Jdiesel 1435 Posted August 10, 2017 Posted August 10, 2017 (edited) Playback was working fine yesterday on Beta version .46. Now playback of any video fails to start, just get a spinning circle. The only change I can think of is updating the server from 3.2.26.17 to 3.2.26.18. Sent a in app log from user Jeff. Playback works fine on Android and Chrome. Edited August 10, 2017 by Jdiesel
Jdiesel 1435 Posted August 10, 2017 Author Posted August 10, 2017 Tested with 3.2.26.19 and same issue. Reverted to 3.2.26.17 and playback is restored. Let me know if you need any further testing.
Luke 42242 Posted August 10, 2017 Posted August 10, 2017 Hi there @@Jdiesel, please attach the information requested in how to report a media playback issue. thanks !
Chillout 111 Posted August 10, 2017 Posted August 10, 2017 (edited) Version 3.2.26.19 beta Same problem. Roku wont playback. The wheel shows up but doesnt spin. Going back a menu doesnt remove the wheel. I have to exit emby channel. Playback works fine on web browser Edited August 26, 2017 by Chillout
Happy2Play 9811 Posted August 10, 2017 Posted August 10, 2017 I get a "no dynamic playback error" in neon and spinning circle in new app.
mikeraburn 71 Posted August 10, 2017 Posted August 10, 2017 In taptalk I cannot tell if this a server beta thread so I apologise in advance if it is. Sent from my SM-T560NU using Tapatalk
mikeraburn 71 Posted August 10, 2017 Posted August 10, 2017 Synology server 3.2.26.0 is working fine with Blue Neon. Sent from my SM-T560NU using Tapatalk
Happy2Play 9811 Posted August 10, 2017 Posted August 10, 2017 I downgraded to .15 since it was the oldest version I had, i didn't have time to check which version broke playback.
Jdiesel 1435 Posted August 10, 2017 Author Posted August 10, 2017 .17 is the last version that is not affected
Happy2Play 9811 Posted August 10, 2017 Posted August 10, 2017 Do the apps or the server need updated to correct this issue? Error in log above, can provide additional logs if needed. System.FormatException: Input string was not in a correct format.
Happy2Play 9811 Posted August 10, 2017 Posted August 10, 2017 Try the latest beta server. Thanks. .20 fixed playback but broke CA.
Jdiesel 1435 Posted August 11, 2017 Author Posted August 11, 2017 .20 fixed playback but broke CA. Can you expand on that? I'm still on .17 and haven't updated to .20 yet
Happy2Play 9811 Posted August 11, 2017 Posted August 11, 2017 Can you expand on that? I'm still on .17 and haven't updated to .20 yet There was a CoverArt/Image issue introduced in .20 but play back was fixed. The CoverArt/Image issue was fixed in .21 and CA plugin update. So everything is working again in both apps. 1
Jdiesel 1435 Posted August 11, 2017 Author Posted August 11, 2017 There was a CoverArt/Image issue introduced in .20 but play back was fixed. The CoverArt/Image issue was fixed in .21 and CA plugin update. So everything is working again in both apps. Thanks, will update now
