:09] scan: 10 previews, 704x480, 29.970 fps, autocrop = 4/28/86/90, aspect 16:9, PAR 40:33 [00:25:09] libhb: scan thread found 1 valid title(s) + Using preset: CLI Default + title 1: + stream: /media/Visual/TV Shows/Recorded/Mystery Science Theater 3000 (1987)/Season 4/Mystery Science Theater 3000 S04E04 Teenagers From Outer Space.ts + duration: 01:28:44 + size: 704x480, pixel aspect: 40/33, display aspect: 1.78, 29.970 fps + autocrop: 4/28/86/90 + chapters: + 1: duration 01:28:44 + audio tracks: + 1, English (AC3) (2.0 ch) (192 kbps) (iso639-2: eng), 48000Hz, 192000bps + subtitle tracks: + 1, English, Closed Caption [CC608] Warning: Could not find audio track 2, skipped Warning: Could not find audio track 3, skipped Warning: Could not find audio track 4, skipped Warning: Could not find audio track 5, skipped Warning: Could not find audio track 6, skipped Warning: Could not find audio track 7, skipped Warning: Could not find audio track 8, skipped Warning: Could not find audio track 9, skipped Warning: Could not find audio track 10, skipped Warning: Could not find audio track 11, skipped Dropping excess audio encoders Dropping excess audio mixdowns [00:25:09] Starting work at: Sat Jan 18 00:25:09 2020 [00:25:09] 1 job(s) to process [00:25:09] json job: { "Audio": { "AudioList": [ { "Encoder": 65536, "Mixdown": 4, "Track": 0 }, { "Encoder": 1125984256, "Mixdown": 9, "Track": 0 } ], "CopyMask": [ "copy:aac", "copy:ac3", "copy:eac3", "copy:truehd", "copy:dts", "copy:dtshd", "copy:flac" ], "FallbackEncoder": "aac" }, "Destination": { "AlignAVStart": false, "ChapterList": [ { "Duration": { "Hours": 1, "Minutes": 28, "Seconds": 44, "Ticks": 479172497 }, "Name": "Chapter 1" } ], "ChapterMarkers": false, "File": "/media/Visual/TV Shows/Recorded/Mystery Science Theater 3000 (1987)/Season 4/Mystery Science Theater 3000 S04E04 Teenagers From Outer Space.mp4", "InlineParameterSets": false, "Mp4Options": { "IpodAtom": false, "Mp4Optimize": true }, "Mux": "m4v" }, "Filters": { "FilterList": [ { "ID": 3, "Settings": { "block-height": "16", "block-thresh": "40", "block-width": "16", "filter-mode": "2", "mode": "3", "motion-thresh": "1", "spatial-metric": "2", "spatial-thresh": "1" } }, { "ID": 4, "Settings": { "mode": "7" } }, { "ID": 6, "Settings": { "mode": 0 } }, { "ID": 12, "Settings": { "crop-bottom": 28, "crop-left": 86, "crop-right": 90, "crop-top": 4, "height": 448, "width": 528 } } ] }, "Metadata": {}, "PAR": { "Den": 33, "Num": 40 }, "SequenceID": 0, "Source": { "Angle": 0, "Path": "/media/Visual/TV Shows/Recorded/Mystery Science Theater 3000 (1987)/Season 4/Mystery Science Theater 3000 S04E04 Teenagers From Outer Space.ts", "Range": { "End": 1, "Start": 1, "Type": "chapter" }, "Title": 1 }, "Subtitle": { "Search": { "Burn": true, "Default": false, "Enable": false, "Forced": false }, "SubtitleList": [] }, "Video": { "ColorFormat": 0, "ColorMatrix": 6, "ColorPrimaries": 6, "ColorRange": 1, "ColorTransfer": 1, "Encoder": "x264", "Level": "4.1", "Options": "", "Preset": "slow", "Profile": "high", "QSV": { "AsyncDepth": 4, "Decode": false }, "Quality": 18.0, "Tune": "", "Turbo": false, "TwoPass": false } } [00:25:09] Starting Task: Encoding Pass [00:25:09] Skipping vfr filter [00:25:09] Auto Passthru: allowed codecs are AAC, AC3, E-AC3, TrueHD, DTS, DTS-HD, FLAC [00:25:09] Auto Passthru: fallback is AAC (avcodec) [00:25:09] Auto Passthru: using AC3 Passthru for track 2 [00:25:09] work: bitrate not specified, track 1 setting bitrate 160 