Vertax 0 Posted August 12, 2017 Posted August 12, 2017 Hey Guy´s, first of all here´s my Emby-Server Environment: System: AMD 5350 4GB DDR3 RAM Debian 8 Nginx reverse Proxy to reach Emby over the WAN: server { listen 443 ssl; listen [::]:443 ssl; ssl_certificate /etc/ssl/certs/openmediavault-aff560f5-e5ed-4d99-999a-c99ca1f4c046.crt; ssl_certificate_key /etc/ssl/private/openmediavault-aff560f5-e5ed-4d99-999a-c99ca1f4c046.key; server_name emby.mysite.de; index index.html; access_log /var/log/nginx/1c0b8dd1-deda-4fa6-b157-28427511ce88-access.log; error_log /var/log/nginx/1c0b8dd1-deda-4fa6-b157-28427511ce88-error.log; large_client_header_buffers 4 8k; location /.well-known/acme-challenge { root /var/www/openmediavault; } ssl_session_timeout 30m; ssl_protocols TLSv1.2 TLSv1.1 TLSv1; ssl_session_cache shared:SSL:10m; if ($scheme = http) { return 301 https://$server_name$request_uri; } location / { proxy_pass http://192.168.2.101:8096; # Local emby ip and non SSL port proxy_hide_header X-Powered-By; proxy_set_header Range $http_range; proxy_set_header If-Range $http_if_range; proxy_set_header X-Real-IP $remote_addr; proxy_set_header Host $host; proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for; #Next three lines allow websockets proxy_http_version 1.1; proxy_set_header Upgrade $http_upgrade; proxy_set_header Connection "upgrade"; } } server { listen 80; listen [::]:80; server_name emby.mysite.de access_log /var/log/nginx/99e70848-4f1f-4327-b041-c918f0b559b4-access.log; error_log /var/log/nginx/99e70848-4f1f-4327-b041-c918f0b559b4-error.log; large_client_header_buffers 4 8k; return 301 https://$host$request_uri; } On Emby Server Config, I set in the Hosting Tab the Public Port to 443 and my external Domain name with the *.pfx Certificate. Now to my Problem: I use Kodi with the Ember for Kodi Plugin and set the Server to my Domain Name. If i start a Movie for Direct Stream the Movie starts for a few minutes and then suddenly stops. In the Webclient all works fine with the External Domain address, also when using Transcoding. If i change the server address to the local IP in the Kodi Addon its still working, so it seems a problem with the external usage. It would be very nice if something can help me to locate the Problem. server-63638151026.txt kodi.log
pir8radio 1313 Posted August 12, 2017 Posted August 12, 2017 (edited) Hey Guy´s, first of all here´s my Emby-Server Environment: System: AMD 5350 4GB DDR3 RAM Debian 8 Nginx reverse Proxy to reach Emby over the WAN: server { listen 443 ssl; listen [::]:443 ssl; ssl_certificate /etc/ssl/certs/openmediavault-aff560f5-e5ed-4d99-999a-c99ca1f4c046.crt; ssl_certificate_key /etc/ssl/private/openmediavault-aff560f5-e5ed-4d99-999a-c99ca1f4c046.key; server_name emby.mysite.de; index index.html; access_log /var/log/nginx/1c0b8dd1-deda-4fa6-b157-28427511ce88-access.log; error_log /var/log/nginx/1c0b8dd1-deda-4fa6-b157-28427511ce88-error.log; large_client_header_buffers 4 8k; location /.well-known/acme-challenge { root /var/www/openmediavault; } ssl_session_timeout 30m; ssl_protocols TLSv1.2 TLSv1.1 TLSv1; ssl_session_cache shared:SSL:10m; if ($scheme = http) { return 301 https://$server_name$request_uri; } location / { proxy_pass http://192.168.2.101:8096; # Local emby ip and non SSL port proxy_hide_header X-Powered-By; proxy_set_header Range $http_range; proxy_set_header If-Range $http_if_range; proxy_set_header X-Real-IP $remote_addr; proxy_set_header Host $host; proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for; #Next three lines allow websockets proxy_http_version 1.1; proxy_set_header Upgrade $http_upgrade; proxy_set_header Connection "upgrade"; } } server { listen 80; listen [::]:80; server_name emby.mysite.de access_log /var/log/nginx/99e70848-4f1f-4327-b041-c918f0b559b4-access.log; error_log /var/log/nginx/99e70848-4f1f-4327-b041-c918f0b559b4-error.log; large_client_header_buffers 4 8k; return 301 https://$host$request_uri; } On Emby Server Config, I set in the Hosting Tab the Public Port to 443 and my external Domain name with the *.pfx Certificate. Now to my Problem: I use Kodi with the Ember for Kodi Plugin and set the Server to my Domain Name. If i start a Movie for Direct Stream the Movie starts for a few minutes and then suddenly stops. In the Webclient all works fine with the External Domain address, also when using Transcoding. If i change the server address to the local IP in the Kodi Addon its still working, so it seems a problem with the external usage. It would be very nice if something can help me to locate the Problem. nothing jumps out, PM me your URL if you would like a second set of eyes on the server results. Also have to tried this externally? Not from your local network using the domain name.. Maybe from a different internet connection? Edited August 12, 2017 by pir8radio
Vertax 0 Posted August 13, 2017 Author Posted August 13, 2017 Yes tested on a other network. I will tomorrow test it again with different settings. Have a look in the log files and seems to be a websocket Problem.
pir8radio 1313 Posted August 14, 2017 Posted August 14, 2017 (edited) Yes tested on a other network. I will tomorrow test it again with different settings. Have a look in the log files and seems to be a websocket Problem. like i said if you get stuck PM me your URL no need to create me an account or anything on your server I shouldn't need access. Otherwise use chrome developer options Network/WS see whats there and what errors you are getting for the websockets. Edited August 14, 2017 by pir8radio
