Luke 42245 Posted August 11, 2017 Posted August 11, 2017 I tested american reunion and that worked fine. keep in mind if you changed the setting after the movie was already imported, then that would explain it.
famulor 1 Posted August 11, 2017 Author Posted August 11, 2017 I tested american reunion and that worked fine. keep in mind if you changed the setting after the movie was already imported, then that would explain it. Changed what setting? I set it up when i made the library in emby.
Luke 42245 Posted August 11, 2017 Posted August 11, 2017 Ok, we'd have to look at the log from when that particular movie was scanned in as it's going to be difficult to try and guess what might have happened after the fact. You could try refreshing one of those titles individually using the 3-dot menu on the detail screen to see if that pulls in Danish metadata.
famulor 1 Posted August 11, 2017 Author Posted August 11, 2017 I tried to rescan all of the metadata and it seemed to have fixed the issue. I dont know what happended but atleast it works now for now thanks for the quick support