Kbps [00:25:09] job configuration: [00:25:09] * source [00:25:09] + /media/Visual/TV Shows/Recorded/Mystery Science Theater 3000 (1987)/Season 4/Mystery Science Theater 3000 S04E04 Teenagers From Outer Space.ts [00:25:09] + title 1, chapter(s) 1 to 1 [00:25:09] * destination [00:25:09] + /media/Visual/TV Shows/Recorded/Mystery Science Theater 3000 (1987)/Season 4/Mystery Science Theater 3000 S04E04 Teenagers From Outer Space.mp4 [00:25:09] + container: MPEG-4 (libavformat) [00:25:09] + optimized for HTTP streaming (fast start) [00:25:09] * video track [00:25:09] + decoder: mpeg2video [00:25:09] + bitrate 200 kbps [00:25:09] + filters [00:25:09] + Comb Detect (mode=3:spatial-metric=2:motion-thresh=1:spatial-thresh=1:filter-mode=2:block-thresh=40:block-width=16:block-height=16) [00:25:09] + Decomb (mode=39) [00:25:09] + Crop and Scale (width=528:height=448:crop-top=4:crop-bottom=28:crop-left=86:crop-right=90) [00:25:09] + source: 704 * 480, crop (4/28/86/90): 528 * 448, scale: 528 * 448 [00:25:09] + Output geometry [00:25:09] + storage dimensions: 528 x 448 [00:25:09] + pixel aspect ratio: 40 : 33 [00:25:09] + display dimensions: 640 x 448 [00:25:09] + encoder: H.264 (libx264) [00:25:09] + preset: slow [00:25:09] + profile: high [00:25:09] + level: 4.1 [00:25:09] + quality: 18.00 (RF) [00:25:09] + color profile: 6-1-6 [00:25:09] * audio track 1 [00:25:09] + decoder: English (AC3) (2.0 ch) (192 kbps) (track 1, id 0x101) [00:25:09] + bitrate: 192 kbps, samplerate: 48000 Hz [00:25:09] + mixdown: Stereo [00:25:09] + dither: triangular [00:25:09] + encoder: AAC (libavcodec) [00:25:09] + bitrate: 160 kbps, samplerate: 48000 Hz [00:25:09] * audio track 2 [00:25:09] + decoder: English (AC3) (2.0 ch) (192 kbps) (track 1, id 0x101) [00:25:09] + bitrate: 192 kbps, samplerate: 48000 Hz [00:25:09] + AC3 Passthru [00:25:09] file is MPEG Transport Stream with 188 byte packets offset 0 bytes [00:25:09] sync: expecting 159564 video frames [00:25:09] encx264: min-keyint: 30, keyint: 300 [00:25:09] encx264: encoding at constant RF 18.000000 [00:25:09] encx264: unparsed options: level=4.1:ref=5:direct=auto:subme=8:trellis=2:vbv-bufsize=78125:vbv-maxrate=62500:rc-lookahead=50 x264 [info]: using SAR=40/33 x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX FMA3 BMI2 AVX2 x264 [info]: profile High, level 4.1, 4:2:0, 8-bit [00:25:09] sync: first pts audio 0x101 is 0 [00:25:09] sync: first pts audio 0x101 is 0 [00:25:09] sync: first pts video is 8067 Encoding: task 1 of 1, 2.21 % (67.76 fps, avg 70.02 fps, ETA 00h37m09s)[00:26:00] sync: audio 0x101 time went backwards 96 ms, dropped 3 frames. PTS 10607040 [00:26:00] 119.340401s: Video -> Film Encoding: task 1 of 1, 2.22 % (70.65 fps, avg 70.22 fps, ETA 00h37m02s)[00:26:00] 120.057777s: Film -> Video Encoding: task 1 of 1, 6.82 % (62.56 fps, avg 66.38 fps, ETA 00h37m20s)[00:27:54] 364.735565s: Video -> Film Encoding: task 1 of 1, 7.37 % (60.81 fps, avg 65.58 fps, ETA 00h37m34s)[00:28:09] 401.438904s: Film -> Video Encoding: task 1 of 1, 7.38 % (60.81 fps, avg 65.58 fps, ETA 00h37m34s)[00:28:09] 402.606720s: Video -> Film Encoding: task 1 of 1, 7.40 % (61.21 fps, avg 65.59 fps, ETA 00h37m33s)[00:28:09] 403.274048s: Film -> Video [00:28:09] 403.440887s: Video -> Film Encoding: task 1 of 1, 7.42 % (61.21 fps, avg 65.59 fps, ETA 00h37m33s)[00:28:10] 404.942413s: Film -> Video Encoding: task 1 of 1, 8.30 % (51.56 fps, avg 64.38 fps, ETA 00h37m53s)[00:28:35] 451.822540s: Video -> Film Encoding: task 1 of 1, 8.32 % (51.56 fps, avg 64.38 fps, ETA 00h37m53s)[00:28:36] 452.489868s: Film -> Video Encoding: task 1 of 1, 8.72 % (57.63 fps, avg 64.08 fps, ETA 00h37m53s)[00:28:47] 474.345062s: Video -> Film [00:28:47] 474.511871s: Film -> Video [00:28:47] 474.678711s: Video -> Film Encoding: task 1 of 1, 8.74 % (57.63 fps, avg 64.08 fps, ETA 00h37m53s)[00:28:47] 475.212585s: Film -> Video [00:28:47] 475.512878s: Video -> Film [00:28:47] 475.679749s: Film -> Video [00:28:47] 475.846527s: Video -> Film Encoding: task 1 of 1, 8.76 % (58.11 fps, avg 64.05 fps, ETA 00h37m53s)[00:28:48] 476.013367s: Film -> Video Encoding: task 1 of 1, 8.76 % (58.11 fps, avg 64.05 fps, ETA 00h37m53s)[00:28:48] 476.680725s: Video -> Film Encoding: task 1 of 1, 8.81 % (53.78 fps, avg 63.95 fps, ETA 00h37m56s)[00:28:49] 479.850525s: Film -> Video Encoding: task 1 of 1, 9.22 % (62.36 fps, avg 63.81 fps, ETA 00h37m50s)[00:29:00] 502.206207s: Video -> Film Encoding: task 1 of 1, 9.26 % (60.04 fps, avg 63.75 fps, ETA 00h37m51s)[00:29:01] 503.741058s: Film -> Video Encoding: task 1 of 1, 9.31 % (51.64 fps, avg 63.66 fps, ETA 00h37m53s)[00:29:03] 506.543854s: Video -> Film Encoding: task 1 of 1, 9.31 % (51.64 fps, avg 63.66 fps, ETA 00h37m53s)[00:29:03] 507.544891s: Film -> Video Encoding: task 1 of 1, 9.70 % (66.60 fps, avg 63.43 fps, ETA 00h37m51s)[00:29:14] 527.898560s: Video -> Film Encoding: task 1 of 1, 9.72 % (66.60 fps, avg 63.43 fps, ETA 00h37m51s)[00:29:14] 528.732727s: Film -> Video Encoding: task 1 of 1, 15.22 % (79.59 fps, avg 65.82 fps, ETA 00h34m16s)[00:31:18] 822.025696s: Video -> Film [00:31:18] 822.192505s: Film -> Video Encoding: task 1 of 1, 15.67 % (69.00 fps, avg 65.82 fps, ETA 00h34m05s)[00:31:29] 845.549255s: Video -> Film [00:31:29] 846.249939s: Film -> Video Encoding: task 1 of 1, 15.95 % (63.03 fps, avg 65.75 fps, ETA 00h34m00s)[00:31:36] 860.897888s: Video -> Film [00:31:36] 861.098022s: Film -> Video [00:31:36] 861.231567s: Video -> Film Encoding: task 1 of 1, 15.97 % (63.03 fps, avg 65.75 fps, ETA 00h34m00s)[00:31:37] 861.431763s: Film -> Video Encoding: task 1 of 1, 16.07 % (65.98 fps, avg 65.75 fps, ETA 00h33m56s)[00:31:39] 867.404358s: Video -> Film Encoding: task 1 of 1, 16.09 % (65.98 fps, avg 65.75 fps, ETA 00h33m56s)[00:31:40] 868.438782s: Film -> Video [00:31:40] 868.572205s: Video -> Film [00:31:40] 869.406372s: Film -> Video Encoding: task 1 of 1, 16.11 % (59.32 fps, avg 65.72 fps, ETA 00h33m57s)[00:31:41] 869.906860s: Video -> Film [00:31:41] 870.073669s: Film -> Video Encoding: task 1 of 1, 16.13 % (59.32 fps, avg 65.72 fps, ETA 00h33m57s)[00:31:41] 870.407349s: Video -> Film Encoding: task 1 of 1, 16.24 % (57.50 fps, avg 65.65 fps, ETA 00h33m56s)[00:31:44] 877.748108s: Film -> Video Encoding: task 1 of 1, 16.64 % (74.43 fps, avg 65.78 fps, ETA 00h33m42s)[00:31:53] 899.102783s: Video -> Film Encoding: task 1 of 1, 16.68 % (65.41 fps, avg 65.75 fps, ETA 00h33m42s)[00:31:54] 902.472717s: Film -> Video Encoding: task 1 of 1, 16.94 % (68.46 fps, avg 65.77 fps, ETA 00h33m36s)[00:32:00] 915.952881s: Video -> Film [00:32:00] 916.119751s: Film -> Video [00:32:00] 916.286560s: Video -> Film [00:32:00] 916.453308s: Film -> Video Encoding: task 1 of 1, 17.01 % (68.26 fps, avg 65.76 fps, ETA 00h33m34s)[00:32:03] sync: audio 0x101 time went backwards 64 ms, dropped 2 frames. PTS 82785600 [00:32:03] sync: video time went backwards 33 ms, dropped 1 frames. PTS 82873786 Encoding: task 1 of 1, 28.73 % (77.79 fps, avg 65.60 fps, ETA 00h28m53s)[00:36:48] sync: audio 0x101 time went backwards 64 ms, dropped 2 frames. PTS 139075200 Encoding: task 1 of 1, 28.76 % (77.79 fps, avg 65.60 fps, ETA 00h28m53s)x264 [warning]: non-strictly-monotonic PTS Encoding: task 1 of 1, 29.96 % (62.57 fps, avg 65.58 fps, ETA 00h28m24s)ERROR: avformatMux: track 0, av_interleaved_write_frame failed with error 'Invalid argument' [00:37:18] work: average encoding speed for job is 65.584961 fps Encoding: task 1 of 1, 29.97 % (62.57 fps, avg 65.58 fps, ETA 00h28m24s)[00:37:18] comb detect: heavy 3394 | light 8459 | uncombed 35943 | total 47796 [00:37:18] decomb: deinterlaced 3394 | blended 8458 | unfiltered 35935 | total 47787 [00:37:18] stream: 48335 good frames, 0 errors (0%) [00:37:18] ac3-decoder done: 50390 frames, 0 decoder errors [00:37:18] ac3-decoder done: 50390 frames, 0 decoder errors [00:37:18] mpeg2video-decoder done: 47872 frames, 0 decoder errors [00:37:18] sync: got 47830 frames, 159564 expected [00:37:18] sync: framerate min 0.698 fps, max 29.970 fps, avg 29.687 fps [aac @ 0x8097f0600] Qavg: 202.774 [aac @ 0x8097f0600] 2 frames left in the queue on closing x264 [info]: frame I:270 Avg QP:16.28 size: 29865 x264 [info]: frame P:12745 Avg QP:18.61 size: 10810 x264 [info]: frame B:34703 Avg QP:22.69 size: 1991 x264 [info]: consecutive B-frames: 1.5% 3.3% 3.6% 91.5% x264 [info]: mb I I16..4: 5.3% 70.6% 24.2% x264 [info]: mb P I16..4: 1.2% 6.5% 0.8% P16..4: 45.6% 29.2% 13.2% 0.0% 0.0% skip: 3.5% x264 [info]: mb B I16..4: 0.1% 0.4% 0.0% B16..8: 38.0% 6.7% 1.3% direct: 6.5% skip:47.0% L0:38.5% L1:45.8% BI:15.7% x264 [info]: 8x8 transform intra:75.9% inter:54.5% x264 [info]: direct mvs spatial:99.9% temporal:0.1% x264 [info]: coded y,uvDC,uvAC intra: 81.6% 72.1% 39.6% inter: 26.5% 22.1% 2.1% x264 [info]: i16 v,h,dc,p: 38% 24% 10% 28% x264 [info]: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 15% 12% 8% 7% 10% 12% 10% 13% 12% x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 15% 12% 6% 8% 12% 13% 11% 11% 12% x264 [info]: i8c dc,h,v,p: 34% 30% 23% 13% x264 [info]: Weighted P-Frames: Y:31.6% UV:2.2% x264 [info]: ref P L0: 52.4% 17.3% 17.2% 6.3% 4.8% 2.0% 0.1% x264 [info]: ref B L0: 86.9% 10.1% 2.1% 0.9% x264 [info]: ref B L1: 97.1% 2.9% x264 [info]: kb/s:1069.74 [mp4 @ 0x809122a00] Starting second pass: moving the moov atom to the beginning of the file Muxing: this may take awhile...[00:37:19] mux: track 0, 47717 frames, 214927120 bytes, 1067.16 kbps, fifo 4096 [00:37:19] mux: track 1, 75523 frames, 32350758 bytes, 160.63 kbps, fifo 8192 [00:37:19] mux: track 2, 50350 frames, 38668800 bytes, 192.00 kbps, fifo 4096 [00:37:19] Finished work at: Sat Jan 18 00:37:19 2020 [00:37:19] libhb: work result = 4 Encode failed (error 4). HandBrake has exited. I won't have time for a couple weeks to research the error outputs from ffmpeg and handbrake and devise a capture and escape from the clean up routine. If you think your youngest would like a challenge this is a good opportunity to learn error handling.
Baenwort 119 Posted March 19, 2020 Posted March 19, 2020 As a FYI if you are running this script and are not having successful conversions the problem lies with the recent dav1d version .6 talked about here: https://emby.media/community/index.php?/topic/83647-dav1d-upgraded-to-version-060/ Comskip requires libavutil.so.56 and if you run your script manually and it gives you an error of 'Shared object "libavutil.so.56" not found, required by "comskip"' this may be the same cause.
